- 02-Configuration Examples
- 01-H3C_AAA_Configuration_Examples
- 02-H3C_ACL_Configuration_Examples
- 03-H3C_IGMP_Configuration_Examples
- 04-H3C_IP_Source_Guard_Configuration_Examples
- 05-H3C_Ethernet_OAM_Configuration_Examples
- 06-H3C_NQA_Configuration_Examples
- 07-H3C_QinQ_Configuration_Examples
- 08-H3C_OSPF_Configuration_Examples
- 09-H3C_MPLS_TE_Configuration_Examples
- 10-H3C_OpenFlow_Configuration_Examples
- 11-H3C_NAT_Configuration_Examples
- 12-H3C_RBAC_Configuration_Examples
- 13-H3C_DHCP_Relay_Redundancy_Configuration_Examples
- 14-H3C_DLDP_Configuration_Examples
- 15-H3C_IS-IS_Configuration_Examples
- 16-H3C_MPLS_L3VPN_Configuration_Examples
- 17-H3C_SSH_Configuration_Examples
- 18-H3C_Login_Management_Configuration_Examples
- 19-H3C_SNMP_Configuration_Examples
- 20-H3C_Priority_Marking_and_Queue_Scheduling_Configuration_Examples
- 21-H3C_Multicast_VPN_Configuration_Examples
- 22-H3C_BGP_Configuration_Examples
- 23-H3C_HoVPN_Configuration_Examples
- 24-H3C_L2TP_Configuration_Examples
- 25-H3C_VRRP_Configuration_Examples
- 26-H3C_Traffic_Filtering_Configuration_Examples
- 27-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
- 28-H3C_MPLS_L2VPN_Configuration_Examples
- 29-H3C_NetStream_Configuration_Examples
- 30-H3C_Policy-Based_Routing_Configuration_Examples
- 31-H3C_Traffic_Policing_Configuration_Examples
- 32-H3C_BFD_Configuration_Examples
- 33-H3C_OSPFv3_Configuration_Examples
- 34-H3C_VPLS_Configuration_Examples
- 35-H3C_GTS_and_Rate_Limiting_Configuration_Examples
- 36-H3C_IPv6_IS-IS_Configuration_Examples
- 37-H3C_MPLS OAM_Configuration_Examples
- 38-H3C_BGP_Route_Selection_Configuration_Examples
- 39-H3C_IS-IS_Route_Summarization_Configuration_Examples
- 40-H3C_SRv6 Configuration Examples
- 41-H3C_Attack_Protection_Configuration_Examples
- 42-H3C_OSPF_Multi-Process_Configuration_Examples
- 43-H3C_OSPF_with_Multi-Instance_Configuration_Examples
- 44-H3C_ARP_Attack_Protection_Configuration_Examples
- 45-H3C_DHCPv6_Server_and_DHCPv6_Prefix_Client_Configuration_Examples
- 46-General QoS Configuration Examples
- 47-GRE Tunnel Establishment Using OSPF Configuration Examples
- 48-GRE Tunnel Establishment Using Static Routes Configuration Examples
- 49-QoS Configuration Examples for the Financial Industry
| 28-H3C_MPLS_L2VPN_Configuration_Examples | 259.60 KB |
Introduction
This document provides MPLS L2VPN configuration examples.
MPLS L2VPN is an MPLS-based Layer 2 VPN technology. It can transparently transmit Layer 2 data for different data link layer protocols over an MPLS network.
MPLS L2VPN can be implemented through the following PWs:
· LDP PWs.
· BGP PWs.
This document assumes that you have basic knowledge of MPLS L2VPN.
Example: Configuring LDP PWs
As shown in Figure 1, the MPLS network provides L2VPN services for a customer. Configure LDP PWs between PE 1 and PE 2 so the R&D and Marketing departments use different VPN connections to achieve data isolation.
Analysis
To use LDP PWs to implement MPLS L2VPN, configure two levels of labels:
· Inner labels—PW labels dynamically generated by LDP.
· Outer labels—Public tunnel labels dynamically generated by LDP in this example.
To identify packets to be transported by MPLS L2VPN, configure subinterfaces on the CE-facing ports of PEs.
Procedures
1. Configure OSPF on the MPLS backbone to ensure IP connectivity within the backbone:
# On PE 1, configure an IP address for Loopback 0.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
# On PE 1, configure an IP address for Ten-GigabitEthernet 0/0/16.
[PE1] interface Ten-GigabitEthernet0/0/16
[PE1-Ten-GigabitEthernet0/0/16] ip address 10.1.1.1 24
[PE1-Ten-GigabitEthernet0/0/16] quit
# On PE 1, configure OSPF.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# On P, configure an IP address for Loopback 0.
