- 12-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-SAVI-MIB
- 15-HH3C-DOT11-WM2U-MIB
- 16-HH3C-DOT11-PROBE-MIB
- 17-HH3C-DOT11S-MESH-MIB
13-HH3C-DOT11-RRM-MIB | 168.17 KB |
hh3cDot11APInterfNumThreshhd (1.3.6.1.4.1.25506.2.75.8.1.1.9)
hh3cDot11StaInterfNumThreshhd (1.3.6.1.4.1.25506.2.75.8.1.1.10)
hh3cDot11MonitorDetectedDevTable
HH3C-DOT11-RRM-MIB
About this MIB
Use this MIB to manage wireless resources.
MIB file name
hh3c-dot11-rrm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11RRM(8)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11APInterfNumThreshhd (1.3.6.1.4.1.25506.2.75.8.1.1.9) |
read-write |
Integer32 |
As per the MIB. |
AP interference threshold. If the AP interference value exceeds this threshold, the device will send an AP interference trap. If the value for this node is 0, the device will send an AP interference trap immediately. |
Supported |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11StaInterfNumThreshhd (1.3.6.1.4.1.25506.2.75.8.1.1.10) |
read-write |
Integer32 |
As per the MIB. |
Client interference threshold. If the client interference value exceeds this threshold, the device will send a client interference trap. If the value for this node is 0, the device will send a client interference trap immediately. |
Supported |
Tabular objects
hh3cDot11RRMAPCfgTable
About this table
Use this table to configure RRM-related parameters for an AP.
Support for operations
Create:Not supported
Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cDot11APElementIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RRMAPWorkMode (1.3.6.1.4.1.25506.2.75.8.1.3.1.1) |
read-write |
INTEGER |
normal(1) monitor(2) hybrid(3) |
AP operating modes |
As per the MIB. |
hh3cDot11RRMSDRadioGroupTable
About this table
Use this table to configure an RRM holddown group.
Create:Supported
Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cDot11RRMSDRadioGroupId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RRMSDRadioGroupId (1.3.6.1.4.1.25506.2.75.8.1.4.1.1) |
not-accessible |
Unsigned32 |
Unsigned32(1..128) |
ID of the RRM holddown group. |
As per the MIB. |
hh3cDot11RRMSDRadioGroupDesc(1.3.6.1.4.1.25506.2.75.8.1.4.1.2) |
read-create |
OCTET STRING |
OCTET STRING(0..64) |
Description of the RRM holddown group. |
As per the MIB. |
hh3cDot11RRMSDRdGrpChlHolddownTm(1.3.6.1.4.1.25506.2.75.8.1.4.1.3) |
read-create |
Unsigned32 |
Unsigned32(10..1140) |
Channel holddown time for the RRM holddown group. |
As per the MIB. |
hh3cDot11RRMSDRdGrpPwrHolddownTm(1.3.6.1.4.1.25506.2.75.8.1.4.1.4) |
read-create |
Unsigned32 |
Power holddown time for the RRM holddown group. |
As per the MIB. |
hh3cDot11RRMSDRdGroupRowStatus(1.3.6.1.4.1.25506.2.75.8.1.4.1.5) |
read-create |
RowStatus |
active(1) notInService(2) notReady (3) createAndGo(4) createAndWait (5) destroy(6) |
Row state of the table. |
As per the MIB. |
hh3cDot11RRMAPCfg2Table
About this table
Modify:Supported
Read:Supported
Columns
The table index is hh3cDot11RRMAPSerialID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RRMAPSerialID (1.3.6.1.4.1.25506.2.75.8.1.5.1.1) |
not-accessible |
Hh3cDot11ObjectIDType |
OCTET STRING(0..127) |
AP Serial ID |
As per the MIB. |
hh3cDot11RRMAPIntfThreshold (1.3.6.1.4.1.25506.2.75.8.1.5.1.2) |
read-write |
Integer32 |
Integer32(1..64) |
AP interference threshold. If the number of interference sources exceeds this threshold, the device will send an AP interference trap. |
As per the MIB. |
hh3cDot11RRMStaIntfThreshold (1.3.6.1.4.1.25506.2.75.8.1.5.1.3) |
read-write |
Integer32 |
Integer32(1..64) |
Client interference threshold. If the number of interference sources exceeds this threshold, the device will send a client interference trap. |
As per the MIB. |
hh3cDot11RRMCoChlIntfTrapThhd(1.3.6.1.4.1.25506.2.75.8.1.5.1.4) |
read-write |
Integer32 |
Integer32(10..90) |
Interference trap threshold for the current AP. If the device signal strength exceeds this threshold, a trap will be sent. |
As per the MIB. |
hh3cDot11RRMAdjChlIntfTrapThhd(1.3.6.1.4.1.25506.2.75.8.1.5.1.5) |
read-write |
Integer32 |
Integer32(10..90) |
Trap threshold for adjacent-channel interference for the current AP. If the signal strength on a device exceeds this threshold, a trap will be sent. |
As per the MIB. |
hh3cDot11RRMChlRptTable
About this table
Use this table to display RRM channel information for each radio on all APs.
