- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
14-T11-FC-FABRIC-CONFIG-SERVER-MIB | 155.65 KB |
About this MIB
Use this MIB to implement the functions supported by RFC 4935. The t11FcsPlatformTable and t11FcsNodeNameListTable tables are not supported.
MIB file name
rfc4935-t11-fc-fabric-config-server.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).t11FcFabricConfigServerMIB(162)
Scalar objects
t11FcsMgmtAddrChangeFabricIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsMgmtAddrChangeFabricIndex (1.3.6.1.2.1.162.1.4.2) |
accessible-for-notify
T11FabricIndex |
Unsigned32 (0..4095) |
ID of the VSAN in which a management address change has been detected.. |
Not supported |
t11FcsMgmtAddrChangeIeName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsMgmtAddrChangeIeName (1.3.6.1.2.1.162.1.4.3) |
FcNameIdOrZero |
OCTET STRING (0 | 8 | 16) |
WWN of the IE for which a management address change has been detected. |
Not supported |
Tabular objects
t11FcsFabricDiscoveryTable
About this table
This table contains control information for discovery of Fabric configuration by switches.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Not supported |
Columns
The table indexes are fcmInstanceIndex and fcmSwitchIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsFabricDiscoveryRangeLow (1.3.6.1.2.1.162.1.1.1.1.1) |
read-write |
T11FabricIndex |
Start VSAN of the VSAN range for discovery. |
As per the MIB. |
t11FcsFabricDiscoveryRangeHigh (1.3.6.1.2.1.162.1.1.1.1.2) |
read-write |
T11FabricIndex |
End VSAN of the VSAN range for discovery. |
As per the MIB. |
t11FcsFabricDiscoveryStart (1.3.6.1.2.1.162.1.1.1.1.3) |
read-write |
INTEGER |
INTEGER |
Initiates a topology discovery. |
As per the MIB. |
t11FcsFabricDiscoveryTimeOut (1.3.6.1.2.1.162.1.1.1.1.4) |
read-write |
Unsigned32 |
Unsigned32 |
Minimum interval of time for which the discovered Fabric information is cached. |
As per the MIB. |
t11FcsDiscoveryStateTable
About this table
This table contains the status of discovery.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, and t11FcsFabricIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsFabricIndex (1.3.6.1.2.1.162.1.1.2.1.1) |
not-accessible |
T11FabricIndex |
VSAN index. |
As per the MIB. |
t11FcsDiscoveryStatus (1.3.6.1.2.1.162.1.1.2.1.2) |
read-write |
INTEGER |
1:inProgress(1) |
Status of the discovery. |
As per the MIB. |
t11FcsDiscoveryCompleteTime (1.3.6.1.2.1.162.1.1.2.1.3) |
read-only |
TimeTicks |
TimeTicks (0.. 4294967295) |
Time when discovery was most recently completed. |
As per the MIB. |
t11FcsIeTable
About this table
This table contains information about Interconnect Elements (IEs).
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsFabricIndex, and t11FcsIeName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsIeName (1.3.6.1.2.1.162.1.2.1.1.1) |
not-accessible |
OCTET STRING |
FcNameIdOrZero |
IE WWN. |
As per the MIB. |
t11FcsIeType (1.3.6.1.2.1.162.1.2.1.1.2) |
read-only |
INTEGER |
T11FcIeType |
IE type. |
As per the MIB. |
t11FcsIeDomainId (1.3.6.1.2.1.162.1.2.1.1.3) |
read-only |
Integer32 |
FcDomainIdOrZero |
IE domain ID. |
As per the MIB. |
t11FcsIeMgmtId (1.3.6.1.2.1.162.1.2.1.1.4) |
read-only |
OCTET STRING |
FcAddressIdOrZero |
Domain controller address of the IE. |
As per the MIB. |
t11FcsIeFabricName (1.3.6.1.2.1.162.1.2.1.1.5) |
read-only |