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
# On P, configure an IP address for Ten-GigabitEthernet 0/0/15.
[P] interface Ten-GigabitEthernet0/0/15
[P-Ten-GigabitEthernet0/0/15] ip address 10.1.2.1 24
[P-Ten-GigabitEthernet0/0/15] quit
# On P, configure an IP address for Ten-GigabitEthernet 0/0/16.
[P] interface Ten-GigabitEthernet0/0/16
[P-Ten-GigabitEthernet0/0/16] ip address 10.1.1.2 24
[P-Ten-GigabitEthernet0/0/16] quit
# On P, configure OSPF.
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# On PE 2, configure an IP address for Loopback 0.
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
# On PE 2, configure an IP address for Ten-GigabitEthernet 0/0/16.
[PE2] interface Ten-GigabitEthernet 0/0/16
[PE2-Ten-GigabitEthernet0/0/16] ip address 10.1.2.2 24
[PE2-Ten-GigabitEthernet0/0/16] quit
# On PE 2, configure OSPF.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
2. Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# On PE 1, configure an LSR ID.
[PE1] mpls lsr-id 1.1.1.9
# On PE 1, enable LDP globally.
[PE1] mpls ldp
[PE1-ldp] quit
# On PE 1, enable MPLS and LDP on Ten-GigabitEthernet 0/0/16.
[PE1] interface Ten-GigabitEthernet 0/0/16
[PE1-Ten-GigabitEthernet 0/0/16] mpls enable
[PE1-Ten-GigabitEthernet 0/0/16] mpls ldp enable
[PE1-Ten-GigabitEthernet 0/0/16] quit
# On P, configure an LSR ID.
[P] mpls lsr-id 2.2.2.9
# On P, enable LDP globally.
[P] mpls ldp
[P-ldp] quit
# On P, enable MPLS and LDP on Ten-GigabitEthernet 0/0/15.
[P-Ten-GigabitEthernet0/0/15] mpls enable
# On P, enable MPLS and LDP on Ten-GigabitEthernet 0/0/16.
[P-Ten-GigabitEthernet0/0/16] mpls enable
# On PE 2, configure an LSR ID.
[PE2] mpls lsr-id 3.3.3.9
# On PE 2, enable LDP globally.
[PE2] mpls ldp
[PE2-ldp] quit
# On PE 2, enable MPLS and LDP on Ten-GigabitEthernet 0/0/16.
[PE2-Ten-GigabitEthernet0/0/16] mpls enable
[PE2-Ten-GigabitEthernet0/0/16] mpls ldp enable
3. Configure a subinterface for each department and bind the subinterfaces to their respective VPN connections:
# On PE 1, enable MPLS L2VPN globally.
[PE1] l2vpn enable
# On PE 1, create subinterfaces Ten-GigabitEthernet 0/0/15.100 and Ten-GigabitEthernet 0/0/15.200.
[PE1] interface Ten-GigabitEthernet 0/0/15.100
[PE1-Ten-GigabitEthernet0/0/15.100] vlan-type dot1q vid 100
[PE1-Ten-GigabitEthernet0/0/15.100] quit
[PE1] interface Ten-GigabitEthernet 0/0/15.200
[PE1-Ten-GigabitEthernet0/0/15.200] vlan-type dot1q vid 200
[PE1-Ten-GigabitEthernet0/0/15.200] quit
# On PE 1, create cross-connect group vpna, create cross-connect ldp in the group, and bind Ten-GigabitEthernet0/0/15.100 to the cross-connect.
[PE1] xconnect-group vpna
[PE1-xcg-vpna] connection ldp
[PE1-xcg-vpna-ldp] ac interface Ten-GigabitEthernet 0/0/15.100
[PE1-xcg-vpna-ldp-Ten-GigabitEthernet0/0/15.100] quit
[PE1-xcg-vpna-ldp] peer 3.3.3.9 pw-id 100
[PE1-xcg-vpna-ldp-3.3.3.9-100] quit
[PE1-xcg-vpna-ldp] quit
[PE1-xcg-vpna] quit
# On PE 1, create cross-connect group vpnb, create cross-connect ldp in the group, and bind Ten-GigabitEthernet 0/0/15.200 to the cross-connect.
