- 02-Configuration Examples
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_IGMP_Configuration_Examples
- 04-H3C_IP_Source_Guard_Configuration_Examples
- 05-H3C_Ethernet_OAM_Configuration_Examples
- 06-H3C_NQA_Configuration_Examples
- 07-H3C_QinQ_Configuration_Examples
- 08-H3C_OSPF_Configuration_Examples
- 09-H3C_MPLS_TE_Configuration_Examples
- 10-H3C_OpenFlow_Configuration_Examples
- 11-H3C_NAT_Configuration_Examples
- 12-H3C_RBAC_Configuration_Examples
- 13-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 14-H3C_DLDP_Configuration_Examples
- 15-H3C_IS-IS_Configuration_Examples
- 16-H3C_MPLS_L3VPN_Configuration_Examples
- 17-H3C_SSH_Configuration_Examples
- 18-H3C_Login_Management_Configuration_Examples
- 19-H3C_SNMP_Configuration_Examples
- 20-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 21-H3C_Multicast_VPN_Configuration_Examples
- 22-H3C_BGP_Configuration_Examples
- 23-H3C_HoVPN_Configuration_Examples
- 24-H3C_L2TP_Configuration_Examples
- 25-H3C_VRRP_Configuration_Examples
- 26-H3C_Traffic_Filtering_Configuration_Examples
- 27-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 28-H3C_MPLS_L2VPN_Configuration_Examples
- 29-H3C_NetStream_Configuration_Examples
- 30-H3C_Policy-Based_Routing_Configuration_Examples
- 31-H3C_Traffic_Policing_Configuration_Examples
- 32-H3C_BFD_Configuration_Examples
- 33-H3C_OSPFv3_Configuration_Examples
- 34-H3C_VPLS_Configuration_Examples
- 35-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 36-H3C_IPv6_IS-IS_Configuration_Examples
- 37-H3C_MPLS OAM_Configuration_Examples
- 38-H3C_BGP_Route_Selection_Configuration_Examples
- 39-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 40-H3C_SRv6 Configuration Examples
- 41-H3C_Attack_Protection_Configuration_Examples
- 42-H3C_OSPF_Multi-Process_Configuration_Examples
- 43-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 44-H3C_ARP_Attack_Protection_Configuration_Examples
- 45-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 46-General QoS Configuration Examples
- 47-GRE Tunnel Establishment Using OSPF Configuration Examples
- 48-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 49-QoS Configuration Examples for the Financial Industry
| 09-H3C_MPLS_TE_Configuration_Examples | 248.34 KB |
CRLSP establishment with RSVP-TE
Example: Establishing MPLS TE tunnels with RSVP-TE
Example: Configuring MPLS TE FRR
Introduction
This document provides examples for establishing an MPLS traffic engineering (TE) tunnel with RSVP-TE and examples for configuring MPLS TE fast reroute (FRR).
MPLS TE combines the MPLS technology and traffic engineering. It reserves resources by establishing LSP tunnels along the specified paths, allowing traffic to bypass congested nodes to achieve appropriate load distribution. The LSPs are also called Constraint-based Routed Label Switched Paths (CRLSPs).
CRLSPs can be manually specified or dynamically established. This document provides examples for establishing MPLS TE tunnels that use CRLSPs dynamically established by RSVP-TE.
MPLS TE FRR provides the link protection and node protection modes. This document provides MPLS TE FRR link protection examples.
CRLSPs can be static or dynamic.
· A static CRLSP is established by manually specifying the incoming label, outgoing label, and other constraints on each hop along the path that the traffic travels. Static CRLSPs are easy to configure. However, they cannot automatically adapt to network changes.
· A dynamic CRLSP is established as follows:
a. An IGP advertises TE attributes for links.
b. MPLS TE uses the CSPF algorithm to calculate the shortest path to the tunnel destination.
c. A label distribution protocol (such as RSVP-TE) advertises labels to establish the CRLSP and reserves bandwidth resources on each node along the calculated path.
Dynamic CRLSPs can adapt to network changes and support CRLSP backup and fast reroute. However, their configuration is complex.
This document provides examples for establishing MPLS TE tunnels over dynamic CRLSPs established through RSVP-TE.
MPLS TE FRR
MPLS TE provides fast reroute (FRR) and CRLSP backup for network protection.
· FRR protects CRLSPs from link and node failures and enables 50-millisecond CRLSP failover.
After FRR is enabled for an MPLS TE tunnel, once a link or node fails on the primary CRLSP, FRR reroutes the traffic to a bypass tunnel. The ingress node attempts to set up a new CRLSP. After the new CRLSP is set up, traffic is forwarded on the new CRLSP.
· CRLSP backup provides end-to-end path protection for a CRLSP without time limitation.
FRR provides quick but temporary protection for a link or node on a CRLSP. CRLSP backup provides end-to-end path protection for a CRLSP without time limitation. Choose either of the features depending on the network requirements.
FRR provides the following protection modes:
· Link protection—The PLR and the MP are connected through a direct link and the primary CRLSP traverses this link. When the link fails, traffic is switched to the bypass tunnel. As shown in Figure 1, the primary CRLSP is Device A—Device B—Device C—Device D, and the bypass tunnel is Device B—Device F—Device C. This mode is also called next-hop (NHOP) protection.
