09-组播VPN命令
本章节下载: 09-组播VPN命令 (179.52 KB)
1.1.3 display bgp mdt routing-table
1.1.4 display multicast-domain vpn-instance share-group
1.1.5 display multicast-domain vpn-instance switch-group receive
1.1.6 display multicast-domain vpn-instance switch-group send
1.1.8 multicast-domain log switch-group-reuse
1.1.9 multicast-domain share-group
1.1.10 multicast-domain switch-delay
1.1.11 multicast-domain switch-group-pool
1.1.12 peer enable (BGP-MDT subaddress family view)
1.1.13 peer group (BGP-MDT subaddress family view)
1.1.14 peer reflect-client (BGP-MDT subaddress family view)
1.1.15 reflect between-clients (BGP-MDT subaddress family view)
1.1.16 reflector cluster-id (BGP-MDT subaddress family view)
display bgp mdt group [ group-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-name:查看指定名称的BGP MDT对等体组的信息,为1~47个字符的字符串,不可以包含空格,区分大小写。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display bgp mdt group命令用来查看BGP MDT对等体组的信息。
# 查看BGP MDT对等体组test的信息。
<Sysname> display bgp mdt group test
BGP peer-group is test
Remote AS 2004
Type : external
Threshold: 75%
Configured hold timer value: 180
Keepalive timer value: 60
Minimum time between advertisement runs is 30 seconds
Connect-interface has been configured
Multi-hop ebgp been enabled
Peer Preferred Value: 0
Members:
2.2.2.1 2004 0 0 0 0 00:01:21 Active
表1-1 display bgp mdt group命令显示信息描述表
BGP peer-group |
对等体组的名称 |
Remote AS |
对等体组的AS号 |
Type |
对等体组的类型: · external:表示EBGP对等体组 · internal:表示IBGP对等体组 |
Maximum allowed prefix number |
允许的最大路由数 |
Threshold |
配置了允许从对等体/对等体组收到的最大路由数后,路由器开始生成告警消息时路由数占允许最大路由数的百分比 |
Configured hold timer value |
保持时间间隔 |
Keepalive timer value |
存活时间间隔 |
Minimum time between advertisement runs |
路由发布最小时间间隔 |
Connect-interface has been configured |
建立TCP连接的源接口已配置 |
Multi-hop ebgp been enabled |
允许邻居的TCP连接跳数超过1,但不超过配置值 |
Peer Preferred Value |
为来自对等体路由指定的首选值 |
No routing policy is configured |
没有针对该对等体组指定任何路由策略 |
Members |
对等体组中所含成员的详细信息 |
Peer |
对等体的IP地址 |
AS |
对等体所在的自治系统号 |
MsgRcvd |
收到的消息数 |
MsgSent |
发送的消息数 |
OutQ |
待发送的消息数 |
PrefRcv |
收到的前缀数 |
Up/Down |
会话已建立的时长/(会话未建立时)当前状态的时长 |
State |
对等体的状态: · Active:TCP连接建立失败后等待TCP再次建立 · Connect:对等体已发起TCP连接请求但尚未成功建立 · Established:对等体已成功建立 · Idle:对等体配置后尚未发起TCP连接请求 · Idle(Admin):通过命令强制对等体不发起TCP连接请求 · Openconfirm:已收到对等体的Open报文,正等待Keepalive报文 · Opensent:已成功向对等体发送了Open报文 |
display bgp mdt peer [ [ ip-address ] verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ip-address:查看指定IP地址的BGP MDT对等体的信息。
verbose:查看BGP MDT对等体的详细信息。
【描述】
display bgp mdt peer命令用来查看BGP MDT对等体的信息。
# 查看BGP MDT对等体2.2.2.1的详细信息。
<Sysname> display bgp mdt peer 2.2.2.1 verbose
Peer: 2.2.2.1 Local: 2.2.2.2
Type: IBGP link
BGP version 4, remote router ID 1.1.1.1
BGP current state: Established, Up for 00h01m51s
BGP current event: RecvKeepalive
BGP last state: OpenConfirm
Port: Local - 1029 Remote - 179
Configured: Active Hold Time: 180 sec Keepalive Time: 60 sec
Received : Active Hold Time: 180 sec
Negotiated: Active Hold Time: 180 sec Keepalive Time:60 sec
Peer optional capabilities:
Peer support bgp multi-protocol extended
Peer support bgp route refresh capability
