12-WLAN
HomeSupportReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R54xx)-6W10012-WLAN
06-HH3C-WAPI-MIB
06-HH3C-WAPI-MIB 189.83 KB
HH3C-WAPI-MIB
About this MIB
Use this MIB to manage WLAN Authentication and Privacy Infrastructure (WAPI) configuration and operating state monitoring objects.
MIB file name
hh3c-wapi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cwapiMIB(77)
Scalar objects
hh3cwapiTrapInfoMacAddr (1.3.6.1.4.1.25506.2.77.4.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
MacAddress
OCTET STRING (6)
MAC address of a WAPI user.
As per the MIB.
hh3cwapiTrapInfoAPId (1.3.6.1.4.1.25506.2.77.4.1.2)
Object (OID)
Access
Value range
Implementation
Integer32
Standard MIB values.
Unique identifier of an AP.
As per the MIB.
hh3cwapiTrapInfoRadioId (1.3.6.1.4.1.25506.2.77.4.1.3)
Object (OID)
Access
Value range
Implementation
Integer32
Radio ID.
As per the MIB.
hh3cwapiTrapInfoBSSId (1.3.6.1.4.1.25506.2.77.4.1.4)
Object (OID)
Access
Value range
Implementation
MacAddress
OCTET STRING (6)
BSSID.
As per the MIB.
Object (OID)
Access
Value range
Implementation
MacAddress
OCTET STRING (6)
MAC address of an AP.
As per the MIB.
Tabular objects
hh3cwapiConfigExtTable
About this table
Use this table to implement service set identifier (SSID)-based WAPI configuration.
Support for operations
CreateNot supported.
Edit/ModifySupported
DeleteNot supported.
ReadSupported
Columns
The table index is hh3cwapiConfigServicePolicyID.
Object (OID)
Access
Value range
Implementation
hh3cwapiCfgExtCertInstalled
(1.3.6.1.4.1.25506.2.77.3.2.1.10)
read-only
TruthValue
true(1),
false(2)
This object indicates whether this entity has a certificate installed.
If this value is TRUE, it indicates that the SSID has a certificate installed. If not, it indicates that the SSID does not have a certificate installed.
As per the MIB.
hh3cwapiConfigVersion
(1.3.6.1.4.1.25506.2.77.3.2.1.11)
read-only
Integer32
Highest WAPI version supported by this entity.
As per the MIB.
hh3cwapiControlledAuthControl
(1.3.6.1.4.1.25506.2.77.3.2.1.12)
read-only
TruthValue
true(1),
false(2)
This object indicates whether this entity has identity authentication enabled.
If this value is FALSE, it indicates that identity authentication is not enabled on the entity, and the state of the controlled port is authenticated.
If this value is TRUE, it indicates that identity authentication is enabled and the state of the controlled port is determined by hh3cwapiControlledPortControl.
As per the MIB.
(1.3.6.1.4.1.25506.2.77.3.2.1.13)
read-only
Integer32
This object indicates the control type of the entity port.
When hh3cwapiControlledAuthControl is TRUE, this object is available. If this value is 0, it indicates "automatic," and the state of the controlled port is determined by the authentication result.
If this value is 1, it indicates "force unauthenticated," and the state of the controlled port is "unauthenticated."
As per the MIB.
hh3cwapiOptionImplemented
(1.3.6.1.4.1.25506.2.77.3.2.1.14)
read-only
TruthValue
true(1),
false(2)
This object indicates whether this entity supports WAPI.
If this value is TRUE, it indicates that the entity supports WAPI.
If not, it indicates that the entity does not support WAPI.
As per the MIB.
hh3cwapiPreauthImplemented
(1.3.6.1.4.1.25506.2.77.3.2.1.15)
read-only
TruthValue
true(1),
false(2)
This object indicates whether this entity supports WAPI preauthentication.
You cannot set this object to TRUE unless hh3cwapiOptionImplemented is TRUE.