· Node protection—The PLR and the MP are connected through a device and the primary CRLSP traverses this device. When the device fails, traffic is switched to the bypass tunnel. As shown in Figure 2, the primary CRLSP is Device A—Device B—Device C—Device D—Device E, and the bypass tunnel is Device B—Device F—Device D. Device C is the protected device. This mode is also called next-next-hop (NNHOP) protection.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of MPLS TE.
As shown in Figure 3, use RSVP-TE to establish two MPLS TE tunnels between Router A and Router D. The MPLS TE tunnel for Enterprise A requires a bandwidth of 20000 kbps. The MPLS TE tunnel for Enterprise B requires a bandwidth of 30000 kbps.
The maximum bandwidth of the link that each tunnel traverses is 50000 kbps. The maximum reservable bandwidth of each link is 40000 kbps.
Analysis
To establish MPLS TE tunnels through RSVP-TE, you must perform the following tasks:
· Enable MPLS, MPLS TE, and RSVP-TE on each interface that the MPLS TE tunnels traverse.
· On each interface that the MPLS TE tunnels traverse, configure link TE attributes, including the maximum link bandwidth and maximum reservable bandwidth.
· On each node that the MPLS TE tunnels traverse, configure the IGP TE extension to advertise the link TE attributes, which generates a TEDB on each node.
Based on the TEDB, CSPF calculates the shortest, TE constraints-compliant path to the tunnel destination. If you do not configure the IGP TE extension, the path is created based on IGP routing. The supported IGP TE extensions are OSPF TE and ISIS TE. This example uses OSPF TE.
· Create a tunnel interface on the ingress node of each MPLS TE tunnel, and perform the following tasks on the tunnel interface:
¡ Specify the tunnel destination address.
¡ Specify the tunnel bandwidth as required (20000 kbps for Enterprise A and 30000 kbps for Enterprise B).
¡ Specify the MPLS TE signaling protocol as RSVP-TE.
RSVP-TE advertises labels to establish CRLSPs and reserves bandwidth resources on each node along the calculated path.
· On the ingress node of each MPLS TE tunnel, configure static routing to direct traffic to the MPLS TE tunnel.
Before configuration, disable the spanning tree feature globally or map each VLAN to an MSTI.
Procedures
1. Configure IP addresses for interfaces:
Configure IP addresses and masks for interfaces on Router A, including the loopback interface, as shown in Network configuration. (Details not shown.)
2. Configure OSPF to ensure IP connectivity among the routers:
# Configure Router A.
<RouterA> System-view
[RouterA] ospf
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[RouterA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[RouterA-ospf-1] quit
# Configure Router B.
<RouterB> System-view
[RouterB] ospf
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterB-ospf-1] quit
# Configure Router C.
<RouterC> System-view
[RouterC] ospf
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[RouterC-ospf-1] quit
# Configure Router D.
<RouterD> System-view
[RouterD] ospf
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[RouterD-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
# Execute the display ip routing-table command on each router to verify that the routers have learned the routes to one another, including the routes to the loopback interfaces. The following shows the output on Router A.
Destinations : 21 Routes : 21
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
1.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.2/32 O_INTRA 10 1 10.1.1.2 XGE0/0/15
3.3.3.3/32 O_INTRA 10 1 30.1.1.3 XGE0/0/16
4.4.4.4/32 O_INTRA 10 2 10.1.1.2 XGE0/0/15
10.1.1.0/24 Direct 0 0 10.1.1.1 XGE0/0/15
10.1.1.0/32 Direct 0 0 10.1.1.1 XGE0/0/15
10.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.255/32 Direct 0 0 10.1.1.1 XGE0/0/15
20.1.1.0/24 O_INTRA 10 2 10.1.1.2 XGE0/0/15
30.1.1.0/24 Direct 0 0 30.1.1.1 XGE0/0/16
30.1.1.0/32 Direct 0 0 30.1.1.1 XGE0/0/16
30.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
30.1.1.255/32 Direct 0 0 30.1.1.1 XGE0/0/16
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
3. Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE:
[RouterA] mpls lsr-id 1.1.1.1
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterA] interface Ten-GigabitEthernet0/0/15
[RouterA-Ten-GigabitEthernet0/0/15 mpls enable
[RouterA-Ten-GigabitEthernet0/0/15] mpls te enable
[RouterA-Ten-GigabitEthernet0/0/15] rsvp enable
[RouterA-Ten-GigabitEthernet0/0/15] quit
[RouterA] interface Ten-GigabitEthernet0/0/16
[RouterA-Ten-GigabitEthernet0/0/16] mpls enable
[RouterA-Ten-GigabitEthernet0/0/16] mpls te enable
[RouterA-Ten-GigabitEthernet0/0/16] rsvp enable
[RouterA-Ten-GigabitEthernet0/0/16] quit
