02-Fundamentals
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10002-Fundamentals
02-HH3C-FLASH-MAN-MIB
02-HH3C-FLASH-MAN-MIB 185.62 KB
HH3C-FLASH-MAN-MIB
About this MIB
Use this MIB to obtain information about storage media, partitions, and files as well as manage files on the storage media.
MIB file name
hh3c-flash-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cFlash(5)
Scalar objects
hh3cFlhSupportNum (1.3.6.1.4.1.25506.2.5.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Standard MIB values.
Maximum number of storage media supported by the system.
As per the MIB.
Tabular objects
hh3cFlashTable
About this table
Use this table to obtain information about storage media.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cFlhIndex.
Object (OID)
Access
Value range
Implementation
hh3cFlhIndex (1.3.6.1.4.1.25506.2.5.1.1.2.1.1)
read-only
Integer32
Integer32 (1..2147483647)
Index of a storage medium.
If the most significant 16 bits are all zeros, the system does not support distributed file systems.
If the most significant 16 bits are not all zeros, the system supports distributed file systems.
For distributed file systems, the most significant 16 bits represent the entity index of the slot where a storage medium resides and the least significant 16 bits represent the number of the storage medium in the slot. The lowest number is 1 and the highest number is the number of storage media in the slot.
hh3cFlhSize (1.3.6.1.4.1.25506.2.5.1.1.2.1.2)
read-only
Integer32
Integer32 (-2147483648..2147483647)
Total size of the storage medium, in bytes.
As per the MIB.
hh3cFlhPos (1.3.6.1.4.1.25506.2.5.1.1.2.1.3)
read-only
PhysicalIndex
Entity index of the storage medium.
Not supported.
hh3cFlhName (1.3.6.1.4.1.25506.2.5.1.1.2.1.4)
read-only
DisplayString
OCTET STRING (0..255)
Storage medium name.
As per the MIB.
hh3cFlhChipNum (1.3.6.1.4.1.25506.2.5.1.1.2.1.5)
read-only
Integer32
Integer32 (1..64)
Number of chips on the storage medium.
Not supported.
hh3cFlhDescr (1.3.6.1.4.1.25506.2.5.1.1.2.1.6)
read-only
DisplayString
OCTET STRING(0~64)
Storage medium description.
Not supported.
hh3cFlhInitTime (1.3.6.1.4.1.25506.2.5.1.1.2.1.8)
read-only
TimeStamp
Initialization time of the storage medium.
Not supported.
hh3cFlhRemovable (1.3.6.1.4.1.25506.2.5.1.1.2.1.9)
read-only
TruthValue
true(1)
false(2)
Whether the storage medium is removable.
Not supported.
hh3cFlhPartitionBool (1.3.6.1.4.1.25506.2.5.1.1.2.1.11)
read-write
TruthValue
true(1)
false(2)
Whether the storage medium can be partitioned.
Not supported.
hh3cFlhMinPartitionSize (1.3.6.1.4.1.25506.2.5.1.1.2.1.12)
read-only
Integer32
Minimum partition size supported by the storage medium.
Not supported.
hh3cFlhMaxPartitions (1.3.6.1.4.1.25506.2.5.1.1.2.1.13)
read-only
Integer32
Integer32 (1..8)
Maximum number of partitions supported by the storage medium.
Not supported.
hh3cFlhPartitionNum (1.3.6.1.4.1.25506.2.5.1.1.2.1.14)
read-only
Integer32
Actual number of partitions on the storage medium.
Not supported.
hh3cFlhKbyteSize (1.3.6.1.4.1.25506.2.5.1.1.2.1.15)
read-only
Integer32
Total size of the storage medium, in kbytes.
As per the MIB.
hh3cFlhHCSize
(1.3.6.1.4.1.25506.2.5.1.1.2.1.16)
read-only
CounterBasedGauge64
Counter64 (0..18446744073709551615)
Total size of the storage medium.
This object is a 64-bit substitute for hh3cFlhSize.
If the total size of the storage medium exceeds 2 GB, the value of hh3cFlhSize is not accurate.
The value of hh3cFlhHCSize is the actual value.
hh3cFlhPartitionTable
About this table
Use this table to obtain information about partitions.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cFlhIndex and hh3cFlhPartIndex.