As per the MIB.
hh3cwapiEnabled (1.3.6.1.4.1.25506.2.77.3.2.1.16)
Read-write
TruthValue
true(1),
false(2)
When this object is set to TRUE, it indicates that WAPI is enabled on this entity.
The entity will advertise the WAPI information element in its beacons and probe responses.
As per the MIB.
hh3cwapiPreauthEnabled
(1.3.6.1.4.1.25506.2.77.3.2.1.17)
Read-write
TruthValue
true(1),
false(2)
If this object is set to TRUE, it indicates that WAPI preauthentication has been enabled on this entity.
If not, it indicates that WAPI preauthentication is disabled on this entity.
This object requires setting hh3cWAPIEnabled to TRUE.
As per the MIB.
hh3cwapiCfgUniKeysSupported
(1.3.6.1.4.1.25506.2.77.3.2.1.18)
read-only
Unsigned32
This object indicates the number of WAPI USKs that the entity supports.
As per the MIB.
hh3cwapiCfgUniRekeyMethod
(1.3.6.1.4.1.25506.2.77.3.2.1.19)
read-write
INTEGER
disabled(1), timeBased(2), packetBased(3), timepacketBased(4)
This object specifies a WAPI USK update mode.
By default, the value is timeBased and USK update occurs once a day. USK update is only applicable to entities acting as Authentication Entity (AE) or Authentication Supplicant Entity (ASUE).
As per the MIB.
hh3cwapiCfgUniRekeyTime
(1.3.6.1.4.1.25506.2.77.3.2.1.20)
read-write
Unsigned32
Unsigned32 (1..4294967295)
WAPI USK update interval (in seconds).
The timer starts when the MLME-SETVPIKEYS request primitive is used to set the USK.
As per the MIB.
hh3cwapiCfgUniRekeyPackets
(1.3.6.1.4.1.25506.2.77.3.2.1.21)
read-write
Unsigned32
Packet count (a multiple of 1000) that triggers a WAPI USK update.
The packet counter starts when the MLME-SETKEYS request primitive is used to set the USK and counts all packets encrypted by using the current USK.
As per the MIB.
hh3cwapiCfgMultiCipher
(1.3.6.1.4.1.25506.2.77.3.2.1.22)
read-write
OCTET STRING
OCTET STRING (4)
This object specifies the MSK suite selector that the entity must use. The MSK suite in the WAPI information should get its value from this variable.
It contains an OUI (the first three bytes) and a suite type (the last byte).
As per the MIB.
hh3cwapiCfgMultiRekeyMethod
(1.3.6.1.4.1.25506.2.77.3.2.1.23)
read-write
INTEGER
This object specifies a WAPI MSK update mode.
By default, the value is timeBased and MSK update occurs once a day.
MSK update is only applicable to entities acting as Authentication Entity (AE) or Authentication Supplicant Entity (ASUE).
As per the MIB.
hh3cwapiCfgMultiRekeyTime
(1.3.6.1.4.1.25506.2.77.3.2.1.24)
read-write
Unsigned32
WAPI MSK update interval (in seconds).
The timer starts when the MLME-SETVPIKEYS request primitive is used to set the MSK.
As per the MIB.
hh3cwapiCfgMultiRekeyPackets
(1.3.6.1.4.1.25506.2.77.3.2.1.25)
read-write
Unsigned32
Packet count (a multiple of 1000) that triggers a WAPI MSK update.
The packet counter should start when the MLME-SETKEYS request primitive is used to set the MSK and counts all packets encrypted with the current MSK.
As per the MIB.
hh3cwapiCfgMultiRekeyStrict
(1.3.6.1.4.1.25506.2.77.3.2.1.26)
read-write
TruthValue
true(1),
false(2)
This object indicates that the MSK should be updated whenever the station (STA) leaves a basic service set (BSS) with an MSK.
As per the MIB.
hh3cwapiCfgPSKValue
(1.3.6.1.4.1.25506.2.77.3.2.1.27)
read-write
OCTET STRING
OCTET STRING (2..32)
When WAPI is in preshared key (PSK) mode, the PSK value is the selected AKM suite.