[RouterB] mpls lsr-id 2.2.2.2
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterB] interface Ten-GigabitEthernet0/0/15
[RouterB-Ten-GigabitEthernet0/0/15] mpls enable
[RouterB-Ten-GigabitEthernet0/0/15] mpls te enable
[RouterB-Ten-GigabitEthernet0/0/15] rsvp enable
[RouterB-Ten-GigabitEthernet0/0/15] quit
[RouterB] interface Ten-GigabitEthernet0/0/16
[RouterB-Ten-GigabitEthernet0/0/16] mpls enable
[RouterB-Ten-GigabitEthernet0/0/16] mpls te enable
[RouterB-Ten-GigabitEthernet0/0/16] rsvp enable
[RouterB-Ten-GigabitEthernet0/0/16] quit
[RouterC] mpls lsr-id 3.3.3.3
[RouterC] mpls te
[RouterC-te] quit
[RouterC] rsvp
[RouterC-rsvp] quit
[RouterC] interface Ten-GigabitEthernet0/0/15
[RouterC-Ten-GigabitEthernet0/0/15] mpls enable
[RouterC-Ten-GigabitEthernet0/0/15 mpls te enable
[RouterC-Ten-GigabitEthernet0/0/15] rsvp enable
[RouterC-Ten-GigabitEthernet0/0/15] quit
[RouterC] interface Ten-GigabitEthernet0/0/16
[RouterC-Ten-GigabitEthernet0/0/16] mpls enable
[RouterC-Ten-GigabitEthernet0/0/16] mpls te enable
[RouterC-Ten-GigabitEthernet0/0/16 rsvp enable
[RouterC-Ten-GigabitEthernet0/0/16] quit
[RouterD] mpls lsr-id 4.4.4.4
[RouterD] mpls te
[RouterD-te] quit
[RouterD] rsvp
[RouterD-rsvp] quit
[RouterD] interface Ten-GigabitEthernet0/0/15
[RouterD-Ten-GigabitEthernet0/0/15] mpls enable
[RouterD-Ten-GigabitEthernet0/0/15] mpls te enable
[RouterD-Ten-GigabitEthernet0/0/15] rsvp enable
[RouterD-Ten-GigabitEthernet0/0/15] quit
[RouterD] interface Ten-GigabitEthernet0/0/16
[RouterD-Ten-GigabitEthernet0/0/16] mpls enable
[RouterD-Ten-GigabitEthernet0/0/16] mpls te enable
[RouterD-Ten-GigabitEthernet0/0/16] rsvp enable
[RouterD-Ten-GigabitEthernet0/0/16] quit
4. Configure MPLS TE attributes of links:
# Configure the maximum link bandwidth and maximum reservable bandwidth on Router A.
[RouterA-Ten-GigabitEthernet0/0/15] mpls te max-link-bandwidth 50000
[RouterA-Ten-GigabitEthernet0/0/15] mpls te max-reservable-bandwidth 40000
[RouterA-Ten-GigabitEthernet0/0/16] mpls te max-link-bandwidth 50000
[RouterA-Ten-GigabitEthernet0/0/16] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth and maximum reservable bandwidth on Router B.
[RouterB-Ten-GigabitEthernet0/0/15] mpls te max-link-bandwidth 50000
[RouterB-Ten-GigabitEthernet0/0/15 mpls te max-reservable-bandwidth 40000
[RouterB-Ten-GigabitEthernet0/0/16] mpls te max-link-bandwidth 50000
[RouterB-Ten-GigabitEthernet0/0/16] mpls te max-reservable-bandwidth 40000
[RouterB-Ten-GigabitEthernet0/0/16 quit
# Configure the maximum link bandwidth and maximum reservable bandwidth on Router C.
[RouterC-Ten-GigabitEthernet0/0/15] mpls te max-link-bandwidth 50000
[RouterC-Ten-GigabitEthernet0/0/15] mpls te max-reservable-bandwidth 40000
[RouterC-Ten-GigabitEthernet0/0/16] mpls te max-link-bandwidth 50000
[RouterC-Ten-GigabitEthernet0/0/16] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth and maximum reservable bandwidth on Router D.
[RouterD-Ten-GigabitEthernet0/0/15] mpls te max-link-bandwidth 50000
[RouterD-Ten-GigabitEthernet0/0/15] mpls te max-reservable-bandwidth 40000
[RouterD-Ten-GigabitEthernet0/0/16] mpls te max-link-bandwidth 50000
[RouterD-Ten-GigabitEthernet0/0/16] mpls te max-reservable-bandwidth 40000
5. Configure OSPF TE to advertise link TE attributes:
# Enable opaque LSA advertisement and reception on Router A. By default, the opaque LSA advertisement and reception capability is enabled.
[RouterA] ospf
[RouterA-ospf-1] opaque-capability enable
# Enable MPLS TE for OSPF area 0 on Router A.
[RouterA-ospf-1-area-0.0.0.0] mpls te enable
# Enable opaque LSA advertisement and reception on Router B. By default, the opaque LSA advertisement and reception capability is enabled.
[RouterB] ospf
[RouterB-ospf-1] opaque-capability enable
# Enable MPLS TE for OSPF area 0 on Router B.
[RouterB-ospf-1-area-0.0.0.0] mpls te enable
# Enable opaque LSA advertisement and reception on Router C. By default, the opaque LSA advertisement and reception capability is enabled.
[RouterC] ospf
[RouterC-ospf-1] opaque-capability enable
# Enable MPLS TE for OSPF area 0 on Router C.
[RouterC-ospf-1-area-0.0.0.0] mpls te enable
# Enable opaque LSA advertisement and reception on Router D. By default, the opaque LSA advertisement and reception capability is enabled.
[RouterD] ospf
[RouterD-ospf-1] opaque-capability enable
# Enable MPLS TE for OSPF area 0 on Router D.
[RouterD-ospf-1-area-0.0.0.0] mpls te enable
6. Configure MPLS TE tunnels on Router A:
# Configure MPLS TE tunnel interface Tunnel 1 to forward traffic of Enterprise A.
[RouterA] interface tunnel 1 mode mpls-te
[RouterA-Tunnel1] ip address 7.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Router D, use RSVP-TE to establish the tunnel, and assign 20000 kbps bandwidth to the tunnel.