Object (OID)
Access
Value range
Implementation
hh3cFlhPartIndex (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.1)
not-accessible
Integer32
Integer32 (1..8)
Index of a partition on a storage medium.
As per the MIB.
hh3cFlhPartFirstChip (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.2)
read-only
Integer32
Integer32 (1..64)
The lowest chip number.
Not supported.
hh3cFlhPartLastChip (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.3)
read-only
Integer32
Integer32 (1..64)
The highest chip number.
Not supported.
hh3cFlhPartSpace (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.4)
read-only
Integer32
Total size of the partition, in bytes.
As per the MIB.
hh3cFlhPartSpaceFree (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.5)
read-only
Gauge32
Free size of the partition, in bytes.
As per the MIB.
hh3cFlhPartFileNum (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.6)
read-only
Integer32
Number of files in the partition.
Not supported.
hh3cFlhPartChecksumMethod (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.7)
read-only
INTEGER
simpleChecksum(1)
undefined(2)
simpleCRC(3)
Checksum calculation method.
Not supported.
hh3cFlhPartStatus (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.8)
read-only
Hh3cFlashPartitionStatus
readOnly(1)
runFromFlash(2)
readWrite(3)
Partition status.
As per the MIB.
hh3cFlhPartUpgradeMode (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.9)
read-only
Hh3cFlashPartitionUpgradeMode
unknown(1)
rxbootFLH(2)
direct(3)
Upgrade mode of the partition.
Not supported.
hh3cFlhPartName (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.10)
read-only
DisplayString
Partition name.
As per the MIB.
hh3cFlhPartRequireErase (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.11)
read-only
TruthValue
true(1)
false(2)
Whether a write operation is conditional on partition erase.
Not supported.
hh3cFlhPartFileNameLen (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.12)
read-only
Integer32
Integer32 (1..256)
Maximum filename length.
Not supported.
hh3cFlhPartBootable (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.13)
read-only
TruthValue
true(1)
false(2)
Whether the partition is a bootable partition.
As per the MIB.
hh3cFlhPartPathForGlobalOpt (1.3.6.1.4.1.25506.2.5.1.1.4.1.1.14)
read-write
TruthValue
true(1)
false(2)
Whether the partition is used in a global file operation.
Supports only the true(1) value.
The true(1) value indicates that in one global file operation, files will be copied to or deleted from this partition. By default, the value is true(1) only for the partition where the default working directory resides.
For rows whose hh3cFlhPartBootable value is false, the value for the hh3cFlhPartPathForGlobalOpt object is always false. In addition, you cannot change the value to true for this object.
If you change the value of hh3cFlhPartPathForGlobalOpt to true for a partition in the hh3cFlhPartitionTable table, the system automatically changes the value of hh3cFlhPartPathForGlobalOpt to false for other partitions on the same entity (slot) as that partition.
The same entity (slot) can have only one partition whose value for the hh3cFlhPartPathForGlobalOpt object is true.
hh3cFlhPartHCSpace
(1.3.6.1.4.1.25506.2.5.1.1.4.1.1.15)
read-only
CounterBasedGauge64
Total size of the partition.
This node is a 64-bit substitute for hh3cFlhPartSpace.
If the total size of the partition exceeds 2 GB, the value of hh3cFlhPartSpace is not accurate. The value of hh3cFlhPartHCSpace is the actual value.
hh3cFlhPartHCSpaceFree
(1.3.6.1.4.1.25506.2.5.1.1.4.1.1.16)
read-only
CounterBasedGauge64
Free size of the partition.
This node is a 64-bit substitute for hh3cFlhPartSpaceFree.
If the free size of the partition exceeds 2 GB, the value of hh3cFlhPartSpaceFree is not accurate. The value of hh3cFlhPartHCSpaceFree is the actual value.
hh3cFlhFileTable
About this table
Use this table to obtain information about files.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cFlhIndex, hh3cFlhPartIndex, and hh3cFlhFileIndex.
Object (OID)
Access
Value range
Implementation
hh3cFlhFileIndex (1.3.6.1.4.1.25506.2.5.1.1.4.2.1.1.1)
not-accessible
Integer32
Index of a file.
As per the MIB.
hh3cFlhFileName (1.3.6.1.4.1.25506.2.5.1.1.4.2.1.1.2)
read-only
DisplayString
OCTET STRING (1..255)
File or directory name.
