- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
04-HH3C-FCOE-MIB | 146.07 KB |
HH3C-FCOE-MIB
About this MIB
Use this MIB to configure FCoE information.
MIB file name
hh3c-fcoe.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cFCoE(120)
Tabular objects
hh3cFCoECfgTable
About this table
This table obtains FCoE configuration information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is fcmInstanceIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFCoECfgFcmap (1.3.6.1.4.1.25506.2.120.1.1.1.1.1) |
read-write |
OCTET STRING |
OCTET STRING (3) |
FC map value. |
As per the MIB. |
hh3cFCoECfgDynamicVfcCreation (1.3.6.1.4.1.25506.2.120.1.1.1.1.2) |
read-write |
TruthValue |
true(1), |
Indicates whether the switch can automatically VFC interfaces. |
The value can only be false(2). |
hh3cFCoECfgDefaultFCFPriority (1.3.6.1.4.1.25506.2.120.1.1.1.1.3) |
read-write |
Unsigned32 |
Unsigned32 0..255 |
System FCF priority. |
As per the MIB. |
hh3cFCoECfgDATov (1.3.6.1.4.1.25506.2.120.1.1.1.1.4) |
read-write |
Unsigned32 |
Unsigned32 4..600 |
Keepalive timer. |
As per the MIB. |
hh3cFcoECfgAddressingMode (1.3.6.1.4.1.25506.2.120.1.1.1.1.5) |
read-write |
INTEGER |
INTEGER 1:fpma(1) 2:spma(2) 3:fpmaAndSpma(3) |
Address mode. |
The value can only be fpma(1). |
hh3cFCoEVLANTable
About this table
This table configures or obtains VLAN-VSAN mappings.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, hh3cFCoEVLANIndex, and hh3cFCoEFabricIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFCoEVLANIndex (1.3.6.1.4.1.25506.2.120.1.1.2.1.1) |
not-accessible |
VlanIndex |
Unsigned32 |
VLAN index. |
As per the MIB. |
hh3cFCoEFabricIndex (1.3.6.1.4.1.25506.2.120.1.1.2.1.2) |
not-accessible |
T11FabricIndex |
Unsigned32 |
VSAN index. |
As per the MIB. |
hh3cFCoEVLANOperState (1.3.6.1.4.1.25506.2.120.1.1.2.1.3) |
read-only |
INTEGER |
1:up(1) |
VLAN-VSAN mapping state. |
If the VSAN exists, the VLAN-VSAN mapping is up. If the VSAN does not exist, the VLAN-VSAN mapping is down. |
hh3cFCoEVLANRowStatus (1.3.6.1.4.1.25506.2.120.1.1.2.1.4) |
read-create |
RowStatus |
1:active(1) |
Row status. |
Supports only the following values: · createandgo. · createandwait. · destroy. |
hh3cFCoEStaticVfcTable
About this table
This table configures or obtains VFC interface information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are fcmInstanceIndex and hh3cFCoEStaticVfcIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFCoEStaticVfcIndex (1.3.6.1.4.1.25506.2.120.1.1.3.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 |
VFC record index. |
As per the MIB. |
hh3cFCoEStaticVfcFCFPriority (1.3.6.1.4.1.25506.2.120.1.1.3.1.2) |
read-create |
Unsigned32 |
Unsigned32 |
FCF priority. |
The default value is 128. |
hh3cFCoEStaticVfcBindType (1.3.6.1.4.1.25506.2.120.1.1.3.1.3) |
read-create |
Hh3cFCoEVfcBindType |
INTEGER |
Binding type. |
The interfaceIndex (1) value is required, and the macAddress(2) is optional. |
hh3cFCoEStaticVfcBindIfIndex (1.3.6.1.4.1.25506.2.120.1.1.3.1.4) |
read-create |
InterfaceIndexOrZero |
Integer32 |
Index of the bound Ethernet interface. |
hh3cFCoEStaticVfcBindMACAddress (1.3.6.1.4.1.25506.2.120.1.1.3.1.5) |
read-create |
MacAddress |
OCTET STRING (6) |
