02-Configuration Examples
HomeSupportRoutersH3C SR8800-X Router SeriesConfigure & DeployConfiguration ExamplesH3C SR8800-X Routers Configuration Examples All-In-One-R8630Pxx-6W10002-Configuration Examples
Table of Contents
Related Documents
54-OSPF over IPsec for Overseas Branch Access Configuration Examples
Using encrypted tunnels for overseas branch access in international financial enterprises (OSPF over IPsec)
Introduction
Enterprises with international businesses usually require transnational office networks. To ensure data security and confidentiality, it is necessary to build secure office networks over the insecure international Internet. OSPF over IPsec can safeguard service packets and routing protocol packets. It encrypts and protects data transmission through IPsec tunnels, ensuring data integrity and confidentiality, and preventing network eavesdropping and tampering. In this way, international enterprises can establish secure office networks over the international Internet and achieve efficient data transmission.
Example: Using encrypted tunnels for overseas branch access in international financial enterprises (OSPF over IPsec)
·     Connect the headquarter to Branch A and Branch B. Establish IPsec tunnels to transmit OSPF packets and service packets, thus protecting data against network eavesdropping and tampering.
·     At the headquarter, configure smaller OSPF cost values for IPsec tunnels on Router B than those on Router C to make sure service packets are transmitted preferentially through Router B, with Router C as a backup.
·     At Branch A, configure smaller OSPF cost values for IPsec tunnels on Router E than those on Router F to make sure service packets are transmitted preferentially through Router E, with Router F as a backup.
·     At Branch B, configure smaller OSPF cost values for IPsec tunnels on Router H than those on Router I to make sure service packets are transmitted preferentially through Router H, with Router I as a backup.
