12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R54xx)-6W10012-WLAN
10-HH3C-DOT11-STATION-MIB
10-HH3C-DOT11-STATION-MIB 252.90 KB
About this MIB
Use this MIB to manage client configuration and statistics.
MIB file name
hh3c-dot11-station.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11STATION(3)
Tabular objects
hh3cDot11StationAssociateTable
About this table
Use this table to display association information for wireless clients.
Support for operations
CreateNot supported
ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11StationMAC.
Object (OID)
Access
Value range
Implementation
hh3cDot11StationMAC (1.3.6.1.4.1.25506.2.75.3.1.1.1.1)
not-accessible
MacAddress
OCTET STRING (6)
MAC address of the client.
As per the MIB.
hh3cDot11StationIPAddress (1.3.6.1.4.1.25506.2.75.3.1.1.1.2)
read-only
IpAddress
Standard MIB values.
IP address of the client.
As per the MIB.
hh3cDot11StationUserName
(1.3.6.1.4.1.25506.2.75.3.1.1.1.3)
read-only
OCTET STRING
Username for the client.
As per the MIB.
hh3cDot11StationTxRateSet
(1.3.6.1.4.1.25506.2.75.3.1.1.1.4)
read-only
OCTET STRING
Transmission rate for the client. If the MSB (most significant bit) is set, the rate is mandatory. If it is not set, the rate is optional.
As per the MIB.
hh3cDot11StationUpTime
(1.3.6.1.4.1.25506.2.75.3.1.1.1.5)
read-only
Unsigned32
How long the client has been associated with this device.
As per the MIB.
hh3cDot11StationSignalStrength (1.3.6.1.4.1.25506.2.75.3.1.1.1.6)
read-only
Integer32
Current signal strength of the client.
As per the MIB.
hh3cDot11StationRSSI (1.3.6.1.4.1.25506.2.75.3.1.1.1.7)
read-only
Integer32
Strength of the received signal.
The maximum value is defined by the chipset vendor.
As per the MIB.
hh3cDot11StationChannel (1.3.6.1.4.1.25506.2.75.3.1.1.1.8)
read-only
Integer32
Channel used by the client.
As per the MIB.
hh3cDot11StationPowerSaveMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.9)
read-only
INTEGER
active(1),
powersave(2)
Power management mode for the client.
As per the MIB.
hh3cDot11StationAid (1.3.6.1.4.1.25506.2.75.3.1.1.1.10)
read-only
Integer32
ID of the client.
As per the MIB.
hh3cDot11StationVlanId (1.3.6.1.4.1.25506.2.75.3.1.1.1.11)
read-only
Integer32
VLAN ID associated with the client.
As per the MIB.
hh3cDot11StationSSIDName (1.3.6.1.4.1.25506.2.75.3.1.1.1.12)
read-only
Hh3cDot11SSIDStringType
ESS name.
As per the MIB.
hh3cDot11StationAuthenMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.13)
read-only
Hh3cDot11AuthenType
none(1),
opensystem(2),
sharedkey(3),
all(4)
Authentication mode defined by 802.11.
As per the MIB.
hh3cDot11StationAKMMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.14)
read-only
Hh3cDot11AKMType
none(1),
psk(2),
dot1x(3),
ext(4)
Authentication and key management mode.
As per the MIB.
hh3cDot11StationSecurityCiphers (1.3.6.1.4.1.25506.2.75.3.1.1.1.15)
read-only
Hh3cDot11CipherType
none(1),
wep40(2),
tkip(4),
aesccmp(16),
wep104(32),
wpisms4(64),
wep(128)
Cipher suite
As per the MIB.
hh3cDot11StationSSIDEncryptMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.16)
read-only
Hh3cDot11SSIDEncryptModeType
cleartxt(1),
cipher(2),
ext(3)
Encryption mode for the ESS.
As per the MIB.
hh3cDot11StationRxSNR (1.3.6.1.4.1.25506.2.75.3.1.1.1.17)
read-only
Integer32
Signal-to-noise ratio for frame receiving.