Bound MAC address. |
As per the MIB. |
hh3cFCoEStaticVfcIfIndex (1.3.6.1.4.1.25506.2.120.1.1.3.1.6) |
read-only |
InterfaceIndex |
Integer32 |
VFC interface index. |
As per the MIB. |
hh3cFCoEStaticVfcCreationTime (1.3.6.1.4.1.25506.2.120.1.1.3.1.7) |
read-only |
TimeStamp |
TimeTicks |
Creation time. |
As per the MIB. |
hh3cFCoEStaticVfcFailureCause (1.3.6.1.4.1.25506.2.120.1.1.3.1.8) |
read-only |
SnmpAdminString |
OCTET STRING (0...255) |
Last binding failure time. |
As per the MIB. |
hh3cFCoEStaticVfcRowStatus (1.3.6.1.4.1.25506.2.120.1.1.3.1.9) |
read-create |
RowStatus |
1:active(1)
Row status. |
hh3cFCoEFIPSnoopingTable
About this table
This table obtains FIP snooping settings for a VLAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex and hh3cFCoEFIPSnoopingVLANIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFCOEFipSnoopingVLANIndex (1.3.6.1.4.1.25506.2.120.1.1.4.1.1) |
not-accessible |
VlanIndex |
Unsigned32 |
VLAN index. |
As per the MIB. |
hh3cFCoEFIPSnoopingEnable (1.3.6.1.4.1.25506.2.120.1.1.4.1.2) |
read-write |
TruthValue |
true(1), |
FIP snooping state. |
The default value is false(2). |
hh3cFCoEFIPSnoopingFcmap (1.3.6.1.4.1.25506.2.120.1.1.4.1.3) |
read-write |
OCTET STRING |
OCTET STRING (3) |
FC-MAP value. |
As per the MIB. |
hh3cFCoEVlanCfgTable
About this table
This table configures FCoE settings in a VLAN. This table is supported only when the switch is operating is FCF-NPV mode.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cFCoEVLANIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
not-accessible |
VlanIndex |
Unsigned32(0..4094) |
VLAN index. |
As per the MIB. |
hh3cFCoEVlanCfgFcmap (1.3.6.1.4.1.25506.2.120.1.1.5.1.1) |
read-create |
OCTET STRING |
OCTET STRING (SIZE (3)) |
FC-MAP value. |
As per the MIB. |
hh3cFCoEVlanCfgFCFPriority (1.3.6.1.4.1.25506.2.120.1.1.5.1.2) |
read-create |
Unsigned32 |
Unsigned32 (0..255) |
FCF priority. |
As per the MIB. |
hh3cFCoEVlanCfgDATov (1.3.6.1.4.1.25506.2.120.1.1.5.1.3) |
read-create |
Unsigned32 |
Unsigned32 (4..600) |
FKA advertisement interval in seconds. |
As per the MIB. |
hh3cFCoEVlanCfgRowStatus (1.3.6.1.4.1.25506.2.120.1.1.5.1.4) |
read-create |
RowStatus |
1:active(1) |
Row status. |
As per the MIB. |
hh3cFCoEFIPSnoopingFCFTable
About this table
This table obtains FIP snooping FCF information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, hh3cFCoEFIPSnoopingFCFVLANIndex, hh3cFCoEFIPSnoopingFCFIfIndex, and hh3cFCoEFIPSnoopingFCFMAC.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFCoEFIPSnoopingFCFVLANIndex(1.3.6.1.4.1.25506.2.120.1.1.6.1.1) |
not-accessible |
VlanIndex |
Unsigned32
VLAN index. |
As per the MIB. |
hh3cFCoEFIPSnoopingFCFIfIndex(1.3.6.1.4.1.25506.2.120.1.1.6.1.2) |
not-accessible |
InterfaceIndex |
Integer32 |
Index of the Ethernet interface connected to the FCF. |
As per the MIB. |
hh3cFCoEFIPSnoopingFCFMAC(1.3.6.1.4.1.25506.2.120.1.1.6.1.3) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address of the FCF connected to the FIP snooping device. |
As per the MIB. |
hh3cFCoEFIPSnoopingFCFSwitchName(1.3.6.1.4.1.25506.2.120.1.1.6.1.4) |
read-only |
Hh3cFcNameId |
OCTET STRING |
FCF switch name. |
As per the MIB. |