Table 1 Network diagram
Device
IP address
Router A
XGE3/1/1
192.168.0.1/24
XGE3/1/2
1.2.1.1/24
XGE3/1/3
1.3.1.1/24
Loopback0
1.1.1.1/32
Router B
XGE3/1/1
1.2.1.2/24
XGE3/1/2
2.5.1.1/24
XGE3/1/3
2.8.1.1/24
XGE3/1/4
2.3.1.1/24
Loopback0
2.2.2.2/32
Tunnel1
10.2.5.1/24
Tunnel2
10.2.8.1/24
Router C
XGE3/1/1
1.3.1.2/24
XGE3/1/2
3.9.1.1/24
XGE3/1/3
3.6.1.1/24
XGE3/1/4
2.3.1.2/24
Loopback0
3.3.3.3/32
Tunnel1
10.3.6.1/24
Tunnel2
10.3.9.1/24
Router D
XGE3/1/1
192.168.1.1/24
XGE3/1/2
4.5.1.1/24
XGE3/1/3
4.6.1.1/24
Loopback0
4.4.4.4/32
Router E
XGE3/1/1
4.5.1.2/24
XGE3/1/2
2.5.1.2/24
XGE3/1/3
5.6.1.1/24
Loopback0
5.5.5.5/32
Tunnel1
10.2.5.2/24
Router F
XGE3/1/1
4.6.1.2/24
XGE3/1/2
3.6.1.2/24
XGE3/1/3
5.6.1.2/24
Loopback0
6.6.6.6/32
Tunnel1
10.3.6.2/24
Router G
XGE3/1/1
192.168.2.1/24
XGE3/1/2
7.9.1.1/24
XGE3/1/3
7.8.1.1/24
Loopback0
7.7.7.7/32
Router H
XGE3/1/1
7.8.1.2/24
XGE3/1/2
2.8.1.2/24
XGE3/1/3
8.9.1.1/24
Loopback0
8.8.8.8/32
Tunnel1
10.2.8.2/24
Router I
XGE3/1/1
7.9.1.2/24
XGE3/1/2
3.9.1.2/24
XGE3/1/3
8.9.1.2/24
Loopback0
9.9.9.9/24
Tunnel1
10.3.9.2/24
Procedures
Configuring Router A
1.     Configure IP addresses for interfaces:
# Assign IP addresses to interfaces according to the network diagram.
[RouterA] interface ten-gigabitethernet 3/1/1
[RouterA-Ten-GigabitEthernet3/1/1] ip address 192.168.0.1 24
[RouterA-Ten-GigabitEthernet3/1/1] quit
[RouterA] interface ten-gigabitethernet 3/1/2
[RouterA-Ten-GigabitEthernet3/1/2] ip address 1.2.1.1 24
[RouterA-Ten-GigabitEthernet3/1/2] quit
[RouterA] interface ten-gigabitethernet 3/1/3
[RouterA-Ten-GigabitEthernet3/1/3] ip address 1.3.1.1 24
[RouterA-Ten-GigabitEthernet3/1/3] quit
[RouterA-LoopBack0] ip address 1.1.1.1 32
[RouterA-LoopBack0] quit
2.     Configure a routing policy:
# Create IPv4 prefix list 1 to permit only routes destined for network 192.168.0.1/24.
[RouterA] ip prefix-list 1 permit 192.168.0.1 24
# Create routing policy 1 and associate node 1 of routing policy 1 with IPv4 prefix list 1.
[RouterA] route-policy 1 permit node 1
[RouterA-route-policy-1-1] if-match ip address prefix-list 1
[RouterA-route-policy-1-1] quit
3.     Configure OSPF:
# Configure OSPF process 1 to advertise public network routes.
[RouterA] ospf 1
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[RouterA-ospf-1-area-0.0.0.0] network 1.2.1.1 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 1.3.1.1 0.0.0.255
[RouterA-ospf-1] import-route direct route-policy 1
[RouterA-ospf-1] quit
Configuring Router B
<RouterB> system-view
[RouterB] interface ten-gigabitethernet 3/1/1
[RouterB-Ten-GigabitEthernet3/1/1] ip address 1.2.1.2 24
[RouterB-Ten-GigabitEthernet3/1/1] quit
[RouterB] interface ten-gigabitethernet 3/1/2
[RouterB-Ten-GigabitEthernet3/1/2] ip address 2.5.1.1 24
[RouterB-Ten-GigabitEthernet3/1/2] quit
[RouterB] interface ten-gigabitethernet 3/1/3
[RouterB-Ten-GigabitEthernet3/1/3] ip address 2.8.1.1 24
[RouterB-Ten-GigabitEthernet3/1/3] quit
[RouterB] interface ten-gigabitethernet 3/1/4
[RouterB-Ten-GigabitEthernet3/1/4] ip address 2.3.1.1 24
[RouterB-Ten-GigabitEthernet3/1/4] quit
[RouterB-LoopBack0] ip address 2.2.2.2 32
[RouterB-LoopBack0] quit
2.     Configure an IPsec profile:
# Create IPsec transform set abc and enter its view.
[RouterB] ipsec transform-set abc
# Specify the AES algorithm in CBC mode as the encryption algorithm for ESP, which uses a 128-bit key.
[RouterB-ipsec-transform-set-abc] esp encryption-algorithm aes-cbc-128
# Specify the HMAC-SHA1 algorithm as the authentication algorithm for ESP, which uses a 160-bit key.
[RouterB-ipsec-transform-set-abc] esp authentication-algorithm sha1
[RouterB-ipsec-transform-set-abc] quit
# Create IKE keychain abc, and enter its view.
[RouterB] ike keychain abc
# Specify admin@123 in plain text as the pre-shared key used for IKE negotiation with peer 2.5.1.2.
[RouterB-ike-keychain-abc] pre-shared-key address 2.5.1.2 24 key simple admin@123
# Specify admin@123 in plain text as the pre-shared key used for IKE negotiation with peer 2.8.1.2.
[RouterB-ike-keychain-abc] pre-shared-key address 2.8.1.2 24 key simple admin@123
[RouterB-ike-keychain-abc] quit
# Create IKE profile abc and enter its view.
[RouterB] ike profile abc
# Specify IKE keychain abc for IKE profile abc.
[RouterB-ike-profile-abc] keychain abc
# Specify peer address 2.5.1.2 as the peer ID for IKE profile matching.
[RouterB-ike-profile-abc] match remote identity address 2.5.1.2 24
# Specify peer address 2.8.1.2 as the peer ID for IKE profile matching.
[RouterB-ike-profile-abc] match remote identity address 2.8.1.2 24
[RouterB-ike-profile-abc] quit
# Create IPsec profile abc with the IPsec SA setup mode as IKE.
[RouterB] ipsec profile abc isakmp
# Specify IPsec transform set abc for the IPsec profile.
[RouterB-ipsec-profile-isakmp-abc] transform-set abc
# Specify IKE profile abc for the IPsec profile.
[RouterB-ipsec-profile-isakmp-abc] ike-profile abc
[RouterB-ipsec-profile-isakmp-abc] quit
3.     Configure IPsec tunnel interfaces:
# Create IPsec/IPv4 tunnel interface Tunnel 1 and enter its view.
[RouterB] interface tunnel 1 mode ipsec
# Configure an IP address for Tunnel 1.
[RouterB-Tunnel1] ip address 10.2.5.1 24
# Configure the IP address of XGE3/1/2 as the source address for Tunnel 1.
[RouterB-Tunnel1] source 2.5.1.1
Configure the IP address of XGE3/1/2 on Router E as the destination address for Tunnel 1.
[RouterB-Tunnel1] destination 2.5.1.2
# Set the OSPF cost for Tunnel 1 to 900.
[RouterB-Tunnel1] ospf cost 900
# Apply IPsec profile abc to the tunnel interface.
[RouterB-Tunnel1] tunnel protection ipsec profile abc
[RouterB-Tunnel1] quit
# Create IPsec/IPv4 tunnel interface Tunnel 2 and enter its view.
[RouterB] interface tunnel 2 mode ipsec
# Configure an IP address for Tunnel 2.
[RouterB-Tunnel2] ip address 10.2.8.1 24
# Configure the IP address of XGE3/1/3 as the source address for Tunnel 2.
[RouterB-Tunnel2] source 2.8.1.1
Configure the IP address of XGE3/1/2 on Router H as the destination address for Tunnel 2.