As per the MIB.
hh3cFlhFileSize (1.3.6.1.4.1.25506.2.5.1.1.4.2.1.1.3)
read-only
Integer32
File size.
As per the MIB.
hh3cFlhFileStatus (1.3.6.1.4.1.25506.2.5.1.1.4.2.1.1.4)
read-only
INTEGER
deleted(1)
invalidChecksum(2)
valid(3)
File status.
As per the MIB.
hh3cFlhFileChecksum (1.3.6.1.4.1.25506.2.5.1.1.4.2.1.1.5)
read-only
OCTET STRING
File checksum.
Not supported.
hh3cFlhFileHCSize
(1.3.6.1.4.1.25506.2.5.1.1.4.2.1.1.6)
read-only
CounterBasedGauge64
File size.
This node is a 64-bit substitue for hh3cFlhFileSize.
If the file size exceeds 2 GB, the value of hh3cFlhFileSize is not accurate. The value of hh3cFlhFileHCSize is the actual value.
hh3cFlhFileType (1.3.6.1.4.1.25506.2.5.1.1.4.2.1.1.7)
read-only
INTEGER
file(1)
directory(2)
File type.
As per the MIB.
hh3cFlhOpTable
About this table
Use this table to perform the following operations:
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cFlhOperIndex.
Object (OID)
Access
Value range
Implementation
hh3cFlhOperIndex (1.3.6.1.4.1.25506.2.5.1.2.1.1.1)
not-accessible
Integer32
Index of a file operation.
If the value is within the range from 0x10000 to 0x1FFFF, the net2FlashWithErase, net2FlashWithoutErase, or delete operation will be performed on all partitions whose value for the hh3cFlhPartPathForGlobalOpt object is true.
hh3cFlhOperType (1.3.6.1.4.1.25506.2.5.1.2.1.1.2)
read-create
INTEGER
net2FlashWithErase(1)
net2FlashWithoutErase(2)
flash2Net(3)
delete(4)
rename(5)
mkdir(6)
rmdir(7)
copy(8)
File operation type.
For TFTP, the net2FlashWithoutErase operation is the same as the net2FlashWithErase.
TFTP does not support the rename and delete operations.
hh3cFlhOperProtocol (1.3.6.1.4.1.25506.2.5.1.2.1.1.3)
read-create
INTEGER
ftp(1)
tftp(2)
clusterftp(3)
clustertftp(4)
sftp(5)
Protocol used by file transfer.
Supports only FTP, TFTP, and SFTP.
If FTP is used, you must specify the hh3cFlhOperServerUser and hh3cFlhOperPassword objects.
By default, FTP is used.
hh3cFlhOperServerAddress (1.3.6.1.4.1.25506.2.5.1.2.1.1.4)
read-create
IpAddress
OCTET STRING (4)
Address of the remote file transfer server.
As per the MIB.
hh3cFlhOperServerUser (1.3.6.1.4.1.25506.2.5.1.2.1.1.5)
read-create
DisplayString
Username used to access the file transfer server.
As per the MIB.
hh3cFlhOperPassword (1.3.6.1.4.1.25506.2.5.1.2.1.1.6)
read-create
DisplayString
Password used to access the file transfer server.
When read, this node returns a zero-length string.
hh3cFlhOperSourceFile (1.3.6.1.4.1.25506.2.5.1.2.1.1.7)
read-create
DisplayString
Source file or directory of the operation.
If the index is within the range from 0x10000 to 0x1FFFF, the net2FlashWithErase, net2FlashWithoutErase, or delete operation supports only pure file names. A pure file name cannot contain a forward slash (/).
hh3cFlhOperDestinationFile (1.3.6.1.4.1.25506.2.5.1.2.1.1.8)
read-create
DisplayString
Destination file name of the operation.
As per the MIB.
hh3cFlhOperStatus (1.3.6.1.4.1.25506.2.5.1.2.1.1.9)
read-only
Hh3cFlashOperationStatus
opInProgress(1)
opSuccess(2)
opInvalid(3)
opInvalidProtocol(4)
opInvalidSourceName(5)
opInvalidDestName(6)
opInvalidServerAddress(7)
opDeviceBusy(8)
opDeviceOpenError(9)
opDeviceError(10)
opDeviceNotProgrammable(11)
opDeviceFull(12)
opFileOpenError(13)
opFileTransferError(14)
opFileChecksumError(15)
opNoMemory(16)
opAuthFail(17)
opTimeout(18)
opUnknownFailure(19)
opDeleteFileOpenError(20)
opDeleteInvalidDevice(21)
opDeleteInvalidFunction(22)
opDeleteOperationError(23)
opDeleteInvalidFileName(24)
opDeleteDeviceBusy(25)
opDeleteParaError(26)
opDeleteInvalidPath(27)
opDeleteFileNotExistInSlave(28)
opDeleteFileFailedInSlave(29)
opSlaveFull(30)
opCopyToSlaveFailure(31)
File operation status.