OCTET STRING |
FcNameIdOrZero |
Fabric name (WWN) of the IE. |
As per the MIB. |
t11FcsIeLogicalName (1.3.6.1.2.1.162.1.2.1.1.6) |
read-only |
OCTET STRING |
OCTET
STRING |
Logical name (WWN) of the IE. |
As per the MIB. |
t11FcsIeMgmtAddrListIndex (1.3.6.1.2.1.162.1.2.1.1.7) |
read-only |
Unsigned32 |
T11FcListIndexPointerOrZero |
Management address list index for the IE. |
As per the MIB. |
t11FcsIeInfoList (1.3.6.1.2.1.162.1.2.1.1.8) |
read-only |
OCTET STRING |
OCTET STRING |
Information list for the IE, including vendor name, model name/number, and release code/level, and vendor-specific information. |
As per the MIB. |
t11FcsMgmtAddrListTable
About this table
This table contains information about management address lists.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsMgmtAddrListIndex, and t11FcsMgmtAddrIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsMgmtAddrListIndex (1.3.6.1.2.1.162.1.2.2.1.1) |
not-accessible |
Unsigned32 |
T11FcListIndex |
Management address list index. |
As per the MIB. |
t11FcsMgmtAddrIndex (1.3.6.1.2.1.162.1.2.2.1.2) |
not-accessible |
Unsigned32 |
Unsigned32 |
Management address index. |
As per the MIB. |
t11FcsMgmtAddr (1.3.6.1.2.1.162.1.2.2.1.3) |
read-only |
OCTET STRING |
URLString |
Management address. |
As per the MIB. |
t11FcsPortTable
About this table
This table contains information about the ports of IEs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsIeName, and t11FcsPortName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsPortName (1.3.6.1.2.1.162.1.2.4.1.1) |
not-accessible |
OCTET STRING |
FcNameIdOrZero |
Port name (WWN) of the port. |
As per the MIB. |
t11FcsPortType (1.3.6.1.2.1.162.1.2.4.1.2) |
read-only |
Unsigned32 |
FcPortType |
Port type. |
As per the MIB. |
t11FcsPortTxType (1.3.6.1.2.1.162.1.2.4.1.3) |
read-only |
INTEGER |
T11FcPortTxType |
Port Tx Type. |
As per the MIB. |
t11FcsPortModuleType (1.3.6.1.2.1.162.1.2.4.1.4) |
read-only |
Unsigned32 |
Unsigned32 |
Port module type. |
As per the MIB. |
t11FcsPortPhyPortNum (1.3.6.1.2.1.162.1.2.4.1.5) |
read-only |
Unsigned32 |
Unsigned32 |
Physical port number. |
As per the MIB. |
t11FcsPortAttachPortNameIndex (1.3.6.1.2.1.162.1.2.4.1.6) |
read-only |
Unsigned32 |
Attached port name list. |
As per the MIB. |
t11FcsPortState (1.3.6.1.2.1.162.1.2.4.1.7) |
read-only |
INTEGER |
T11FcPortState |
Port status. |
As per the MIB. |
t11FcsPortSpeedCapab (1.3.6.1.2.1.162.1.2.4.1.8) |
read-only |
OCTET STRING |
OCTET STRING |
Port speed capabilities. |
As per the MIB. |
t11FcsPortOperSpeed (1.3.6.1.2.1.162.1.2.4.1.9) |
read-only |
OCTET STRING |
OCTET
STRING |
Operating port speed. |
As per the MIB. |
t11FcsPortZoningEnfStatus (1.3.6.1.2.1.162.1.2.4.1.10) |
read-only |
OCTET STRING |
OCTET STRING |
Zoning enforcement status. |
As per the MIB. |
t11FcsAttachPortNameListTable
About this table
This table contains all the lists of attached port names.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsAttachPortNameListIndex, and t11FcsAttachPortName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsAttachPortNameListIndex (1.3.6.1.2.1.162.1.2.5.1.1) |
not-accessible |
Unsigned32 |
T11FcListIndex |
Attached port name list index. |
As per the MIB. |
t11FcsAttachPortName (1.3.6.1.2.1.162.1.2.5.1.2) |
read-only |
OCTET STRING |
OCTET STRING |
Attached port name, inlcuding port WWN, port flag, and port type. |