[RouterA-Tunnel1] destination 4.4.4.4
[RouterA-Tunnel1] mpls te signaling rsvp-te
[RouterA-Tunnel1] mpls te bandwidth 20000
# Enable route recording for MPLS TE tunnel 1.
[RouterA-Tunnel1] mpls te record-route
[RouterA-Tunnel1] quit
# Configure MPLS TE tunnel interface Tunnel 2 to forward traffic of Enterprise B.
[RouterA] interface tunnel 2 mode mpls-te
[RouterA-Tunnel2] ip address 8.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Router D, use RSVP-TE to establish the tunnel, and assign 30000 kbps bandwidth to the tunnel.
[RouterA-Tunnel2] destination 4.4.4.4
[RouterA-Tunnel2] mpls te signaling rsvp-te
[RouterA-Tunnel2] mpls te bandwidth 30000
# Enable route recording for MPLS TE tunnel 2.
[RouterA-Tunnel2] mpls te record-route
[RouterA-Tunnel2] quit
7. Configure static routing on Router A to direct traffic to the MPLS TE tunnels:
# Configure a static route to direct traffic destined for 50.1.1.0/24 to MPLS TE tunnel interface Tunnel 1.
[RouterA] ip route-static 50.1.1.0 24 tunnel 1 preference 1
# Configure a static route to direct traffic destined for 60.1.1.0/24 to MPLS TE tunnel interface Tunnel 2.
[RouterA] ip route-static 60.1.1.0 24 tunnel 2 preference 1
# Execute the display interface tunnel command on Router A. The output shows that the two tunnel interfaces are up.
[RouterA] display interface tunnel
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum Transmit Unit: 64000
Internet Address is 7.1.1.1/24 (primary)
Tunnel source unknown, destination 4.4.4.4
Tunnel TTL 255
Tunnel2
Current state: UP
Description: Tunnel2 Interface
Bandwidth: 64kbps
Internet Address is 8.1.1.1/24 (primary)
Tunnel TTL 255
# Execute the display mpls te tunnel-interface command on Router A to display detailed information about the MPLS TE tunnels.
[RouterA] display mpls te tunnel-interface
Tunnel Name : Tunnel 1
Tunnel State : Up (Main CRLSP up, Shared-resource CRLSP down)
Tunnel Attributes :
LSP ID : 46362 Tunnel ID : 1
Admin State : Normal
Ingress LSR ID : 1.1.1.1 Egress LSR ID : 4.4.4.4
Signaling : RSVP-TE Static CRLSP Name : -
Resv Style : SE
Tunnel mode : -
Reverse-LSP name : -
Class Type : CT0 Tunnel Bandwidth : 20000 kbps
Reserved Bandwidth : 20000 kbps
Setup Priority : 7 Holding Priority : 7
Affinity Attr/Mask : 0/0
Explicit Path : -
Backup Explicit Path : -
Metric Type : TE
Record Route : Enabled Record Label : Disabled
FRR Flag : Disabled Bandwidth Protection : Disabled
Backup Bandwidth Flag: Disabled Backup Bandwidth Type: -
Backup Bandwidth : -
Bypass Tunnel : No Auto Created : No
Route Pinning : Disabled
Retry Limit : 3 Retry Interval : 2 sec
Reoptimization : Disabled Reoptimization Freq : -
Backup Type : None Backup LSP ID : -
Auto Bandwidth : Disabled Auto Bandwidth Freq : -
Collected Bandwidth : - Service-Class : -
Traffic Policy : Disable
Last Down Reason : Admin Down
Down Time : 2017-12-05 11:23:35:535
Tunnel Name : Tunnel 2
Tunnel Attributes :
LSP ID : 46362 Tunnel ID : 2
Resv Style : SE
Tunnel mode : -
Class Type : CT0 Tunnel Bandwidth : 30000 kbps
Reserved Bandwidth : 30000 kbps
Explicit Path : -
Metric Type : TE
# Execute the display ip routing-table command on Router A. The output shows two static route entries with output interfaces of Tunnel 1 and Tunnel 2.
Destinations : 30 Routes : 30
7.1.1.0/24 Direct 0 0 7.1.1.1 Tun1
7.1.1.0/32 Direct 0 0 7.1.1.1 Tun1
7.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
7.1.1.255/32 Direct 0 0 7.1.1.1 Tun1
8.1.1.0/24 Direct 0 0 8.1.1.1 Tun2
8.1.1.0/32 Direct 0 0 8.1.1.1 Tun2
8.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
8.1.1.255/32 Direct 0 0 8.1.1.1 Tun2
50.1.1.0/24 Static 1 0 0.0.0.0 Tun1
60.1.1.0/24 Static 1 0 0.0.0.0 Tun2
# Execute the display rsvp lsp verbose command on Router A to verify the following information:
· Tunnel 1 uses path Router A—Router B—Router D, and has a bandwidth of 20000 kbps.
· Tunnel 2 uses path Router A—Router C—Router D, and has a bandwidth of 30000 kbps.
