- 19-FC and FCoE
- 01-FC-MGMT-MIB
- 02-HH3C-FC-FLOGIN-MIB
- 03-HH3C-FC-NAME-SERVER-MIB
- 04-HH3C-FCOE-MIB
- 05-HH3C-FCOE-MODE-MIB
- 06-HH3C-FC-PING-MIB
- 07-HH3C-FC-PSM-MIB
- 08-HH3C-FC-TRACE-ROUTE-MIB
- 09-HH3C-FC-ZONE-SERVER-MIB
- 10-HH3C-FDMI-MIB
- 11-HH3C-NPV-MIB
- 12-HH3C-SAN-AGG-MIB
- 13-HH3C-VSAN-MIB
- 14-T11-FC-FABRIC-CONFIG-SERVER-MIB
- 15-T11-FC-NAME-SERVER-MIB
- 16-T11-FC-ROUTE-MIB
- 17-T11-FC-VIRTUAL-FABRIC-MIB
- 18-T11-FC-ZONE-SERVER-MIB
13-HH3C-VSAN-MIB | 117.48 KB |
hh3cVsanDmFabricChangeNotifyEnable
hh3cVsanDmDomainIdChangeNotifyEnable
hh3cVsanDmDomainIdNotAssignedNotify
hh3cVsanDmNewPrincipalSwitchNotify
HH3C-VSAN-MIB
About this MIB
Use this MIB to configure or obtain VSAN settings.
MIB file name
hh3c-vsan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSan(127).hh3cVsan(1)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmFabricChangeNotifyEnable (1.3.6.1.4.1.25506.2.127.1.1.3.1.1) |
read-write |
TruthValue |
TruthValue |
Trap switch for hh3cVsanDmFabricChangeNotify |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmDomainIdChangeNotifyEnable (1.3.6.1.4.1.25506.2.127.1.1.3.1.2) |
read-write |
TruthValue |
TruthValue |
Trap switch for hh3cVsanDmDomainIdChangeNotify |
As per the MIB. |
Tabular objects
hh3cVsanTable
About this table
This table creates or deletes a VSAN, and obtains the physical switch name.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is hh3cVsanIndex.
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.1.1
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanIndex (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.1) |
accessible-for-notify |
Unsigned32 |
Unsigned32 |
VSAN ID |
The value range is 2 to 3839 for creating, configuring, or deleting a VSAN. VSAN 1 is the default VSAN, and VSAN 4079 is the control VSAN. |
hh3cVsanCoreSwitchName (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.2) |
read-only |
Hh3cFcNameIdOrZero |
OCTET STRING (8 | 16) |
Physical switch name. |
As per the MIB. |
hh3cVsanRowStatus (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.3) |
read-create |
INTEGER |
1:active(1) |
Row status. |
VSANs 2 to 3839 support the following values: · active(1). · createAndGo(4). · destroy(6). VSAN 1 and VSAN 4079 support only active(1). |
hh3cVsanName (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.4) |
read-create |
OCTET STRING |
OCTET STRING |
VSAN name. |
As per the MIB. |
hh3cVsanWorkingMode (1.3.6.1.4.1.25506.2.127.1.1.1.1.1.5) |
read-write |
Integer32 |
Integer32 |
Operating mode of the VSAN. |
As per the MIB. |
hh3cVsanDmTable
About this table
This table configures or obtains domain information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
OID of this table is: 1.3.6.1.4.1.25506.2.127.1.1.1.2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmDomainConfigureEnable (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.1) |
read-write |
TruthValue |
true(1), |
Fabric configuration status. |
As per the MIB. |
hh3cVsanDmFabricNameConfigured (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.2) |
read-write |
OCTET STRING (0 | 8 | 16) |
Configured fabric name. |
As per the MIB. |
hh3cVsanDmPriorityConfigured (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.3) |
read-write |
Unsigned32 |
noOperation(1) |
Configured switch priority. |
As per the MIB. |
hh3cVsanDmAllowedDomainIdList (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.4) |
read-write |
OCTET STRING |
disabledWithNoDomain(1), |
Allowed domain ID list. |
As per the MIB. |
hh3cVsanDmDomainIdConfigured (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.5) |
read-write |
Hh3cFcDomainIdOrZero |
Integer32 |
Configured domain ID. |
As per the MIB. |
hh3cVsanDmDomainIdTypeConfigured (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.6) |
read-write |
INTEGER |
static(1), |
Configured domain ID type. |
As per the MIB. |
hh3cVsanDmAutoReconfigureEnable (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.7) |
read-write |
TruthValue |
true(1), |
Automatic reconfiguration status. |
As per the MIB. |
hh3cVsanDmDomainRestart (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.8) |
read-write |
INTEGER |
noOperation(1), |
Fabric reconfiguration type. |