[RouterB-Tunnel2] destination 2.8.1.2
# Set the OSPF cost for Tunnel 2 to 900.
[RouterB-Tunnel2] ospf cost 900
[RouterB-Tunnel2] tunnel protection ipsec profile abc
[RouterB-Tunnel2] quit
4.     Configure OSPF:
[RouterB] ospf 1
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 1.2.1.2 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 2.3.1.1 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[RouterB-ospf-1] area 1
[RouterB-ospf-1-area-0.0.0.1] network 10.2.5.1 0.0.0.255
[RouterB-ospf-1-area-0.0.0.1] quit
[RouterB-ospf-1] area 2
[RouterB-ospf-1-area-0.0.0.2] network 10.2.8.1 0.0.0.255
[RouterB-ospf-1-area-0.0.0.2] quit
[RouterB-ospf-1] quit
Configuring Router C
<RouterC> system-view
[RouterC] interface ten-gigabitethernet 3/1/1
[RouterC-Ten-GigabitEthernet3/1/1] ip address 1.3.1.2 24
[RouterC-Ten-GigabitEthernet3/1/1] quit
[RouterC] interface ten-gigabitethernet 3/1/2
[RouterC-Ten-GigabitEthernet3/1/2] ip address 3.9.1.1 24
[RouterC-Ten-GigabitEthernet3/1/2] quit
[RouterC] interface ten-gigabitethernet 3/1/3
[RouterC-Ten-GigabitEthernet3/1/3] ip address 3.6.1.1 24
[RouterC-Ten-GigabitEthernet3/1/3] quit
[RouterC] interface ten-gigabitethernet 3/1/4
[RouterC-Ten-GigabitEthernet3/1/4] ip address 2.3.1.2 24
[RouterC-Ten-GigabitEthernet3/1/4] quit
[RouterC] interface loopback 0
[RouterC-LoopBack0] ip address 3.3.3.3 32
[RouterC-LoopBack0] quit
[RouterC] ipsec transform-set abc
[RouterC-ipsec-transform-set-abc] esp encryption-algorithm aes-cbc-128
[RouterC-ipsec-transform-set-abc] esp authentication-algorithm sha1
[RouterC-ipsec-transform-set-abc] quit
[RouterC] ike keychain abc
# Specify admin@123 in plain text as the pre-shared key used for IKE negotiation with peer 3.6.1.2.
[RouterC-ike-keychain-abc] pre-shared-key address 3.6.1.2 24 key simple admin@123
# Specify admin@123 in plain text as the pre-shared key used for IKE negotiation with peer 3.9.1.2.
[RouterC-ike-keychain-abc] pre-shared-key address 3.9.1.2 24 key simple admin@123
[RouterC-ike-keychain-abc] quit
[RouterC] ike profile abc
[RouterC-ike-profile-abc] keychain abc
# Specify peer address 3.6.1.2 as the peer ID for IKE profile matching.
[RouterC-ike-profile-abc] match remote identity address 3.6.1.2 24
# Specify peer address 3.9.1.2 as the peer ID for IKE profile matching.
[RouterC-ike-profile-abc] match remote identity address 3.9.1.2 24
[RouterC-ike-profile-abc] quit
[RouterC] ipsec profile abc isakmp
[RouterC-ipsec-profile-isakmp-abc] transform-set abc
[RouterC-ipsec-profile-isakmp-abc] ike-profile abc
[RouterC-ipsec-profile-isakmp-abc] quit
[RouterC] interface tunnel 1 mode ipsec
[RouterC-Tunnel1] ip address 10.3.6.1 24
# Configure the IP address of XGE3/1/3 as the source address for Tunnel 1.
[RouterC-Tunnel1] source 3.6.1.1
# Configure the destination address for Tunnel 1 as the IP address of XGE3/1/2 on Router F.
[RouterC-Tunnel1] destination 3.6.1.2
# Set the OSPF cost for Tunnel 1 to 1000.
[RouterC-Tunnel1] ospf cost 1000
[RouterC-Tunnel1] tunnel protection ipsec profile abc
[RouterC-Tunnel1] quit
[RouterC] interface tunnel 2 mode ipsec
[RouterC-Tunnel2] ip address 10.3.9.1 24
# Configure the IP address of XGE3/1/2 as the source address for Tunnel 2.
[RouterC-Tunnel2] source 3.9.1.1
Configure the IP address of XGE3/1/2 on Router I as the destination address for Tunnel 2.