As per the MIB.
hh3cFlhOperEndNotification (1.3.6.1.4.1.25506.2.5.1.2.1.1.10)
read-create
TruthValue
true(1)
false(2)
Whether to notify that the file operation ends.
As per the MIB.
hh3cFlhOperProgress (1.3.6.1.4.1.25506.2.5.1.2.1.1.11)
read-only
TimeTicks
TimeTicks
Time taken by the file operation.
As per the MIB.
hh3cFlhOperRowStatus (1.3.6.1.4.1.25506.2.5.1.2.1.1.12)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
Supports only the active, createAndGo, and destroy operations.
hh3cFlhOperServerPort (1.3.6.1.4.1.25506.2.5.1.2.1.1.13)
read-create
Integer32
Integer32 (0..65535)
Port number of the file transfer server.
This node takes effect only when the file transfer protocol is FTP.
hh3cFlhOperFailReason (1.3.6.1.4.1.25506.2.5.1.2.1.1.14)
read-only
DisplayString
File operation failure reason.
As per the MIB.
hh3cFlhOperSrvAddrType (1.3.6.1.4.1.25506.2.5.1.2.1.1.15)
read-create
InetAddressType
ipv4(1)
ipv6(2)
dns(16)
Address type of the file transfer server.
As per the MIB.
hh3cFlhOperSrvAddrRev (1.3.6.1.4.1.25506.2.5.1.2.1.1.16)
read-create
InetAddress
Address of the file transfer server.
As per the MIB.
hh3cFlhOperSrvVPNName (1.3.6.1.4.1.25506.2.5.1.2.1.1.17)
read-create
DisplayString
VPN instance name of the file transfer operation.
As per the MIB.
hh3cFlhChipTable
About this table
Use this table to obtain information about the features of all flash memory chips. It is mainly used for diagnostics.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cFlhIndex and  hh3cFlhChipSerialNo.
Object (OID)
Access
Value range
Implementation
hh3cFlhChipSerialNo (1.3.6.1.4.1.25506.2.5.1.1.3.1.1.1)
not-accessible
Integer32
Integer32 (1..64)
Operation table index.
As per the MIB.
hh3cFlhChipID (1.3.6.1.4.1.25506.2.5.1.1.3.1.1.2)
read-only
DisplayString
(SIZE (0..5))
Chip manufacturer code (high bytes) and device code (low bytes). Unknown chips will be displayed as 00:00.
As per the MIB.
hh3cFlhChipDescr (1.3.6.1.4.1.25506.2.5.1.1.3.1.1.3)
read-only
DisplayString
(SIZE (0..32))
Flash memory chip description
As per the MIB.
hh3cFlhChipWriteTimesLimit (1.3.6.1.4.1.25506.2.5.1.1.3.1.1.4)
read-only
Integer32
Upper limit on the number of rewrites on flash memory chips. If the limit is exceeded, the management layer will report an error.
As per the MIB.
hh3cFlhChipWriteTimes (1.3.6.1.4.1.25506.2.5.1.1.3.1.1.5)
read-only
Counter32
Rewrite count since the flash memory chip's initialization.
If the count on a single chip is equal to or greater than 25, a write error occurred. The management layer is expected to record this count in the MIB before and after a write operation, and report errors based on the difference between these two counts.
As per the MIB.
hh3cFlhChipEraseTimesLimit (1.3.6.1.4.1.25506.2.5.1.1.3.1.1.6)
read-only
Integer32
Upper limit on the number of erases on flash memory chips. If the limit is exceeded, the management layer will report an error.
As per the MIB.
hh3cFlhChipEraseTimes (1.3.6.1.4.1.25506.2.5.1.1.3.1.1.6)
read-only
Counter32
Erase count since the flash memory chip's initialization.