[RouterA] display rsvp lsp verbose
Tunnel name: RouterA_t1
Destination: 4.4.4.4 Source: 1.1.1.1
Tunnel ID: 1 LSP ID: 46362
LSR type: Ingress Direction: Unidirectional
Setup priority: 7 Holding priority: 7
In-Label: - Out-Label: 1150
In-Interface: - Out-Interface: XGE0/0/15
Nexthop: 10.1.1.2 Exclude-any: 0
Include-Any: 0 Include-all: 0
Mean rate (CIR): 20000 kbps Mean burst size (CBS): 1000.00 bytes
Path MTU: 1500 Class type: CT0
RRO number: 6
10.1.1.1/32 Flag: 0x00 (No FRR)
10.1.1.2/32 Flag: 0x40 (No FRR/In-Int)
2.2.2.2/32 Flag: 0x20 (No FRR/Node-ID)
20.1.1.2/32 Flag: 0x00 (No FRR)
20.1.1.4/32 Flag: 0x40 (No FRR/In-Int)
4.4.4.4/32 Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: None
Tunnel name: RouterA_t2
Tunnel ID: 2 LSP ID: 46362
In-Interface: - Out-Interface: XGE0/0/16
Nexthop: 30.1.1.3 Exclude-any: 0
Mean rate (CIR): 30000 kbps Mean burst size (CBS): 1000.00 bytes
RRO number: 6
30.1.1.1/32 Flag: 0x00 (No FRR)
30.1.1.3/32 Flag: 0x40 (No FRR/In-Int)
3.3.3.3/32 Flag: 0x20 (No FRR/Node-ID)
40.1.1.3/32 Flag: 0x00 (No FRR)
40.1.1.4/32 Flag: 0x40 (No FRR/In-Int)
Configuration files
· Router A:
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 1.1.1.1
mpls te
rsvp
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
port link-mode route
mpls enable
mpls te enable
rsvp enable
ip address 30.1.1.1 255.255.255.0
mpls enable
mpls te enable
rsvp enable
interface Tunnel1 mode mpls-te
mpls te bandwidth ct0 20000
destination 4.4.4.4
interface Tunnel2 mode mpls-te
mpls te bandwidth ct0 30000
destination 4.4.4.4
ip route-static 50.1.1.0 24 Tunnel1 preference 1
ip route-static 60.1.1.0 24 Tunnel2 preference 1
· Router B:
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 2.2.2.2
mpls te
rsvp
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
mpls enable
mpls te enable
rsvp enable
ip address 20.1.1.2 255.255.255.0
mpls enable
mpls te enable
rsvp enable
· Router C:
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 3.3.3.3
mpls te
rsvp
interface LoopBack0
ip address 3.3.3.3 255.255.255.0
ip address 40.1.1.3 255.255.255.0
mpls enable
mpls te enable
rsvp enable
ip address 30.1.1.3 255.255.255.0
mpls enable
mpls te enable
rsvp enable
· Router D:
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 4.4.4.4
mpls te
rsvp
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
ip address 40.1.1.4 255.255.255.0
mpls enable
mpls te enable
rsvp enable
ip address 20.1.1.4 255.255.255.0
mpls enable
mpls te enable
rsvp enable
As shown in Figure 4, on the primary CRLSP Router A—Router B—Router C—Router D, configure MPLS TE FRR to protect the link Router B—Router C. When the link between Router B and Router C fails, MPLS TE can immediately switch traffic to the bypass tunnel Router B—Router E—Router C.
The primary CRLSP and the bypass tunnel each require a bandwidth of 30000 kbps. The maximum bandwidth of the link that each tunnel traverses is 50000 kbps. The maximum reservable bandwidth of each link is 40000 kbps.
Analysis
To implement MPLS TE FRR, you must perform the following tasks:
· Enable MPLS, MPLS TE, and RSVP-TE on each router for primary and bypass tunnel establishment.
· Configure explicit paths for the primary CRLSP and the bypass tunnel as required.
· Configure BFD for RSVP-TE on Router B and Router C for quick detection of the link failure.
BFD can immediately detect the failure of the protected link and notify RSVP-TE of the failure.
· Configure MPLS TE FRR on the ingress node of the primary CRLSP to ensure that traffic can be immediately switched to the bypass tunnel when BFD detects the failure of the protected link.
When you configure MPLS TE FRR, follow these restrictions and guidelines:
· Only MPLS TE tunnels established through RSVP-TE support FRR.
· Do not configure both FRR and RSVP authentication on the same interface.
· Use bypass tunnels to protect only critical interfaces or links when bandwidth is insufficient. Bypass tunnels are pre-established and require extra bandwidth.
· Make sure the bandwidth assigned to the bypass tunnel is no less than the total bandwidth needed by all primary CRLSPs to be protected by the bypass tunnel. Otherwise, some primary CRLSPs might not be protected by the bypass tunnel.
· A bypass tunnel typically does not forward data when the primary CRLSP operates correctly. For a bypass tunnel to also forward data during tunnel protection, you must assign enough bandwidth to the bypass tunnel.
· A bypass tunnel cannot be used for services such as VPN.
· You cannot configure FRR for a bypass tunnel. A bypass tunnel cannot act as a primary CRLSP.
· Make sure the protected node or interface is not on the bypass tunnel.
· After an FRR, the primary CRLSP will be down if the FRR protection type (whether or not to provide bandwidth protection for the primary CRLSP) is changed.
Procedures
Configure IP addresses and masks for interfaces on Router A, including the loopback interface, as shown in Figure 4. (Details not shown.)
