- 02-Configuration Examples
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_IGMP_Configuration_Examples
- 04-H3C_IP_Source_Guard_Configuration_Examples
- 05-H3C_Ethernet_OAM_Configuration_Examples
- 06-H3C_NQA_Configuration_Examples
- 07-H3C_QinQ_Configuration_Examples
- 08-H3C_OSPF_Configuration_Examples
- 09-H3C_MPLS_TE_Configuration_Examples
- 10-H3C_OpenFlow_Configuration_Examples
- 11-H3C_NAT_Configuration_Examples
- 12-H3C_RBAC_Configuration_Examples
- 13-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 14-H3C_DLDP_Configuration_Examples
- 15-H3C_IS-IS_Configuration_Examples
- 16-H3C_MPLS_L3VPN_Configuration_Examples
- 17-H3C_SSH_Configuration_Examples
- 18-H3C_Login_Management_Configuration_Examples
- 19-H3C_SNMP_Configuration_Examples
- 20-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 21-H3C_Multicast_VPN_Configuration_Examples
- 22-H3C_BGP_Configuration_Examples
- 23-H3C_HoVPN_Configuration_Examples
- 24-H3C_L2TP_Configuration_Examples
- 25-H3C_VRRP_Configuration_Examples
- 26-H3C_Traffic_Filtering_Configuration_Examples
- 27-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 28-H3C_MPLS_L2VPN_Configuration_Examples
- 29-H3C_NetStream_Configuration_Examples
- 30-H3C_Policy-Based_Routing_Configuration_Examples
- 31-H3C_Traffic_Policing_Configuration_Examples
- 32-H3C_BFD_Configuration_Examples
- 33-H3C_OSPFv3_Configuration_Examples
- 34-H3C_VPLS_Configuration_Examples
- 35-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 36-H3C_IPv6_IS-IS_Configuration_Examples
- 37-H3C_MPLS OAM_Configuration_Examples
- 38-H3C_BGP_Route_Selection_Configuration_Examples
- 39-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 40-H3C_SRv6 Configuration Examples
- 41-H3C_Attack_Protection_Configuration_Examples
- 42-H3C_OSPF_Multi-Process_Configuration_Examples
- 43-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 44-H3C_ARP_Attack_Protection_Configuration_Examples
- 45-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 46-General QoS Configuration Examples
- 47-GRE Tunnel Establishment Using OSPF Configuration Examples
- 48-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 49-QoS Configuration Examples for the Financial Industry
| 41-H3C_Attack_Protection_Configuration_Examples | 520.81 KB |
Example: Configuring link layer attack protection
Example: Configuring ARP attack protection
Example: Configuring network layer attack protection
Verifying source address spoofing prevention
Verifying TTL attack protection
Example: Configuring transport layer attack protection
Introduction
This document provides configuration examples of link layer attack protection, ARP attack protection, network layer attack protection, and transport layer attack protection, as defined in Table 1.
Table 1 Attack protection types
Attack protection types |
Link layer attack protection |
MAC address attack protection |
Prevents the attack of packets with different source MAC addresses or VLANs by configuring the maximum number of MAC addresses that an interface can learn. |
STP packet attack protection |
Provides protection measures such as BPDU guard, root guard, loop guard, and TC-BPDU guard. |
ARP attack protection |
ARP source suppression |
Prevents IP attack packets from fixed sources. |
ARP black hole routing |
Prevents IP attack packets from sources that are not fixed. |
ARP active acknowledgement |
Prevents user spoofing. |
Source MAC-based ARP attack detection |
Prevents ARP packet attacks from the same source MAC. |
ARP packet source MAC consistency check |
Prevents attacks from ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body. |
Network layer attack protection |
uRPF check |
Protects a network against source spoofing attacks. |
TTL attack protection |
Prevents an attack by disabling sending ICMP time exceeded messages. |
Transport layer attack protection |
SYN flood attack protection |
Enables the server to return a SYN ACK message when it receives a TCP connection request, without establishing a half-open TCP connection. |
This document assumes that you have basic knowledge of attack protection.
As shown in Figure 1, Device A, Device B, and Device C run MSTP. Device B acts as the root bridge, and XGE0/0/15 on Device C is blocked.
Configure the following features to prevent link layer attacks:
· Configure root guard on XGE0/0/15 and XGE0/0/16 of Device B for Device B to act as the root bridge.
· Configure loop guard on XGE0/0/16 of Device C to prevent temporary loops. The loop guard feature keeps the port in Discarding state in all MSTIs when it receives no BPDU.
· Configure BPDU guard on ports at the access side of Device A and Device C. The BPDU guard feature prevents the ports from performing spanning tree calculations when it receives forged BPDUs with a higher priority.
