- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
10-HH3C-FDMI-MIB | 64.35 KB |
HH3C-FDMI-MIB
About this MIB
Use this MIB to obtain FDMI information.
MIB file name
hh3c-fdmi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cFdmi(7)
Tabular objects
hh3cFdmiHbaInfoTable
About this table
This table obtains information about HBAs registered with FDMI.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, hh3cFdmiHbaInfoFabricIndex, and hh3cFdmiHbaInfoId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFdmiHbaInfoFabricIndex (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 1..3839 |
VSAN ID. |
As per the MIB. |
hh3cFdmiHbaInfoId (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.2) |
not-accessible |
OCTET STRING |
FcNameIdOrZero Size: 8 |
HBA WWN. |
As per the MIB. |
hh3cFdmiHbaInfoNodeName (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.3) |
read-only |
OCTET STRING |
Node WWN. |
As per the MIB. |
hh3cFdmiHbaInfoMfg (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.4) |
read-only |
OCTET STRING |
OCTET STRING Size: 1..63 |
HBA manufacturer. |
As per the MIB. |
hh3cFdmiHbaInfoSn (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.5) |
read-only |
OCTET STRING |
HBA serial number. |
As per the MIB. |
hh3cFdmiHbaInfoModel (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.6) |
read-only |
OCTET STRING |
OCTET STRING Size: 1..255 |
HBA model. |
As per the MIB. |
hh3cFdmiHbaInfoModelDescr (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.7) |
read-only |
OCTET STRING |
HBA model description. |
As per the MIB. |
hh3cFdmiHbaInfoHwVer (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.8) |
read-only |
OCTET STRING |
HBA hardware version. |
As per the MIB. |
hh3cFdmiHbaInfoDriverVer (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.9) |
read-only |
OCTET STRING |
HBA driver version number. |
As per the MIB. |
hh3cFdmiHbaInfoOptROMVer (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.10) |
read-only |
OCTET STRING |
HBA Option ROM or BIOS version. |
As per the MIB. |
hh3cFdmiHbaInfoFwVer (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.11) |
read-only |
OCTET STRING |
HBA firmware version number. |
As per the MIB. |
hh3cFdmiHbaInfoOSInfo (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.12) |
read-only |
OCTET STRING |
Operating system type and version number. |
As per the MIB. |
hh3cFdmiHbaInfoMaxCTPayload (1.3.6.1.4.1.25506.2.127.7.1.1.1.1.13) |
read-only |
Unsigned32 |
Unsigned32
Maximum length of CT payload allowed by the HBA. |
As per the MIB. |
hh3cFdmiHbaPortTable
About this table
This table obtains information about HBA ports registered with FDMI.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, hh3cFdmiHbaInfoFabricIndex, hh3cFdmiHbaInfoId, and hh3cFdmiHbaPortId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFdmiHbaPortId (1.3.6.1.4.1.25506.2.127.7.1.1.2.1.1) |
not-accessible |
OCTET STRING |
Port WWN. |
As per the MIB. |
hh3cFdmiHbaPortSupportedFC4Type (1.3.6.1.4.1.25506.2.127.7.1.1.2.1.2) |
read-only |
OCTET STRING |
OCTET STRING Size: 1..0 2..32 |
FC-4 types supported by the port. |
As per the MIB. |
hh3cFdmiHbaPortSupportedSpeed (1.3.6.1.4.1.25506.2.127.7.1.1.2.1.3) |
read-only |
Unsigned32 |
Unsigned32 |
Speeds supported by the port. |
As per the MIB. |
hh3cFdmiHbaPortCurrentSpeed (1.3.6.1.4.1.25506.2.127.7.1.1.2.1.4) |
read-only |
Unsigned32 |
Unsigned32 |
Current port speed. |
As per the MIB. |
hh3cFdmiHbaPortMaxFrameSize (1.3.6.1.4.1.25506.2.127.7.1.1.2.1.5) |
read-only |
Unsigned32 |
Unsigned32 |
Maximum frame size supported by the port. |
As per the MIB. |
hh3cFdmiHbaPortOsDevName (1.3.6.1.4.1.25506.2.127.7.1.1.2.1.6) |
read-only |
OCTET STRING |
Operating system name for the port. . |
As per the MIB. |
hh3cFdmiHbaPortHostName (1.3.6.1.4.1.25506.2.127.7.1.1.2.1.7) |
read-only |
OCTET STRING |
Name of the node where the port resides. |
As per the MIB. |
