- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
09-HH3C-FC-ZONE-SERVER-MIB | 195.39 KB |
hh3cFcZsZoneAliasNextFreeIndex
hh3cFcZsDefaultZoneChangedEnable
hh3cFcZsActivationCompletedEnable
hh3cFcZsZoneMemberNextFreeIndexTable
hh3cFcZsDefaultZoneChangedNotify
hh3cFcZsActivationCompletedNotify
About this MIB
Use this MIB to configure or obtain zoning settings.
MIB file name
hh3c-fc-zone-server.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cFcZoneServer(9)
Scalar objects
hh3cFcZsClearAllPktStats
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsClearAllPktStats (1.3.6.1.4.1.25506.2.127.9.1.2.5) |
read-write |
INTEGER |
noOper(1) clearStats(2) |
Clears packet statistics for all VSANs. |
As per the MIB. |
hh3cFcZsZonesetNextFreeIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsZonesetNextFreeIndex (1.3.6.1.4.1.25506.2.127.9.1.3.5.1) |
read-only |
Unsigned32 |
Unsigned32(1..4294967295) |
Smallest available index used to create s zone set. |
The value range varies by product. |
hh3cFcZsZoneNextFreeIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsZoneNextFreeIndex (1.3.6.1.4.1.25506.2.127.9.1.3.5.2) |
read-only |
Unsigned32 |
Smallest available index used to create s zone. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsZoneAliasNextFreeIndex (1.3.6.1.4.1.25506.2.127.9.1.3.5.3) |
read-only |
Unsigned32 |
Smallest available index used to create s zone alias. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsDefaultZoneChangedEnable (1.3.6.1.4.1.25506.2.127.9.1.4.1.1) |
read-write |
TruthValue |
true(1) false(2) |
Trap switch for hh3cFcZsDefaultZoneChangedNotify. |
As per the MIB. |
hh3cFcZsHardZoneChangedEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsHardZoneChangedEnable (1.3.6.1.4.1.25506.2.127.9.1.4.1.2) |
read-write |
TruthValue |
true(1) false(2) |
Trap switch for hh3cFcZsHardZoneChangedNotify. |
As per the MIB. |
hh3cFcZsMergeFailedEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsMergeFailedEnable (1.3.6.1.4.1.25506.2.127.9.1.4.1.3) |
read-write |
TruthValue |
true(1) false(2) |
Trap switch for hh3cFcZsMergeFailedNotify. |
As per the MIB. |
hh3cFcZsMergeSucceededEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsMergeSucceededEnable (1.3.6.1.4.1.25506.2.127.9.1.4.1.4) |
read-write |
INTEGER |
true(1) false(2) |
Trap switch for hh3cFcZsMergeSucceededNotify. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsActivationCompletedEnable (1.3.6.1.4.1.25506.2.127.9.1.4.1.5) |
read-write |
TruthValue |
true(1) false(2) |
Trap switch for hh3cFcZsActivationCompletedNotify. |
As per the MIB. |
hh3cFcZsLocalSwitchWWN
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsLocalSwitchWWN (1.3.6.1.4.1.25506.2.127.9.1.4.2.1) |
accessible-for-notify |
Hh3cFcNameId |
OCTET STRING(8) |
Local switch WWN. |
As per the MIB. |
hh3cFcZsPeerSwitchWWN
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsPeerSwitchWWN (1.3.6.1.4.1.25506.2.127.9.1.4.2.2) |
Hh3cFcNameId |
OCTET STRING(8) |
Peer switch WWN. |
As per the MIB. |
hh3cFcZsMergeFailCause
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsMergeFailCause (1.3.6.1.4.1.25506.2.127.9.1.4.2.3) |
INTEGER |
zoneModeInconsistent(1), zonePolicyNotEqual(2), hardZoneInconsistent(3), dataNotEqualInRestrict(4), activeZoneSetMergeFailed(5), zoneMergeDataTooBig(6), zoningObjectNumberTooBig(7), zoneDbMergeFaildInBasic(8), zoneDbMergeFaildInEnhanced(9), other(10) |
Zone merge failure cause. |
As per the MIB. |
Tabular objects
hh3cFcZsServerTable
About this table
This table configures or obtains zoning configuration.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cVsanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsZoneModeCfg (1.3.6.1.4.1.25506.2.127.9.1.1.1.1.1) |
read-write |
INTEGER |
basic(1) |
Zoning mode. |
As per the MIB. |
hh3cFcZsHardZoneEnable (1.3.6.1.4.1.25506.2.127.9.1.1.1.1.2) |
