- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
07-HH3C-FC-PSM-MIB | 171.32 KB |
HH3C-FC-PSM-MIB
About this MIB
Use this MIB to configure port security.
MIB file name
hh3c-fc-psm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cFcPsm(8)
Scalar objects
hh3cFcPsmNotifyEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPsmNotifyEnable (1.3.6.1.4.1.25506.2.127.8.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Notifications state |
The default value is false(2). |
Tabular objects
hh3cFcPsmEnableTable
About this table
This table enables port security in a VSAN.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cFcPsmEnableVsanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPsmEnableVsanIndex (1.3.6.1.4.1.25506.2.127.8.1.2.1.1.1) |
not-accessible |
Unsigned32 |
Unsigned32(1..4095) |
VSAN ID |
As per the MIB. |
hh3cFcPsmEnable (1.3.6.1.4.1.25506.2.127.8.1.2.1.1.2) |
read-write |
INTEGER |
enable(1), enableWithAutoLearn(2), disable(3), noop(4) |
Enable type. |
As per the MIB. |
hh3cFcPsmEnableState (1.3.6.1.4.1.25506.2.127.8.1.2.1.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Enable status. |
As per the MIB. |
hh3cFcPsmConfigTable
About this table
This table configures port security settings.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Not supported |
Columns
The table indexes are hh3cFcPsmEnableVsanIndex and hh3cFcPsmIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPsmIndex (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32(1..32768) |
Index of the port bound to the VSAN. |
As per the MIB. |
hh3cFcPsmLoginDevType (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.2) |
read-create |
Hh3cFcPsmPortBindDevType
nWWN(1), pWWN(2), sWWN(3), wildCard(4) |
Device type. |
As per the MIB. |
hh3cFcPsmLoginDev (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.3) |
read-create |
Hh3cFcNameIdOrZero |
OCTET STRING(0..255) |
Device address. |
As per the MIB. |
hh3cFcPsmLoginPoint (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.4) |
read-create |
InterfaceIndexOrZero |
Integer32(0..255) |
Port address. |
As per the MIB. |
hh3cFcPsmRowStatus (1.3.6.1.4.1.25506.2.127.8.1.2.2.1.5) |
read-create |
RowStatus |
INTEGER (0..7) |
Row status. |
As per the MIB. |
hh3cFcPsmEnfTable
About this table
This table obtains port security database information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cFcPsmEnableVsanIndex and hh3cFcPsmEnfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPsmEnfIndex (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..32768) |
As per the MIB. |
hh3cFcPsmEnfLoginDevType (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.2) |
read-only |
Device type. |
As per the MIB. |
hh3cFcPsmEnfLoginDev (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.3) |
read-only |
OCTET STRING (0..255) |
Device address. |
As per the MIB. |
hh3cFcPsmEnfLoginPoint (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.4) |
read-only |
Integer32(0..255) |
Port address. |
As per the MIB. |
hh3cFcPsmEnfEntryType (1.3.6.1.4.1.25506.2.127.8.1.2.3.1.5) |
read-only |
INTEGER |
learning(1), learned(2), static(3) |
Binding entry type. |
As per the MIB. |
hh3cFcPsmCopyToConfigTable
About this table
This table converts learned entries to static entries.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPsmCopyToConfig (1.3.6.1.4.1.25506.2.127.8.1.2.4.1.1) |
read-write |
INTEGER |
copy(1), noop(2) |
Converts learned entries to static entries. |
As per the MIB. |
hh3cFcPsmAutoLearnTable
About this table
This table enables auto learning.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPsmAutoLearnEnable (1.3.6.1.4.1.25506.2.127.8.1.2.5.1.1) |
not-accessible |
TruthValue |
true(1), false(2) |
Enables auto learning. |
As per the MIB. |
hh3cFcPsmClearTable
About this table
This table clears binding entries in the port security database and port security statistics for an interface.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPsmClearType (1.3.6.1.4.1.25506.2.127.8.1.2.6.1.1) |
read-write |
Hh3cFcPsmClearEntryType
clearStatic(1), clearAutolearn(2), clearAll(3), noop(4) |
As per the MIB. |
hh3cFcPsmClearIntf (1.3.6.1.4.1.25506.2.127.8.1.2.6.1.2) |
read-write |
Integer32 (0..2147483647) |
Interface index. |
As per the MIB. |
hh3cFcPsmStatsTable
About this table
This table obtains port security statistics on the local device.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPsmAllowedLogins (1.3.6.1.4.1.25506.2.127.8.1.3.1.1.1) |
read-only |
Counter32 |
Standard MIB values. |
Number of allowed logins. |
As per the MIB. |
hh3cFcPsmDeniedLogins (1.3.6.1.4.1.25506.2.127.8.1.3.1.1.2) |
read-only |
Counter32 |
Number of denied logins. |
As per the MIB. |
hh3cFcPsmStatsClear (1.3.6.1.4.1.25506.2.127.8.1.3.1.1.3) |
read-write |
INTEGER |
clear(1), noop(2) |
Clears statistics of hh3cFcPsmStatsTable. |
As per the MIB. |
hh3cFcPsmViolationTable
About this table
This table obtains security violation entries. If a WWN logs in to an interface repeatedly, the system updates the login time and count.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cFcPsmEnableVsanIndex and hh3cFcPsmViolationIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPsmViolationIndex (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32(1..1024) |
Violation index. |
As per the MIB. |
hh3cFcPsmLoginPWWN (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.2) |
read-only |
OCTET STRING(0 | 8) |
pWWN of a denied device. |
As per the MIB. |
hh3cFcPsmLoginNWWN (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.3) |
read-only |
nWWN of a denied device. |
As per the MIB. |
hh3cFcPsmLoginSWWN (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.4) |
read-only |
sWWN of a denied device. |
As per the MIB. |
hh3cFcPsmLoginIntf (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.5) |
read-only |
InterfaceIndex |
Integer32(1..2147483647) |
Port index of a denied device. |
As per the MIB. |
hh3cFcPsmLoginTime (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.6) |
read-only |
DateAndTime |
OCTET STRING(1..255) |
Violation time. |
As per the MIB. |
hh3cFcPsmLoginCount (1.3.6.1.4.1.25506.2.127.8.1.3.2.1.7) |
read-only |
Counter32 |
Number of violations. |
As per the MIB. |
Notifications
hh3cFcPsmFPortDenyNotify
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.127.8.0.1 |
F_Port denied device login |
Informational |
OFF |
An F_Port denied device login.
Status control
ON
· MIB: Set hh3cFcPsmNotifyEnable to true(1).
OFF
· MIB: Set hh3cFcPsmNotifyEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
ifDescr name |
No |
STRING |
OCTET STRING(0…255) |
1.3.6.1.4.1.25506.2.127.8.1.3.2.1.2 (hh3cFcPsmLoginPWWN) |
No |
1.3.6.1.4.1.25506.2.127.8.1.3.2.1.5 (hh3cFcPsmLoginIntf) |
No |
InterfaceIndex |
1.3.6.1.4.1.25506.2.127.8.1.3.2.1.6 (hh3cFcPsmLoginTime) |
Violation time. |
No |
DateAndTime |
Recommended action
No action is required.
hh3cFcPsmEPortDenyNotify
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.8.0.2 |
E_Port denied device login |
Informational |
OFF |
An E_Port denied device login.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
ifDescr name |
No |
STRING |
1.3.6.1.4.1.25506.2.127.8.1.3.2.1.4 (hh3cFcPsmLoginSWWN) |
No |
No |
InterfaceIndex |
Violation time. |
No |
DateAndTime |
Recommended action
