- 11-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-SAVI-MIB
- 15-HH3C-DOT11-WM2U-MIB
- 16-HH3C-DOT11-PROBE-MIB
- 17-HH3C-DOT11S-MESH-MIB
| 14-HH3C-DOT11-SAVI-MIB | 87.48 KB |
HH3C-DOT11-SAVI-MIB
About this MIB
Use this MIB to manage SAVI objects in WLAN scenarios.
MIB file name
hh3c-dot11-savi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11SAVI(20)
Tabular objects
hh3cDot11SAVIServiceTable
About this table
This table contains information about SAVI operating parameters for each service.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cDot11SAVIServiceIPVersion and hh3cDot11SAVIServiceServiceName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11SAVIServiceIPVersion (1.3.6.1.4.1.25506.2.75.20.1.1.1.1) |
not-accessible |
InetVersion |
unknown(0), ipv4(1), ipv6(2) |
IP version. |
As per the MIB. |
hh3cDot11SAVIServiceServiceName (1.3.6.1.4.1.25506.2.75.20.1.1.1.2) |
not-accessible |
OCTET STRING |
OCTET STRING(1..255) |
Service name. |
As per the MIB. |
hh3cDot11SAVIServiceValidStatus (1.3.6.1.4.1.25506.2.75.20.1.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Whether to check the validity state of the source address. If you set the attribute value to true, the interface will verify the source addresses. |
As per the MIB. |
hh3cDot11SAVIFilteringTable
About this table
This table contains packet filtering information.
Create:Not supported.
Edit/Modify:Not supported.
Delete:Not supported.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11SAVIFilteringIpType (1.3.6.1.4.1.25506.2.75.20.1.2.1.1) |
not-accessible |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
Source IP address type. |
As per the MIB. |
hh3cDot11SAVIFilteringServName (1.3.6.1.4.1.25506.2.75.20.1.2.1.2) |
not-accessible |
OCTET STRING |
Service name. |
OCTET STRING |
hh3cDot11SAVIFilteringIpAddress (1.3.6.1.4.1.25506.2.75.20.1.2.1.3) |
not-accessible |
InetAddress |
InetAddress(0..255) |
Source IP address. |
As per the MIB. |
hh3cDot11SAVIFilteringMacAddr (1.3.6.1.4.1.25506.2.75.20.1.2.1.4) |
read-only |
MacAddress |
MacAddress(6) |
Source MAC address. |
As per the MIB. |
hh3cDot11SAVICountTable
About this table
This table contains statistics on packets dropped due to SAVI check failures.
Read:Supported
Columns
The table indexes are hh3cDot11SAVICountIPVersion and hh3cDot11SAVICountServiceString.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11SAVICountIPVersion (1.3.6.1.4.1.25506.2.75.20.1.3.1.1) |
not-accessible |
InetVersion |
IP version. |
As per the MIB. |
hh3cDot11SAVICountServiceString (1.3.6.1.4.1.25506.2.75.20.1.3.1.2) |
not-accessible |
OCTET STRING |
Service name. |
As per the MIB. |
hh3cDot11SAVICountFilterPkts (1.3.6.1.4.1.25506.2.75.20.1.3.1.3) |
read-only |
Counter64 |
Standard MIB values. |
Number of lost packets. |
As per the MIB. |
hh3cDot11SAVIStatisTable
About this table
This table contains SAVI statistics.
Read:Supported
Columns
The table indexes are hh3cDot11SAVIStatisAPID and hh3cDot11SAVIStatisRadioID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11SAVIStatisAPID (1.3.6.1.4.1.25506.2.75.20.1.4.1.1) |
not-accessible |
Hh3cDot11ObjectIDType |
Hh3cDot11ObjectIDType(0..127) |
Unique ID of an AP. |
As per the MIB. |
hh3cDot11SAVIStatisRadioID (1.3.6.1.4.1.25506.2.75.20.1.4.1.2) |
not-accessible |
Hh3cDot11RadioScopeType |
Radio ID. |
As per the MIB. |
hh3cDot11SAVIStatisCount (1.3.6.1.4.1.25506.2.75.20.1.4.1.3) |
read-only |
Counter64 |
Number of data packets dropped due to SAVI check failures. |
As per the MIB. |
hh3cDot11SAVIStatisBytes (1.3.6.1.4.1.25506.2.75.20.1.4.1.4) |
read-only |
Counter64 |
Number of bytes dropped due to SAVI check failures. |
As per the MIB. |
hh3cDot11SAVIBindingCount (1.3.6.1.4.1.25506.2.75.20.1.4.1.5) |
read-only |
Counter64 |
Number of binding entries. |
As per the MIB. |