[RouterC-Tunnel2] destination 3.9.1.2
# Set the OSPF cost for Tunnel 2 to 1000.
[RouterC-Tunnel2] ospf cost 1000
[RouterC-Tunnel2] tunnel protection ipsec profile abc
[RouterC-Tunnel2] quit
4.     Configure OSPF:
[RouterC] ospf 1
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 1.3.1.2 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 2.3.1.2 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[RouterC-ospf-1] area 1
[RouterC-ospf-1-area-0.0.0.1] network 10.3.6.1 0.0.0.255
[RouterC-ospf-1-area-0.0.0.1] quit
[RouterC-ospf-1] area 2
[RouterC-ospf-1-area-0.0.0.2] network 10.3.9.1 0.0.0.255
[RouterC-ospf-1-area-0.0.0.2] quit
[RouterC-ospf-1] quit
Configuring Router D
<RouterD> system-view
[RouterD] interface ten-gigabitethernet 3/1/1
[RouterD-Ten-GigabitEthernet3/1/1] ip address 192.168.1.1 24
[RouterD-Ten-GigabitEthernet3/1/1] quit
[RouterD] interface ten-gigabitethernet 3/1/2
[RouterD-Ten-GigabitEthernet3/1/2] ip address 4.5.1.1 24
[RouterD-Ten-GigabitEthernet3/1/2] quit
[RouterD] interface ten-gigabitethernet 3/1/3
[RouterD-Ten-GigabitEthernet3/1/3] ip address 4.6.1.1 24
[RouterD-Ten-GigabitEthernet3/1/3] quit
[RouterD] interface loopback 0
[RouterD-LoopBack0] ip address 4.4.4.4 32
[RouterD-LoopBack0] quit
# Create IPv4 prefix list 1 to permit only routes destined for network 192.168.1.1/24.
[RouterD] ip prefix-list 1 permit 192.168.1.1 24
[RouterD] route-policy 1 permit node 1
[RouterD-route-policy-1-1] if-match ip address prefix-list 1
[RouterD-route-policy-1-1] quit
3.     Configure OSPF:
[RouterD] ospf 1
[RouterD-ospf-1] area 1
[RouterD-ospf-1-area-0.0.0.1] network 4.4.4.4 0.0.0.0
[RouterD-ospf-1-area-0.0.0.1] network 4.5.1.1 0.0.0.255
[RouterD-ospf-1-area-0.0.0.1] network 4.6.1.1 0.0.0.255
[RouterD-ospf-1-area-0.0.0.1] quit
[RouterD-ospf-1] import-route direct route-policy 1
[RouterD-ospf-1] quit
Configuring Router E
<RouterE> system-view
[RouterE] interface ten-gigabitethernet 3/1/1
[RouterE-Ten-GigabitEthernet3/1/1] ip address 4.5.1.2 24
[RouterE-Ten-GigabitEthernet3/1/1] quit
[RouterE] interface ten-gigabitethernet 3/1/2
[RouterE-Ten-GigabitEthernet3/1/2] ip address 2.5.1.2 24
[RouterE-Ten-GigabitEthernet3/1/2] quit
[RouterE] interface ten-gigabitethernet 3/1/3
[RouterE-Ten-GigabitEthernet3/1/3] ip address 5.6.1.1 24
[RouterE-Ten-GigabitEthernet3/1/3] quit
[RouterE] interface loopback 0
[RouterE-LoopBack0] ip address 5.5.5.5 32
[RouterE-LoopBack0] quit
[RouterE] ipsec transform-set abc
[RouterE-ipsec-transform-set-abc] esp encryption-algorithm aes-cbc-128
[RouterE-ipsec-transform-set-abc] esp authentication-algorithm sha1
[RouterE-ipsec-transform-set-abc] quit
[RouterE] ike keychain abc
# Specify admin@123 in plain text as the pre-shared key used for IKE negotiation with peer 2.5.1.1.
[RouterE-ike-keychain-abc] pre-shared-key address 2.5.1.1 24 key simple admin@123
[RouterE-ike-keychain-abc] quit
[RouterE] ike profile abc
[RouterE-ike-profile-abc] keychain abc
# Specify peer address 2.5.1.1 as the peer ID for IKE profile matching.
[RouterE-ike-profile-abc] match remote identity address 2.5.1.1 24
[RouterE-ike-profile-abc] quit
[RouterE] ipsec profile abc isakmp
[RouterE-ipsec-profile-isakmp-abc] transform-set abc
[RouterE-ipsec-profile-isakmp-abc] ike-profile abc
[RouterE-ipsec-profile-isakmp-abc] quit
[RouterE] interface tunnel 1 mode ipsec
[RouterE-Tunnel1] ip address 10.2.5.2 24
[RouterE-Tunnel1] source 2.5.1.2
Configure the IP address of XGE3/1/2 on Router B as the destination address for Tunnel 1.