read-write |
TruthValue |
true(1) |
Hard zoning. |
As per the MIB. |
hh3cFcZsDistributeRule (1.3.6.1.4.1.25506.2.127.9.1.1.1.1.3) |
read-write |
INTEGER |
none(1) |
Zone distribution type. |
As per the MIB. |
hh3cFcZsDefaultZoneSetting (1.3.6.1.4.1.25506.2.127.9.1.1.1.1.4) |
read-write |
INTEGER |
deny(1) |
Default zone policy. |
As per the MIB. |
hh3cFcZsMergeControlSetting (1.3.6.1.4.1.25506.2.127.9.1.1.1.1.5) |
read-write |
INTEGER |
none(1) |
Merge control mode. |
As per the MIB. |
hh3cFcZsServerLastResult (1.3.6.1.4.1.25506.2.127.9.1.1.1.1.6) |
read-only |
INTEGER |
none(1) |
Last operation result. |
As per the MIB. |
hh3cFcZsZonesetTable
About this table
This table creates, deletes, or renames a zone set.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cVsanIndex and hh3cFcZsZonesetIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsZonesetIndex (1.3.6.1.4.1.25506.2.127.9.1.1.2.1.1) |
not-accessible |
Unsigned32 |
Zone set index. |
hh3cFcZsZonesetName (1.3.6.1.4.1.25506.2.127.9.1.1.2.1.2) |
read-create |
Hh3cFcZsGenName |
OCTET STRING (1..255) |
Zone set name. |
N/A. |
Hh3cFcZsZonesetRowStatus (1.3.6.1.4.1.25506.2.127.9.1.1.2.1.3) |
read-create |
RowStatus |
active(1) notInService(2) |
Row status. |
Supports only the following values: · active(1) . · createAndGo(4). · destroy(6). |
hh3cFcZsZoneTable
About this table
This table creates, deletes, or renames a zone, or change the Pairwise enable status for the zone.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Not supported |
Columns
The table indexes are hh3cVsanIndex and hh3cFcZsZoneIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsZoneIndex (1.3.6.1.4.1.25506.2.127.9.1.1.3.1.1) |
not-accessible |
Unsigned32 |
Zone index. |
hh3cFcZsZoneName (1.3.6.1.4.1.25506.2.127.9.1.1.3.1.2) |
read-create |
Hh3cFcZsGenName |
Zone name. |
As per the MIB. |
hh3cFcZsZonePairwiseEnable (1.3.6.1.4.1.25506.2.127.9.1.1.3.1.3) |
read-create |
TruthValue |
true(1) |
Pairwise enable status. |
As per the MIB. |
hh3cFcZsZoneRowStatus (1.3.6.1.4.1.25506.2.127.9.1.1.3.1.4) |
read-create |
RowStatus |
active(1) |
Row status. |
hh3cFcZsSetZoneTable
About this table
This table assigns a zone to a zone set.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are hh3cVsanIndex, hh3cFcZsZonesetIndex, and hh3cFcZsZoneIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsSetZoneRowStatus (1.3.6.1.4.1.25506.2.127.9.1.1.4.1.1) |
read-create |
RowStatus |
active(1), |
Row status. |
hh3cFcZsZoneAliasTable
About this table
This table configures or obtains zone aliases in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cVsanIndex and hh3cFcZsZoneAliasIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsZoneAliasIndex (1.3.6.1.4.1.25506.2.127.9.1.1.5.1.1) |
not-accessible |
Unsigned32 |
Unsigned32(1.. 4294967295) |
Zone alias index. |
hh3cFcZsZoneAliasName (1.3.6.1.4.1.25506.2.127.9.1.1.5.1.2) |
read-create |
Hh3cFcZsGenName |
Zone alias name. |
As per the MIB. |
hh3cFcZsZoneAliasRowStatus (1.3.6.1.4.1.25506.2.127.9.1.1.5.1.3) |
read-create |
RowStatus |
active(1) notInService(2) notReady(3) createAndGo(4) createAndWait(5) destroy(6) |
Row status. |
hh3cFcZsZoneMemberTable
About this table
This table configures or obtains the members of a zone or zone alias in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cVsanIndex, hh3cFcZsZoneMemberParentType, hh3cFcZsZoneMemberParentIndex, and hh3cFcZsZoneMemberIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsZoneMemberParentType (1.3.6.1.4.1.25506.2.127.9.1.1.6.1.1) |
not-accessible |
INTEGER |
zone(1) |
Parent type. |
As per the MIB. |
hh3cFcZsZoneMemberParentIndex (1.3.6.1.4.1.25506.2.127.9.1.1.6.1.2) |
not-accessible |
Unsigned32 |
Zone index or zone alias index. |
As per the MIB. |
hh3cFcZsZoneMemberIndex (1.3.6.1.4.1.25506.2.127.9.1.1.6.1.3) |
not-accessible |
Unsigned32 |
