05-HH3C-RBAC-MIB | 110.11 KB |
hh3cRbacRoleDefaultEnable (1.3.6.1.4.1.25506.2.158.1.2.1)
hh3cRbacRoleDefaultRoleName (1.3.6.1.4.1.25506.2.158.1.2.2)
HH3C-RBAC-MIB
About this MIB
Use this MIB to manage RBAC.
MIB file name
hh3c-rbac.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cRbac(158)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRbacRoleDefaultEnable (1.3.6.1.4.1.25506.2.158.1.2.1) |
read-write |
INTEGER |
true(1), false(2), |
Status of the default user role feature. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRbacRoleDefaultRoleName (1.3.6.1.4.1.25506.2.158.1.2.2) |
read-write |
DisplayString |
OCTET STRING (1..63) |
Default user role name. |
As per the MIB. |
Tabular objects
hh3cRbacFeatureTable
About this table
Use this table to display features on the device.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cRbacFeatureName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRbacFeatureName (1.3.6.1.4.1.25506.2.158.1.1.1.1.1) |
not-accessible |
OCTET STRING |
(SIZE(1..15)) |
Feature name. |
As per the MIB. |
hh3cRbacFeatureDescription (1.3.6.1.4.1.25506.2.158.1.1.1.1.2) |
read-only |
OCTET STRING |
(SIZE(1..63)) |
Basic introduction of the feature. |
As per the MIB. |
hh3cRbacRoleTable
About this table
Use this table to manage basic settings for all user roles.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cRbacRoleName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRbacRoleName (1.3.6.1.4.1.25506.2.158.1.2.3.1.1) |
not-accessible |
OCTET STRING |
(SIZE(1.. 63)) |
User role name. |
As per the MIB. |
hh3cRbacRoleDescription (1.3.6.1.4.1.25506.2.158.1.2.3.1.2) |
read-create |
OCTET STRING |
(SIZE(1.. 128)) |
User role description. |
As per the MIB. |
hh3cRbacRoleResourceAccess (1.3.6.1.4.1.25506.2.158.1.2.3.1.3) |
read-create |
Hh3cResourceType |
Standard MIB values. |
Default access permissions defined for resources that can be controlled by RBAC. For example, you can define 0011 for a user role if that user role can access all VLANs and all interfaces, but cannot access any VPN instances or security zones. |
As per the MIB. |
hh3cRbacRoleStorageType (1.3.6.1.4.1.25506.2.158.1.2.3.1.4) |
read-only |
StorageType |
Storage type of the role. |
As per the MIB. |
hh3cRbacRoleRowStatus (1.3.6.1.4.1.25506.2.158.1.2.3.1.5) |
read-create |
RowStatus |
Role status. |
As per the MIB. |
hh3cRbacRuleTable
About this table
Use this table to manage rules for all user roles.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cRbacRoleName, hh3cRbacRuleType, and hh3cRbacRuleNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRbacRuleType (1.3.6.1.4.1.25506.2.158.1.2.4.1.1) |
not-accessible |
Hh3cRuleType |
Rule type. |
As per the MIB. |
hh3cRbacRuleNumber (1.3.6.1.4.1.25506.2.158.1.2.4.1.2) |
not-accessible |
Unsigned32 |
Unsigned32(1..256) |
Rule number. The system supports predefined user role rules and user-defined user role rules for a user role. The total number of user-defined user role rules cannot exceed 1024. If a predefined user role rule and a user-defined user role rule conflict, the user-defined user role rule takes effect. If user role rules of the same type conflict, the following guidelines apply: For non-OID rules, if two rules of the same entity type conflict, the rule with the higher rule number takes effect. For OID rules, if the MIB node specified in one rule is a subnode to the MIB nodes specified in other rules, only this rule can take effect. If the same OID is specified in multiple rules, only the rule with the highest rule number takes effect. |