As per the MIB.
hh3cDot11StationTxRate (1.3.6.1.4.1.25506.2.75.3.1.1.1.18)
read-only
Integer32
Transmission rate of frames.
As per the MIB.
hh3cDot11StationRxRate (1.3.6.1.4.1.25506.2.75.3.1.1.1.19)
read-only
Integer32
Receive rate of frames.
As per the MIB.
hh3cDot11StationVendorName (1.3.6.1.4.1.25506.2.75.3.1.1.1.20)
read-only
OCTET STRING
OCTET STRING (0..127)
Vendor name for the client.
As per the MIB.
hh3cDot11StationRadioMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.21)
read-only
INTEGER
dot11a(1),
dot11b(2),
dot11g(4),
dot11n(8),
dot11gn(16),
dot11an(32),
dot11ac(64),
dot11gac(128),
dot11ax(256),
dot11gax(512)
Radio type supported by the client.
As per the MIB.
hh3cDot11StationRxNoise (1.3.6.1.4.1.25506.2.75.3.1.1.1.22)
read-only
Integer32
Noise received by the client.
As per the MIB.
hh3cDot11StationMACAddress (1.3.6.1.4.1.25506.2.75.3.1.1.1.23)
read-only
MacAddress
OCTET STRING (6)
As per the MIB.
hh3cDot11StationTxSpeed (1.3.6.1.4.1.25506.2.75.3.1.1.1.24)
read-only
Integer32
Number of bytes sent to the client per second within the sample interval.
As per the MIB.
hh3cDot11StationRxSpeed (1.3.6.1.4.1.25506.2.75.3.1.1.1.25)
read-only
Integer32
Number of bytes received by the client per second within the sample interval.
As per the MIB.
hh3cDot11StationWmmMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.26)
read-only
INTEGER
wmm(1),
nonwmm(2)
QoS mode of the client.
As per the MIB.
hh3cDot11StationSecIEStatus (1.3.6.1.4.1.25506.2.75.3.1.1.1.27)
read-only
INTEGER
none(1),
rsn(2),
wpa(3),
all(4),
ext(5)
Security information element of the client.
As per the MIB.
hh3cDot11StationUpTimeTicks (1.3.6.1.4.1.25506.2.75.3.1.1.1.28)
read-only
TimeTicks
As per the MIB.
hh3cDot11StationRadioMode2 (1.3.6.1.4.1.25506.2.75.3.1.1.1.29)
read-only
INTEGER
dot11a(1),
dot11b (2),
dot11g (4),
dot11an (8),
dot11gn (16),
dot11ac (32),
dot11gac (64),
dot11ax(128),
dot11gax(256)
As per the MIB.
hh3cDot11StationAssTime (1.3.6.1.4.1.25506.2.75.3.1.1.1.30)
read-only
DateAndTime
DateAndTime (8),
DateAndTime (11)
How long the client has been connected to the wireless network.
As per the MIB.
hh3cDot11StationUserAuthType (1.3.6.1.4.1.25506.2.75.3.1.1.1.31)
read-only
INTEGER
portalAuth(1),
authFree(2),
associateAuth(3),
macAuth(4)
Authentication mode for the client.
As per the MIB.
hh3cDot11StationRfPingTest (1.3.6.1.4.1.25506.2.75.3.1.1.1.32)
read-only
TruthValue
true(1),
false(2)
Use this node to start the RF ping test for the client. For get operations, it will return false.
As per the MIB.
hh3cDot11StationMaxRate (1.3.6.1.4.1.25506.2.75.3.1.1.1.33)
read-only
Integer32
Maximum negotiated rate for the client.
As per the MIB.
hh3cDot11StationPowerSaveModeCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.34)
read-only
INTEGER
active(0),
powersave(1)
As per the MIB.
hh3cDot11StationAuthenModeCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.35)
read-only
INTEGER
opensystem(0),
sharedkey(1),
As per the MIB.
hh3cDot11StationAKMModeCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.36)
read-only
INTEGER
none(0),
psk(1),
radius(2),
wlanex(3)
Key management mode defined by 802.11i.