Member index. |
As per the MIB. |
hh3cFcZsZoneMemberFormat (1.3.6.1.4.1.25506.2.127.9.1.1.6.1.4) |
read-create |
Hh3cFcZsZoneMemberType |
fcid(1) |
Member type. |
As per the MIB. |
hh3cFcZsZoneMemberIdentifier (1.3.6.1.4.1.25506.2.127.9.1.1.6.1.5) |
read-create |
OCTET STRING |
OCTET STRING (SIZE (1..255)) |
Member. |
As per the MIB. |
hh3cFcZsZoneMemberPairwiseRole (1.3.6.1.4.1.25506.2.127.9.1.1.6.1.6) |
read-create |
INTEGER |
none(1) |
Member role. |
This object is applicable only to port members, and the default value is both(2). For a zone alias member, the member role can only be none(1). |
hh3cFcZsZoneMemberRowStatus (1.3.6.1.4.1.25506.2.127.9.1.1.6.1.7) |
read-create |
RowStatus |
active(1) |
Row status. |
hh3cFcZsActivateTable
About this table
This table activates or deactivates a zone set and obtains the result.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsActivate (1.3.6.1.4.1.25506.2.127.9.1.2.1.1.1) |
read-write |
Hh3cFcZsGenNameOrZero |
OCTET STRING (0..255) |
Name of the zone set to be activated. |
As per the MIB. |
hh3cFcZsDeactivate (1.3.6.1.4.1.25506.2.127.9.1.2.1.1.2) |
read-write |
INTEGER |
noOper(1) |
Name of the zone set to be deactivated. |
As per the MIB. |
hh3cFcZsActivateResult (1.3.6.1.4.1.25506.2.127.9.1.2.1.1.3) |
read-only |
INTEGER |
none(1) |
Last zone set activation or deactivation result. |
As per the MIB. |
hh3cFcZsActivateFailReason (1.3.6.1.4.1.25506.2.127.9.1.2.1.1.4) |
read-only |
INTEGER |
none(1) |
Failure cause of the last zone set activation or deactivation. |
As per the MIB. |
hh3cFcZsDistributeTable
About this table
This table triggers a zone distribution and obtains the result.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsDistribute (1.3.6.1.4.1.25506.2.127.9.1.2.2.1.1) |
read-write |
INTEGER |
noOper(1) |
Triggers a zone distribution. |
As per the MIB. |
hh3cFcZsDistributeLastResult (1.3.6.1.4.1.25506.2.127.9.1.2.2.1.2) |
read-only |
INTEGER |
none(1) |
Last distribution result. |
As per the MIB. |
hh3cFcZsDistributeReasonCode (1.3.6.1.4.1.25506.2.127.9.1.2.2.1.3) |
read-only |
Unsigned32 |
Unsigned32 |
Reason code for the last distribution result. |
As per the MIB. |
hh3cFcZsDistributeExplainCode (1.3.6.1.4.1.25506.2.127.9.1.2.2.1.4) |
read-only |
Unsigned32 |
Unsigned32 |
Explanation code for the reason code of the last distribution result. |
As per the MIB. |
hh3cFcZsClearDatabaseTable
About this table
This table clears the zone database in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Not supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsClearDatabase (1.3.6.1.4.1.25506.2.127.9.1.2.3.1.1) |
read-write |
INTEGER |
noOper(1) |
Clears the zone database in a VSAN. |
As per the MIB. |
hh3cFcZsClearPktStatsTable
About this table
This table clears zoning packet statistics in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Not supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsClearPktStats (1.3.6.1.4.1.25506.2.127.9.1.2.4.1.1) |
read-write |
INTEGER |
noOper(1) |
Clears zoning packet statistics in a VSAN. |
As per the MIB. |
hh3cFcZsActiveZoneTable
About this table
This table obtains information about the active zone.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cVsanIndex and t11ZsActiveZoneIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsActiveZonePairwiseEnable (1.3.6.1.4.1.25506.2.127.9.1.3.1.1.1) |
read-only |
TruthValue |
true(1) |
Pairwise enable status for the active zone. |
As per the MIB. |
hh3cFcZsActiveMemberTable
About this table
This table obtains information about members in the active zone.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cVsanIndex, t11ZsActiveZoneIndex, and t11ZsActiveZoneMemberIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsActiveMemberPairwiseRole (1.3.6.1.4.1.25506.2.127.9.1.3.2.1.1) |
read-only |
INTEGER |
both(1) |
Member role. |
