- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
15-T11-FC-NAME-SERVER-MIB | 105.72 KB |
About this MIB
Use this MIB to implement the functions supported by RFC 4438. A switch does not support this MIB when it is operating is NPV mode.
MIB file name
rfc4438-t11-fc-name-server.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).t11FcNameServerMIB(135)
Tabular objects
t11NsInfoSubsetTable
About this table
This table contains one entry for each Name Server Information Subset within each Fibre Channel management instance.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Not supported |
Columns
The table indexes are fcmInstanceIndex and t11NsInfoSubsetIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11NsInfoSubsetIndex (1.3.6.1.2.1.135.1.1.1.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 |
An arbitrary integer value that uniquely identifies this Name Server Information Subset. |
As per the MIB. |
t11NsInfoSubsetSwitchIndex (1.3.6.1.2.1.135.1.1.1.1.2) |
read-only |
Unsigned32 |
Unsigned32 |
Switch index. |
As per the MIB. |
t11NsInfoSubsetTableLastChange (1.3.6.1.2.1.135.1.1.1.1.3) |
read-only |
TimeStamp |
Timeticks (0.. 4294967295) |
Last entry update time. |
As per the MIB. |
t11NsInfoSubsetNumRows (1.3.6.1.2.1.135.1.1.1.1.4) |
read-only |
Integer32 |
Integer32 |
Number of Nx_Ports currently registered in this Name Server Information Subset. |
As per the MIB. |
t11NsInfoSubsetTotalRejects (1.3.6.1.2.1.135.1.1.1.1.5) |
read-only |
Counter32 |
Counter32 |
Total number of (CT_IU) Requests for Name Server functions that were rejected for inclusion in this Name Server Information Subset. |
As per the MIB. |
t11NsInfoSubsetRejReqNotfyEnable (1.3.6.1.2.1.135.1.1.1.1.6) |
read-write |
TruthValue |
true(1), |
Indicates notifications are generated by rejections of requests to register information in this Name Server Information Subset. |
As per the MIB. |
t11NsRegTable
About this table
This table contains entries for all Nx_Ports registered in the identified Name Server Information Subsets across all Fabrics for which such subsets contain information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, t11NsInfoSubsetIndex, t11NsRegFabricIndex, and t11NsRegPortIdentifier.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11NsRegFabricIndex (1.3.6.1.2.1.135.1.1.2.1.1) |
not-accessible |
T11FabricIndex |
Unsigned32 (0..4095) |
VSAN ID. |
As per the MIB. |
t11NsRegPortIdentifier (1.3.6.1.2.1.135.1.1.2.1.2) |
not-accessible |
FcAddressIdOrZero |
OCTET STRING (0 | 3) |
FC ID of the Nx_Port. |
As per the MIB. |
t11NsRegPortName (1.3.6.1.2.1.135.1.1.2.1.3) |
read-only |
FcNameIdOrZero |
OCTET STRING (0 | 8 | 16) |
Port WWN of the Nx_Port. |
As per the MIB. |
t11NsRegNodeName (1.3.6.1.2.1.135.1.1.2.1.4) |
read-only |
FcNameIdOrZero |
Node WWN of the Nx_Port. |
As per the MIB. |
t11NsRegClassOfSvc (1.3.6.1.2.1.135.1.1.2.1.5) |
read-only |
FcClasses |
BITS { classF(0), class1(1), class2(2), class3(3), class4(4), class5(5), class6(6) } |
Class of service indicator. |
As per the MIB. |
t11NsRegNodeIpAddress (1.3.6.1.2.1.135.1.1.2.1.6) |
read-only |
OCTET STRING |
OCTET STRING (0 | 16) |
IP address of the node of the Nx_Port. |
As per the MIB. |
t11NsRegProcAssoc (1.3.6.1.2.1.135.1.1.2.1.7) |
read-only |
OCTET STRING |
OCTET STRING (0 | 8) |
Fibre Channel Initial Process Associator. |
As per the MIB. Obsoleted in the FC-GS-6(09-153v1). |
t11NsRegFc4Type (1.3.6.1.2.1.135.1.1.2.1.8) |
read-only |
OCTET STRING |
OCTET STRING (0 | 32) |
FC-4 protocol types supported by the Nx_Port. |
As per the MIB. |
t11NsRegPortType (1.3.6.1.2.1.135.1.1.2.1.9) |
read-only |
FcPortType |
Unsigned32 |
Port type. |
As per the MIB. |
t11NsRegPortIpAddress (1.3.6.1.2.1.135.1.1.2.1.10) |
read-only |
OCTET STRING |
IP address of the associated port. |