[RouterA] ospf
[RouterA-ospf-1-area-0.0.0.0] network 2.1.1.0 0.0.0.255
[RouterB] ospf
[RouterB-ospf-1-area-0.0.0.0] network 2.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 3.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 3.2.1.0 0.0.0.255
[RouterC] ospf
[RouterC-ospf-1-area-0.0.0.0] network 3.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 3.3.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 4.1.1.0 0.0.0.255
[RouterD] ospf
[RouterD-ospf-1-area-0.0.0.0] network 4.1.1.0 0.0.0.255
# Configure Router E.
<RouterE> System-view
[RouterE] ospf
[RouterE-ospf-1] area 0
[RouterE-ospf-1-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[RouterE-ospf-1-area-0.0.0.0] network 3.2.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] network 3.3.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] quit
[RouterE-ospf-1] quit
# Execute the display ip routing-table command on each router to verify that the routers have learned the routes to one another, including the routes to the loopback interfaces. The following shows the output on Router A:
Destinations : 19 Routes : 19
2.1.1.0/24 Direct 0 0 2.1.1.1 XGE0/0/15
2.1.1.0/32 Direct 0 0 2.1.1.1 XGE0/0/15
2.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
2.1.1.255/32 Direct 0 0 2.1.1.1 XGE0/0/15
2.2.2.2/32 O_INTRA 10 1 2.1.1.2 XGE0/0/15
3.1.1.0/24 O_INTRA 10 2 2.1.1.2 XGE0/0/15
3.2.1.0/24 O_INTRA 10 2 2.1.1.2 XGE0/0/15
3.3.1.0/24 O_INTRA 10 3 2.1.1.2 XGE0/0/15
3.3.3.3/32 O_INTRA 10 2 2.1.1.2 XGE0/0/15
5.5.5.5/32 O_INTRA 10 2 2.1.1.2 XGE0/0/15
3. Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each router. Enable BFD for RSVP-TE on Router B and Router C:
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterA-Ten-GigabitEthernet0/0/15] mpls enable
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterB-Ten-GigabitEthernet0/0/16] rsvp bfd enable
[RouterB] interface Ten-GigabitEthernet0/0/17
[RouterB-Ten-GigabitEthernet0/0/17] mpls enable
[RouterB-Ten-GigabitEthernet0/0/17] mpls te enable
[RouterB-Ten-GigabitEthernet0/0/17] rsvp enable
[RouterB-Ten-GigabitEthernet0/0/17] quit
[RouterC] mpls te
[RouterC-te] quit
[RouterC] rsvp
[RouterC-rsvp] quit
[RouterC-Ten-GigabitEthernet0/0/15] mpls te enable
[RouterC-Ten-GigabitEthernet0/0/16] rsvp enable
[RouterC-Ten-GigabitEthernet0/0/16] rsvp bfd enable
[RouterC] interface Ten-GigabitEthernet0/0/17
[RouterC-Ten-GigabitEthernet0/0/17] mpls enable
[RouterC-Ten-GigabitEthernet0/0/17] mpls te enable
[RouterC-Ten-GigabitEthernet0/0/17] rsvp enable
[RouterC-Ten-GigabitEthernet0/0/17] quit
[RouterD] mpls te
[RouterD-te] quit
[RouterD] rsvp
[RouterD-rsvp] quit
[RouterE] mpls lsr-id 5.5.5.5
[RouterE] mpls te
[RouterE-te] quit
[RouterE] rsvp
[RouterE-rsvp] quit
[RouterE] interface Ten-GigabitEthernet0/0/15
[RouterE-Ten-GigabitEthernet0/0/15] mpls enable
[RouterE-Ten-GigabitEthernet0/0/15] mpls te enable
[RouterE-Ten-GigabitEthernet0/0/15] rsvp enable
[RouterE-Ten-GigabitEthernet0/0/15] quit
[RouterE] interface Ten-GigabitEthernet0/0/16
[RouterE-Ten-GigabitEthernet0/0/16] mpls enable
[RouterE-Ten-GigabitEthernet0/0/16] mpls te enable
[RouterE-Ten-GigabitEthernet0/0/16] rsvp enable
[RouterE-Ten-GigabitEthernet0/0/16] quit
# Configure the maximum link bandwidth on Router A.
# Configure the maximum link bandwidth on Router B.
[RouterB-Ten-GigabitEthernet0/0/15] mpls te max-reservable-bandwidth 40000
[RouterB-Ten-GigabitEthernet0/0/17] mpls te max-link-bandwidth 50000
[RouterB-Ten-GigabitEthernet0/0/17] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth on Router C.
[RouterC-Ten-GigabitEthernet0/0/17] mpls te max-link-bandwidth 50000
[RouterC-Ten-GigabitEthernet0/0/17] mpls te max-reservable-bandwidth 40000
# Configure the maximum link bandwidth on Router D.
# Configure the maximum link bandwidth on Router E.
[RouterE-Ten-GigabitEthernet0/0/15] mpls te max-link-bandwidth 50000
[RouterE-Ten-GigabitEthernet0/0/15] mpls te max-reservable-bandwidth 40000
[RouterE-Ten-GigabitEthernet0/0/16] mpls te max-link-bandwidth 50000
[RouterE-Ten-GigabitEthernet0/0/16] mpls te max-reservable-bandwidth 40000
[RouterA] ospf
[RouterB] ospf
[RouterC] ospf
[RouterD] ospf
# Enable opaque LSA advertisement and reception on Router E. By default, the opaque LSA advertisement and reception capability is enabled.