[PE1] xconnect-group vpnb
[PE1-xcg-vpnb] connection ldp
[PE1-xcg-vpnb-ldp] ac interface Ten-GigabitEthernet 0/0/15.200
[PE1-xcg-vpnb-ldp] peer 3.3.3.9 pw-id 200
[PE1-xcg-vpnb-ldp-3.3.3.9-200] quit
[PE1-xcg-vpnb-ldp] quit
[PE1-xcg-vpnb] quit
# On PE 2, enable MPLS L2VPN globally.
[PE2] l2vpn enable
# On PE 2, create subinterfaces Ten-GigabitEthernet 0/0/15.100 and Ten-GigabitEthernet 0/0/15.200.
[PE2] interface Ten-GigabitEthernet 0/0/15.100
[PE2-Ten-GigabitEthernet0/0/15.100] vlan-type dot1q vid 100
[PE2-Ten-GigabitEthernet0/0/15.100] quit
[PE2] interface Ten-GigabitEthernet 0/0/15.200
[PE2-Ten-GigabitEthernet0/0/15.200] vlan-type dot1q vid 200
[PE2-Ten-GigabitEthernet0/0/15.200] quit
# On PE 2, create cross-connect group vpna, create cross-connect ldp in the group, and bind Ten-GigabitEthernet 0/0/15.100 to the cross-connect.
[PE2] xconnect-group vpna
[PE2-xcg-vpna] connection ldp
[PE2-xcg-vpna-ldp] ac interface Ten-GigabitEthernet 0/0/15.100
[PE2-xcg-vpna-ldp-Ten-GigabitEthernet0/0/15.100] quit
# On PE 2, create an LDP PW for the cross-connect to bind the AC to the PW.
[PE2-xcg-vpna-ldp] peer 1.1.1.9 pw-id 100
[PE2-xcg-vpna-ldp-1.1.1.9-100] quit
[PE2-xcg-vpna-ldp] quit
[PE2-xcg-vpna] quit
# On PE 2, create cross-connect group vpnb, create cross-connect ldp in the group, and bind Ten-GigabitEthernet 0/0/15.200 to the cross-connect.
[PE2] xconnect-group vpnb
[PE2-xcg-vpnb] connection ldp
[PE2-xcg-vpnb-ldp] ac interface Ten-GigabitEthernet 0/0/15.200
[PE2-xcg-vpna-ldp-Ten-GigabitEthernet0/0/15.200] quit
[PE2-xcg-vpnb-ldp] peer 1.1.1.9 pw-id 200
[PE2-xcg-vpnb-ldp-1.1.1.9-200] quit
[PE2-xcg-vpnb-ldp] quit
[PE2-xcg-vpnb] quit
4. Allow CE access to PEs:
# On CE 1, configure the interface connected to the PE to permit tagged packets from the customer VLANs.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
[CE1] vlan 200
[CE1-vlan200] quit
[CE1] interface Ten-GigabitEthernet 0/0/15
[CE1-Ten-GigabitEthernet0/0/15] port link-type trunk
[CE1-Ten-GigabitEthernet0/0/15] port trunk permit vlan 100 200
# Configure other CEs in the same way that CE 1 is configured. (Details not shown.)
# Display L2VPN PW information on PE 1. The output shows that two LDP PWs have been established.
[PE1] display l2vpn pw
N - no split horizon, A - administration, ABY – ac-bypass
PBY – pw-bypass
Total number of PWs: 2
2 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
Xconnect-group Name: vpna
Peer PWID/RmtSite/SrvID In/Out Label Proto Flag Link ID State
3.3.3.9 100 65663/65663 LDP M 1 Up
Xconnect-group Name: vpnb
3.3.3.9 200 65662/65662 LDP M 1 Up
# Display L2VPN PW information on PE 2. The output shows that two LDP PWs have been established.
[PE2] display l2vpn pw
PBY – pw-bypass
1.1.1.9 100 65663/65663 LDP M 1 Up
1.1.1.9 200 65662/65662 LDP M 1 Up
# Verify that the host and the server in the same VLAN can ping each other. (Details not shown.)
Configuration files
· CE 1 and CE 2:
vlan 100
vlan 200
port link-mode bridge
port trunk permit vlan 1 100 200
· PE 1:
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
l2vpn enable
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
port link-mode route
interface Ten-GigabitEthernet0/0/15.100
interface Ten-GigabitEthernet0/0/15.200
mpls enable
mpls ldp enable
xconnect-group vpna
connection ldp
ac interface Ten-GigabitEthernet0/0/15.100
xconnect-group vpnb
connection ldp
ac interface Ten-GigabitEthernet0/0/15.200
· P:
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
ip address 10.1.2.1 255.255.255.0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
· PE 2:
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
l2vpn enable
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
ip address 10.1.2.2 255.255.255.0
mpls enable
mpls ldp enable
xconnect-group vpna
connection ldp
xconnect-group vpnb
connection ldp
Example: Configuring a BGP PW
As shown in Figure 2, a customer has two VPN sites and will add eight sites in the future. Configure a BGP PW between PE 1 and PE 2 to allow VPN communication between the two sites and reserve enough VPN resources for future extension.