t11NsRegFabricPortName (1.3.6.1.2.1.135.1.1.2.1.11) |
read-only |
FcNameIdOrZero |
Fabric Port Name (WWN) of the Fx_Port to which the Nx_Port is attached. |
As per the MIB. |
t11NsRegHardAddress (1.3.6.1.2.1.135.1.1.2.1.12) |
read-only |
FcAddressIdOrZero |
Hardware address. |
As per the MIB. |
t11NsRegSymbolicPortName (1.3.6.1.2.1.135.1.1.2.1.13) |
read-only |
SnmpAdminString |
OCTET STRING |
User-defined name of the port. |
As per the MIB. |
t11NsRegSymbolicNodeName (1.3.6.1.2.1.135.1.1.2.1.14) |
read-only |
SnmpAdminString |
OCTET STRING |
User-defined name of the node of this port. |
As per the MIB. |
t11NsRegFc4Features (1.3.6.1.2.1.135.1.1.2.1.15) |
read-only |
OCTET STRING |
OCTET STRING (0 | 128) |
FC-4 Features associated with FC-4 Types on this port. |
As per the MIB. |
t11NsRejectTable
About this table
This table contains information about the most recent Name Server Registration Request failures for various ports on various Fabrics.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11NsRejectCtCommandString (1.3.6.1.2.1.135.1.1.4.1.1) |
read-only |
OCTET STRING |
OCTET STRING |
Binary content of the Registration Request. |
As per the MIB. |
t11NsRejectReasonCode (1.3.6.1.2.1.135.1.1.4.1.2) |
read-only |
T11NsGs4RejectReasonCode |
none(1), |
Registration reject reason code. |
As per the MIB. |
t11NsRejReasonCodeExp (1.3.6.1.2.1.135.1.1.4.1.3) |
read-only |
T11NsRejReasonCodeExpl |
noAdditionalExplanation(1), |
Registration reject reason code explanation. |
As per the MIB. |
t11NsRejReasonVendorCode (1.3.6.1.2.1.135.1.1.4.1.4) |
read-only |
OCTET STRING |
OCTET STRING |
Registration reject vendor-specific code. |
As per the MIB. |
t11NsStatsTable
About this table
This table contains per-Fabric state and statistics for operations upon the identified Name Server Information Subsets.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are fcmInstanceIndex, t11NsInfoSubsetIndex, and t11NsRegFabricIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
t11NsInGetReqs (1.3.6.1.2.1.135.1.2.1.1.1) |
read-only |
Counter32 |
Counter32 |
Total number of (CT_IU) Get Requests received requesting information from this Name Server Information Subset on this Fabric. |
As per the MIB. |
t11NsOutGetReqs (1.3.6.1.2.1.135.1.2.1.1.2) |
read-only |
Counter32 |
Counter32 |
Total number of (CT_IU) Get Requests sent in order to obtain information needed in this Name Server Information Subset on this Fabric. |
As per the MIB. |
t11NsInRegReqs (1.3.6.1.2.1.135.1.2.1.1.3) |
read-only |
Counter32 |
Counter32 |
Total number of (CT_IU) Registration Requests received to register information in the Name Server Information Subset on this Fabric. |
As per the MIB. |
t11NsInDeRegReqs (1.3.6.1.2.1.135.1.2.1.1.4) |
read-only |
Counter32 |
Counter32 |
Total number of (CT_IU) De-registration Requests received to de-register information from this Name Server Information Subset on this Fabric. |
As per the MIB. |
t11NsInRscns (1.3.6.1.2.1.135.1.2.1.1.5) |
read-only |
Counter32 |
Counter32 |
Total number of received RSCNs, indicating Name Server-related changes relating to this Name Server Information Subset on this Fabric. |
As per the MIB. |
t11NsOutRscns (1.3.6.1.2.1.135.1.2.1.1.6) |
read-only |
Counter32 |
Counter32 |
Total number of transmitted RSCNs, indicating Name Server-related changes relating to this Name Server Information Subset on this Fabric. |
As per the MIB. |
t11NsRejects (1.3.6.1.2.1.135.1.2.1.1.7) |
read-only |
Counter32 |
Counter32 |
Total number of CT_IU Requests for Name Server functions on this Name Server Information Subset on this Fabric that were rejected. |
As per the MIB. |
t11NsDatabaseFull (1.3.6.1.2.1.135.1.2.1.1.8) |
read-only |
TruthValue |
true(1) |
Indicates whether the database containing this Name Server Information Subset is full. |
As per the MIB. |