Address family IPv4 Unicast: advertised and received
Address family IPv4 MDT: advertised and received
Received: Total 5 messages, Update messages 1
Sent: Total 4 messages, Update messages 0
Threshold: 75%
Optional capabilities:
Routing policy configured:
表1-2 display bgp mdt peer命令显示信息描述表
Peer |
对等体的IP地址 |
Local |
本地的路由器ID |
Type |
对等体类型: · IBGP link:表示IBGP对等体 · EBGP link:表示EBGP对等体 |
BGP version |
BGP协议的版本号 |
remote router ID |
对等体的路由器ID |
BGP current state |
对等体的当前状态: · Active:TCP连接建立失败后等待TCP再次建立 · Connect:对等体已发起TCP连接请求但尚未成功建立 · Established:对等体已成功建立 · Idle:对等体配置后尚未发起TCP连接请求 · Idle(Admin):通过命令强制对等体不发起TCP连接请求 · Openconfirm:已收到对等体的Open报文,正等待Keepalive报文 · Opensent:已成功向对等体发送了Open报文 |
BGP current event |
对等体的当前事件: · AdvTimerExpired:发送路由定时器超时 · ConnCloesed:TCP连接请求关闭 · ConnOpen:已发起TCP连接请求 · ConnOpenFailed:TCP连接请求失败 · CRTTimerExpired:发起TCP连接请求定时器超时 · HOLDTimerExpired:Holdtime定时器超时 · KATTimerExpired:Keepalive定时器超时 · RecvKeepalive:收到对等体的Keepalive报文 · RecvNotification:收到对等体的Notification报文 · RecvOpen:收到对等体的Open报文 · RecvRouteRefresh:收到对等体的Route-refresh报文 · RecvUpdate:收到对等体的Update报文 · Start:对等体配置后尚未发起TCP连接请求 · Stop:通过命令强制对等体不发起TCP连接请求 · TransFatalError:TCP连接发生致命错误 |
BGP last state |
对等体的上一个状态: · Active:TCP连接建立失败后等待TCP再次建立 · Connect:对等体已发起TCP连接请求但尚未成功建立 · Established:对等体已成功建立 · Idle:对等体配置后尚未发起TCP连接请求 · Idle(Admin):通过命令强制对等体不发起TCP连接请求 · Openconfirm:已收到对等体的Open报文,正等待Keepalive报文 · Opensent:已成功向对等体发送了Open报文 |
Port |
建立TCP连接时,本地(Local)和对等体(Remote)分别使用的端口号 |
Configured |
本地配置的定时器值: · Active Hold Time:与对等体连接的保持时间 · Keepalive Time:与对等体连接的存活时间 |
Received |
收到的对等体上配置的定时器值: Active Hold Time:与对等体连接的保持时间 |
Negotiated |
协商后的定时器值: · Active Hold Time:与对等体连接的保持时间 · Keepalive Time:与对等体连接的存活时间 |
Peer optional capabilities |
对等体所支持的可选扩展能力 |
Peer support bgp multi-protocol extended |
对等体支持BGP多协议扩展 |
Peer support bgp route refresh capability |
对等体支持BGP路由刷新 |
Address family IPv4 Unicast: advertised and received |
以IPv4单播形式通告和接收路由 |
Address family IPv4 MDT: advertised and received |
以IPv4组播形式通告和接收路由 |
Received |
本地接收的总报文数和更新报文数 |
Sent |
本地发送的总报文数和更新报文数 |
可接收的最大路由数 |
Threshold |
路由发布最小时间间隔 |
Optional capabilities |
对等体所使能的可选扩展能力 |
Route refresh capability has been enabled |
路由刷新能力已使能 |
建立TCP连接的源接口已配置 |
为来自对等体的路由所指定的首选值 |
Routing policy configured |
本地采取的路由策略 |
没有配置路由策略 |
display bgp mdt { all | route-distinguisher route-distinguisher } routing-table [ ip-address [ mask | mask-length ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:查看所有的BGP MDT路由信息。
route-distinguisher route-distinguisher:查看指定路由标识符的BGP MDT路由信息。其中route-distinguisher为路由标识符的值,格式为nn:nn或IP-address:nn,为3~21个字符的字符串。
ip-address:表示目的网段的IP地址。
mask:表示目的网段IP地址的掩码,缺省值为255.255.255.255。
mask-length:表示目的网段IP地址的掩码长度,取值范围为0~32,缺省值为32。
【描述】
display bgp mdt all routing-table命令用来查看BGP MDT路由信息。
# 查看所有BGP MDT路由信息。
<Sysname> display bgp mdt all routing-table
BGP Local router ID is 2.2.2.2
Status codes: * - valid, ^ - VPNv4 best, > - best, d - damped,
h - history, i - internal, s - suppressed, S - Stale
Origin : i - IGP, e - EGP, ? - incomplete
Total number of MDT routes: 1
Route Distinguisher: 100:1
*> 1.1.1.1/32 3.3.3.3 0 100 10 ?