Modify:Supported
Read:Supported
Columns
The table indexes are hh3cDot11RRMRadioIndex and hh3cDot11RRMChlRptChlNum.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RRMRadioIndex (1.3.6.1.4.1.25506.2.75.8.2.1.1.1) |
accessible-for-notify |
Hh3cDot11RadioElementIndex |
Standard MIB values. |
Radio ID and AP ID. |
As per the MIB. |
hh3cDot11RRMChlRptChlNum (1.3.6.1.4.1.25506.2.75.8.2.1.1.2) |
Integer32 |
Channel number. |
As per the MIB. |
hh3cDot11RRMChlRptChlType (1.3.6.1.4.1.25506.2.75.8.2.1.1.3) |
read-only |
INTEGER |
primeChannel(1) offChannel(2) |
Channel type. |
As per the MIB. |
hh3cDot11RRMChlRptChlQlty (1.3.6.1.4.1.25506.2.75.8.2.1.1.4) |
read-only |
INTEGER |
good(1) bad(2) |
Channel quality. |
As per the MIB. |
hh3cDot11RRMChlRptNbrCnt (1.3.6.1.4.1.25506.2.75.8.2.1.1.5) |
read-only |
Integer32 |
Number of neighbors on the current channel. |
As per the MIB. |
hh3cDot11RRMChlRptLoad (1.3.6.1.4.1.25506.2.75.8.2.1.1.6) |
read-only |
Integer32 |
Integer32 (0..100) |
Load percentage on the channel. |
As per the MIB. |
hh3cDot11RRMChlRptUtlz (1.3.6.1.4.1.25506.2.75.8.2.1.1.7) |
read-only |
Integer32 |
Channel usage. |
As per the MIB. |
hh3cDot11RRMChlRptIntrf (1.3.6.1.4.1.25506.2.75.8.2.1.1.8) |
read-only |
Integer32 |
Percentage of interference observed on the channel. |
As per the MIB. |
hh3cDot11RRMChlRptPER (1.3.6.1.4.1.25506.2.75.8.2.1.1.9) |
read-only |
Integer32 |
Package error rate observed on the channel. |
As per the MIB. |
hh3cDot11RRMChlRptRetryRate (1.3.6.1.4.1.25506.2.75.8.2.1.1.10) |
read-only |
Integer32 |
Packet retransmission rate on the channel. |
As per the MIB. |
hh3cDot11RRMChlRptNoise (1.3.6.1.4.1.25506.2.75.8.2.1.1.11) |
read-only |
Integer32 |
Noise on the channel. |
As per the MIB. |
hh3cDot11RRMChlRptRadarIndtcr(1.3.6.1.4.1.25506.2.75.8.2.1.1.12) |
read-write |
INTEGER |
detected(1) notDetected(2) |
Radar state. |
As per the MIB. |
hh3cDot11RRMNbrInfoTable
About this table
Use this table to display neighbor information for each radio on all APs.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cDot11RRMRadioIndex and hh3cDot11RrmNbrBSSID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RrmNbrBSSID (1.3.6.1.4.1.25506.2.75.8.2.2.1) |
not-accessible |
MacAddress |
AP's MAC address. |
As per the MIB. |
hh3cDot11RrmNbrChl (1.3.6.1.4.1.25506.2.75.8.2.2.2) |
read-only |
Hh3cDot11ChannelScopeType |
Neighbor's channel number. |
As per the MIB. |
hh3cDot11RRMNbrIntrf (1.3.6.1.4.1.25506.2.75.8.2.2.3) |
read-only |
Integer32 |
Integer32(0..100) |
Neighbor channel interference percentage. |
As per the MIB. |
hh3cDot11RrmNbrRSSI (1.3.6.1.4.1.25506.2.75.8.2.2.4) |
read-only |
Integer32 |
AP signal strength. |
As per the MIB. |
hh3cDot11RrmNbrType (1.3.6.1.4.1.25506.2.75.8.2.2.5) |
read-only |
INTEGER |
managed(1) unmanaged(2) |
Neighbor type, managed or unmanaged. |
As per the MIB. |
hh3cDot11RrmNbrSSID (1.3.6.1.4.1.25506.2.75.8.2.2.6) |
read-only |
Hh3cDot11SSIDStringType |
Neighbor's SSID. |
As per the MIB. |
hh3cDot11RrmNbrSNR (1.3.6.1.4.1.25506.2.75.8.2.2.7) |
read-only |
Integer32 |
Signal-to-noise ratio of the AP. |
As per the MIB. |
hh3cDot11RrmNbrNF (1.3.6.1.4.1.25506.2.75.8.2.2.8) |
read-only |
Integer32 |
AP’s noise floor. |
As per the MIB. |
hh3cDot11RRMHistoryTable
About this table
Use this table to display details of adjustments to AP channel, power, and bandwidth, including the time of change, the reasons for the change, and parameters related to channel, power, and interference.