If the count on a single chip is equal to or greater than 2000, an error occurred.
As per the MIB.
Notifications
hh3cFlhOperNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.5.1.3.1
A file operation completed.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when a file operation completes if the value of hh3cFlhOperEndNotification is true.
The parameters included in this notification vary by file operation. For more information, see the online help for the NMS.
System impact
No negative impact on the system.
Status control
ON
MIB: Set hh3cFlhOperEndNotification to true(1).
OFF
MIB: Set hh3cFlhOperEndNotification to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.5.1.2.1.1.9 (hh3cFlhOperStatus)
N/A
opInProgress(1), opSuccess(2), opInvalid(3), opInvalidProtocol(4), opInvalidSourceName(5), opInvalidDestName(6), opInvalidServerAddress(7), opDeviceBusy(8), opDeviceOpenError(9), opDeviceError(10), opDeviceNotProgrammable(11), opDeviceFull(12), opFileOpenError(13), opFileTransferError(14), opFileChecksumError(15), opNoMemory(16), opAuthFail(17), opTimeout(18), opUnknownFailure(19), opDeleteFileOpenError(20), opDeleteInvalidDevice(21), opDeleteInvalidFunction(22), opDeleteOperationError(23), opDeleteInvalidFileName(24), opDeleteDeviceBusy(25), opDeleteParaError(26), opDeleteInvalidPath(27), opDeleteFileNotExistInSlave(28), opDeleteFileFailedInSlave(29), opSlaveFull(30), opCopyToSlaveFailure(31)
Recommended action
If the operation finishes successfully, no action is required.
If the operation fails, handle the issue according to the failure reason. If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cFlhUsageOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.5.1.4.0.1
The disk usage exceeded the threshold.
Informational
Warning
1.3.6.1.4.1.25506.2.5.1.4.0.2 (hh3cFlhUsageResume)
ON
This notification is generated when the disk usage exceeds the alarm threshold.
System impact
If disk space is insufficient, file operations that require high disk space might fail, such as transferring, downloading, or loading version files.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.5.1.5.1 (hh3cFlhUsageRate)
Current disk usage.
N/A
Integer32
1.3.6.1.4.1.25506.2.5.1.5.2 (hh3cFlhUsageRateThreshold)
Disk usage threshold.
N/A
Integer32
1.3.6.1.4.1.25506.2.5.1.5.3 (hh3cFlhNameForTrap)
Disk name.
N/A
DisplayString
Recommended action
1.Verify that the disk space is insufficient and clear unnecessary files as needed.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cFlhUsageResume
Basic information
OID
Event
Severity
Default status
The disk usage dropped below the threshold.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the disk usage drops below the alarm threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Current disk usage.
N/A
Integer32
N/A
Integer32
Disk name.
N/A
DisplayString
Recommended action
No action is required.
hh3cFlhStateFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.5.1.4.0.3
An error occurred on the file system.
Informational
Warning
N/A (N/A)
ON
This notification is generated when an error occurred on the file system.
System impact
The file system is faulty.
Status control
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.5.1.5.4 (hh3cFlhStateSrcChassis)
Source chassis ID
N/A
Integer32
1.3.6.1.4.1.25506.2.5.1.5.5 (hh3cFlhStateSrcSlot)
Source slot ID
N/A
Integer32
1.3.6.1.4.1.25506.2.5.1.5.6 (hh3cFlhStateSrcCpu)
Source CPU ID
N/A
Integer32
1.3.6.1.4.1.25506.2.5.1.5.7 (hh3cFlhStateDestChassis)
Destination chassis ID
N/A
Integer32
1.3.6.1.4.1.25506.2.5.1.5.8 (hh3cFlhStateDestSlot)
Destination slot ID
N/A
Integer32
1.3.6.1.4.1.25506.2.5.1.5.9 (hh3cFlhStateDestCpu)
Destination CPU ID
N/A
Integer32
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help
hh3cFlhStateResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.5.1.4.0.4
The file system status is restored.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the file system status is restored.
System impact
Status control
Object
OID (object name)
Index
Value range
Source chassis ID
N/A
Integer32
Source slot ID
N/A
Integer32
Source CPU ID
N/A
Integer32
N/A
Integer32
Destination slot ID
N/A
Integer32
Destination CPU ID
N/A
Integer32
Recommended action