· Enable TC-BPDU guard on Device A, Device B, and Device C. The TC-BPDU guard feature prevents a large number of TC-BPDUs from affecting the network in a short time.
· Set the maximum number of MAC addresses that can be learned by ports at the access side of Device A and Device C. This configuration protects the devices from a large number of attack packets that have different source MAC addresses. The attack packets might cause a large MAC table and low forwarding performance.
Analysis
For the ports at the access side of Device A and Device C to rapidly transit to the forwarding state, use the stp edged-port command to configure these ports as edge ports.
This example uses XGE0/0/17 to illustrate the configuration on the ports at the access side on Device A and Device C.
On a port, the loop guard feature is mutually exclusive with the root guard feature or the edge port setting.
Do not configure the loop guard feature on ports at the access side. Otherwise, the ports stay in Discarding state in all MSTIs because they cannot receive BPDUs.
Procedures
Configuring Device B
# Specify IP addresses for interfaces. (Details not shown.)
# Configure root guard on XGE0/0/15 and XGE0/0/16.
[DeviceB] interface range Ten-GigabitEthernet0/0/15 to Ten-GigabitEthernet0/0/16
[DeviceB-if-range] stp root-protection
[DeviceB-if-range] quit
# Configure TC-BPDU guard.
[DeviceB] stp tc-protection
[DeviceB] stp tc-protection threshold 10
Configuring Device A
# Configure STP BPDU guard.
[DeviceA] stp bpdu-protection
# Configure XGE0/0/17 as an edge port.
[DeviceA] interface Ten-GigabitEthernet0/0/17
[DeviceA-Ten-GigabitEthernet0/0/17] stp edged-port
[DeviceA-Ten-GigabitEthernet0/0/17] quit
[DeviceA] stp tc-protection
[DeviceA] stp tc-protection threshold 10
# Set the maximum number of MAC addresses that XGE0/0/17 can learn.
[DeviceA-Ten-GigabitEthernet0/0/17] mac-address max-mac-count 1024
Configuring Device C
<DeviceC> system-view
[DeviceC] stp bpdu-protection
[DeviceC] interface Ten-GigabitEthernet0/0/17
[DeviceC-Ten-GigabitEthernet0/0/17] stp edged-port
[DeviceC-Ten-GigabitEthernet0/0/17] quit
# Configure root guard on XGE0/0/15.
[DeviceC] interface Ten-GigabitEthernet0/0/15
[DeviceC-Ten-GigabitEthernet0/0/15] stp root-protection
[DeviceC-Ten-GigabitEthernet0/0/15] quit
# Configure loop guard on XGE0/0/16.
[DeviceC] interface Ten-GigabitEthernet0/0/16
[DeviceC-Ten-GigabitEthernet0/0/16] stp loop-protection
[DeviceC-Ten-GigabitEthernet0/0/16] quit
[DeviceC] stp tc-protection
[DeviceC] stp tc-protection threshold 10
[DeviceC-Ten-GigabitEthernet0/0/17] mac-address max-mac-count 1024
# Verify that the edge ports go down after they receives STP BPDUs. (Details not shown.)
# Bring the edge ports up by using the undo shutdown command. (Details not shown.)
# Verify that the root ports do not change and that the STP topology remains stable after STP BPDUs with higher priority are sent to the designated ports. (Details not shown.)
# Verify that the devices do not refresh the FIB table frequently and that no serious packet loss occurs after a large number of various TC BPDUs are sent to the devices. (Details not shown.)
# Verify that the uplink ports are not flooded after a large number of broadcasts are sent to the edge ports on Device A and Device C. (Details not shown.)
Configuration files
· Device A:
stp bpdu-protection
port link-mode bridge
stp edged-port
· Device B:
stp root-protection
stp root-protection
· Device C:
stp bpdu-protection
stp root-protection
stp loop-protection
stp edged-port
As shown in Figure 2, the device is the gateway for the internal network. Configure ARP attack protection on the device to prevent ARP attacks.
Procedures
# Enable ARP source suppression.
[Device] arp source-suppression enable
# Configure the device to accept a maximum of 8 unresolvable packets per source IP address in 5 seconds.
[Device] arp source-suppression limit 8
# Enable ARP black hole routing to prevent unresolvable IP packet attacks.
[Device] arp resolving-route enable
# Enable ARP active acknowledgment to prevent user spoofing.
[Device] arp active-ack enable
# Configure source MAC-based ARP attack detection to prevent ARP packet attacks from the same source MAC.
[Device] arp source-mac filter
[Device] arp source-mac threshold 25
# Enable ARP packet source MAC address consistency check to prevent attacks from ARP packets with different source MAC addresses in the Ethernet header and in the message body.