Read:Supported
Columns
The table indexes are hh3cDot11RRMRadioIndex, hh3cDot11RRMHistoryId, and hh3cDot11RRMHistoryRecIndctr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RRMHistoryId (1.3.6.1.4.1.25506.2.75.8.2.3.1.1) |
not-accessible |
Integer32 |
Change history number |
As per the MIB. |
hh3cDot11RRMHistoryRecIndctr (1.3.6.1.4.1.25506.2.75.8.2.3.1.2) |
not-accessible |
INTEGER |
before(1) after(2) |
Change history type. |
As per the MIB. |
hh3cDot11RRMHistoryChl (1.3.6.1.4.1.25506.2.75.8.2.3.1.3) |
read-only |
Channel where the radio is running before and after changes. |
As per the MIB. |
hh3cDot11RRMHistoryPwr (1.3.6.1.4.1.25506.2.75.8.2.3.1.4) |
read-only |
Integer32 |
Power of the radio before and after changes. |
As per the MIB. |
hh3cDot11RRMHistoryLoad (1.3.6.1.4.1.25506.2.75.8.2.3.1.5) |
read-only |
Integer32 |
Integer32(0..100) |
Load percentage on the radio before or after the channel or power is changed. |
As per the MIB. |
hh3cDot11RRMHistoryUtlz (1.3.6.1.4.1.25506.2.75.8.2.3.1.6) |
read-only |
Integer32 |
Integer32(0..100) |
Radio usage before or after the channel or power is changed. |
As per the MIB. |
hh3cDot11RRMHistoryIntrf (1.3.6.1.4.1.25506.2.75.8.2.3.1.7) |
read-only |
Integer32 |
Integer32(0..100) |
Interference percentage on the radio before or after the channel or power is changed. |
As per the MIB. |
hh3cDot11RRMHistoryNoise (1.3.6.1.4.1.25506.2.75.8.2.3.1.8) |
read-only |
Integer32 |
Noise on the radio before or after the channel or power is changed. |
As per the MIB. |
hh3cDot11RRMHistoryPER (1.3.6.1.4.1.25506.2.75.8.2.3.1.9) |
read-only |
Integer32 |
Integer32(0..100) |
Error rate on the radio before or after the channel or power is changed. |
As per the MIB. |
hh3cDot11RRMHistoryRetryRate (1.3.6.1.4.1.25506.2.75.8.2.3.1.10) |
read-only |
Integer32 |
Integer32(0..100) |
Retransmission ratio on the radio before or after the channel or power is changed. |
As per the MIB. |
hh3cDot11RRMHistoryChgReason(1.3.6.1.4.1.25506.2.75.8.2.3.1.11) |
read-only |
BITS |
others(0) coverage(1) radar(2) retransmission(3) packetsDiscarded(4) interference(5) |
Reasons for changes in power and channel. |
As per the MIB. |
hh3cDot11RRMHistoryChgDateTime(1.3.6.1.4.1.25506.2.75.8.2.3.1.12) |
read-only |
DateAndTime |
Time of power or channel change. |
As per the MIB. |
hh3cDot11RRMRadioNbrInfoTable
About this table
Use this table to manage information about the neighbors of each radio on all APs.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cDot11RRMRadioNbrAPID and hh3cDot11RRMRadioNbrRadioID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11RRMRadioNbrAPID (1.3.6.1.4.1.25506.2.75.8.2.4.1.1) |
not-accessible |
AP ID. |
As per the MIB. |
hh3cDot11RRMRadioNbrRadioID (1.3.6.1.4.1.25506.2.75.8.2.4.1.2) |
not-accessible |
Hh3cDot11RadioScopeType |
AP radio ID. |
As per the MIB. |
hh3cDot11RRMRadioNbrSSID (1.3.6.1.4.1.25506.2.75.8.2.4.1.3) |
read-only |
OCTET STRING |
Information about all neighbors detected by the specified radio. |
As per the MIB. |
About this table
Use this table to configure detected device information.
