02-Fundamentals
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10002-Fundamentals
03-HH3C-FTPS-MIB
03-HH3C-FTPS-MIB 81.13 KB
HH3C-FTPS-MIB
About this MIB
Use this MIB to obtain basic FTP server information and information about notifications.
MIB file name
hh3c-ftps.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2). hh3cFtps(248)
Scalar objects
hh3cFtpsLoginFailedTimes (1.3.6.1.4.1.25506.2.248.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Unsigned32
Standard MIB values.
Number of login failures.
As per the MIB.
hh3cFtpsLoginFailedStatPeriod (1.3.6.1.4.1.25506.2.248.1.2)
Object (OID)
Access
Value range
Implementation
Unsigned32
Statistics interval for user login failures.
As per the MIB.
Notifications
hh3cFtpsLoginFailed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.248.2.0.1
FTP login fails frequently.
Error
Warning
1.3.6.1.4.1.25506.2.248.2.0.2 (hh3cFtpsLoginFailedClear)
ON
Notification triggers
This notification is generated when the number of FTP login failures reaches the upper alarm threshold in the specified interval. The reason for this notification might be that user has attempted to log in to the FTP server for a long time, but no attempt succeeds.
System impact
The system might be under attack.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.248.1.1 (hh3cFtpsLoginFailedTimes)
Number of user login failures.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.248.1.2 (hh3cFtpsLoginFailedStatPeriod)
N/A
Unsigned32
Recommended action
To resolve the issue:
1.Verify that the login username and password are correct.
2.Configure ACLs to deny access requests from illegal addresses.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
An alarm on FTP login failures is cleared.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when an alarm on FTP login failures is cleared. The reason for this notification might be that the number of FTP login failures in a statistics period drops below the alarm clearance threshold.
System impact
No impact on the system.
Status control
Object
OID (object name)
Index
Value range
Recommended action
No action is required.
