- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
11-HH3C-NPV-MIB | 90.44 KB |
HH3C-NPV-MIB
About this MIB
Use this MIB to configure or obtain NPV settings.
MIB file name
hh3c-npv.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cNpv(6)
Scalar objects
hh3cNpvLoadbalanceVsan
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNpvLoadbalanceVsan (1.3.6.1.4.1.25506.2.127.6.1.1.1.1) |
read-write |
Unsigned32 |
Unsigned32 |
Initiates a load balancing process in a VSAN. |
Supports only the write operation. |
Tabular objects
hh3cNpvTrafficMapConfigTable
About this table
This table configures or obtains downlink-to-uplink interface mappings.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ifIndex and hh3cVsanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNpvTrafficMapExternalIfIndexList (1.3.6.1.4.1.25506.2.127.6.1.1.2.1.1) |
read-create |
OCTET STRING |
octet string (size(4..65535)) |
List of uplink interface indexes. |
As per the MIB. |
hh3cNpvTrafficMapLastChange (1.3.6.1.4.1.25506.2.127.6.1.1.2.1.2) |
read-only |
TimeStamp |
TimeTicks (0.. 4294967295) |
Last mapping change time. |
As per the MIB. |
hh3cNpvTrafficMapRowStatus (1.3.6.1.4.1.25506.2.127.6.1.1.2.1. 3) |
read-create |
RowStatus |
1:active(1) 2:notInService(2) 3:notReady(3) 4:createAndGo(4) 5:createAndWait(5) 6:destroy(6) |
Row status. |
As per the MIB. |
hh3cNpvServerIfTable
About this table
This table obtains uplink interface indexes.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNpvExternalIfIndex (1.3.6.1.4.1.25506.2.127.6.1.1.1.3.1.1) |
read-only |
Integer32 |
Integer32 (0..32767) |
Uplink interface index. |
As per the MIB. |
hh3cNpvLoadBalanceTable
About this table
This table configures automatic load balancing.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cVsanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNpvAutoLoadBalanceEnable (1.3.6.1.4.1.25506.2.127.6.1.1.4.1.1) |
read-write |
TruthValue |
TruthValue true(1) false(2) |
Enables/Disables automatic load balancing. |
As per the MIB. |
hh3cNpvAutoLoadBalanceInterval (1.3.6.1.4.1.25506.2.127.6.1.1.4.1.2) |
read-write |
Unsigned32 |
Unsigned32 (1..300) |
Delay timer for automatic load balancing, in seconds. |
As per the MIB. |