As per the MIB. |
hh3cFcZsServerStatusTable
About this table
This table obtains the zoning configuration and status in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsServerStatus (1.3.6.1.4.1.25506.2.127.9.1.3.3.1.1) |
read-only |
INTEGER |
free(1) |
Zone service status. |
As per the MIB. |
hh3cFcZsHardZoneStatus (1.3.6.1.4.1.25506.2.127.9.1.3.3.1.2) |
read-only |
INTEGER |
enable(1) |
Hard zoning status. |
As per the MIB. |
hh3cFcZsAliasCount (1.3.6.1.4.1.25506.2.127.9.1.3.3.1.3) |
read-only |
Unsigned32 |
Unsigned32(0..4294967295) |
Number of zone aliases. |
As per the MIB. |
hh3cFcZsZoneCount (1.3.6.1.4.1.25506.2.127.9.1.3.3.1.4) |
read-only |
Unsigned32 |
Number of zones. |
As per the MIB. |
hh3cFcZsZonesetCount (1.3.6.1.4.1.25506.2.127.9.1.3.3.1.5) |
read-only |
Unsigned32 |
Number of zone sets. |
As per the MIB. |
hh3cFcZsPktStatsTable
About this table
This table obtains the zoning packet statistics in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsPktInMergeReqCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.1) |
read-only |
Counter64 |
Counter64 |
Number of incoming Merge Request packets. |
As per the MIB. |
hh3cFcZsPktOutMergeReqCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.2) |
read-only |
Counter64 |
Counter64 |
Number of outgoing Merge Request packets. |
As per the MIB. |
hh3cFcZsPktInMergeAccCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.3) |
read-only |
Counter64 |
Counter64 |
Number of incoming Merge Accept packets. |
As per the MIB. |
hh3cFcZsPktOutMergeAccCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.4) |
read-only |
Counter64 |
Counter64 |
Number of outgoing Accept Request packets. |
As per the MIB. |
hh3cFcZsPktInMergeRjtCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.5) |
read-only |
Counter64 |
Counter64 |
Number of incoming Merge Reject packets. |
As per the MIB. |
hh3cFcZsPktOutMergeRjtCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.6) |
read-only |
Counter64 |
Counter64 |
Number of outgoing Merge Reject packets. |
As per the MIB. |
hh3cFcZsPktInChangeReqCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.7) |
read-only |
Counter64 |
Counter64 |
Number of incoming Distribution Request packets. |
As per the MIB. |
hh3cFcZsPktOutChangeReqCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.8) |
read-only |
Counter64 |
Counter64 |
Number of outgoing Distribution Request packets. |
As per the MIB. |
hh3cFcZsPktInChangeAccCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.9) |
read-only |
Counter64 |
Counter64 |
Number of incoming Distribution Accept packets. |
As per the MIB. |
hh3cFcZsPktOutChangeAccCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.10) |
read-only |
Counter64 |
Counter64 |
Number of outgoing Distribution Accept packets. |
As per the MIB. |
hh3cFcZsPktInChangeRjtCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.11) |
read-only |
Counter64 |
Counter64 |
Number of incoming Distribution Reject packets. |
As per the MIB. |
hh3cFcZsPktOutChangeRjtCount (1.3.6.1.4.1.25506.2.127.9.1.3.4.1.12) |
read-only |
Counter64 |
Counter64 |
Number of outgoing Distribution Reject packets. |
As per the MIB. |
About this table
This table obtains the smallest available index used to create a member.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cFcZsZoneMemberParentType and hh3cFcZsZoneMemberParentIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcZsZoneMemberNextFreeIndex (1.3.6.1.4.1.25506.2.127.9.1.3.5.4.1.1) |
read-only |
Unsigned32 |
Smallest available index used to create a member. |
As per the MIB. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.127.9.1.4.0.1 |
Default zone policy changed |
Informational |
N/A |
N/A |
OFF |
The default zone policy changes in a VSAN.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-zone defaultzone-change command.
