- 12-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-SAVI-MIB
- 15-HH3C-DOT11-WM2U-MIB
- 16-HH3C-DOT11-PROBE-MIB
- 17-HH3C-DOT11S-MESH-MIB
16-HH3C-DOT11-PROBE-MIB | 138.15 KB |
About this MIB
Use this MIB to configure the probe feature and display statistics for detected APs and clients.
MIB file name
hh3c-dot11-probe.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11PROBE(17)
Tabular objects
hh3cDot11PROBERadioCfgTable
About this table
Use this table to configure the enabling status for the probe feature.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cDot11PROBERadioCfgApName and hh3cDot11PROBERadioCfgRadioId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11PROBERadioCfgApName (1.3.6.1.4.1.25506.2.75.17.1.1.1.1) |
not-accessible |
DisplayString |
OCTET STRING (1..64) |
Name of the AP configured for the probe feature. |
As per the MIB. |
hh3cDot11PROBERadioCfgRadioId (1.3.6.1.4.1.25506.2.75.17.1.1.1.2) |
not-accessible |
INTEGER |
Integer32 (1..4) |
Radio ID configured for the probe feature. |
As per the MIB. |
hh3cDot11PROBERadioCfgStatus (1.3.6.1.4.1.25506.2.75.17.1.1.1.3) |
read-write |
INTEGER |
enabled(1), disabled(2) |
Status of the probe feature. |
As per the MIB. |
hh3cDot11PROBEClientTable
About this table
Use this table to display information about the detected clients.
Edit/Modify:Not supported
Read:Supported
Columns
The table index is hh3cDot11PROBEClientMac.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11PROBEClientMac (1.3.6.1.4.1.25506.2.75.17.2.1.1.1 ) |
not-accessible |
MacAddress |
OCTET STRING (6) |
Client MAC address |
As per the MIB. |
hh3cDot11PROBEClientBSSID (1.3.6.1.4.1.25506.2.75.17.2.1.1.2) |
read-only |
MacAddress |
OCTET STRING (6) |
BSSID to which the client is associated. |
As per the MIB. |
hh3cDot11PROBEClientSSID (1.3.6.1.4.1.25506.2.75.17.2.1.1.3) |
read-only |
Octets |
OCTET STRING (0..32) |
As per the MIB. |
hh3cDot11PROBEClientIsDiss (1.3.6.1.4.1.25506.2.75.17.2.1.1.4) |
read-only |
TruthValue |
true(1), false(2) |
Whether the detected client has been disassociated. |
As per the MIB. |
hh3cDot11PROBEClientStatus (1.3.6.1.4.1.25506.2.75.17.2.1.1.5) |
read-only |
INTEGER |
active(1), inactive(2) |
Detected client status. |
As per the MIB. |
hh3cDot11PROBEClientDuratTime (1.3.6.1.4.1.25506.2.75.17.2.1.1.6) |
read-only |
TimeTicks |
Standard MIB values. |
Duration of the detected client status. |
As per the MIB. |
hh3cDot11PROBEClientVendor (1.3.6.1.4.1.25506.2.75.17.2.1.1.7) |
read-only |
DisplayString |
OCTET STRING (1..127) |
Vendor of the detected client. |
As per the MIB. |
hh3cDot11PROBEClientRptApNum (1.3.6.1.4.1.25506.2.75.17.2.1.1.8) |
read-only |
Integer32 |
Number of sensors that detected the client. |
hh3cDot11PROBEClientWorkChannel (1.3.6.1.4.1.25506.2.75.17.2.1.1.9) |
read-only |
Integer32 |
Integer32 (1..224) |
Client channel detected by the sensor. |
hh3cDot11PROBEClientRSSIMax (1.3.6.1.4.1.25506.2.75.17.2.1.1.10) |
read-only |
Integer32 |
Maximum RSSI of the detected client. |
hh3cDot11PROBEClientRSSIMin (1.3.6.1.4.1.25506.2.75.17.2.1.1.11) |
read-only |
Integer32 |
Minimum RSSI of the detected client. |
hh3cDot11PROBEClientRSSI (1.3.6.1.4.1.25506.2.75.17.2.1.1.12) |
read-only |
Integer32 |
RSSI of the detected client |
hh3cDot11PROBEClientFirstTime (1.3.6.1.4.1.25506.2.75.17.2.1.1.13) |
read-only |
DisplayString |
OCTET STRING (1..256) |
First report time of the detected client. |
hh3cDot11PROBEClientLastTime (1.3.6.1.4.1.25506.2.75.17.2.1.1.14) |
read-only |
DisplayString |
Last report time of the detected client. |
hh3cDot11PROBEStatTable
About this table
Use this table to display the statistics of detected clients.