As per the MIB. |
hh3cVsanDmState (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.9) |
read-only |
Hh3cFcDmState |
Domain status. |
As per the MIB. |
hh3cVsanDmDomainIdAssigned (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.10) |
read-only |
Integer32 (0..239) |
Assigned domain ID. |
As per the MIB. |
hh3cVsanDmPrincipalSwitchWWN (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.11) |
read-only |
Hh3cFcNameId |
OCTET STRING (8) |
Principal switch WWN. |
As per the MIB. |
hh3cVsanDmLocalSwitchWWN (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.12) |
read-only |
Hh3cFcNameId |
OCTET STRING (8) |
Local switch WWN. |
As per the MIB. |
hh3cVsanDmPrincipalSwRunPriority (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.13) |
read-only |
Hh3cFcDomainPriority |
Unsigned32 (1..254) |
Principal switch runtime priority. |
As per the MIB. |
hh3cVsanDmLocalSwRunPriority (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.14) |
read-only |
Local switch runtime priority. |
As per the MIB. |
hh3cVsanDmPrincipalSwSlctCnt (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.15) |
read-only |
Counter32 |
Standard MIB values. |
Number of times the local switch participates in principal switch election is a VSAN. |
As per the MIB. |
hh3cVsanDmLocalPrincipalSwSlctCnt(1.3.6.1.4.1.25506.2.127.1.1.1.2.1.16) |
read-only |
Counter32 |
Number of times the local switch becomes the principal switch. |
As per the MIB. |
hh3cVsanDmBFCnt (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.17) |
read-only |
Counter32 |
Number of times the local switch participates in nondisruptive reconfiguration. |
As per the MIB. |
hh3cVsanDmRCFCnt (1.3.6.1.4.1.25506.2.127.1.1.1.2.1.18) |
read-only |
Counter32 |
Number of times the local switch participates in disruptive reconfiguration. |
As per the MIB. |
hh3cVsanDmIfConfigTable
About this table
This table configures domain information for an interface in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Not supported |
Columns
The table indexes are ifIndex and hh3cVsanIndex.
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.1.3
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmIfConfigRcfReject (1.3.6.1.4.1.25506.2.127.1.1.1.3.1.1) |
read-write |
TruthValue |
true(1), |
Indicates whether the interface rejects incoming RCF requests. |
As per the MIB. |
hh3cVsanDmDatabaseTable
About this table
This table obtains the physical switch name for a domain ID in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cVsanIndex and hh3cVsanDmDatabaseDomainId.
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.2.1
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmDatabaseDomainId (1.3.6.1.4.1.25506.2.127.1.1.2.1.1.1) |
not-accessible |
Integer32 |
Integer32 |
Domain ID. |
As per the MIB. |
hh3cVsanDmDatabaseSwitchWWN (1.3.6.1.4.1.25506.2.127.1.1.2.1.1.2) |
read-only |
OCTET STRING |
octet string |
As per the MIB. |
hh3cVsanDmIfInfoTable
About this table
This table obtains interface status in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.2.2
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanDmIfInfoRole (1.3.6.1.4.1.25506.2.127.1.1.2.2.1.1) |
read-only |
INTEGER |
nonPrincipal(1) |
Status of an interface in a VSAN. |
As per the MIB. |
hh3cVsanFcIdTable
About this table
This table configures or obtains the persistent FC ID feature information in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.1.4
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanFreeFcIds(1.3.6.1.4.1.25506.2.127.1.1.1.4.1.1) |
read-only |
Counter32 |
Counter32 |
Free FC IDs. |
As per the MIB. |
hh3cVsanAssignedFcIds(1.3.6.1.4.1.25506.2.127.1.1.1.4.1.2) |
read-only |
Counter32 |
Counter32 |
Assigned FC IDs. |
As per the MIB. |
hh3cVsanFcIdPersistency(1.3.6.1.4.1.25506.2.127.1.1.1.4.1.3) |
read-write |
INTEGER |
TruthValue |
Persistent FC ID feature. |
As per the MIB. |
hh3cVsanFcIdPurge(1.3.6.1.4.1.25506.2.127.1.1.1.4.1.4) |
read-write |
INTEGER |
noOp(1) |
FC ID purging. |
As per the MIB. |
hh3cVsanFcIdPersistencyTable
About this table
This table manages the persistent FC ID database in a VSAN.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cVsanIndex and hh3cVsanFcIdPersistencyWwn.