As per the MIB. |
hh3cRbacRuleAction (1.3.6.1.4.1.25506.2.158.1.2.4.1.3) |
read-create |
Hh3cRuleAction |
Rule action. |
As per the MIB. |
hh3cRbacRuleOperation (1.3.6.1.4.1.25506.2.158.1.2.4.1.4) |
read-create |
Hh3cRuleOperation |
Operation type restricted by the rule. |
As per the MIB. |
hh3cRbacRuleEntityType (1.3.6.1.4.1.25506.2.158.1.2.4.1.5) |
read-create |
Hh3cEntityType |
Entity type restricted by the rule. The following entity types are supported: unknown—Invalid type. command—A command or a group of commands that match with a regular expression. feature—A feature that contains a group of commands. featuregroup—A group of features. webmenu—Web menus. xmlelement—XML elements. oid—A MIB node and its child nodes |
As per the MIB. |
hh3cRbacRuleEntity (1.3.6.1.4.1.25506.2.158.1.2.4.1.5) |
read-create |
OCTET STRING |
(SIZE (0..255)) |
Entity restricted by the rule. The value is a regular expression that might match commands, features, feature groups, Web menus, XML elements, or MIB nodes. If the entity type is feature, webmenu, or xmlelement, and the entity is an empty string, this rule applies to all features, Web menus, or XML elements. |
As per the MIB. |
hh3cRbacRuleRowStatus (1.3.6.1.4.1.25506.2.158.1.2.4.1.5) |
read-create |
RowStatus |
Row status of the rule. |
As per the MIB. |
hh3cRbacPolicyTable
About this table
Use this table to display accessible resource access policies for all user roles.
Read:Supported
Columns
The table indexes are hh3cRbacRoleName, hh3cRbacPolicyType, and hh3cRbacPolicyValue.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRbacPolicyType (1.3.6.1.4.1.25506.2.158.1.1.5.1.1) |
not-accessible |
INTEGER |
vlan(1), interface(2), vrf(3), seczone(4) |
Type of a resource access policy. |
As per the MIB. |
hh3cRbacPolicyValue (1.3.6.1.4.1.25506.2.158.1.1.5.1.2) |
not-accessible |
OCTET STRING |
(SIZE(1..64)) |
Resources accessible to a user role. If the value for the hh3cRbacPolicyType object is vlan or interface, the value for the hh3cRbacPolicyValue object must be four eight-bit octets that represent VLAN IDs or interface indexes. If the value for the hh3cRbacPolicyType object is vrf or seczone, the value for the hh3cRbacPolicyValue object represents a string of VPN instance names or security zone names. |
As per the MIB. |
hh3cRbacPolicyRowStatus (1.3.6.1.4.1.25506.2.158.1.1.5.1.2) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
hh3cRbacFeatureGroupTable
About this table
Use this table to manage feature groups on the device.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cRbacFeatureGroupName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRbacFeatureGroupName (1.3.6.1.4.1.25506.2.158.1.2.6.1.1) |
not-accessible |
OCTET STRING |
(SIZE(1..31)) |
Name of a feature group. |
As per the MIB. |
hh3cRbacFeatureGroupRowStatus (1.3.6.1.4.1.25506.2.158.1.2.6.1.2) |
read-create |
RowStatus |
Row status of the feature group. |
As per the MIB. |
hh3cRbacFeatureInGroupTable
About this table
Use this table to manage features in feature groups on the device.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cRbacFeatureGroupName and hh3cRbacFeatureNameInGroup.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cRbacFeatureNameInGroup (1.3.6.1.4.1.25506.2.158.1.2.7.1.1) |
not-accessible |
OCTET STRING |
(SIZE(1..15)) |
Name of a feature in a feature group. |
As per the MIB. |
hh3cRbacFeatureInGroupRowStatus (1.3.6.1.4.1.25506.2.158.1.2.7.1.2) |
read-create |
RowStatus |
Row status of the feature. |
As per the MIB. |