As per the MIB.
hh3cDot11StationSecurityCiphersCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.37)
read-only
INTEGER
none(0),
wep40(1),
wep104(2)
tkip(3),
aesccmp(4),
wpisms4(5)
Type of password used for frame encryption on the client.
As per the MIB.
hh3cDot11StationSecIEStatusCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.38)
read-only
INTEGER
none(0),
wpa(1),
wpa2(2),
wlanex(3)
As per the MIB.
hh3cDot11StationIPv6Address
(1.3.6.1.4.1.25506.2.75.3.1.1.1.39)
read-only
OCTET STRING
IPv6 address of the client.
As per the MIB.
hh3cDot11StationAssociateAPMACAddressCM
(1.3.6.1.4.1.25506.2.75.3.1.1.1.40)
read-only
MacAddress
MacAddress(6)
MAC address of the client currently connected to the AP.
As per the MIB.
hh3cDot11StationDeviceType(1.3.6.1.4.1.25506.2.75.3.1.1.1.41)
read-only
OCTET STRING
Type of device with which the client will be associated.
As per the MIB.
hh3cDot11StationTxRateCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.42)
read-only
OCTET STRING
As per the MIB.
hh3cDot11StationRxRateCM(1.3.6.1.4.1.25506.2.75.3.1.1.1.43)
read-only
OCTET STRING
As per the MIB.
hh3cDot11StationAPRelationTable
About this table
Use this table to save the relationships between AP, radio, and WLAN ID, as well as the detailed information about a client.
CreateNot supported
ModifyNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11CurrAPID (1.3.6.1.4.1.25506.2.75.3.1.2.1.1)
read-only
OCTET STRING
OCTET STRING
(0..127)
To uniquely identify each AP, the relationship between hh3cDot11CurrAPID and the AP device will be static.
As per the MIB.
hh3cDot11CurrRadioID
(1.3.6.1.4.1.25506.2.75.3.1.2.1.2)
read-only
Integer32
Each radio.
As per the MIB.
hh3cDot11CurrWlanID
(1.3.6.1.4.1.25506.2.75.3.1.2.1.3)
read-only
Integer32
WLAN ID of the BSS associated with the client.
As per the MIB.
hh3cDot11CurrAntennaID
(1.3.6.1.4.1.25506.2.75.3.1.2.1.4)
read-only
Integer32
Radio ID of the client.
As per the MIB.
hh3cDot11StationStatisTable
About this table
Use this table to display all statistical information and states for clients.
CreateNot supported
ModifyNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDot11StationRxFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.1)
read-only
Counter32
Number of frames received by the AP from the client.
As per the MIB.
hh3cDot11StationTxFrameCnt
(1.3.6.1.4.1.25506.2.75.3.1.3.1.2)
read-only
Counter32
Number of frames sent from the AP to the client.
As per the MIB.
hh3cDot11StationDropFrameCnt
(1.3.6.1.4.1.25506.2.75.3.1.3.1.3)
read-only
Counter32
Number of discarded frames.
As per the MIB.
hh3cDot11StationRxFrameBytes
(1.3.6.1.4.1.25506.2.75.3.1.3.1.4)
read-only
Counter64
Number of bytes received by the AP from the client.
As per the MIB.
hh3cDot11StationTxFrameBytes
(1.3.6.1.4.1.25506.2.75.3.1.3.1.5)
read-only
Counter64
Number of bytes sent from the AP to the client.
As per the MIB.
hh3cDot11StationDropFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.6)
read-only
Counter64
Number of discarded bytes.
As per the MIB.
hh3cDot11StationRxRetryPkts
(1.3.6.1.4.1.25506.2.75.3.1.3.1.7)
read-only
Counter32
Number of frames retransmitted from the client to the AP.
As per the MIB.
hh3cDot11StationTxRetryPkts (1.3.6.1.4.1.25506.2.75.3.1.3.1.8)
read-only
Counter32
Number of frames retransmitted from the AP to the client.