Modify:Supported
Read:Supported
Columns
The table indexes are hh3cDot11MonitorDevMAC and hh3cDot11APElementIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11MonitorDevMAC (1.3.6.1.4.1.25506.2.75.8.4.1.1.1) |
not-accessible |
MacAddress |
MAC address of the detected device. |
As per the MIB. |
hh3cDot11MonitorDevType (1.3.6.1.4.1.25506.2.75.8.4.1.1.2) |
read-only |
INTEGER |
client(1) ap(2) adhoc(3) wirelessBridge(4) unknown(5) |
Type of the detected device. |
As per the MIB. |
hh3cDot11MonitorDevVendor (1.3.6.1.4.1.25506.2.75.8.4.1.1.3) |
read-only |
OCTET STRING |
Vendor for the detected device. |
As per the MIB. |
hh3cDot11MonitorDevSSID (1.3.6.1.4.1.25506.2.75.8.4.1.1.4) |
read-only |
OCTET STRING |
SSID type for the device, ap or adhoc. |
As per the MIB. |
hh3cDot11MonitorDevBSSID (1.3.6.1.4.1.25506.2.75.8.4.1.1.5) |
read-only |
MacAddress |
BSSID of the detected device. |
As per the MIB. |
hh3cDot11MonitorDevChannel (1.3.6.1.4.1.25506.2.75.8.4.1.1.6) |
read-only |
Channel of the device detected last time. The AP will select the channel with the strongest signal as the effective channel due to interference between adjacent channels. |
As per the MIB. |
hh3cDot11MonitorRadioId (1.3.6.1.4.1.25506.2.75.8.4.1.1.7) |
read-only |
Radio ID detected by the AP. |
As per the MIB. |
hh3cDot11MonitorDevMaxRSSI (1.3.6.1.4.1.25506.2.75.8.4.1.1.8) |
read-only |
Integer32 |
Maximum RSSI value detected by the device during the scan report period. |
As per the MIB. |
hh3cDot11MonitorDevBeaconIntvl (1.3.6.1.4.1.25506.2.75.8.4.1.1.9) |
read-only |
Integer32 |
Beacon interval for the detected device (excluding clients). |
As per the MIB. |
hh3cDot11MonitorDevFstDctTime (1.3.6.1.4.1.25506.2.75.8.4.1.1.10) |
read-only |
DateAndTime |
OCTET STRING (SIZE (8 | 11)) (without time zone: 8, with time zone: 11) |
Time when the device was first detected |
As per the MIB. |
hh3cDot11MonitorDevLstDctTime (1.3.6.1.4.1.25506.2.75.8.4.1.1.11) |
read-only |
DateAndTime |
Last time the device was detected. |
As per the MIB. |
hh3cDot11MonitorDevClear (1.3.6.1.4.1.25506.2.75.8.4.1.1.12) |
read-write |
TruthValue |
true(1) false(2) |
Clear the detected device information. |
As per the MIB. |
hh3cDot11MonitorDevSNR(1.3.6.1.4.1.25506.2.75.8.4.1.1.13) |
read-only |
Integer32 |
Signal-to-noise ratio during the scan period. |
As per the MIB. |
Notifications
hh3cDot11RRMIntrfLimit
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.75.8.3.1.0.1 |
Air interface interference crossing threshold alarm. |
Informational |
Warning |
N/A (N/A) |
Off |
Notification triggers
This notification is triggered when the air interface detects that channel interference exceeds the specified threshold.
System impact
None.
Status control
ON
CLI: Use the snmp-agent trap enable wlan rrm command.
OFF
CLI: Use the undo snmp-agent trap enable wlan rrm command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.8.2.1.1.8 (hh3cDot11RRMChlRptIntrf) |
Channel interference. |
N/A |
Integer32 |
Integer32, (0..100) |
Recommended action
1.No action is required.
hh3cDot11RRMPERLimit
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.8.3.1.0.2 |
Error packet crossing threshold alarm |
Informational |
Warning |
N/A (N/A) |
Off |
This notification is triggered when the air interface detects that the proportion of received error packets exceeds the specified threshold.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.8.2.1.1.9 (hh3cDot11RRMChlRptPER) |
Error packet ratio |
N/A |
Integer32 |
Recommended action
hh3cDot11RRMPowerChange
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.8.3.2.0.1 |
Power change notification |
Informational |
Warning |
N/A (N/A) |
Off |
This notification is triggered when the transmission power of a radio changes.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.8.2.1.1.1 (hh3cDot11RRMRadioIndex) |
RADIO ID |
N/A |
Integer32 |
Integer32, (1..4) |
1.3.6.1.4.1.25506.2.75.8.3.3.1 (hh3cDot11NewPower) |
New power value. |
N/A |
Integer32 |
Integer32, (1..100) |
1.3.6.1.4.1.25506.2.75.8.3.3.2 (hh3cDot11OldPower) |
Old power value. |
N/A. |
Integer32 |
Recommended action
