- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
02-HH3C-FC-FLOGIN-MIB | 75.33 KB |
HH3C-FC-FLOGIN-MIB
About this MIB
Use this MIB to obtain Fabric Login information
MIB file name
hh3c-fc-flogin.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cFcFLogin(3)
Scalar objects
hh3cFcFLoginVsanID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcFLoginVsanID (1.3.6.1.4.1.25506.2.127.3.1.2.1) |
accessible-for-notify |
Integer32 |
Integer32 (1..3839) |
VSAN ID value. |
As per the MIB. |
hh3cFcFLoginMaxNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcFLoginMaxNum (1.3.6.1.4.1.25506.2.127.3.1.2.2) |
Integer32 |
Integer32 (1..65535) |
Maximum number of logged-in nodes allowed in the VSAN. |
As per the MIB. |
hh3cFcFLoginMaxTrapCntl
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcFLoginMaxTrapCntl (1.3.6.1.4.1.25506.2.127.3.1.3.1) |
read-write |
TruthValue |
Integer32 (1,2) |
Specifies whether a notification is sent when the maximum number of logged-in nodes allowed in the VSAN is exceeded. |
As per the MIB. |
Tabular objects
hh3cFcFLoginTable
About this table
This table obtains the information held by FC switches about the Nx_Ports that are attached to their Fx_Ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ifIndex, hh3cVsanIndex, and hh3cFcFLoginIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcFLoginIndex (1.3.6.1.4.1.25506.2.127.3.1.1.1.1) |
not-accessible |
Hh3cFcAddressId |
OCTET STRING (0..255) |
Fabric Login index. |
As per the MIB. |
hh3cFcFLoginPortNodeWWN (1.3.6.1.4.1.25506.2.127.3.1.1.1.2) |
read-only |
Hh3cFcNameId |
OCTET STRING (0 | 8) |
Node WWN for an Nx_Port. |
As per the MIB. |
hh3cFcFLoginPortWWN (1.3.6.1.4.1.25506.2.127.3.1.1.1.3) |
read-only |
Hh3cFcNameId |
Nx_Port WWN. |
As per the MIB. |
hh3cFcFLoginPortFcId (1.3.6.1.4.1.25506.2.127.3.1.1.1.4) |
read-only |
Hh3cFcAddressId |
FC ID assigned to the Nx_Port. |
As per the MIB. |
hh3cFcFLoginRxBbCredit (1.3.6.1.4.1.25506.2.127.3.1.1.1.5) |
read-only |
Hh3cFcBbCredit |
Integer32(0..32767) |
Number of buffers available for holding frames to be received from the Nx_Port. |
As per the MIB. |
hh3cFcFLoginTxBbCredit (1.3.6.1.4.1.25506.2.127.3.1.1.1.6) |
read-only |
Hh3cFcBbCredit |
Number of buffers available for holding frames to be transmitted to the Nx_Port. |
As per the MIB. |
hh3cFcFLoginClass2RxMTU (1.3.6.1.4.1.25506.2.127.3.1.1.1.7) |
read-only |
Hh3cFcRxMTU |
Integer32(128..2112) |
MTU value for Class 2 frames to the Nx_Port. |
As per the MIB. |
hh3cFcFLoginClass3RxMTU (1.3.6.1.4.1.25506.2.127.3.1.1.1.8) |
read-only |
Hh3cFcRxMTU |
MTU value for Class 3 frames to the Nx_Port. |
As per the MIB. |
hh3cFcFLoginSuppClassRequested (1.3.6.1.4.1.25506.2.127.3.1.1.1.9) |
read-only |
Hh3cFcClassOfServices |
BITS{ classF(0), class1(1), class2(2), class3(3), class4(4), class5(5), class6(6) } |
Classes of Service that the Nx_Port requests from the Fx_Port. |
As per the MIB. |
hh3cFcFLoginClass2ReqAgreed (1.3.6.1.4.1.25506.2.127.3.1.1.1.10) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the Fx_Port supports Class 2. |
As per the MIB. |
hh3cFcFLoginClass3ReqAgreed (1.3.6.1.4.1.25506.2.127.3.1.1.1.11) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the Fx_Port supports Class 3. |
As per the MIB. |
Notifications
hh3cFcFLoginMaxNotify
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
(1.3.6.1.4.1.25506.2.127.3.1.4.0.1) |
Alarm generated when the maximum number of logged-in nodes allowed in the current VSAN is exceeded. |
Informational |
OFF |
This notification is generated when the maximum number of logged-in nodes allowed in the current VSAN is exceeded.
Status control
ON
· CLI: snmp-agent trap enable fc-link login-max
· MIB: Set hh3cCfgOperateEndNotificationSwitch to true(1).
OFF
· CLI: undo snmp-agent trap enable fc-link login-max
· MIB: Set hh3cCfgOperateEndNotificationSwitch to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
VSAN ID value. |
No |
Integer32 |
No |
Integer32 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