hh3cFCoEFIPSnoopingFCFFabricName(1.3.6.1.4.1.25506.2.120.1.1.6.1.5) |
read-only |
Hh3cFcNameId |
OCTET STRING |
FCF fabric name. |
As per the MIB. |
hh3cFCoEFIPSnoopingFCFENodeCount(1.3.6.1.4.1.25506.2.120.1.1.6.1.6) |
read-only |
Unsigned32 |
Unsigned32 |
Number of ENodes connected to the FCF through the Ethernet interface. |
As per the MIB. |
hh3cFCoEFIPSnoopingENodeTable
About this table
This table obtains FIP snooping ENode information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, hh3cFCoEFIPSnoopingENodeVLANIndex, hh3cFCoEFIPSnoopingENodeIfIndex, and hh3cFCoEFIPSnoopingENodeMAC.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFCoEFIPSnoopingENodeVLANIndex(1.3.6.1.4.1.25506.2.120.1.1.7.1.1) |
not-accessible |
VlanIndex |
Unsigned32 |
VLAN index. |
As per the MIB. |
hh3cFCoEFIPSnoopingENodeIfIndex(1.3.6.1.4.1.25506.2.120.1.1.7.1.2) |
not-accessible |
InterfaceIndex |
Integer32 |
Index of the Ethernet interface connected to the ENode. |
As per the MIB. |
hh3cFCoEFIPSnoopingENodeMAC(1.3.6.1.4.1.25506.2.120.1.1.7.1.3) |
not-accessible |
MacAddress |
OCTET STRING (6) |
ENode MAC address. |
As per the MIB. |
hh3cFCoEFIPSnoopingENodeName(1.3.6.1.4.1.25506.2.120.1.1.7.1.4) |
read-only |
Hh3cFcNameId |
OCTET STRING |
ENode node name. |
As per the MIB. |
hh3cFCoEFIPSnoopingVNTable
About this table
This table obtains FIP snooping VN information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, hh3cFCoEFIPSnoopingVNVLANIndex, hh3cFCoEFIPSnoopingVNENodeIfIndex, hh3cFCoEFIPSnoopingVNENodeMAC, hh3cFCoEFIPSnoopingVNFCFMAC, and hh3cFCoEFIPSnoopingVNMAC.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFCoEFIPSnoopingVNVLANIndex(1.3.6.1.4.1.25506.2.120.1.1.8.1.1) |
not-accessible |
VlanIndex |
Unsigned32 |
VLAN index. |
As per the MIB. |
hh3cFCoEFIPSnoopingVNENodeIfIndex(1.3.6.1.4.1.25506.2.120.1.1.8.1.2) |
not-accessible |
InterfaceIndex |
Integer32 |
As per the MIB. |
hh3cFCoEFIPSnoopingVNENodeMAC(1.3.6.1.4.1.25506.2.120.1.1.8.1.3) |
not-accessible |
MacAddress |
OCTET STRING (6) |
As per the MIB. |
hh3cFCoEFIPSnoopingVNFCFMAC(1.3.6.1.4.1.25506.2.120.1.1.8.1.4) |
not-accessible |
MacAddress |
OCTET STRING (6) |
FCF MAC address. |
As per the MIB. |
hh3cFCoEFIPSnoopingVNMAC(1.3.6.1.4.1.25506.2.120.1.1.8.1.5) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address of the virtual N_Port. |
As per the MIB. |
hh3cFCoEFIPSnoopingVNName(1.3.6.1.4.1.25506.2.120.1.1.8.1.6) |
read-only |
Hh3cFcNameId |
OCTET STRING |
Port name of the virtual N_Port. |
As per the MIB. |
hh3cFCoEFIPSnoopingVNFCFIfIndex(1.3.6.1.4.1.25506.2.120.1.1.8.1.7) |
read-only |
InterfaceIndex |
Integer32 |
As per the MIB. |
hh3cFCoEFIPSnoopingIfCfgTable
About this table
This table configures or obtains Ethernet interface settings for FIP snooping.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex and hh3cFCoEFIPSnoopingIfCfgIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFCoEFIPSnoopingIfCfgIfIndex(1.3.6.1.4.1.25506.2.120.1.1.9.1.1) |
not-accessible |
InterfaceIndex |
Integer32 |
Ethernet interface index. |
As per the MIB. |
hh3cFCoEFIPSnoopingIfCfgPortType(1.3.6.1.4.1.25506.2.120.1.1.9.1.2) |
read-write |
INTEGER |
INTEGER |
Ethernet interface operating mode. |
As per the MIB. |