As per the MIB.
hh3cDot11StationRxRetryBytes
(1.3.6.1.4.1.25506.2.75.3.1.3.1.9)
read-only
Counter64
Number of bytes retransmitted from the client to the AP.
As per the MIB.
hh3cDot11StationTxRetryBytes
(1.3.6.1.4.1.25506.2.75.3.1.3.1.10)
read-only
Counter64
Number of bytes retransmitted from the AP to the client.
As per the MIB.
hh3cDot11StationThroughput
(1.3.6.1.4.1.25506.2.75.3.1.3.1.11)
read-only
Counter64
Number of valid load in the data frames transmitted and received by the client.
As per the MIB.
hh3cDot11StationSuccessTxCnt
(1.3.6.1.4.1.25506.2.75.3.1.3.1.12)
read-only
Counter32
Number of frames successfully transmitted to the client.
As per the MIB.
hh3cDot11StationSuccessTxDataCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.13)
read-only
Counter32
Number of data frames successfully transmitted to the client.
As per the MIB.
hh3cDot11StationRxDataFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.14)
read-only
Counter32
Number of data frames received from the client.
As per the MIB.
hh3cDot11StationTxDataFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.15)
read-only
Counter32
Number of data frames transmitted to the client.
As per the MIB.
hh3cDot11StationRxDataFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.16)
read-only
Counter64
Number of bytes received from the client.
As per the MIB.
hh3cDot11StationTxDataFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.17)
read-only
Counter64
Number of bytes transmitted to the client.
As per the MIB.
hh3cDot11StationRxFragCnt
(1.3.6.1.4.1.25506.2.75.3.1.3.1.18)
read-only
Counter32
Number of fragmented data frames received from the client.
As per the MIB.
hh3cDot11StaRxErrDataFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.19)
read-only
Counter64
Number of error data frames received by the AP from the client.
As per the MIB.
hh3cDot11StaTxRetryDataFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.20)
read-only
Counter64
Number of data frames retransmitted from the AP to the client.
As per the MIB.
hh3cDot11StaTxDataRatePkts
(1.3.6.1.4.1.25506.2.75.3.1.3.1.21)
read-only
OCTET STRING
Number of data frames received from the client at each rate.
As per the MIB.
hh3cDot11StaRxDataRatePkts
(1.3.6.1.4.1.25506.2.75.3.1.3.1.22)
read-only
OCTET STRING
Numbers of data frames that are transmitted to the client at each rate.
As per the MIB.
hh3cDot11StaTxSignalStrengthPkts (1.3.6.1.4.1.25506.2.75.3.1.3.1.23)
read-only
OCTET STRING
Numbers of data frames received from the client with different signal strengths.
As per the MIB.
hh3cDot11StaInternetRxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.24)
read-only
Counter64
Number of bytes of Internet traffic received from the client.
As per the MIB.
hh3cDot11StaInternetTxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.25)
read-only
Counter64
Number of bytes of Internet traffic sent to the client.
As per the MIB.
hh3cDot11StaLocalRxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.26)
read-only
Counter64
Local traffic in bytes received from the client.
As per the MIB.
hh3cDot11StaLocalTxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.27)
read-only
Counter64
Local traffic in bytes transmitted to the client.
As per the MIB.
Notifications
hh3cDot11StationMICErrorTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.1
A client detected a TKIP decryption MIC error.
Informational
Warning
N/A (N/A)
Off
Notification triggers
This notification is triggered when a MIC error occurs.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable wlan usersec command.
OFF
CLI: Use the undo snmp-agent trap enable wlan usersec command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.3.1.2.1.1 (hh3cDot11CurrAPID)
APID
OCTET STRING
OCTET STRING , (0..127)
1.3.6.1.4.1.25506.2.75.3.1.2.1.2 (hh3cDot11CurrRadioID)
Radio ID
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.1 (hh3cDot11StationTrapBSSID)
BSSID
MacAddress
1.3.6.1.4.1.25506.2.75.3.1.1.1.12 (hh3cDot11StationSSIDName)
SSID
OCTET STRING
OCTET STRING (0..32)
1.3.6.1.4.1.25506.2.75.3.2.1.2 (hh3cDot11StationTrapStaMAC)
Client MAC address.