Analysis
To use BGP PWs to implement MPLS L2VPN, configure two levels of labels:
· Inner labels—PW labels dynamically generated by BGP.
To use BGP to transmit inner labels between PEs, create a subinterface and an IBGP connection, and specify the peer PE as a BGP peer on each PE.
To simplify configuration required by future expansion of the customer network, set the maximum number of CEs in the VPN to 10.
Procedures
<PE1> system-view
[PE1-Ten-GigabitEthernet 0/0/16] ip address 10.1.1.1 24
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
<P> system-view
[P-LoopBack0] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
<PE2> system-view
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# On PE 1, enable MPLS L2VPN and LDP globally.
[PE1] l2vpn enable
[PE1] mpls ldp
[PE1-ldp] quit
[P] mpls ldp
[P-ldp] quit
# On PE 2, enable MPLS L2VPN and LDP globally.
[PE2] l2vpn enable
[PE2] mpls ldp
[PE2-ldp] quit
3. Establish IBGP connections between PEs:
# On PE 1, establish an IBGP connection to PE 2.
[PE1] bgp 100
# On PE 1, enable BGP to exchange L2VPN information with PE 2.
[PE1-bgp-default] address-family l2vpn
[PE1-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE1-bgp-default-l2vpn] quit
[PE1-bgp-default] quit
# On PE 1, create subinterface Ten-GigabitEthernet0/0/15.100, and configure the subinterface to terminate packets whose outermost VLAN ID is 100.
# On PE 1, create cross-connect group vpna, create local site site 1, and create a BGP PW from site 1 to the remote site site 2.
[PE1-xcg-vpna] auto-discovery bgp
[PE1-xcg-vpna-auto] route-distinguisher 2:2
[PE1-xcg-vpna-auto] vpn-target 2:2 export-extcommunity
[PE1-xcg-vpna-auto] vpn-target 2:2 import-extcommunity
[PE1-xcg-vpna-auto] site 1 range 10 default-offset 0
[PE1-xcg-vpna-auto-1] connection remote-site-id 2
# On PE 1, bind Ten-GigabitEthernet 0/0/15.100 to the PW.
[PE1-xcg-vpna-auto-1-2] ac interface Ten-GigabitEthernet 0/0/15.100
[PE1-xcg-vpna-auto-1-2] return
# On PE 2, establish an IBGP connection to PE 1.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
# On PE 2, enable BGP to exchange L2VPN information with PE 1.
[PE2-bgp-default] address-family l2vpn
[PE2-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE2-bgp-default-l2vpn] quit
[PE2-bgp-default] quit
# On PE 2, create subinterface Ten-GigabitEthernet 0/0/15.100, and configure the subinterface to terminate packets whose outermost VLAN ID is 100.
# On PE 2, create cross-connect group vpna, create local site site 2, and create a BGP PW from site 2 to the remote site site 1.
[PE2-xcg-vpna] auto-discovery bgp
[PE2-xcg-vpna-auto] route-distinguisher 2:2
[PE2-xcg-vpna-auto] vpn-target 2:2 export-extcommunity
[PE2-xcg-vpna-auto] vpn-target 2:2 import-extcommunity
[PE2-xcg-vpna-auto] site 2 range 10 default-offset 0
[PE2-xcg-vpna-auto-2] connection remote-site-id 1
# On PE 2, bind Ten-GigabitEthernet 0/0/15.100 to the PW.
[PE2-xcg-vpna-auto-2-1] ac interface Ten-GigabitEthernet 0/0/15.100
[PE2-xcg-vpna-auto-2-1] return
# On CE 1, configure the interface connected to the PE to permit tagged packets from the customer VLAN.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
# Display L2VPN PW information on PE 1. The output shows that a BGP PW has been established.
<PE1> display l2vpn pw
PBY – pw-bypass
Total number of PWs: 1
1 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
3.3.3.9 2 65538/65537 BGP M 1 Up
# Display L2VPN PW information on PE 2. The output shows that a BGP PW has been established.
<PE2> display l2vpn pw
PBY – pw-bypass
1.1.1.9 1 65537/65538 BGP M 1 Up
# Verify that the host and the server can ping each other. (Details not shown.)
Configuration files
· CE1 and CE2:
vlan 100
· PE1:
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
l2vpn enable
interface LoopBack0
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
xconnect-group vpna
auto-discovery bgp
· P:
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
· PE2:
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
l2vpn enable
interface LoopBack0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
xconnect-group vpna
auto-discovery bgp
Related documentation
· H3C CR16000-M1A Routers MPLS Configuration Guide
· H3C CR16000-M1A Routers MPLS Command Reference