[RouterE-Tunnel1] destination 2.5.1.1
[RouterE-Tunnel1] ospf cost 900
[RouterE-Tunnel1] tunnel protection ipsec profile abc
[RouterE-Tunnel1] quit
4.     Configure OSPF:
[RouterE] ospf 1
[RouterE-ospf-1] area 1
[RouterE-ospf-1-area-0.0.0.1] network 5.5.5.5 0.0.0.0
[RouterE-ospf-1-area-0.0.0.1] network 4.5.1.2 0.0.0.255
[RouterE-ospf-1-area-0.0.0.1] network 5.6.1.1 0.0.0.255
[RouterE-ospf-1-area-0.0.0.1] network 10.2.5.2 0.0.0.255
[RouterE-ospf-1-area-0.0.0.1] quit
[RouterE-ospf-1] quit
Configuring Router F
<RouterF> system-view
[RouterF] interface ten-gigabitethernet 3/1/1
[RouterF-Ten-GigabitEthernet3/1/1] ip address 4.6.1.2 24
[RouterF-Ten-GigabitEthernet3/1/1] quit
[RouterF] interface ten-gigabitethernet 3/1/2
[RouterF-Ten-GigabitEthernet3/1/2] ip address 3.6.1.2 24
[RouterF-Ten-GigabitEthernet3/1/2] quit
[RouterF] interface ten-gigabitethernet 3/1/3
[RouterF-Ten-GigabitEthernet3/1/3] ip address 5.6.1.2 24
[RouterF-Ten-GigabitEthernet3/1/3] quit
[RouterF] interface loopback 0
[RouterF-LoopBack0] ip address 6.6.6.6 32
[RouterF-LoopBack0] quit
[RouterF] ipsec transform-set abc
[RouterF-ipsec-transform-set-abc] esp encryption-algorithm aes-cbc-128
[RouterF-ipsec-transform-set-abc] esp authentication-algorithm sha1
[RouterF-ipsec-transform-set-abc] quit
[RouterF] ike keychain abc
# Specify admin@123 in plain text as the pre-shared key used for IKE negotiation with peer 3.6.1.1.
[RouterF-ike-keychain-abc] pre-shared-key address 3.6.1.1 24 key simple admin@123
[RouterF-ike-keychain-abc] quit
[RouterF] ike profile abc
[RouterF-ike-profile-abc] keychain abc
# Specify peer address 3.6.1.1 as the peer ID for IKE profile matching.
[RouterF-ike-profile-abc] match remote identity address 3.6.1.1 24
[RouterF-ike-profile-abc] quit
[RouterF] ipsec profile abc isakmp
[RouterF-ipsec-profile-isakmp-abc] transform-set abc
[RouterF-ipsec-profile-isakmp-abc] ike-profile abc
[RouterF-ipsec-profile-isakmp-abc] quit
[RouterF] interface tunnel 1 mode ipsec
[RouterF-Tunnel1] ip address 10.3.6.2 24
[RouterF-Tunnel1] source 3.6.1.2
Configure the IP address of XGE3/1/3 on Router C as the destination address for Tunnel 1.