· MIB: Set hh3cFcZsDefaultZoneChangedEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-zone defaultzone-change command.
· MIB: Set hh3cFcZsDefaultZoneChangedEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.127.1.1.1.1.1.1 (hh3cVsanIndex) |
VSAN ID. |
Yes |
Hh3cFcVsanIndex |
Unsigned32(1..4095) |
1.3.6.1.4.1.25506.2.127.9.1.4.2.1 (hh3cFcZsLocalSwitchWWN) |
Local switch WWN. |
No |
Hh3cFcNameId |
OCTET STRING (SIZE (8)) |
1.3.6.1.4.1.25506.2.127.9.1.1.1.1.4 (hh3cFcZsDefaultZoneSetting) |
No |
INTEGER |
deny(1) permit(2) |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.9.1.4.0.2 |
Hard zoning status changed |
Informational |
N/A |
N/A |
OFF |
The hard zoning status changes in a VSAN.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-zone hardzone-change command.
· MIB: Set hh3cFcZsHardZoneChangedEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-zone hardzone-change command.
· MIB: Set hh3cFcZsHardZoneChangedEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
VSAN ID. |
Yes |
Hh3cFcVsanIndex |
Local switch WWN. |
No |
Hh3cFcNameId |
1.3.6.1.4.1.25506.2.127.9.1.3.3.1.2 (hh3cFcZsHardZoneStatus) |
No |
INTEGER |
enable(1) adminDisable(2) noResourceDisable(3) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.9.1.4.0.3 |
Zone merge failure |
Error |
Major |
1.3.6.1.4.1.25506.2.127.9.1.4.0.4(hh3cFcZsMergeSucceededNotify) |
OFF |
A zone merge failure occurred.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-zone merge-failed command.
· MIB: Set hh3cFcZsMergeFailedEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-zone merge-failed command.
· MIB: Set hh3cFcZsMergeFailedEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index. |
Yes |
InterfaceIndex |
Integer32(1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface name. |
No |
DisplayString |
OCTET STRING (SIZE (0..255)) |
VSAN ID |
Yes |
Hh3cFcVsanIndex |
Local switch WWN. |
No |
Hh3cFcNameId |
1.3.6.1.4.1.25506.2.127.9.1.4.2.2 (hh3cFcZsPeerSwitchWWN) |
Peer switch WWN. |
No |
Hh3cFcNameId |
1.3.6.1.4.1.25506.2.127.9.1.4.2.3 (hh3cFcZsMergeFailCause) |
No |
INTEGER |
zoneModeInconsistent(1) zonePolicyNotEqual(2) hardZoneInconsistent(3) dataNotEqualInRestrict(4) activeZoneSetMergeFailed(5) zoneMergeDataTooBig(6) zoningObjectNumberTooBig(7) zoneDbMergeFaildInBasic(8) zoneDbMergeFaildInEnhanced(9) other(10) |
Recommended action
To resolve the issue:
1. Check the zoning configuration and make corrections.
2. If the issue persists, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.9.1.4.0.4 |
Zone merge success |
Recovery |
N/A |
N/A |
OFF |
A zone merge is performed successfully.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-zone merge-succeeded command.
· MIB: Set hh3cFcZsMergeSucceededEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-zone merge-succeeded command.
· MIB: Set hh3cFcZsMergeSucceededEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index. |
Yes |
InterfaceIndex |
Interface name. |
No |
DisplayString |
VSAN ID |
Yes |
Hh3cFcVsanIndex |
Local switch WWN. |
No |
Hh3cFcNameId |
Peer switch WWN. |
No |
Hh3cFcNameId |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.9.1.4.0.5 |
Zone set activation or deactivation |
Informational |
N/A |
N/A |
OFF |
A zone set activation or deactivation operation is completed.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-zone activation-completed command.
· MIB: Set hh3cFcZsActivationCompletedEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-zone activation-completed command.
· MIB: Set hh3cFcZsActivationCompletedEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
VSAN ID. |
Yes |
Hh3cFcVsanIndex |
Local switch WWN. |
No |
Hh3cFcNameId |
1.3.6.1.4.1.25506.2.127.9.1.2.1.1.3 (hh3cFcZsActivateResult) |
Activation or deactivation result. |
No |
INTEGER |
none(1) inProgress(2) activateSuccess(3) activateFailure(4) deactivateSuccess(5) deactivateFailure(6) |
Recommended action
If the activation or deactivation result is failure, find out the failure cause and perform an activation or deactivation again.