MacAddress
Recommended action
No action is required.
hh3cDot11StationAuthenErrorTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.2
Client link authentication failed.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when an error occurs during the authentication negotiation process of 802.11 link establishment by a wireless client.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
APID
OCTET STRING
Radio ID
Integer32
BSSID
MacAddress
SSID
OCTET STRING
Client MAC address.
MacAddress
1.3.6.1.4.1.25506.2.75.3.1.1.1.13 (hh3cDot11StationAuthenMode)
Authentication mode.
Hh3cDot11AuthenType
1.3.6.1.4.1.25506.2.75.3.1.1.1.14 (hh3cDot11StationAKMMode)
Key management mode.
Hh3cDot11AKMType
none(1),, psk(2),, dot1x(3),, ext(4)
Recommended action
hh3cDot11StationAuthorFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.3
Client authorization failed.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when a client successfully establishes a wireless link but fails access authentication.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.3.1.1.1.3 (hh3cDot11StationUserName)
OCTET STRING
OCTET STRING, (0..255)
MacAddress
Radio ID
Integer32
SSID
OCTET STRING
hh3cDot11StationAuthorFailCause (hh3cDot11StationAuthorFailCause)
Reasons for client authorization failure.
Hh3cDot11AuthorFailType
1.3.6.1.4.1.25506.2.75.3.2.1.6 (hh3cDot11StationFailCauseDesc)
Fault description for the client.
OCTET STRING
APID
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.11 (hh3cDot11StationBSSID)
BSSID to which the client is connected.
MacAddress
1.3.6.1.4.1.25506.2.75.3.2.1.13 (hh3cDot11StationAuthMode)
Client authentication mode.
INTEGER
1.3.6.1.4.1.25506.2.75.3.2.1.16 (hh3cDot11StationTrapAPMacAddress)
AP's MAC address.
MacAddress
Recommended action
hh3cDot11StationAssocFailTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.4
Client association failed.
Informational
Warning
N/A (N/A)
Off
This notification is triggered when a wireless client fails to establish a connection with an AP.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan client command.
OFF
CLI: Use the undo snmp-agent trap enable wlan client command.
Object
OID (object name)
Index
Value range
Client MAC address.
MacAddress
Radio ID
Integer32
ESS name.
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.4 (hh3cDot11StationAssocFailCause)
Reasons for client association failure.
Hh3cDot11AssocFailType
OCTET STRING
OCTET STRING
AP's MAC address.
MacAddress
MacAddress
Recommended action
hh3cDot11StationDeAssocTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.5
A disassociation request was sent to a client.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when a system needs to transmit a disassociation packet to a wireless client.
System impact
N/A
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
MAC address of the client where a MIC error occurred.
MacAddress
1.3.6.1.4.1.25506.2.75.3.1.1.1.11 (hh3cDot11StationVlanId)
Integer32
Each radio.
Integer32
ESS name.
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.7 (hh3cDot11StationSessionDuration)
Duration of the client session.
Unsigned32
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.10 (hh3cDot11StationAPName)
Name of the AP to which the client is connected.
OCTET STRING
MacAddress
Recommended action
hh3cDot11StationAuthorSuccTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.6
Client authorization succeeded.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when the system determines that the client has successfully connected to the WLAN network and completed link negotiation and access authentication.
System impact
N/A
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
MacAddress
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.3 (hh3cDot11StationSessionStartTime)
DateAndTime
Each radio.
Integer32
ESS name.
OCTET STRING
OCTET STRING
OCTET STRING
MacAddress
Recommended action
hh3cDot11StationRoamingTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.7
A client roamed to another AP.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when a client roams from one AP to another.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan mobility command.
OFF
CLI: Use the undo snmp-agent trap enable wlan mobility command.