[RouterF-Tunnel1] destination 3.6.1.1
[RouterF-Tunnel1] ospf cost 1000
[RouterF-Tunnel1] tunnel protection ipsec profile abc
[RouterF-Tunnel1] quit
4.     Configure OSPF:
[RouterF] ospf 1
[RouterF-ospf-1] area 1
[RouterF-ospf-1-area-0.0.0.1] network 6.6.6.6 0.0.0.0
[RouterF-ospf-1-area-0.0.0.1] network 4.6.1.2 0.0.0.255
[RouterF-ospf-1-area-0.0.0.1] network 5.6.1.2 0.0.0.255
[RouterF-ospf-1-area-0.0.0.1] network 10.3.6.2 0.0.0.255
[RouterF-ospf-1-area-0.0.0.1] quit
[RouterF-ospf-1] quit
Configuring Router G
<RouterG> system-view
[RouterG] interface ten-gigabitethernet 3/1/1
[RouterG-Ten-GigabitEthernet3/1/1] ip address 192.168.2.1 24
[RouterG-Ten-GigabitEthernet3/1/1] quit
[RouterG] interface ten-gigabitethernet 3/1/2
[RouterG-Ten-GigabitEthernet3/1/2] ip address 7.9.1.1 24
[RouterG-Ten-GigabitEthernet3/1/2] quit
[RouterG] interface ten-gigabitethernet 3/1/3
[RouterG-Ten-GigabitEthernet3/1/3] ip address 7.8.1.1 24
[RouterG-Ten-GigabitEthernet3/1/3] quit
[RouterG] interface loopback 0
[RouterG-LoopBack0] ip address 7.7.7.7 32
[RouterG-LoopBack0] quit
[RouterG] ip prefix-list 1 permit 192.168.2.1 24
[RouterG] route-policy 1 permit node 1
[RouterG-route-policy-1-1] if-match ip address prefix-list 1
[RouterG-route-policy-1-1] quit
3.     Configure OSPF:
[RouterG] ospf 1
[RouterG-ospf-1] area 2
[RouterG-ospf-1-area-0.0.0.2] network 7.7.7.7 0.0.0.0
[RouterG-ospf-1-area-0.0.0.2] network 7.9.1.1 0.0.0.255
[RouterG-ospf-1-area-0.0.0.2] network 7.8.1.1 0.0.0.255
[RouterG-ospf-1-area-0.0.0.2] quit
[RouterG-ospf-1] import-route direct route-policy 1
[RouterG-ospf-1] quit
Configuring Router H
<RouterH> system-view
[RouterH] interface ten-gigabitethernet 3/1/1
[RouterH-Ten-GigabitEthernet3/1/1] ip address 7.8.1.2 24
[RouterH-Ten-GigabitEthernet3/1/1] quit
[RouterH] interface ten-gigabitethernet 3/1/2
[RouterH-Ten-GigabitEthernet3/1/2] ip address 2.8.1.2 24
[RouterH-Ten-GigabitEthernet3/1/2] quit
[RouterH] interface ten-gigabitethernet 3/1/3
[RouterH-Ten-GigabitEthernet3/1/3] ip address 8.9.1.1 24
[RouterH-Ten-GigabitEthernet3/1/3] quit
[RouterH] interface loopback 0
[RouterH-LoopBack0] ip address 8.8.8.8 32
[RouterH-LoopBack0] quit
[RouterH] ipsec transform-set abc
[RouterH-ipsec-transform-set-abc] esp encryption-algorithm aes-cbc-128
[RouterH-ipsec-transform-set-abc] esp authentication-algorithm sha1
[RouterH-ipsec-transform-set-abc] quit
[RouterH] ike keychain abc
# Specify admin@123 in plain text as the pre-shared key used for IKE negotiation with peer 2.8.1.1.
[RouterH-ike-keychain-abc] pre-shared-key address 2.8.1.1 24 key simple admin@123
[RouterH-ike-keychain-abc] quit
[RouterH] ike profile abc
[RouterH-ike-profile-abc] keychain abc
# Specify peer address 2.8.1.1 as the peer ID for IKE profile matching.
[RouterH-ike-profile-abc] match remote identity address 2.8.1.1 24
[RouterH-ike-profile-abc] quit
[RouterH] ipsec profile abc isakmp
[RouterH-ipsec-profile-isakmp-abc] transform-set abc
[RouterH-ipsec-profile-isakmp-abc] ike-profile abc
[RouterH-ipsec-profile-isakmp-abc] quit
[RouterH] interface tunnel 1 mode ipsec
[RouterH-Tunnel1] ip address 10.2.8.2 24
[RouterH-Tunnel1] source 2.8.1.2
Configure the IP address of XGE3/1/3 on Router B as the destination address for Tunnel 1.
[RouterH-Tunnel1] destination 2.8.1.1
[RouterH-Tunnel1] ospf cost 900
[RouterH-Tunnel1] tunnel protection ipsec profile abc
[RouterH-Tunnel1] quit
4.     Configure OSPF:
[RouterH] ospf 1
[RouterH-ospf-1] area 2
[RouterH-ospf-1-area-0.0.0.2] network 8.8.8.8 0.0.0.0
[RouterH-ospf-1-area-0.0.0.2] network 7.8.1.2 0.0.0.255
[RouterH-ospf-1-area-0.0.0.2] network 8.9.1.1 0.0.0.255
[RouterH-ospf-1-area-0.0.0.2] network 10.2.8.2 0.0.0.255
[RouterH-ospf-1-area-0.0.0.2] quit
[RouterH-ospf-1] quit
Configuring Router I
<RouterI> system-view
[RouterI] interface ten-gigabitethernet 3/1/1
[RouterI-Ten-GigabitEthernet3/1/1] ip address 7.9.1.2 24
[RouterI-Ten-GigabitEthernet3/1/1] quit
[RouterI] interface ten-gigabitethernet 3/1/2
[RouterI-Ten-GigabitEthernet3/1/2] ip address 3.9.1.2 24
[RouterI-Ten-GigabitEthernet3/1/2] quit
[RouterI] interface ten-gigabitethernet 3/1/3
[RouterI-Ten-GigabitEthernet3/1/3] ip address 8.9.1.2 24
[RouterI-Ten-GigabitEthernet3/1/3] quit
[RouterI] interface loopback 0
[RouterI-LoopBack0] ip address 9.9.9.9 24
[RouterI-LoopBack0] quit
[RouterI] ipsec transform-set abc
[RouterI-ipsec-transform-set-abc] esp encryption-algorithm aes-cbc-128
[RouterI-ipsec-transform-set-abc] esp authentication-algorithm sha1
[RouterI-ipsec-transform-set-abc] quit
[RouterI] ike keychain abc
# Specify admin@123 in plain text as the pre-shared key used for IKE negotiation with peer 3.9.1.1.
[RouterI-ike-keychain-abc] pre-shared-key address 3.9.1.1 24 key simple admin@123
[RouterI-ike-keychain-abc] quit
[RouterI] ike profile abc
[RouterI-ike-profile-abc] keychain abc
# Specify peer address 3.9.1.1 as the peer ID for IKE profile matching.
[RouterI-ike-profile-abc] match remote identity address 3.9.1.1 24
[RouterI-ike-profile-abc] quit
[RouterI] ipsec profile abc isakmp
[RouterI-ipsec-profile-isakmp-abc] transform-set abc
[RouterI-ipsec-profile-isakmp-abc] ike-profile abc
[RouterI-ipsec-profile-isakmp-abc] quit
[RouterI] interface tunnel 1 mode ipsec
[RouterI-Tunnel1] ip address 10.3.9.2 24
[RouterI-Tunnel1] source 3.9.1.2
Configure the IP address of XGE3/1/2 on Router C as the destination address for Tunnel 1.