As per the MIB. |
t11FcsPlatformTable
About this table
This table contains information on platforms.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsFabricIndex, and t11FcsPlatformIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsPlatformIndex (1.3.6.1.2.1.162.1.2.6.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 |
Platform index. |
As per the MIB. |
t11FcsPlatformName (1.3.6.1.2.1.162.1.2.6.1.2) |
read-only |
OCTET STRING |
OCTET STRING |
Platform name. |
As per the MIB. |
t11FcsPlatformType (1.3.6.1.2.1.162.1.2.6.1.3) |
read-only |
OCTET STRING |
OCTET STRING |
Platform type. |
As per the MIB. |
t11FcsPlatformNodeNameListIndex (1.3.6.1.2.1.162.1.2.6.1.4) |
read-only |
Unsigned32 |
List of nodes for this platform. |
As per the MIB. |
t11FcsPlatformMgmtAddrListIndex (1.3.6.1.2.1.162.1.2.6.1.5) |
read-only |
Unsigned32 |
List of management addresses for this platform. |
As per the MIB. |
t11FcsPlatformVendorId (1.3.6.1.2.1.162.1.2.6.1.6) |
read-only |
SnmpAdminString |
OCTET STRING (0 | 12) |
Vendor of this platform. |
As per the MIB. |
t11FcsPlatformProductId (1.3.6.1.2.1.162.1.2.6.1.7) |
read-only |
SnmpAdminString |
OCTET STRING (0 | 20) |
Vendor's product and/or model identifier for this platform. |
As per the MIB. |
t11FcsPlatformProductRevLevel (1.3.6.1.2.1.162.1.2.6.1.8) |
read-only |
SnmpAdminString |
OCTET STRING (0 | 4..32) |
Product revision level for this platform. |
As per the MIB. |
t11FcsPlatformDescription (1.3.6.1.2.1.162.1.2.6.1.9) |
read-only |
SnmpAdminString |
OCTET STRING (0 | 4..128) |
Description of this platform. |
As per the MIB. |
t11FcsPlatformLabel (1.3.6.1.2.1.162.1.2.6.1.10) |
read-only |
SnmpAdminString |
OCTET STRING (0 | 4..64) |
Administratively assigned symbolic name for the platform. |
As per the MIB. |
t11FcsPlatformLocation (1.3.6.1.2.1.162.1.2.6.1.11) |
read-only |
SnmpAdminString |
Physical location of the platform. |
As per the MIB. |
t11FcsPlatformSystemID (1.3.6.1.2.1.162.1.2.6.1.12) |
read-only |
SnmpAdminString |
ID of the hosting system that this platform is associated with. |
As per the MIB. |
t11FcsPlatformSysMgmtAddr (1.3.6.1.2.1.162.1.2.6.1.13) |
read-only |
Unsigned32 |
List of management addresses for the platform. |
As per the MIB. |
t11FcsPlatformClusterId (1.3.6.1.2.1.162.1.2.6.1.14) |
read-only |
SnmpAdminString |
ID of the cluster that this platform is associated with. |
As per the MIB. |
t11FcsPlatformClusterMgmtAddr (1.3.6.1.2.1.162.1.2.6.1.15) |
read-only |
Unsigned32 |
List of management addresses for the cluster. |
As per the MIB. |
t11FcsPlatformFC4Types (1.3.6.1.2.1.162.1.2.6.1.16) |
read-only |
OCTET STRING |
OCTET STRING |
FC-4 types supported by this platform. |
As per the MIB. |
About this table
This table contains all the lists of nodes.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, fcmSwitchIndex, t11FcsNodeNameListIndex, and t11FcsNodeName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsNodeNameListIndex (1.3.6.1.2.1.162.1.2.7.1.1) |
not-accessible |
T11FcListIndex |
Unsigned32 (1..4294967295) |
Node name list index. |
As per the MIB. |
t11FcsNodeName (1.3.6.1.2.1.162.1.2.7.1.2) |
read-only |
OCTET STRING |
FcNameIdOrZero |
Node name. |
As per the MIB. |
t11FcsStatsTable
About this table
This table contains all the statistics related to the Fabric Configuration Server (FCS).