表1-3 display bgp mdt all routing-table命令显示信息描述表
BGP Local router ID |
BGP本地路由器ID |
Status codes |
路由状态标志: · * - valid:表示合法 · ^ - VPNv4 best:表示VPNv4优选路由 · > - best:表示普通优选路由 · d - damped:表示震荡抑制路由 · h - history:表示历史路由 · i - internal:表示内部路由 · s - suppressed:表示聚合路由 · S - Stale:表示过期路由 |
Origin |
路由起源标志: · i - IGP:表示网络层可达信息来源于AS内部 · e - EGP:表示网络层可达信息通过EGP学习 · ? - incomplete:表示网络层可达信息通过其它方式学习 |
Total number of MDT routes |
MDT路由总数 |
Route Distinguisher |
路由标识符 |
Network |
从BGP路由表中显示MD源地址 |
NextHop |
下一跳IP地址 |
MED |
与目的网络关联的度量值 |
LocPrf |
本地优先级 |
PrefVal |
路由首选值 |
Path |
路由的AS路径(AS_PATH)属性,记录了此路由所穿过的所有AS区域,可以避免路由环路的出现 |
Ogn |
路由的起源(ORIGIN)属性,表示路由相对于发出它的自治系统的路由更新起点,有以下三种取值: · i:表示该路由是AS内部的。BGP把聚合路由和用network命令定义的路由看成是AS内部的,起点类型设置为IGP · e:表示该路由是从外部网关协议(EGP)学习到的 · ?:表示该路由的来源无法确定。例如,引入的其它路由协议的MDT路由信息 |
display multicast-domain vpn-instance vpn-instance-name share-group { local | remote } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
vpn-instance-name:表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
local:查看本地Share-Group组信息。
remote:查看远端Share-Group组信息。
【描述】
display multicast-domain vpn-instance share-group命令用来查看MD中指定VPN实例的Share-Group组信息。
# 查看MD中VPN实例mvpn的本地Share-Group组信息。
<Sysname> display multicast-domain vpn-instance mvpn share-group local
MD local share-group information for VPN-Instance: mvpn
Share-group: 225.2.2.2
MTunnel address: 1.1.1.1
# 查看MD中VPN实例mvpn的远端Share-Group组信息。
<Sysname> display multicast-domain vpn-instance mvpn share-group remote
MD remote share-group information for VPN-Instance: mvpn
Route-Distinguisher Router-ID Share-Group Next-Hop
1:1 2.2.2.2 225.2.2.2 10.1.1.1
表1-4 display multicast-domain vpn-instance share-group命令显示信息描述表
MD local share-group information for VPN-Instance: mvpn |
VPN实例mvpn的本地Share-Group组信息 |
MD remote share-group information for VPN-Instance: mvpn |
VPN实例mvpn的远端Share-Group组信息 |
Share-group |
Share-Group地址 |
MTunnel address |
Share-Group绑定的MTI接口地址 |
Route-Distinguisher |
路由标识符 |
Router-ID |
发送路由的对等体的路由器ID |
Next-Hop |
下一跳IP地址 |
display multicast-domain vpn-instance vpn-instance-name switch-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
brief:查看收到的Switch-Group简要信息。
active:查看收到的已加入Switch-MDT的Switch-Group信息。
group-address:查看与指定公网组播组相关的Switch-Group信息,取值范围为224.0.1.0~239.255.255.255。
source-address:查看与指定公网组播源相关的Switch-Group信息。
vpn-source-address:查看与指定VPN组播源相关的Switch-Group信息。
mask:表示VPN组播源或组播组地址的掩码,缺省值为255.255.255.255。