[RouterI-Tunnel1] destination 3.9.1.1
[RouterI-Tunnel1] ospf cost 1000
[RouterI-Tunnel1] tunnel protection ipsec profile abc
[RouterI-Tunnel1] quit
4.     Configure OSPF:
[RouterI] ospf 1
[RouterI-ospf-1] area 2
[RouterI-ospf-1-area-0.0.0.2] network 9.9.9.9 0.0.0.0
[RouterI-ospf-1-area-0.0.0.2] network 7.9.1.2 0.0.0.255
[RouterI-ospf-1-area-0.0.0.2] network 8.9.1.2 0.0.0.255
[RouterI-ospf-1-area-0.0.0.2] network 10.3.9.2 0.0.0.255
[RouterI-ospf-1-area-0.0.0.2] quit
[RouterI-ospf-1] quit
# On Router A, use the ping command to ping the addresses of Branch A and Branch B.
[RouterA] ping -a 192.168.0.1 192.168.1.1
Ping 192.168.1.1 (192.168.1.1) from 192.168.0.1: 56 data bytes, press CTRL_C to break
56 bytes from 192.168.1.1: icmp_seq=0 ttl=253 time=2.000 ms
56 bytes from 192.168.1.1: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 192.168.1.1: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 192.168.1.1: icmp_seq=3 ttl=253 time=2.000 ms
56 bytes from 192.168.1.1: icmp_seq=4 ttl=253 time=1.000 ms
--- Ping statistics for 192.168.1.1 ---
round-trip min/avg/max/std-dev = 1.000/1.600/2.000/0.490 ms
[RouterA]%Jul 17 14:56:49:694 2023 RouterA PING/6/PING_STATISTICS: Ping statistics for 192.168.1.1: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.000/1.600/2.000/0.490 ms.
[RouterA] ping -a 192.168.0.1 192.168.2.1
Ping 192.168.2.1 (192.168.2.1) from 192.168.0.1: 56 data bytes, press CTRL_C to break
56 bytes from 192.168.2.1: icmp_seq=0 ttl=253 time=2.000 ms
56 bytes from 192.168.2.1: icmp_seq=1 ttl=253 time=2.000 ms
56 bytes from 192.168.2.1: icmp_seq=2 ttl=253 time=1.000 ms
56 bytes from 192.168.2.1: icmp_seq=3 ttl=253 time=1.000 ms
56 bytes from 192.168.2.1: icmp_seq=4 ttl=253 time=1.000 ms
--- Ping statistics for 192.168.2.1 ---
round-trip min/avg/max/std-dev = 1.000/1.400/2.000/0.490 ms
[RouterA]%Jul 17 14:56:54:783 2023 RouterA PING/6/PING_STATISTICS: Ping statistics for 192.168.2.1: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.000/1.400/2.000/0.490 ms.
The output shows that the headquarter can access both of the overseas branches.
# On Router A, display routes destined for 192.168.1.1/24 and 192.168.2.1/24.
[RouterA] display ip routing-table 192.168.1.1 24
Summary count : 1
192.168.1.0/24     O_ASE2  150 902         1.2.1.2         XGE3/1/2
[RouterA] display ip routing-table 192.168.2.1 24
Summary count : 1
192.168.2.0/24     O_ASE2  150 902         1.2.1.2         XGE3/1/2
# On Router B, display routes destined for 192.168.1.1/24 and 192.168.2.1/24.
[RouterB] display ip routing-table 192.168.1.1 24
Summary count : 1
192.168.1.0/24     O_ASE2  150 901         10.2.5.2        Tun1
[RouterB] display ip routing-table 192.168.2.1 24
Summary count : 1
192.168.2.0/24     O_ASE2  150 901         10.2.8.2        Tun2
The output shows that Router A's routes destined for Branch A and Branch B go through the IPsec tunnels of Router B.
# Shut down the IPsec tunnels on Router B, and then display routes destined for 192.168.1.1/24 and 192.168.2.1/24 on Router A.
Summary count : 1
192.168.1.0/24     O_ASE2  150 1002        1.3.1.2         XGE3/1/3
Summary count : 1
192.168.2.0/24     O_ASE2  150 1002        1.3.1.2         XGE3/1/3
# On Router C, display routes destined for 192.168.1.1/24 and 192.168.2.1/24.
[RouterC] display ip routing-table 192.168.1.1 24
Summary count : 1
192.168.1.0/24     O_ASE2  150 1001        10.3.6.2        Tun1
[RouterC] display ip routing-table 192.168.2.1 24
Summary count : 1
192.168.2.0/24     O_ASE2  150 1001        10.3.9.2        Tun2
The output shows that after the IPsec tunnels of Router B fail, Router C operates as a backup to forward the traffic between the headquarter and the branches.
Display routes destined for 192.168.0.1/24 on the routers connected to Branch A and Branch B in the same way as mentioned above.