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsInGetReqs (1.3.6.1.2.1.162.1.3.1.1.1) |
read-only |
Counter32 |
Counter32 |
Number of Get Requests received by the FCS. |
As per the MIB. |
t11FcsOutGetReqs (1.3.6.1.2.1.162.1.3.1.1.2) |
read-only |
Counter32 |
Counter32 |
Number of Get Requests sent by the FCS. |
As per the MIB. |
t11FcsInRegReqs (1.3.6.1.2.1.162.1.3.1.1.3) |
read-only |
Counter32 |
Counter32 |
Number of Registration Requests received by the FCS. |
When read, this object always returns 0. |
t11FcsOutRegReqs (1.3.6.1.2.1.162.1.3.1.1.4) |
read-only |
Counter32 |
Counter32 |
Number of Registration Requests sent by the FCS. |
t11FcsInDeregReqs (1.3.6.1.2.1.162.1.3.1.1.5) |
read-only |
Counter32 |
Counter32 |
Number of Deregistration Requests received by the FCS. |
t11FcsOutDeregReqs (1.3.6.1.2.1.162.1.3.1.1.6) |
read-only |
Counter32 |
Counter32 |
Number of Deregistration Requests sent by the FCS. |
t11FcsRejects (1.3.6.1.2.1.162.1.3.1.1.7) |
read-only |
Counter32 |
Counter32 |
Total number of requests rejected by the FCS. |
As per the MIB. |
t11FcsNotifyControlTable
About this table
This table contains control information for notifications generated due to FCS events.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11FcsReqRejectNotifyEnable (1.3.6.1.2.1.162.1.4.1.1.1) |
read-write |
INTEGER |
TruthValue true(1) false(2) |
Specifies if the FCS should generate t11FcsReqRejectNotifyEnable notifications. |
As per the MIB. |
t11FcsDiscoveryCompNotifyEnable (1.3.6.1.2.1.162.1.4.1.1.2) |
read-write |
INTEGER |
Specifies if the FCS should generate t11FcsDiscoveryCompNotifyEnable notifications. |
As per the MIB. |
t11FcsMgmtAddrChangeNotifyEnable (1.3.6.1.2.1.162.1.4.1.1.3) |
read-write |
INTEGER |
Specifies if the FCS should generate t11FcsMgmtAddrChangeNotifyEnable notifications. |
As per the MIB. |
t11FcsRejectCtCommandString (1.3.6.1.2.1.162.1.4.1.1.4) |
read-only |
OCTET STRING |
OCTET STRING (SIZE (0..255)) |
Binary content of the FCS request. |
As per the MIB. |
t11FcsRejectRequestSource (1.3.6.1.2.1.162.1.4.1.1.5) |
read-only |
OCTET STRING |
FcNameIdOrZero |
WWN that was the source of the CT_IU contained in the corresponding instance of t11FcsRejectCtCommandString. |
As per the MIB. |
t11FcsRejectReasonCode (1.3.6.1.2.1.162.1.4.1.1.6) |
read-only |
T11NsGs4RejectReasonCode |
none(1), invalidCmdCode(2), invalidVerLevel(3), logicalError(4), invalidIUSize(5), logicalBusy(6), protocolError(7), unableToPerformCmdReq(8), cmdNotSupported(9), serverNotAvailable(10), couldNotEstabSession(11), vendorError(12) |
Reason code corresponding to the latest FCS request rejected by the local system. |
As per the MIB. |
t11FcsRejectReasonCodeExp (1.3.6.1.2.1.162.1.4.1.1.7) |
read-only |
T11FcsRejectReasonExplanation |
noAdditionalExplanation(1), invNameIdForIEOrPort(2), ieListNotAvailable(3), ieTypeNotAvailable(4), domainIdNotAvailable(5), mgmtIdNotAvailable(6), fabNameNotAvailable(7), ielogNameNotAvailable(8), mgmtAddrListNotAvailable(9), ieInfoListNotAvailable(10), portListNotAvailable(11), portTypeNotAvailable(12), phyPortNumNotAvailable(13), attPortNameListNotAvailable(14), portStateNotAvailable(15), unableToRegIELogName(16), platformNameNoExist(17), platformNameAlreadyExists(18), platformNodeNameNoExists(19), platformNodeNameAlreadyExists(20), resourceUnavailable(21), noEntriesInLunMap(22), invalidDeviceNameLength(23), multipleAttributes(24), invalidAttribBlockLength(25), attributesMissing(26) |
Corresponding reason code explanation when the corresponding instance of t11FcsRejectReasonCode has the value: 'unable to perform command request'. |
As per the MIB. |
t11FcsRejectReasonVendorCode (1.3.6.1.2.1.162.1.4.1.1.8) |
read-only |
OCTET STRING |
OCTET STRING (SIZE(1)) |
Registration reject vendor-specific code. |
As per the MIB. |
Notifications
This document provides information about the SNMP notifications for T11-FC-FABRIC-CONFIG-SERVER-MIB. It also provides recommended actions to help you remove the error conditions reported through SNMP notifications.
t11FcsRqRejectNotification
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.162.0.1 |
FCS request rejected |
Error |
Major |
N/A |
OFF |
This notification is generated whenever the FCS on a switch (indicated by the value of t11FamLocalSwitchWwn) rejects an FCS request.
