- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
06-HH3C-FC-PING-MIB | 70.36 KB |
HH3C-FC-PING-MIB
About this MIB
Use this MIB to configure an FC ping operation.
MIB file name
hh3c-fc-ping.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cFcPing(5).hh3cFcPingObjects(1).hh3cFcPingConfigurations(1).hh3cFcPingTable(1).hh3cFcPingEntry(1)
Tabular objects
hh3cFcPingTable
About this table
This table initiates an FC ping operation.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Not supported |
Columns
The table index is hh3cFcPingIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPingIndex (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.1) |
accessible-for-notify |
Unsigned32 |
Unsigned32(1..65535) |
FC ping entry index. |
As per the MIB. |
hh3cFcPingVsan (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.2) |
read-create |
Hh3cFcVsanIndex |
Unsigned32(1..4095) |
VSAN for the FC ping operation. |
The value range is 1 to 3839. |
hh3cFcPingAddressType (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.3) |
read-create |
Hh3cFcAddressType |
wwn(1), fcid(2) |
FC ping destination type. |
Supports only fcid(2). |
hh3cFcPingAddress (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.4) |
read-create |
Hh3cFcAddress |
OCTET STRING (3|8) |
FC ping destination address. |
As per the MIB. |
hh3cFcPingPacketCount (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.5) |
read-create |
Unsigned32 |
Unsigned32(1..2147483647) |
Number of echo requests to be sent. |
As per the MIB. |
hh3cFcPingPayLoadSize (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.6) |
read-only |
Unsigned32 |
Standard MIB values. |
Payload size of echo requests. |
As per the MIB. |
hh3cFcPingTimeout (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.7) |
read-create |
Unsigned32 |
Unsigned32(1..10) |
Timeout time for the FC ping operation. |
As per the MIB. |
hh3cFcPingDelay (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.8) |
read-only |
Unsigned32 |
Timeout time for a single echo request. |
As per the MIB. |
hh3cFcPingAgeInterval (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.9) |
read-create |
Unsigned32 |
Unsigned32(500..900) |
Aging time for the FC ping entry. |
As per the MIB. |
hh3cFcPingAdminStatus (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.10) |
read-create |
Hh3cFcStarOper |
enable (1), disable (2) |
Administrative status for the FC ping entry. |
As per the MIB. |
hh3cFcPingOperStatus (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.11) |
read-only |
INTEGER |
inProgress (1), complete (2), disabled(3), failed(4) |
Operational status for the FC ping entry. |
As per the MIB. |
hh3cFcPingTrapOnCompletio n (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.12) |
read-create |
TruthValue |
true (1), false (2) |
Indicates whether to generate traps upon the completion of the FC ping operation. |
As per the MIB. |
hh3cFcPingRowStatus (1.3.6.1.4.1.25506.2.127.5.1.1.1.1.13) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
hh3cFcPingStatTable
About this table
This table obtains FC ping statistics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cFcPingReqPackets (1.3.6.1.4.1.25506.2.127.5.1.2.1.1.1) |
read-only |
Unsigned32 |
Number of echo requests. |
As per the MIB. |
hh3cFcPingResPackets (1.3.6.1.4.1.25506.2.127.5.1.2.1.1.2) |
read-only |
Unsigned32 |
Number of echo replies. |
As per the MIB. |
hh3cFcPingMinTime (1.3.6.1.4.1.25506.2.127.5.1.2.1.1.3) |
read-only |
Integer32 |
Minimum RTT. |
As per the MIB. |
hh3cFcPingAverageTime (1.3.6.1.4.1.25506.2.127.5.1.2.1.1.4) |
read-only |
Integer32 |
Average RTT. |
As per the MIB. |
hh3cFcPingMaxTime (1.3.6.1.4.1.25506.2.127.5.1.2.1.1.5) |
read-only |
Integer32 |
Maximum RTT. |
As per the MIB. |
hh3cFcPingTimeoutNum (1.3.6.1.4.1.25506.2.127.5.1.2.1.1.6) |
read-only |
Unsigned32 |
Number of echo replies received after time out time expires. |
As per the MIB. |
Notifications
hh3cFcPingCompletionNotify
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.127.5.1.3.0.1 |
FC ping operation completed |
Informational |
N/A |
N/A |
OFF |
An FC ping operation is completed.
Status control
ON
MIB: Set hh3cFcPingTrapOnCompletion to true(1).
OFF
MIB: Set hh3cFcPingTrapOnCompletion to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.127.5.1.1.1.1.1 (hh3cFcPingIndex) |
Yes |
Unsigned32 |
Unsigned32 (1..65535) |
1.3.6.1.4.1.25506.2.127.5.1.1.1.1.2 (hh3cFcPingVsan) |
VSAN ID. |
No |
Hh3cFcVsanIndex |
1.3.6.1.4.1.25506.2.127.5.1.1.1.1.3 (hh3cFcPingAddressType) |
Ping packet address type. |
No |
Hh3cFcAddressType |
WWN(1), FCID(2) |
1.3.6.1.4.1.25506.2.127.5.1.1.1.1.4 (hh3cFcPingAddress) |
Ping packet address. |
No |
Hh3cFcAddress |
OCTET STRING (3) |
1.3.6.1.4.1.25506.2.127.5.1.2.1.1.1 (hh3cFcPingReqPackets) |
Ping request length. |
No |
Unsigned32 |
1.3.6.1.4.1.25506.2.127.5.1.2.1.1.2 (hh3cFcPingResPackets) |
Ping reply length. |
No |
Unsigned32 |
Recommended action
No action is required.