In this case, the BK will obtain its value from this object.
This object is logically read-only. When this variable is read, it should return a failure state, null, or zero.
As per the MIB.
hh3cwapiCfgPSKPassPhrase
(1.3.6.1.4.1.25506.2.77.3.2.1.28)
read-write
OCTET STRING
OCTET STRING (1..16)
When WAPI is in PSK mode, the PSK value is the selected AKM suite and is configured by hh3cwapiCfgPSKValue.
Another way to set the PSK is to use a password-to-key algorithm.
This variable provides a method for entering a pass phrase.
When this object is written, the WAPI entity should use a password-to-key algorithm to export a PSK and use this key for padding hh3cwapiCfgPSKValue.
As per the MIB.
hh3cwapiCfgCertUpdateCount
(1.3.6.1.4.1.25506.2.77.3.2.1.29)
read-write
Unsigned32
Number of times WAPI certificate authentication messages will be retried for each certificate authentication handshake attempt.
As per the MIB.
hh3cwapiCfgMultiUpdateCount
(1.3.6.1.4.1.25506.2.77.3.2.1.30)
read-write
Unsigned32
Number of times WAPI MSK handshake messages will be retried for each MSK handshake attempt.
As per the MIB.
hh3cwapiCfgUniUpdateCount
(1.3.6.1.4.1.25506.2.77.3.2.1.31)
read-write
Unsigned32
Number of times WAPI USK handshake messages will be retried for every three handshake attempts.
As per the MIB.
hh3cwapiCfgMultiCipherSize
(1.3.6.1.4.1.25506.2.77.3.2.1.32)
read-write
Unsigned32
Unsigned32 (0..4294967295)
This object sets the MSK length in bits.
SMS4 should use a 256-bit key, with the first 128 bits for encryption and the last 128 bits for integrity checks.
As per the MIB.
hh3cwapiCfgBKLifetime
(1.3.6.1.4.1.25506.2.77.3.2.1.33)
read-write
Unsigned32
Maximum BK lifetime in the BK cache, in seconds.
As per the MIB.
hh3cwapiCfgBKReauthThreshold
(1.3.6.1.4.1.25506.2.77.3.2.1.34)
read-write
Unsigned32
Unsigned32 (1..100)
Percentage of the BK lifetime that should expire before re-authentication occurs.
As per the MIB.
hh3cwapiCfgSATimeout
(1.3.6.1.4.1.25506.2.77.3.2.1.35)
read-write
Unsigned32
Maximum time required to establish a security association (SA), in seconds.
As per the MIB.
hh3cwapiAuthenSuiteSelected
(1.3.6.1.4.1.25506.2.77.3.2.1.36)
read-only
OCTET STRING
OCTET STRING (4)
Final AKM suite selector negotiated.
As per the MIB.
hh3cwapiUniCipherSelected
(1.3.6.1.4.1.25506.2.77.3.2.1.37)
read-only
OCTET STRING
OCTET STRING (4)
Previous USK selector negotiated.
As per the MIB.
hh3cwapiMultiCipherSelected
(1.3.6.1.4.1.25506.2.77.3.2.1.38)
read-only
OCTET STRING
OCTET STRING (4)
Previous MSK selector negotiated.
As per the MIB.
hh3cwapiBKIDUsed
(1.3.6.1.4.1.25506.2.77.3.2.1.39)
read-only
OCTET STRING
OCTET STRING (16)
Last BKID selector used in the previous USK handshake.
As per the MIB.
hh3cwapiAuthenSuiteRequested
(1.3.6.1.4.1.25506.2.77.3.2.1.40)
read-only
OCTET STRING
OCTET STRING (4)
Final AKM suite selector requested.
As per the MIB.
hh3cwapiUniCipherRequested
(1.3.6.1.4.1.25506.2.77.3.2.1.41)
read-only
OCTET STRING
OCTET STRING (4)
Previous USK selector requested.