The FCS should update the t11FcsRejectReasonCode, t11FcsRejectReasonCodeExp and t11FcsRejectReasonVendorCode objects with the corresponding reason code, explanation and vendor specific code before sending the notification.
Status control
ON
MIB: Set t11FcsReqRejectNotifyEnable to true(1).
OFF
MIB: Set t11FcsReqRejectNotifyEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.137.1.1.1.1.8 (t11FamLocalSwitchWwn) |
Local switch WWN. |
No |
FcNameIdOrZero |
OCTET STRING (SIZE (0 | 8 | 16)) |
1.3.6.1.2.1.162.1.4.1.1.6 (t11FcsRejectReasonCode) |
No |
none(1) invalidCmdCode(2) invalidVerLevel(3) logicalError(4) invalidIUSize(5) logicalBusy(6) protocolError(7) unableToPerformCmdReq(8) cmdNotSupported(9) serverNotAvailable(10) couldNotEstabSession(11) vendorError(12) |
1.3.6.1.2.1.162.1.4.1.1.7 (t11FcsRejectReasonCodeExp) |
No |
noAdditionalExplanation(1) invNameIdForIEOrPort(2) ieListNotAvailable(3) ieTypeNotAvailable(4) domainIdNotAvailable(5) mgmtIdNotAvailable(6) fabNameNotAvailable(7) ielogNameNotAvailable(8) mgmtAddrListNotAvailable(9) ieInfoListNotAvailable(10) portListNotAvailable(11) portTypeNotAvailable(12) phyPortNumNotAvailable(13) attPortNameListNotAvailable(14) portStateNotAvailable(15) unableToRegIELogName(16) platformNameNoExist(17) platformNameAlreadyExists(18) platformNodeNameNoExists(19) platformNodeNameAlreadyExists(20) resourceUnavailable(21) noEntriesInLunMap(22) invalidDeviceNameLength(23) multipleAttributes(24) invalidAttribBlockLength(25) attributesMissing(26) |
1.3.6.1.2.1.162.1.4.1.1.8(t11FcsRejectReasonVendorCode) |
No |
OCTET STRING |
SIZE(1) |
Recommended action
To resolve the issue:
1. Verify that the FCS configuration is correct.
2. If the issue persists, contact H3C Support.
t11FcsDiscoveryCompleteNotify
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.162.0.2 |
Discovery completed in VSANs |
Informational |
N/A |
N/A |
OFF |
This notification is generated by the FCS on the completion of the discovery of Fabrics in the range that has t11FcsFabricDiscoveryRangeLow at its low end.
Status control
ON
MIB: Set t11FcsDiscoveryCompNotifyEnable to true(1).
OFF
MIB: Set t11FcsDiscoveryCompNotifyEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.162.1.1.1.1.1 (t11FcsFabricDiscoveryRangeLow) |
Start VSAN ID of the VSAN range. |
Yes |
T11FabricIndex |
Unsigned32(0..4095) |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.162.0.3 |
Management address change |
Informational |
N/A |
N/A |
OFF |
This notification is generated by the FCS whenever the management address of an IE changes, i.e., whenever an entry in the t11FcsMgmtAddrListTable changes.
Status control
ON
MIB: Set t11FcsMgmtAddrChangeNotifyEnable to true(1).
OFF
MIB: Set t11FcsMgmtAddrChangeNotifyEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.162.1.4.2 (t11FcsMgmtAddrChangeFabricIndex) |
VSAN ID. |
Yes |
T11FabricIndex |
1.3.6.1.2.1.162.1.4.3 (t11FcsMgmtAddrChangeIeName) |
Local switch WWN. |
No |
FcNameIdOrZero |
Recommended action
