02-Fundamentals
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10002-Fundamentals
07-HH3C-TELNET-MIB
07-HH3C-TELNET-MIB 81.04 KB
HH3C-TELNET-MIB
About this MIB
Use this MIB to obtain Telnet server basic information or the notifications sent by the Telnet server.
MIB file name
hh3c-telnet.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2). hh3cTelnet(249)
Scalar objects
hh3cTelnetsLoginFailedTimes (1.3.6.1.4.1.25506.2.249.1.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Unsigned32
Standard MIB values.
Number of user login failures.
As per the MIB.
hh3cTelnetsLoginFailedStatPeriod (1.3.6.1.4.1.25506.2.249.1.1.2)
Object (OID)
Access
Value range
Implementation
Unsigned32
Statistical period of user login failures.
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.249.1.2.0.1
A user frequently failed authentication when it logs in to the Telnet server.
Error
Warning
1.3.6.1.4.1.25506.2.249.1.2.0.2 (hh3cTelnetsLoginFailedClear)
ON
Notification triggers
This notification might be generated when the number of Telnet login failures reaches the specified upper threshold.
A user might have attempted to log in to the Telnet server for a long time and the attempts have failed.
System impact
The system might be attacked.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.249.1.1.1 (hh3cTelnetsLoginFailedTimes)
N/A
Unsigned32
1.3.6.1.4.1.25506.2.249.1.1.2 (hh3cTelnetsLoginFailedStatPeriod)
N/A
Unsigned32
Recommended action
To resolve this issue:
1.Verify that the username and password are correct.
2.Verify that an ACL has been configured to filter invalid addresses.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
Notification about Telnet user login failures was cleared.
Recovery
Warning
N/A (N/A)
ON
This notification might be generated when the number of login failures is smaller than the notification clearance threshold within the specified period.
System impact
No negative impact on the system.
Status control
Object
OID (object name)
Index
Value range
Recommended action
No action is required.