Configuration files
Router A
ospf 1
 area 0.0.0.0
  network 1.2.1.0 0.0.0.255
  network 1.3.1.0 0.0.0.255
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
interface Ten-GigabitEthernet3/1/1
 ip address 192.168.0.1 255.255.255.0
interface Ten-GigabitEthernet3/1/2
 ip address 1.2.1.1 255.255.255.0
interface Ten-GigabitEthernet3/1/3
 ip address 1.3.1.1 255.255.255.0
 ip prefix-list 1 index 10 permit 192.168.0.0 24
Router B
ospf 1
 area 0.0.0.0
  network 2.3.1.0 0.0.0.255
 area 0.0.0.1
  network 10.2.5.0 0.0.0.255
 area 0.0.0.2
  network 10.2.8.0 0.0.0.255
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ip address 1.2.1.2 255.255.255.0
 ip address 2.5.1.1 255.255.255.0
 ip address 2.8.1.1 255.255.255.0
interface Ten-GigabitEthernet3/1/4
 ip address 2.3.1.1 255.255.255.0
interface Tunnel1 mode ipsec
 ip address 10.2.5.1 255.255.255.0
 ospf cost 900
 source 2.5.1.1
 destination 2.5.1.2
interface Tunnel2 mode ipsec
 ip address 10.2.8.1 255.255.255.0
 ospf cost 900
 source 2.8.1.1
 destination 2.8.1.2
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
 match remote identity address 2.5.1.2 255.255.255.0
 match remote identity address 2.8.1.2 255.255.255.0
ike keychain abc
 pre-shared-key address 2.5.1.2 255.255.255.0 key simple admin@123
 pre-shared-key address 2.8.1.2 255.255.255.0 key simple admin@123
Router C
ospf 1
 area 0.0.0.0
 area 0.0.0.1
  network 10.3.6.0 0.0.0.255
 area 0.0.0.2
  network 10.3.9.0 0.0.0.255
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ip address 1.3.1.2 255.255.255.0
 ip address 3.9.1.1 255.255.255.0
 ip address 3.6.1.1 255.255.255.0
 ip address 2.3.1.2 255.255.255.0
 ip address 10.3.6.1 255.255.255.0
 ospf cost 1000
 source 3.6.1.1
 destination 3.6.1.2
 ip address 10.3.9.1 255.255.255.0
 ospf cost 1000
 source 3.9.1.1
 destination 3.9.1.2
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
 match remote identity address 3.6.1.2 255.255.255.0
 match remote identity address 3.9.1.2 255.255.255.0
ike keychain abc
 pre-shared-key address 3.6.1.2 255.255.255.0 key simple admin@123
 pre-shared-key address 3.9.1.2 255.255.255.0 key simple admin@123
Router D
ospf 1
 area 0.0.0.1
  network 4.5.1.0 0.0.0.255
  network 4.6.1.0 0.0.0.255
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 4.5.1.1 255.255.255.0
 ip address 4.6.1.1 255.255.255.0
 ip prefix-list 1 index 10 permit 192.168.1.0 24
Router E
ospf 1
 area 0.0.0.1
  network 5.6.1.0 0.0.0.255
interface LoopBack0
 ip address 5.5.5.5 255.255.255.255
 ip address 4.5.1.2 255.255.255.0
 ip address 2.5.1.2 255.255.255.0
 ip address 5.6.1.1 255.255.255.0
 ip address 10.2.5.2 255.255.255.0
 ospf cost 900
 source 2.5.1.2
 destination 2.5.1.1
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
 match remote identity address 2.5.1.1 255.255.255.0
ike keychain abc
 pre-shared-key address 2.5.1.1 255.255.255.0 key simple admin@123
Router F
ospf 1
 area 0.0.0.1
interface LoopBack0
 ip address 6.6.6.6 255.255.255.255
 ip address 4.6.1.2 255.255.255.0
 ip address 3.6.1.2 255.255.255.0
 ip address 5.6.1.2 255.255.255.0
 ip address 10.3.6.2 255.255.255.0
 ospf cost 1000
 source 3.6.1.2
 destination 3.6.1.1
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
 match remote identity address 3.6.1.1 255.255.255.0
ike keychain abc
 pre-shared-key address 3.6.1.1 255.255.255.0 key simple admin@123
Router G
ospf 1
 area 0.0.0.2
  network 7.8.1.0 0.0.0.255
  network 7.9.1.0 0.0.0.255
interface LoopBack0
 ip address 7.7.7.7 255.255.255.255
 ip address 192.168.2.1 255.255.255.0
 ip address 7.9.1.1 255.255.255.0
 ip address 7.8.1.1 255.255.255.0
 ip prefix-list 1 index 10 permit 192.168.2.0 24
Router H
ospf 1
 area 0.0.0.2
  network 8.9.1.0 0.0.0.255
interface LoopBack0
 ip address 8.8.8.8 255.255.255.255
 ip address 7.8.1.2 255.255.255.0
 ip address 2.8.1.2 255.255.255.0
 ip address 8.9.1.1 255.255.255.0
 ip address 10.2.8.2 255.255.255.0
 ospf cost 900
 source 2.8.1.2
 destination 2.8.1.1
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
 match remote identity address 2.8.1.1 255.255.255.0
ike keychain abc
 pre-shared-key address 2.8.1.1 255.255.255.0 key simple admin@123
Router I
ospf 1
 area 0.0.0.2
interface LoopBack0
 ip address 9.9.9.9 255.255.255.0
 ip address 7.9.1.2 255.255.255.0
 ip address 3.9.1.2 255.255.255.0
 ip address 8.9.1.2 255.255.255.0
 ip address 10.3.9.2 255.255.255.0
 ospf cost 1000
 source 3.9.1.2
 destination 3.9.1.1
 transform-set abc
 ike-profile abc
ike profile abc
 keychain abc
 match remote identity address 3.9.1.1 255.255.255.0
ike keychain abc
 pre-shared-key address 3.9.1.1 255.255.255.0 key simple admin@123