Read:Supported
Columns
The table index is hh3cDot11PROBEStatTime.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11PROBEStatTime (1.3.6.1.4.1.25506.2.75.17.2.2.1.1) |
not-accessible |
DisplayString |
Statistics time span for the detected clients. |
As per the MIB. |
hh3cDot11PROBEStatRssiMaxNum (1.3.6.1.4.1.25506.2.75.17.2.2.1.2) |
read-only |
Integer32 |
As per the MIB. |
hh3cDot11PROBEStatRssiMiddleNum (1.3.6.1.4.1.25506.2.75.17.2.2.1.3) |
read-only |
Integer32 |
Media RSSI of the detected clients. |
As per the MIB. |
hh3cDot11PROBEStatRssiMinNum (1.3.6.1.4.1.25506.2.75.17.2.2.1.4) |
read-only |
Integer32 |
As per the MIB. |
hh3cDot11PROBEStatTotalNum (1.3.6.1.4.1.25506.2.75.17.2.2.1.5) |
read-only |
Integer32 |
Total number of detected clients. |
As per the MIB. |
hh3cDot11PROBEStatAssocNum (1.3.6.1.4.1.25506.2.75.17.2.2.1.6) |
read-only |
Integer32 |
Number of associated clients detected. |
As per the MIB. |
hh3cDot11PROBEStatDissocNum (1.3.6.1.4.1.25506.2.75.17.2.2.1.7) |
read-only |
Integer32 |
Number of disassociated clients detected. |
As per the MIB. |
hh3cDot11PROBEApTable
About this table
Use this table to display the statistics of detected APs.
Read:Supported
Columns
The table index is hh3cDot11PROBEApMacAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11PROBEApMacAddress (1.3.6.1.4.1.25506.2.75.17.2.3.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address of a detected AP. |
As per the MIB. |
hh3cDot11PROBEApSsid (1.3.6.1.4.1.25506.2.75.17.2.5.1.2) |
read-only |
DisplayString |
SSID of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApStatus (1.3.6.1.4.1.25506.2.75.17.2.3.1.3) |
read-only |
INTEGER |
Device status of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApStatusDuTime (1.3.6.1.4.1.25506.2.75.17.2.3.1.4) |
read-only |
Timeticks |
Last report time of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApVendor (1.3.6.1.4.1.25506.2.75.17.2.3.1.5) |
read-only |
DisplayString |
OCTET STRING (0..127) |
Vendor of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApRadioType (1.3.6.1.4.1.25506.2.75.17.2.3.1.6) |
read-only |
INTEGER |
dot11a(1), dot11b(2), dot11g(4), dot11n(8), dot11gn(16), dot11an(32), dot11ac(64), dot11gac(128) |
Radio type used by the detected AP. |
As per the MIB. |
hh3cDot11PROBEApSecurityType (1.3.6.1.4.1.25506.2.75.17.2.3.1.7) |
read-only |
INTEGER |
Integer32 (1..255) |
Cipher suite of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApEncryMethod (1.3.6.1.4.1.25506.2.75.17.2.3.1.8) |
read-only |
INTEGER |
Integer32 (1..65535) |
Encryption method used by the detected AP. |
As per the MIB. |
hh3cDot11PROBEApAuthMethod (1.3.6.1.4.1.25506.2.75.17.2.3.1.9) |
read-only |
INTEGER |
Identity verification method used by the detected AP. |
As per the MIB. |
hh3cDot11PROBEApIsBroadSSID (1.3.6.1.4.1.25506.2.75.17.2.3.1.10) |
read-only |
TruthValue |
true(1), false(2) |
Whether the detected AP supports broadcasting SSID. |
As per the MIB. |
hh3cDot11PROBEApQosSupport (1.3.6.1.4.1.25506.2.75.17.2.3.1.11) |
read-only |
TruthValue |
true(1), false(2) |
Whether the detected AP supports QoS. |
As per the MIB. |
hh3cDot11PROBEApBeaconIntvl (1.3.6.1.4.1.25506.2.75.17.2.3.1.12) |
read-only |
Integer32 |
Beacon interval of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApUpDuration (1.3.6.1.4.1.25506.2.75.17.2.3.1.13) |
read-only |
TimeTicks |
The elapsed time since the AP started operating. This time is calculated using beacon and probe response frames. |
As per the MIB. |
hh3cDot11PROBEApSCWS (1.3.6.1.4.1.25506.2.75.17.2.3.1.14) |
read-only |
TruthValue |
true(1), false(2) |
Whether the detected AP supports channel bandwidth. |
As per the MIB. |
hh3cDot11PROBEApRptSensorNum (1.3.6.1.4.1.25506.2.75.17.2.3.1.15) |
read-only |
Integer32 |
Number of sensors that detected the AP. |
As per the MIB. |
hh3cDot11PROBEApChannel (1.3.6.1.4.1.25506.2.75.17.2.3.1.16) |
read-only |
Integer32 |
Running channel of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApRSSIMax (1.3.6.1.4.1.25506.2.75.17.2.3.1.17) |
read-only |
Integer32 |
Maximum RSSI of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApRSSIMin (1.3.6.1.4.1.25506.2.75.17.2.3.1.18) |
read-only |
Integer32 |
Minimum RSSI of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApRSSI (1.3.6.1.4.1.25506.2.75.17.2.3.1.19) |
read-only |
Integer32 |
As per the MIB. |
hh3cDot11PROBEApFirstRptTime (1.3.6.1.4.1.25506.2.75.17.2.3.1.20) |
read-only |
DisplayString |
First report time of the detected AP. |
As per the MIB. |
hh3cDot11PROBEApLastRptTime (1.3.6.1.4.1.25506.2.75.17.2.3.1.21) |
read-only |
DisplayString |
As per the MIB. |
hh3cDot11PROBEApAssoCltTable
About this table
Use this table to display information about associated clients.
