- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
12-HH3C-SAN-AGG-MIB | 81.15 KB |
HH3C-SAN-AGG-MIB
About this MIB
Use this MIB to configure SAN aggregation.
MIB file name
hh3c-san-agg.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cSanAgg(2)
Scalar objects
hh3cSanAggMaxMemberNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSanAggMaxMemberNumber (1.3.6.1.4.1.25506.2.127.2.1.1) |
read-only |
Integer32 |
Integer32 |
Maximum number of member ports allowed in an FC aggregate interface. |
As per the MIB. |
hh3cSanAggGroupPreviousSpeed
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSanAggGroupPreviousSpeed (1.3.6.1.4.1.25506.2.127.2.3.1) |
accessible-for-notify |
Integer32 |
Integer32 |
Speed of the FC aggregate interface before speed change. |
As per the MIB. |
hh3cSanAggGroupCurrentSpeed
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSanAggGroupCurrentSpeed (1.3.6.1.4.1.25506.2.127.2.3.2) |
Integer32 |
Integer32 |
Speed of the FC aggregate interface after speed change. |
As per the MIB. |
Tabular objects
hh3cSanAggGroupTable
About this table
This table configures or obtains FC aggregate interface information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Not supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cSanAggGroupNumber (1.3.6.1.4.1.25506.2.127.2.2.1.1) |
Integer32 |
Integer (32 bit) |
FC aggregate interface number. |
As per the MIB. |
hh3cSanAggGroupIndex (1.3.6.1.4.1.25506.2.127.2.2.1.2) |
read-only |
Integer32 |
Integer (32 bit) |
FC aggregate interface index. |
As per the MIB. |
hh3cSanAggMemberList (1.3.6.1.4.1.25506.2.127.2.2.1.3) |
read-create |
OCTET STRING |
Octets |
List of member port indexes. |
As per the MIB. |
hh3cSanAggMemberStateList (1.3.6.1.4.1.25506.2.127.2.2.1.4) |
read-only |
OCTET STRING |
Octets |
List of member port states. |
As per the MIB. |
hh3cSanAggGroupRowStatus (1.3.6.1.4.1.25506.2.127.2.2.1.5) |
read-create |
INTEGER |
Integer (32 bit) |
Row status. |
Supports the following values: · active(1). · createAndGo(4). · destroy(6). |
Notifications
hh3cSanAggGroupSpeedChange
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.127.2.4.0.1 |
FC aggregate interface speed changed |
Error |
Warning |
N/A |
ON |
This notification is generated when the speed of an FC aggregate interface changes and contains the following information:
· Aggregation group number for the aggregate interface (hh3cSanAggGroupNumber).
· Speed after change.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.127.2.2.1.1 (hh3cSanAggGroupNumber) |
Aggregation group number for the aggregate interface. |
No |
Integer32 |
1..65535 |
1.3.6.1.4.1.25506.2.127.2.3.1 (hh3cSanAggGroupPreviousSpeed) |
Speed of the FC aggregate interface before speed change |
No |
Integer32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.127.2.3.2 (hh3cSanAggGroupCurrentSpeed) |
Speed of the FC aggregate interface after speed change |
No |
Integer32 |
Recommended action
To resolve the issue:
1. Verify that no link error or network topology change occurs.
2. If the issue persists, contact H3C Support.
hh3cSanAggMemberInactive
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.2.4.0.2 |
Member port becoming Unselected |
Error |
Major |
1.3.6.1.4.1.25506.2.127.2.4.0.3(hh3cSanAggMemberActive) |
ON |
This notification is generated when a member port becomes Unselected and contains the following information:
· Index of the member port (ifIndex).
· Description of the member port (ifDescr).
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Integer32 |
1..65535 |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Index of the member port. |
No |
InterfaceIndex |
Integer32(1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Description of the member port. |
No |
DisplayString |
OCTET STRING (SIZE (0..255)) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.2.4.0.3 |
Member port becoming Selected |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a member port becomes Selected and contains the following information:
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
Integer32 |
1..65535 |
No |
InterfaceIndex |
No |
DisplayString |
Recommended action