mask-length:表示VPN组播源或组播组地址的掩码长度,取值范围为0~32,缺省值为32。
vpn-group-address:查看与指定VPN组播组相关的Switch-Group信息,取值范围为224.0.0.0~239.255.255.255。
【描述】
display multicast-domain vpn-instance switch-group receive命令用来查看MD中指定VPN实例收到的Switch-Group信息。
相关配置可参考命令display multicast-domain vpn-instance switch-group send。
# 查看MD中VPN实例mvpn收到的Switch-Group信息。
<Sysname> display multicast-domain vpn-instance mvpn switch-group receive
MD switch-group information received by VPN-Instance: mvpn
Total 2 switch-groups for 8 entries
Total 2 switch-groups for 8 entries matched
switch group: 226.1.1.0 ref count: 4, active count: 2
sender: 172.100.1.1 active count: 1
(192.6.1.5, 239.1.1.1) expire time: 00:03:10 active
(192.6.1.5, 239.1.1.158) expire time: 00:03:10
sender: 181.100.1.1 active count: 1
(195.6.1.2, 239.1.2.12) expire time: 00:03:10 active
(195.6.1.2, 239.1.2.197) expire time: 00:03:10
switch group: 229.1.1.0 ref count: 4, active count: 2
sender: 185.100.1.1 active count: 1
(198.6.1.5, 239.1.3.62) expire time: 00:03:10 active
(198.6.1.5, 225.1.1.109) expire time: 00:03:10
sender: 190.100.1.1 active count: 1
(200.6.1.2, 225.1.4.80) expire time: 00:03:10 active
(200.6.1.2, 225.1.4.173) expire time: 00:03:10
# 查看MD中VPN实例mvpn收到的Switch-Group简要信息。
<Sysname> display multicast-domain vpn-instance mvpn switch-group receive brief
表1-5 display multicast-domain vpn-instance switch-group receive命令显示信息描述表
MD switch-group information received by VPN-Instance: mvpn |
VPN实例mvpn收到的Switch-Group信息 |
Total 2 switch-groups for 8 entries |
总共有2个Switch-Group,对应着8个(S,G)表项 |
Total 2 switch-groups for 8 entries matched |
匹配了共2个Switch-Group,对应着8个(S,G)表项 |
switch group |
收到的Switch-Group地址 |
sender |
发送Switch-Group信息的PE的BGP对等体地址 |
ref count |
Switch-Group引用的私网组播组数量 |
active count |
Switch-Group引用的活跃私网组播组(即存在接收者的组播组)数量 |
expire time |
Switch-Group引用的私网组播(S,G)表项的超时时间 |
display multicast-domain vpn-instance vpn-instance-name switch-group send [ group group-address | reuse interval | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-address:查看与指定组播组相关的Switch-Group信息,取值范围为224.0.1.0~239.255.255.255。
interval:查看MD在指定时间段内发生重用的Switch-Group信息,取值范围为1~2147483647,单位为秒。
【描述】
display multicast-domain vpn-instance switch-group send命令用来查看MD中指定VPN实例发送的Switch-Group信息。
相关配置可参考命令display multicast-domain vpn-instance switch-group receive。
# 查看MD中VPN实例mvpn发送的Switch-Group信息。
<Sysname> display multicast-domain vpn-instance mvpn switch-group send
MD switch-group information sent by VPN-Instance: mvpn