Object
OID (object name)
Index
Value range
OCTET STRING
OCTET STRING
MacAddress
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.8 (hh3cDot11StationRoamingTime)
Time when the client roamed to another AP.
Unsigned32
Each radio.
Integer32
ESS name.
OCTET STRING
1.3.6.1.4.1.25506.2.75.3.2.1.9 (hh3cDot11StationACIPAddress)
IP address of the home AC for roaming clients.
IP address of the foreign AC for roaming clients.
IpAddress
1.3.6.1.4.1.25506.2.75.3.2.1.14 (hh3cDot11StationACIPv6Add)
IPv6 address of the home AC for roaming clients.
IPv6 address of the foreign AC for roaming clients.
OCTET STRING
Recommended action
hh3cDot11StationDisconnectTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.8
A client went offline.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when the system detects that a client is no longer present after the client successfully registers to the system, regardless of how the client left the network.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
MacAddress
ESS name.
OCTET STRING
Unsigned32
Integer32
OCTET STRING
Each radio.
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.12 (hh3cDot11StaDisconnectReason)
Reasons for disconnection between the client and the AP.
OCTET STRING
MacAddress
Recommended action
hh3cDot11UserDisconnectTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.9
A user went offline unexpectedly.
Informational
Warning
N/A (N/A)
OFF
This notification is triggered when a client times out. Set the idle-time to 60 seconds. For a PC, if it goes offline unexpectedly, it will be forcibly shut down. For a client other than a PC, a disassociation packet will be sent. If no username exists, the packet is empty.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
OCTET STRING
MacAddress
1.3.6.1.4.1.25506.2.75.3.2.1.15 (hh3cDot11UserName)
Username.
OCTET STRING
Recommended action
hh3cDot11StationAuditTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.3.2.0.11
Client behavior notification.
Informational
Warning
N/A (N/A)
Off
This notification is triggered when a client comes online, goes offline, roams, or obtains an IP address.
System impact
N/A
Status control
ON
CLI: Use the snmp-agent trap enable wlan client-audit command.
OFF
CLI: Use the undo snmp-agent trap enable wlan client-audit command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.3.2.1.21 (hh3cDot11StationAuditTrapOpType)
Client operation type.
Unsigned32
MacAddress
1.3.6.1.4.1.25506.2.75.3.2.1.22 (hh3cDot11StationTrapStaIPAddress)
IpAddress
AP's MAC address.
MacAddress
1.3.6.1.4.1.25506.2.75.3.2.1.19 (hh3cDot11StationTrapAPIPAddress)
AP's IP address.
IpAddress
1.3.6.1.4.1.25506.2.75.3.2.1.23 (hh3cDot11StationTrapRadioID)
ID of each channel.
Hh3cDot11RadioScopeType
1.3.6.1.4.1.25506.2.75.3.2.1.24 (hh3cDot11StationTrapRadioMode)
Hh3cDot11RadioType2
1.3.6.1.4.1.25506.2.75.3.2.1.25 (hh3cDot11StationTrapWlanID)
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.26 (hh3cDot11StationTrapSSIDName)
ESS name.
1.3.6.1.4.1.25506.2.75.3.2.1.27 (hh3cDot11StationTrapVlan)
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.28 (hh3cDot11StationTrapChannel)
Current channel used by the client.
Hh3cDot11ChannelScopeType
1.3.6.1.4.1.25506.2.75.3.2.1.29 (hh3cDot11StationTrapRSSI)
Integer32
1.3.6.1.4.1.25506.2.75.3.2.1.20 (hh3cDot11StationTrapStartTime)
Time when the device starts connecting to the client.
Unsigned32
Unsigned32
1.3.6.1.4.1.25506.2.75.3.2.1.30 (hh3cDot11StationTrapRxFrameKbit)
Number of data frames bits received from the client.
Counter64
1.3.6.1.4.1.25506.2.75.3.2.1.31 (hh3cDot11StationTrapTxFrameKbit)
Number of data frame bits sent to the client.
Counter64
Recommended action