As per the MIB.
hh3cwapiMultiCipherRequested
(1.3.6.1.4.1.25506.2.77.3.2.1.42)
read-only
OCTET STRING
OCTET STRING (4)
Previous MSK selector requested.
As per the MIB.
hh3cwapiStatsTable
About this table
Use this table to track statistical information for each STA in WAPI.
Edit/ModifyNot supported.
ReadSupported.
Columns
The table index is hh3cwapiStationMAC.
Object (OID)
Access
Value range
Implementation
hh3cwapiStationMAC (1.3.6.1.4.1.25506.2.77.3.3.1.1)
not-accessible
MacAddress
OCTET STRING (6)
MAC address of a station.
As per the MIB.
hh3cwapiStatsSTAAddress (1.3.6.1.4.1.25506.2.77.3.3.1.2)
read-only
MacAddress
OCTET STRING (6)
MAC address of the STA for the statistics information.
As per the MIB.
hh3cwapiStatsVersion
(1.3.6.1.4.1.25506.2.77.3.3.1.3)
read-only
Unsigned32
WAPI version associated with the STA.
As per the MIB.
hh3cwapiStatsCtrlPortStatus
(1.3.6.1.4.1.25506.2.77.3.3.1.4)
read-only
TruthValue
true(1),
false(2)
This object represents the state of the controlled port of the identity authentication entity. If the value is TRUE, it means "authenticated". If not, it means "unauthenticated."
As per the MIB.
hh3cwapiStatsSelectedUniCipher
(1.3.6.1.4.1.25506.2.77.3.3.1.5)
read-only
OCTET STRING
OCTET STRING (4)
USK suite selector used during the association period.
As per the MIB.
hh3cwapiStatsWPIReplayCnt
(1.3.6.1.4.1.25506.2.77.3.3.1.6)
read-only
Counter32
Number of WPI MAC Protocol Data Units (MPDUs) discarded by the replay mechanism.
As per the MIB.
hh3cwapiStatsWPIDecryptErr
(1.3.6.1.4.1.25506.2.77.3.3.1.7)
read-only
Counter32
Number of WPI MPDUs discarded due to key unavailability during the WPI-SMS4 decryption process.
As per the MIB.
hh3cwapiStatsWPIMICErr
(1.3.6.1.4.1.25506.2.77.3.3.1.8)
read-only
Counter32
Number of WPI MPDUs discarded due to Message Integrity Code (MIC) check failure during the WPI-SMS4 decryption process.
As per the MIB.
hh3cwapiStatsWAISignatureErr
(1.3.6.1.4.1.25506.2.77.3.3.1.9)
read-only
Counter32
This counter increments when the system receives a WAI packet with an incorrect signature.
As per the MIB.
hh3cwapiStatsWAIHMACErr
(1.3.6.1.4.1.25506.2.77.3.3.1.10)
read-only
Counter32
This counter increments when a received WAI packet fails the message verification key check.
As per the MIB.
hh3cwapiStatsWAIAuthenFail
(1.3.6.1.4.1.25506.2.77.3.3.1.11)
read-only
Counter32
This counter increments when WAI identity authentication fails.
As per the MIB.
hh3cwapiStatsWAIDiscardCnt
(1.3.6.1.4.1.25506.2.77.3.3.1.12)
read-only
Counter32
This counter increments when a received WAI packet is dropped.
As per the MIB.
hh3cwapiStatsWAITimeoutCnt
(1.3.6.1.4.1.25506.2.77.3.3.1.13)
read-only
Counter32
This counter increments when a WAI packet timeout is detected.
As per the MIB.
hh3cwapiStatsWAIFormatErr
(1.3.6.1.4.1.25506.2.77.3.3.1.14)
read-only
Counter32
This counter increments when a WAI packet format error occurs.
As per the MIB.
hh3cwapiStatsWAICertFail
(1.3.6.1.4.1.25506.2.77.3.3.1.15)
read-only
Counter32
This counter increments when WAI certificate identity authentication fails.