Total 2 switch-groups for 6 entries
Total 2 switch-groups for 6 entries matched
226.1.1.0 reference_count: 3
(192.6.1.5, 239.1.1.1) switch time: 00:00:21
(192.6.1.5, 239.1.1.158) switch time: 00:00:21
(192.6.1.5, 239.1.2.50) switch time: 00:00:05
226.1.1.1 reference_count: 3
(192.6.1.2, 225.1.1.1) switch time: 00:00:21
(192.6.1.2, 225.1.2.50) switch time: 00:00:05
(192.6.1.5, 239.1.1.159) switch time: 00:00:21
# 查看MD中VPN实例mvpn在30秒内发送的Switch-Group的重用信息。
<Sysname> display multicast-domain vpn-instance mvpn switch-group send reuse 30
Total 2 switch-groups for 3 entries
Total 2 switch-groups for 3 entries matched
226.1.1.0 reuse_count: 1
226.1.1.1 reuse_count: 1
226.1.1.2 reuse_count: 1
表1-6 display multicast-domain vpn-instance switch-group send命令显示信息描述表
MD switch-group information sent by VPN-Instance: mvpn |
VPN实例mvpn发送的Switch-Group信息 |
Total 2 switch-groups for 6 entries |
总共有2个Switch-Group,对应着6个(S,G)表项 |
Total 2 switch-groups for 6 entries matched |
匹配了共2个Switch-Group,对应着6个(S,G)表项 |
reference_count |
发送的Switch-Group引用的私网组播组数量 |
switch time |
Switch-Group引用的私网组播(S,G)表项的切换时间 |
reuse_count |
发送的Switch-Group在指定时间段内的重用数量 |
ipv4-family mdt
undo ipv4-family mdt
BGP视图
【缺省级别】
2:系统级
无
【描述】
ipv4-family mdt命令用来进入BGP-MDT子地址族视图。undo ipv4-family mdt命令用来删除BGP-MDT子地址族视图下的所有配置。
# 进入BGP-MDT子地址族视图。
[Sysname] bgp 100
[Sysname-bgp] ipv4-family mdt
[Sysname-bgp-af-mdt]
undo multicast-domain log
VPN实例视图
【缺省级别】
2:系统级
无
【描述】
multicast-domain log switch-group-reuse命令用来打开Switch-Group重用日志输出开关。undo multicast-domain log命令用来关闭Switch-Group重用日志输出开关。
缺省情况下,Switch-Group重用日志输出开关处于关闭状态。
需要注意的是,如果该VPN中的Share-MDT没有配置,则不允许配置本命令。
# 打开VPN实例mvpn中的Switch-Group重用日志输出开关。
[Sysname] ip vpn-instance mvpn
[Sysname-vpn-instance-mvpn] multicast-domain log switch-group-reuse
multicast-domain share-group group-address binding mtunnel mtunnel-number
undo multicast-domain share-group
VPN实例视图
【缺省级别】
2:系统级
group-address:表示组播组地址,取值范围为224.0.1.0~239.255.255.255。
mtunnel-number:要创建的MTI接口编号,取值范围为0~1022。
【描述】
multicast-domain share-group命令用来指定Share-Group并为本VPN实例绑定MTI。undo multicast-domain share-group命令用来恢复缺省情况。
缺省情况下,没有指定Share-Group,也没有为本VPN实例绑定MTI。
· 当把属于公网SSM组范围内的组播组指定为Share-Group时,必须先配置好BGP MDT对等体/对等体组。
· 在同一台PE上,不同VPN实例不能配置相同的组地址,group-address不能与任何VPN实例的Switch-Group组地址相同,mtunnel-number也不能与已创建的组播隧道接口号重复。
· 在相同的VPN实例视图下,不允许重复配置本命令。只有取消了原配置后,才能配置新的地址和组播隧道接口。