Read:Supported
Columns
The table indexes are hh3cDot11PROBEApAssoCltApMac and hh3cDot11PROBEApAssoCltCltMac.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11PROBEApAssoCltApMac (1.3.6.1.4.1.25506.2.75.17.2.4.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address of the AP. |
As per the MIB. |
hh3cDot11PROBEApAssoCltCltMac (1.3.6.1.4.1.25506.2.75.17.2.4.1.2) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address of the client. |
As per the MIB. |
hh3cDot11PROBEApAssoCltIsAsso (1.3.6.1.4.1.25506.2.75.17.2.4.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Whether the detected client has been associated with an AP. |
As per the MIB. |
hh3cDot11PROBEApRepSenTable
About this table
Use this table to display information about sensors that detected APs.
Read:Supported
Columns
The table indexes are hh3cDot11PROBEApRepSenApMac and hh3cDot11PROBEApRepSenSenName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11PROBEApRepSenApMac (1.3.6.1.4.1.25506.2.75.17.2.5.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address of an AP. |
As per the MIB. |
hh3cDot11PROBEApRepSenSenName (1.3.6.1.4.1.25506.2.75.17.2.5.1.2) |
not-accessible |
DisplayString |
Sensor name. |
As per the MIB. |
hh3cDot11PROBEApRepSenRadioId (1.3.6.1.4.1.25506.2.75.17.2.5.1.3) |
read-only |
Integer32 |
Integer32 (1..4) |
Radio ID of the sensor. |
As per the MIB. |
hh3cDot11PROBEApRepSenRssi (1.3.6.1.4.1.25506.2.75.17.2.5.1.4) |
read-only |
Integer32 |
RSSI of the sensor. |
As per the MIB. |
hh3cDot11PROBEApRepSenChannel (1.3.6.1.4.1.25506.2.75.17.2.5.1.5) |
read-only |
Integer32 |
Channel of the AP detected by the sensor. |
As per the MIB. |
hh3cDot11PROBEApRepSenFirRepTim (1.3.6.1.4.1.25506.2.75.17.2.5.1.6) |
read-only |
DisplayString |
OCTET STRING (SIZE (1..256)) |
First report time of the AP detected by the sensor. |
As per the MIB. |
hh3cDot11PROBEApRepSenLasRepTim (1.3.6.1.4.1.25506.2.75.17.2.5.1.7) |
read-only |
DisplayString |
Last report time of the AP detected by the sensor. |
As per the MIB. |
hh3cDot11PROBECliRepSenTable
About this table
Use this table to display information about sensors that detected clients.
Read:Supported
Columns
The table indexes are hh3cDot11PROBECliRepSenCliMac and hh3cDot11PROBECliRepSenSenName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11PROBECliRepSenCliMac (1.3.6.1.4.1.25506.2.75.17.2.6.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address of a client. |
As per the MIB. |
hh3cDot11PROBECliRepSenSenName (1.3.6.1.4.1.25506.2.75.17.2.6.1.2) |
not-accessible |
DisplayString |
Sensor name. |
As per the MIB. |
hh3cDot11PROBECliRepSenRadioId (1.3.6.1.4.1.25506.2.75.17.2.6.1.3) |
read-only |
Integer32 |
Integer32 (1..4) |
As per the MIB. |
hh3cDot11PROBECliRepSenRssi (1.3.6.1.4.1.25506.2.75.17.2.6.1.4) |
read-only |
Integer32 |
As per the MIB. |
hh3cDot11PROBECliRepSenChannel (1.3.6.1.4.1.25506.2.75.17.2.6.1.5) |
read-only |
Integer32 |
Channel detected by the sensor. |
As per the MIB. |
hh3cDot11PROBECliRepSenFRepTime (1.3.6.1.4.1.25506.2.75.17.2.6.1.6) |
read-only |
DisplayString |
As per the MIB. |
hh3cDot11PROBECliRepSenLRepTime (1.3.6.1.4.1.25506.2.75.17.2.6.1.7) |
read-only |
DisplayString |
As per the MIB. |
hh3cDot11PROBECliRepSenAssAPMac (1.3.6.1.4.1.25506.2.75.17.2.6.1.7) |
read-only |
MacAddress |
OCTET STRING (6) |
MAC address of the associated AP. |
As per the MIB. |