As per the MIB.
hh3cwapiStatsWAIUniFail
(1.3.6.1.4.1.25506.2.77.3.3.1.16)
read-only
Counter32
This counter increments when the WAI USK negotiation succeeds.
As per the MIB.
hh3cwapiStatsWAIMultiFail
(1.3.6.1.4.1.25506.2.77.3.3.1.17)
read-only
Counter32
This counter increments when the WAI MSK announcement fails.
As per the MIB.
Notifications
hh3cwapiUserwithInvalidCertificate
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.77.4.0.1
A user uses invalid certificates to breach the network.
Informational
Warning
_ (_)
Off
Notification triggers
This notification is generated when a user uses invalid certificates to breach the network.
System impact
A user cannot successfully access the network.
Status control
ON
CLI: snmp-agent trap enable wlan usersec
Off
CLI: undo snmp-agent trap enable wlan usersec
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Interface index.
ifIndex
InterfaceIndex
Integer32 (1..2147483647)
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Interface description.
ifIndex
DisplayString
OCTET STRING (0..255)
1.3.6.1.4.1.25506.2.77.4.1.1 (hh3cwapiTrapInfoMacAddr)
N/A
MacAddress
OCTET STRING (6)
 (hh3cwapiTrapInfoAPId)
N/A
Integer32
 (hh3cwapiTrapInfoRadioId)
Radio ID.
N/A
Integer32
 (hh3cwapiTrapInfoBSSId)
BSSID.
N/A
MacAddress
OCTET STRING (6)
1.3.6.1.4.1.25506.2.77.4.1.4 (hh3cwapiTrapInfoAPMacAddr)
N/A
MacAddress
OCTET STRING (6)
Recommended action
No action is required.
hh3cwapiStationReplayAttack
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.77.4.0.2
Client replay attack.
Informational
Warning
_ (_)
Off
This notification is generated when the AP receives an illegal AE inquiry.
System impact
Status control
ON
Off
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
InterfaceIndex
ifIndex
DisplayString
N/A
MacAddress
OCTET STRING (6)
N/A
Integer32
Radio ID.
N/A
Integer32
BSSID.
N/A
MacAddress
OCTET STRING (6)
N/A
MacAddress
OCTET STRING (6)
Recommended action
hh3cwapiTamperAttack
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.77.4.0.3
WAPI tampering attack.
Informational
Warning
_ (_)
Off
This notification is generated when the AP receives an incorrect message authentication code.
System impact
Status control
ON
Off
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
InterfaceIndex
ifIndex
DisplayString
N/A
MacAddress
OCTET STRING (6)
N/A
Integer32
Radio ID.
N/A
Integer32
BSSID.
N/A
MacAddress
OCTET STRING (6)
N/A
MacAddress
OCTET STRING (6)
Recommended action
hh3cwapiLowSafeLevelAttack
Basic information
OID
Event
Severity
Default status
WAPI security level downgrade attack.
Informational
Warning
_ (_)
Off
This notification is generated when the AP receives a key negotiation response packet with an incorrect WIEASUE.
System impact
Status control
ON
Off
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
InterfaceIndex
ifIndex
DisplayString
N/A
MacAddress
OCTET STRING (6)
N/A
Integer32
Radio ID.
N/A
Integer32
BSSID.
N/A
MacAddress
OCTET STRING (6)
N/A
MacAddress
OCTET STRING (6)
Recommended action
hh3cwapiAddressRedirectionAttack
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.77.4.0.5
WAPI address redirect attack.
Informational
Warning
_ (_)
Off
This notification is generated when the AP receives an invalid WPI frame.
System impact
Status control
ON
Off
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
InterfaceIndex
ifIndex
DisplayString
N/A
MacAddress
OCTET STRING (6)
N/A
Integer32
Radio ID.
N/A
Integer32
BSSID.
N/A
MacAddress
OCTET STRING (6)
N/A
MacAddress
OCTET STRING (6)
Recommended action