OID of this table is:1.3.6.1.4.1.25506.2.127.1.1.1.5
Note: When creating a new instance of this table, the following objects should be set simultaneously
hh3cVsanFcIdPersistencyFcId, hh3cVsanFcIdPersistencyType, hh3cVsanFcIdPersistencyRowStatus.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVsanFcIdPersistencyWwn(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.1) |
not-accessible |
OCTET STRING |
Octets |
Persistent WWN. |
As per the MIB. |
hh3cVsanFcIdPersistencyFcId(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.2) |
read-create |
OCTET STRING |
Octets |
Persistent FC ID. |
As per the MIB. |
hh3cVsanFcIdPersistencyUsed(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.3) |
read-only |
INTEGER |
TruthValue |
Persistency. |
As per the MIB. |
hh3cVsanFcIdPersistencyType(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.4) |
read-create |
INTEGER |
static(1) |
Persistency type. |
As per the MIB. |
hh3cVsanFcIdPersistencyRowStatus(1.3.6.1.4.1.25506.2.127.1.1.1.5.1.5) |
read-create |
INTEGER |
Integer (32 bit) |
Row status. |
As per the MIB. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.127.1.1.3.0.1 |
Domain ID assignment failure |
Error |
Major |
N/A |
ON |
This notification is generated in any of the following situations:
· The switch's request to apply for a domain ID is rejected.
· The switch receives an assigned domain ID that is different from the statically configured domain ID.
· The switch receives an assigned domain ID that is not in its allowed domain ID list.
· On the switch, the fabric configuration feature is disabled and the configured domain ID is removed.
· On the switch, there is no configured domain ID when the fabric configuration feature is disabled.
Status control
The notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.127.1.1.1.1.1.1 (hh3cVsanIndex) |
VSAN ID. |
Yes |
Hh3cFcVsanIndex |
Unsigned32 (1..4095) |
1.3.6.1.4.1.25506.2.127.1.1.1.2.1.12 (hh3cVsanDmLocalSwitchWWN) |
Local switch WWN. |
No |
Hh3cFcNameId |
OCTET STRING (SIZE (8)) |
Recommended action
To resolve the issue:
1. Verify that the configuration and network topology are correct.
2. If the issue persists, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.1.1.3.0.2 |
A switch selected as the principal switch in a VSAN |
Informational |
N/A |
N/A |
ON |
A switch is selected as the principal switch in a VSAN.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
VSAN ID. |
Yes |
Hh3cFcVsanIndex |
Unsigned32(1..4095) |
Local switch WWN. |
No |
Hh3cFcNameId |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.1.1.3.0.3 |
BF or RCF frames received or sent in a VSAN |
Error |
Warning |
N/A |
OFF |
The switch receives or sends BF or RCF frames in a VSAN.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-fabric fabric-change command.
· MIB: Set hh3cVsanDmFabricChangeNotifyEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-fabric fabric-change command.
· MIB: Set hh3cVsanDmFabricChangeNotifyEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
VSAN ID. |
Yes |
Hh3cFcVsanIndex |
Recommended action
If the BF or RCF frames are desired, no action is required.
If the BF or RCF frames are not desired, to resolve the issue:
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.127.1.1.3.0.4 |
Runtime domain ID changed in a VSAN |
Error |
Warning |
N/A |
OFF |
The runtime domain ID changes in a VSAN.
Status control
ON
· CLI: Use the snmp-agent trap enable fc-fabric domain-id-change command.
· MIB: Set hh3cVsanDmDomainIdChangeNotifyEnable to true(1).
OFF
· CLI: Use the undo snmp-agent trap enable fc-fabric domain-id-change command.
· MIB: Set hh3cVsanDmDomainIdChangeNotifyEnable to false(2).
Objects
OID (object name) |
Index |
Type |
Value range |
VSAN ID. |
Yes |
Hh3cFcVsanIndex |
1.3.6.1.4.1.25506.2.127.1.1.1.2.1.10 (hh3cVsanDmDomainIdAssigned) |
No |
Integer32(0..239) |
Local switch WWN. |
No |
Hh3cFcNameId |
Recommended action
If the domain ID change is desired, no action is required.
If the domain ID change is not desired, to resolve the issue:
