02-Fundamentals
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10002-Fundamentals
08-HH3C-UI-MAN-MIB
08-HH3C-UI-MAN-MIB 131.86 KB
HH3C-UI-MAN-MIB
About this MIB
Use this MIB to obtain and manage alarms on user authentication. This MIB also contains notifications about user login changes.
MIB file name
hh3c-ui-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUIMgt(2)
Scalar objects
hh3cTerminalUserName (1.3.6.1.4.1.25506.2.2.1.1.2.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
DisplayString
Standard MIB values.
Name of a login user.
As per the MIB.
hh3cTerminalSource (1.3.6.1.4.1.25506.2.2.1.1.2.2)
Object (OID)
Access
Value range
Implementation
DisplayString
Login method, including Console, AUX, TTY, and VTY.
As per the MIB.
hh3cTerminalUserAuthFailureReason (1.3.6.1.4.1.25506.2.2.1.1.2.3)
Object (OID)
Access
Value range
Implementation
INTEGER
exceedRetries(1)
authTimeout(2)
otherReason(3)
Failure reason for user authentication.
As per the MIB.
hh3cVtyCurrentVty (1.3.6.1.4.1.25506.2.2.1.1.2.4)
Object (OID)
Access
Value range
Implementation
Unsigned32
Number of used VTY lines.
As per the MIB.
hh3cVtyMaxVty (1.3.6.1.4.1.25506.2.2.1.1.2.5)
Object (OID)
Access
Value range
Implementation
Unsigned32
Maximum number of VTY lines that the system allows users to log in to concurrently.
As per the MIB.
hh3cVtyThreshold (1.3.6.1.4.1.25506.2.2.1.1.2.6)
Object (OID)
Access
Value range
Implementation
Unsigned32
VTY usage alarm threshold.
As per the MIB.
Tabular objects
hh3cVtyAccTable
About this table
Use this table to configure or obtain the permission control information of VTY user interfaces.
Support for operations
CreateSupported
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cVtyAccUserIndex and hh3cVtyAccConnway.
Object (OID)
Access
Value range
Implementation
hh3cVtyAccUserIndex (1.3.6.1.4.1.25506.2.2.1.2.1.1.1)
not-accessible
Integer32
Integer32(0..65535)
Relative index of a VTY user interface.
As per the MIB.
hh3cVtyAccConnway (1.3.6.1.4.1.25506.2.2.1.2.1.1.2)
not-accessible
INTEGER
inbound(1),
outbound(2),
linkinbound(3),
acl6inbound(11),
acl6outbound(12)
inbound(1): Use an IPv4 ACL to filter login connections on the current user interface.
outbound(2): Use an IPv4 ACL to filter logout connections on the current user interface.
linkinbound(3): Use a link layer ACL to filter login connections from the current user interface.
acl6inbound(11): Use an IPv6 ACL to filter login connections on the current user interface.
acl6outbound(12): Use an IPv6 ACL to filter logout connections on the current user interface.
As per the MIB.
hh3cVtyAccAclNum (1.3.6.1.4.1.25506.2.2.1.2.1.1.3)
read-create
Integer32
Integer32 (1...2147483647)
ACL number.
As per the MIB.
hh3cVtyAccEntryRowStatus (1.3.6.1.4.1.25506.2.2.1.2.1.1.4)
read-create
RowStatus
Row status.
Currently, only create, execute, destroy, and activate operations are supported.
As per the MIB.
hh3cConStatusTable
About this table
Use this table to configure or obtain the status of console user interfaces.
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cConUserIndex.
Object (OID)
Access
Value range
Implementation
hh3cConUserIndex (1.3.6.1.4.1.25506.2.2.1.3.1.1.1)
not-accessible
Integer32
Index of a console user interface. The value is the current user ID.
As per the MIB.
hh3cConReAuth (1.3.6.1.4.1.25506.2.2.1.3.1.1.2)
read-write
INTEGER
disable(1),
enable(2)
Reauthentication attribute of the current user interface.
When the current user interface is disconnected and then reconnected, the attribute indicates whether reauthentication is required.
disable(1)—Reauthentication is not required.
enable(2)—Reauthentication is required.
As per the MIB.
Notifications
hh3cLogIn
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.1
User login
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when a user logs in to the system.
System impact
No negative impact on the system.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.2.1.1.2.1 (hh3cTerminalUserName)
Username.
N/A
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.4.1.25506.2.2.1.1.2.2 (hh3cTerminalSource)
User line, including console, AUX, TTY, and VTY.
N/A
DisplayString
Recommended action
No action is required.
hh3cLogOut
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.2
User logout
Informational
Warning
N/A (N/A)
ON
This notification is generated when a user logs out of the system.
System impact
Status control
Object
OID (object name)
Index
Value range
Username.
N/A
DisplayString
User line, including AUX, TTY, and VTY.
N/A
DisplayString
Recommended action
hh3cLogInAuthenFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.3
User authentication failed
Informational
Warning
N/A (N/A)
ON
This notification is generated when a user failed to log in to the system.
System impact
If this notification is generated consecutively, the system might be attacked.
Status control
Object
OID (object name)
Index
Value range
Username.
N/A
DisplayString
N/A
DisplayString
1.3.6.1.4.1.25506.2.2.1.1.2.3 (hh3cTerminalUserAuthFailureReason)
N/A
INTEGER
exceedRetries(1), authTimeout(2), otherReason(3)
Recommended action
1.Verify that the login username and password are correct.
2.Verify that the server settings such as server type are correct.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
hh3cVtyUsageExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.4
The number of used VTY lines reached or exceeded the alarm threshold.
Informational
Warning
1.3.6.1.4.1.25506.2.2.1.1.3.0.5 (hh3cVtyUsageResume)
ON
This notification is generated when the number of used VTY lines reaches or exceeds the alarm threshold.
System impact
Users cannot log in to the system through VTY lines.
Status control
Object
OID (object name)
Index
Value range
 (hh3cVtyCurrentVty)
N/A
Unsigned32
 (hh3cVtyMaxVty)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.2.1.1.2.6 (hh3cVtyThreshold)
N/A
Unsigned32
Recommended action
Quit unnecessary sessions to release user lines.
hh3cVtyUsageResume
Basic information
OID
Event
Severity
Default status
VTY usage alarm was cleared.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the number of used VTY lines drops below the VTY usage alarm threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
 (hh3cVtyCurrentVty)
N/A
Unsigned32
 (hh3cVtyMaxVty)
N/A
Unsigned32
N/A
Unsigned32
Recommended action