[RouterE] ospf
[RouterE-ospf-1] opaque-capability enable
# Enable MPLS TE for OSPF area 0 on Router E.
[RouterE-ospf-1-area-0.0.0.0] mpls te enable
6. Configure an MPLS TE tunnel on Router A (the ingress node of the primary CRLSP):
# Configure an explicit path named pri-path for the primary CRLSP.
[RouterA] explicit-path pri-path
[RouterA-explicit-path-pri-path] nexthop 2.1.1.2
[RouterA-explicit-path-pri-path] nexthop 3.1.1.3
[RouterA-explicit-path-pri-path] nexthop 4.1.1.4
[RouterA-explicit-path-pri-path] nexthop 4.4.4.4
[RouterA-explicit-path-pri-path] quit
# Configure MPLS TE tunnel interface Tunnel 4 for the primary CRLSP.
[RouterA] interface tunnel4 mode mpls-te
[RouterA-Tunnel4] ip address 10.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Router D, configure MPLS TE to use RSVP-TE to establish the tunnel, and assign 30000 kbps bandwidth to the tunnel.
[RouterA-Tunnel4] destination 4.4.4.4
[RouterA-Tunnel4] mpls te signaling rsvp-te
[RouterA-Tunnel4] mpls te bandwidth 30000
# Specify the explicit path to be used as pri-path.
[RouterA-Tunnel4] mpls te path preference 1 explicit-path pri-path
# Enable FRR for the MPLS TE tunnel.
[RouterA-Tunnel4] mpls te fast-reroute
[RouterA-Tunnel4] quit
# Execute the display interface tunnel command on Router A. The output shows that tunnel interface Tunnel 4 is up.
Tunnel4
Current state: UP
Description: Tunnel4 Interface
Bandwidth: 64kbps
Internet Address is 10.1.1.1/24 (primary)
Tunnel TTL 255
# Execute the display mpls te tunnel-interface command on Router A to display detailed information about the MPLS TE tunnel.
Tunnel Name : Tunnel 4
Tunnel Attributes :
LSP ID : 37325 Tunnel ID : 4
Resv Style : SE
Tunnel mode : -
Explicit Path : pri-path
Metric Type : TE
Record Route : Enabled Record Label : Enabled
FRR Flag : Enabled Bandwidth Protection : Disabled
7. Configure a bypass tunnel on Router B (the PLR):
# Configure an explicit path named by-path for the bypass tunnel.
[RouterB] explicit-path by-path
[RouterB-explicit-path-by-path] nexthop 3.2.1.5
[RouterB-explicit-path-by-path] nexthop 3.3.1.3
[RouterB-explicit-path-by-path] nexthop 3.3.3.3
[RouterB-explicit-path-by-path] quit
# Configure MPLS TE tunnel interface Tunnel 5 for the bypass tunnel.
[RouterB] interface tunnel 5 mode mpls-te
[RouterB-Tunnel5] ip address 11.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Router C and configure MPLS TE to use RSVP-TE to establish the tunnel.
[RouterB-Tunnel5] destination 3.3.3.3
[RouterB-Tunnel5] mpls te signaling rsvp-te
# Set the bandwidth that the bypass tunnel can protect to 30000 kbps.
[RouterB-Tunnel5] mpls te backup bandwidth 30000
# Specify the explicit path to be used as by-path.
[RouterB-Tunnel5] mpls te path preference 1 explicit-path by-path
[RouterB-Tunnel5] quit
# Bind the bypass tunnel to the protected interface.
[RouterB-Ten-GigabitEthernet0/0/16] mpls te fast-reroute bypass-tunnel tunnel 5
# Execute the display interface tunnel command on Router B. The output shows that tunnel interface Tunnel 5 is up.
[RouterB] display interface tunnel
Tunnel5
Current state: UP
Line protocol state: DOWN
Description: Tunnel5 Interface
Bandwidth: 64kbps
Internet Address is 11.1.1.1/24 (primary)
Tunnel source unknown, destination 3.3.3.3
Tunnel TTL 255
8. Configure a static route on Router A to direct traffic destined for 4.1.1.0/24 to MPLS TE tunnel interface Tunnel 4.
[RouterA] ip route-static 4.1.1.0 24 tunnel 4 preference 1
# Execute the display mpls lsp command on each Router. The output shows the LSP entries. Router B has two CRLSPs. The bypass tunnel backs up the primary CRLSP.
[RouterA] display mpls lsp
FEC Proto In/Out Label Interface/Out NHLFE
1.1.1.1/4/37325 RSVP -/1150 XGE0/0/15
2.1.1.2 Local -/- XGE0/0/15
Tunnel4 Local -/- NHLFE1026
[RouterB] display mpls lsp
1.1.1.1/4/37325 RSVP 1150/1147 XGE0/0/16
Backup 1150/1147 Tun5
2.2.2.2/5/18928 RSVP -/1149 XGE0/0/17
3.1.1.3 Local -/- XGE0/0/16
3.2.1.5 Local -/- XGE0/0/17
Tunnel5 Local -/- NHLFE1027
[RouterC] display mpls lsp
1.1.1.1/4/37325 RSVP 1147/3 XGE0/0/15
2.2.2.2/5/18928 RSVP 3/- -
4.1.1.4 Local -/- XGE0/0/15
# Shut down the protected interface Ten-GigabitEthernet 0/0/16 on the PLR (Router B).
[RouterB-Ten-GigabitEthernet0/0/16] shutdown
# Execute the display interface tunnel 4 command on Router A to display information about the primary CRLSP. The output shows that the tunnel interface is still up.
[RouterA] display interface tunnel 4
Tunnel4
Current state: UP
Bandwidth: 64kbps
Tunnel TTL 255
# Execute the display mpls te tunnel-interface command on Router A to display detailed information about the tunnel interface.