· 执行undo multicast-domain share-group命令后,将同时删除组播隧道接口以及下列命令所对应的配置:multicast-domain switch-group-pool、multicast-domain log switch-group-reuse和multicast-domain switch-delay。
· 只有VPN实例中使能了IP组播路由,才允许配置本命令。
相关配置可参考命令multicast-domain switch-group-pool、multicast-domain log switch-group-reuse和multicast-domain switch-delay,以及“IP组播命令参考/组播路由与转发”中的命令multicast routing-enable。
# 指定VPN实例mvpn中的Share-Group组为224.1.1.1,并绑定MTI0。
[Sysname-vpn-instance-mvpn] multicast-domain share-group 224.1.1.1 binding mtunnel 0
multicast-domain switch-delay switch-delay
undo multicast-domain switch-delay
VPN实例视图
【缺省级别】
2:系统级
switch-delay:表示由Share-MDT向Switch-MDT切换的延迟时间,取值范围为3~60,单位为秒。
【描述】
multicast-domain switch-delay命令用来配置由Share-MDT向Switch-MDT切换的延迟时间。undo multicast-domain switch-delay命令用来恢复缺省情况。
缺省情况下,由Share-MDT向Switch-MDT切换的延迟时间为5秒。
# 配置VPN实例mvpn中由Share-MDT向Switch-MDT切换的延迟时间为20秒。
[Sysname-vpn-instance-mvpn] multicast-domain switch-delay 20
multicast-domain switch-group-pool switch-group-pool { mask | mask-length } [ acl acl-number ]
undo multicast-domain switch-group-pool
VPN实例视图
【缺省级别】
2:系统级
switch-group-pool:表示Switch-Group-Pool的起始地址,取值范围为224.0.1.0~239.255.255.255。
mask:表示Switch-Group-Pool地址的掩码,取值范围为255.255.255.0~255.255.255.255,即表示Switch-Group-Pool中所包含的组地址个数为1~256个。
mask-length:表示Switch-Group-Pool地址的掩码长度,取值范围为22~32,即表示Switch-Group-Pool中所包含的组地址个数为1~256个。
acl-number:指定高级访问控制列表编号,取值范围为3000~3999。用来指定切换地址池作用的(S,G)表项。如果没有指定ACL,则作用于所有的(S,G)表项。
在定义该ACL时,只允许使用rule命令中类型为ip的source和destination参数来分别指定S和G。
【描述】
multicast-domain switch-group-pool命令用来配置Switch-Group-Pool的范围和切换条件。undo multicast-domain switch-group-pool命令用来恢复缺省情况。
缺省情况下,没有指定Switch-Group-Pool,也永不向Switch-MDT切换。
· 如果该VPN中的Share-Group没有配置,则不允许配置本命令。
· 在一台PE上,一个VPN内配置的Switch-Group地址范围不能包含任何VPN内的Share-Group。
· 在一台PE上,不同VPN实例所对应的Switch-Group地址范围不能互相重叠。在同一个VPN实例视图下进行重复配置时,新配置将覆盖旧配置。
· 在设备上配置了本命令后,当有流量且维持了Switch-Delay时间后就发起向Switch-MDT的切换。
相关配置可参考命令multicast-domain switch-delay。
# 配置VPN实例mvpn中的Switch-Group-Pool范围为从225.2.2.0到225.2.2.15。
[Sysname-vpn-instance-mvpn] multicast-domain switch-group-pool 225.2.2.0 28
peer { group-name | ip-address } enable
undo peer { group-name | ip-address } enable
BGP-MDT子地址族视图
【缺省级别】
2:系统级
group-name:表示BGP MDT对等体组的名称,为1~47个字符的字符串,不可以包含空格,区分大小写。
ip-address:表示BGP MDT对等体的IP地址。
【描述】
peer enable命令用来激活BGP MDT对等体/对等体组。undo peer enable命令用来关闭BGP MDT对等体/对等体组。
缺省情况下,BGP MDT对等体/对等体组处于未激活状态。
需要注意的是,配置本命令前须先配置好相关的BGP对等体/对等体组。
相关配置可参考“三层技术-IP路由命令参考/BGP”中的命令group、peer as-number和peer group。