[Device] arp valid-check enable
1. Verify that ARP attack protection functions on the device:
# Send ARP attack packets to the device. (Details not shown.)
# Verify that the CPU usage does not surge. (Details not shown.)
2. Verify that each ARP attack protection feature functions on the device (this example uses the ARP source suppression feature):
# Send the device 20 forged packets with the same source IP address and unresolvable destination IP addresses. (Details not shown.)
# Verify that the device stops resolving the packets after receiving 8 forged packets within 5 seconds. (Details not shown.)
# Verify the ARP source suppression configuration.
[Device] display arp source-suppression
ARP source suppression is enabled
Current suppression limit: 8
Configuration files
As shown in Figure 3, Device A is the gateway for the internal network. To protect Device A against IP packet attacks from internal and external networks, configure the following network layer attack protection features:
· Configure strict uRPF check to prevent source address spoofing attacks.
· Disabling sending ICMP time exceeded messages. The device will not be flooded by ICMP time exceeded messages when receiving a large number of packets in which the TTL is 1.
After you disable sending ICMP time exceeded messages, the traceroute feature will not be available.
Procedures
# Assign IP addresses to interfaces. (Details not shown.)
# Enable strict uRPF check on Ten-GigabitEthernet 0/0/15 of Device A.
[DeviceA] interface Ten-GigabitEthernet0/0/15
[DeviceA-Ten-GigabitEthernet0/0/15] ip urpf strict
# Disable sending ICMP time exceeded messages. Sending ICMP time exceeded messages is disabled by default.
[DeviceA] undo ip ttl-expires enable
Verify that Device A can prevent source address spoofing attacks:
# Verify that Device A can filter out packets with forged source IP addresses. (Details not shown.)
# Verify the uRPF configuration on Ten-GigabitEthernet 0/0/15 of Device A.
[DeviceA] display ip urpf interface Ten-GigabitEthernet0/0/15 slot 3
uRPF configuration information of interface Ten-GigabitEthernet0/0/15:
Check type: strict
Verify that TTL attack protection functions on Device A:
# Enable ICMP debugging by executing the debugging ip icmp command on Device A. (Details not shown.)
# Use a PC to send packets in which the TTL is 1 to Device A. (Details not shown.)
# Verify that Device A does not display any debugging information and that the PC does not receive any ICMP time exceeded messages. (Details not shown.)
# Enable sending ICMP time exceeded messages and send packets in which the TTL is 1 to Device A. (Details not shown.)
# Verify that Device A responds with ICMP time exceeded messages.
<DeviceA> *Aug 14 16:43:31:068 2016 NM-3 SOCKET/7/ICMP: Slot=3;
Time(s):1371221011 ICMP Output:
ICMP Packet: src = 6.0.0.1, dst = 202.101.0.2
type = 11, code = 0 (ttl-exceeded)
Original IP: src = 202.101.0.2, dst = 192.168.0.2
proto = 253, first 8 bytes = 00000000 00000000
Configuration files
ip urpf strict
As shown in Figure 4, the device is the gateway for the internal network. Configure SYN Cookie protection on the device to protect against SYN flood attacks. With this feature enabled, the device responds to a SYN packet with a SYN ACK packet without establishing a TCP semi-connection. The device establishes a TCP connection only when it receives an ACK packet from the sender.
Procedures
# Enable SYN Cookie.
[Device] tcp syn-cookie enable
# Verify that the device does not have any TCP semi-connections. The state "SYN_RECEIVED" represents semi-connections.
[Device] display tcp
*: TCP Connection with authentication
Local Addr:port Foreign Addr:port State Slot PCB
0.0.0.0:21 0.0.0.0:0 LISTEN 3 0xffffffffffffff9
d
0.0.0.0:23 0.0.0.0:0 LISTEN 3 0xffffffffffffff9
f
192.168.2.88:23 192.168.2.79:2197 ESTABLISHED 3 0xffffffffffffffa
3
192.168.2.88:23 192.168.2.89:2710 ESTABLISHED 3 0xffffffffffffffa
2
192.168.2.88:23 192.168.2.110:50199 ESTABLISHED 3 0xffffffffffffff
Configuration files
Related documentation
· H3C CR16000-M1A Router Layer 2—LAN Switching Configuration Guide
· H3C CR16000-M1A Router Layer 2—LAN Switching Command Reference
· H3C CR16000-M1A Router Security Configuration Guide
· H3C CR16000-M1A Router Security Command Reference
· H3C CR16000-M1A Router Layer 3—IP Services Configuration Guide