Tunnel State : Up (Main CRLSP up, Shared-resource CRLSP being set up)
Tunnel Attributes :
Resv Style : SE
Tunnel mode : -
Metric Type : TE
# Execute the display mpls lsp command on Router B. The output shows that the bypass tunnel is in use.
1.1.1.1/4/37325 RSVP 1150/1147 Tun5
# On the PLR, configure the interval for selecting an optimal bypass tunnel as 5 seconds.
[RouterB] mpls te
[RouterB-te] fast-reroute timer 5
[RouterB-te] quit
# On the PLR, bring up the protected interface Ten-GigabitEthernet 0/0/16.
[RouterB-Ten-GigabitEthernet0/0/16] undo shutdown
# Execute the display interface tunnel 4 command on Router A to display information about the primary CRLSP. The output shows that the tunnel interface is in up state.
Tunnel4
Current state: UP
Bandwidth: 64kbps
Tunnel TTL 255
# Wait for about 5 seconds, execute the display mpls lsp verbose command on Router B. The output shows that Tunnel 5 is bound to interface Ten-GigabitEthernet 0/0/16, but it is not in use.
[RouterB] display mpls lsp verbose
Destination : 4.4.4.4
FEC : 1.1.1.1/4/53319
Protocol : RSVP
LSR Type : Transit
Service : -
In-Label : 1150
Path ID : 0x540000003.1
State : Active
Out-Label : 1150
Nexthop : 3.1.1.3
BkLabel : 1150
BkInterface : Tun5
Destination : 3.3.3.3
FEC : 2.2.2.2/5/16429
Protocol : RSVP
LSR Type : Ingress
Service : -
NHLFE ID : 1025
State : Active
Out-Label : 1151
Nexthop : 3.2.1.5
Out-Interface: XGE0/0/17
Destination : 3.1.1.3
FEC : 3.1.1.3
Protocol : Local
LSR Type : Ingress
Service : -
NHLFE ID : 1027
State : Active
Nexthop : 3.1.1.3
Destination : 3.2.1.5
FEC : 3.2.1.5
Protocol : Local
LSR Type : Ingress
Service : -
NHLFE ID : 1024
State : Active
Nexthop : 3.2.1.5
FEC : Tunnel5
Protocol : Local
LSR Type : Ingress
Service : -
NHLFE ID : 268435461
State : Active
Out-Interface: NHLFE1025
# Execute the display ip routing-table command on Router A. The output shows a static route entry with interface Tunnel 4 as the output interface.
Destinations : 25 Routes : 25
4.1.1.0/24 Static 1 0 0.0.0.0 Tun4
4.4.4.4/32 O_INTRA 10 3 2.1.1.2 XGE0/0/15
10.1.1.0/24 Direct 0 0 10.1.1.1 Tun4
10.1.1.0/32 Direct 0 0 10.1.1.1 Tun4
10.1.1.255/32 Direct 0 0 10.1.1.1 Tun4
Configuration files
· Router A
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 1.1.1.1
mpls te
nexthop index 1 2.1.1.2 include strict
nexthop index 101 3.1.1.3 include strict
nexthop index 201 4.1.1.4 include strict
nexthop index 301 4.4.4.4 include strict
rsvp
interface LoopBack0
ip address 2.1.1.1 255.255.255.0
mpls enable
mpls te enable
rsvp enable
interface Tunnel4 mode mpls-te
destination 4.4.4.4
ip route-static 4.1.1.0 24 Tunnel4 preference 1
· Router B
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 2.2.2.2
mpls te
nexthop index 1 3.2.1.5 include strict
nexthop index 101 3.3.1.3 include strict
nexthop index 201 3.3.3.3 include strict
rsvp
interface LoopBack0
ip address 2.1.1.2 255.255.255.0
mpls enable
mpls te enable
rsvp enable
ip address 3.1.1.2 255.255.255.0
mpls enable
mpls te enable
mpls te fast-reroute bypass-tunnel Tunnel5
rsvp enable
rsvp bfd enable
ip address 3.2.1.2 255.255.255.0
mpls enable
mpls te enable
rsvp enable
interface Tunnel5 mode mpls-te
mpls te backup bandwidth ct0 30000
destination 3.3.3.3
· Router C
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 3.3.3.3
mpls te
rsvp
interface LoopBack0
ip address 3.3.3.3 255.255.255.255
ip address 4.1.1.3 255.255.255.0
mpls enable
mpls te enable
rsvp enable
ip address 3.1.1.3 255.255.255.0
mpls enable
mpls te enable
rsvp enable
rsvp bfd enable
ip address 3.3.1.3 255.255.255.0
mpls enable
mpls te enable
rsvp enable
· Router D
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 4.4.4.4
mpls te
rsvp
interface LoopBack0
ip address 4.1.1.4 255.255.255.0
mpls enable
mpls te enable
rsvp enable
· Router E
ospf 1
area 0.0.0.0
mpls te enable
mpls lsr-id 5.5.5.5
mpls te
rsvp
interface LoopBack0
ip address 5.5.5.5 255.255.255.255
ip address 3.2.1.5 255.255.255.0
mpls enable
mpls te enable
rsvp enable
ip address 3.3.1.5 255.255.255.0
mpls enable
mpls te enable
rsvp enable
Related documentation
· H3C CR16000-M1A MPLS Configuration Guide
· H3C CR16000-M1A MPLS Command Reference