# 配置并激活BGP MDT对等体18.10.0.9。
[Sysname] bgp 100
[Sysname-bgp] peer 18.10.0.9 as-number 100
[Sysname-bgp-af-mdt] peer 18.10.0.9 enable
peer ip-address group group-name
undo peer ip-address group group-name
BGP-MDT子地址族视图
【缺省级别】
2:系统级
【描述】
peer group命令用来向BGP MDT对等体组中添加BGP MDT对等体。undo peer group命令用来从BGP MDT对等体组中删除BGP MDT对等体。
缺省情况下,BGP MDT对等体不属于任何BGP MDT对等体组。
需要注意的是,配置本命令前须先配置并激活BGP MDT对等体/对等体组。
相关配置可参考命令peer enable。
# 配置并激活BGP MDT对等体10.1.1.1和BGP MDT对等体组test,并将该对等体添加到该对等体组中。
[Sysname] bgp 100
[Sysname-bgp] group test
[Sysname-bgp] peer test as-number 2004
[Sysname-bgp] peer 10.1.1.1 group test
[Sysname-bgp-af-mdt] peer test enable
[Sysname-bgp-af-mdt] peer 10.1.1.1 enable
[Sysname-bgp-af-mdt] peer 10.1.1.1 group test
peer { group-name | ip-address } reflect-client
undo peer { group-name | ip-address } reflect-client
BGP-MDT子地址族视图
【缺省级别】
2:系统级
【描述】
peer reflect-client命令用来配置本设备作为路由反射器,并将指定BGP MDT对等体/对等体组作为路由反射器的客户。undo peer reflect-client命令用来取消相应的配置。
缺省情况下,没有配置路由反射器及其客户。
· 配置本命令前须先配置并激活BGP MDT对等体/对等体组。
· 多次执行本命令,只有最后一次的配置生效。
相关配置可参考命令peer enable,reflect between-clients和reflector cluster-id。
# 先配置并激活BGP MDT对等体组test,然后再配置本设备作为路由反射器,并将BGP MDT对等体组test作为路由反射器的客户。
[Sysname] bgp 100
[Sysname-bgp-af-mdt] peer test reflect-client
undo reflect between-clients
BGP-MDT子地址族视图
【缺省级别】
2:系统级
无
【描述】
reflect between-clients命令用来允许客户到客户的路由反射。undo reflect between-clients命令用来禁止客户到客户的路由反射。
缺省情况下,允许客户到客户的路由反射。
相关配置可参考命令peer reflect-client和reflector cluster-id。
# 禁止客户到客户的路由反射。
[Sysname] bgp 100
[Sysname-bgp-af-mdt] undo reflect between-clients
undo reflector cluster-id
BGP-MDT子地址族视图
【缺省级别】
2:系统级
cluster-id:指定路由反射器的集群ID,取值范围为1~4294967295。
ip-address:使用指定BGP MDT对等体的IP地址作为路由反射器的集群ID。
【描述】
reflector cluster-id命令用来配置路由反射器的集群ID。undo reflector cluster-id命令用来删除路由反射器的集群ID。
缺省情况下,路由反射器的Router ID就是其集群ID。
通常,一个集群中只有一个路由反射器,并通过其Router ID来识别该集群。为了增强网络的可靠性,可在一个集群中配置多个路由反射器,此时应为每个路由反射器配置相同的集群ID,以避免产生路由环路。
相关配置可参考命令reflect between-clients和peer reflect-client。
# 配置本设备的集群ID为80。
[Sysname] bgp 100
[Sysname-bgp-af-mdt] reflector cluster-id 80
reset bgp mdt { as-number | ip-address | all | external | group group-name | internal }
【缺省级别】
1:监控级
as-number:复位与指定AS中BGP邻居的BGP MDT连接,取值范围为1~4294967295。
ip-address:复位与指定BGP MDT对等体的连接。
all:复位所有的BGP MDT连接。
external:复位所有的EBGP MDT连接。
group group-name:复位与指定BGP MDT对等体组的连接,group-name为1~47个字符的字符串,不可以包含空格,区分大小写。
internal:复位所有的IBGP MDT连接。
【描述】
reset bgp mdt命令用来复位BGP MDT连接。
# 复位所有的BGP MDT连接。
<Sysname> reset bgp mdt all
