- 11-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-SAVI-MIB
- 15-HH3C-DOT11-WM2U-MIB
- 16-HH3C-DOT11-PROBE-MIB
- 17-HH3C-DOT11S-MESH-MIB
| 05-HH3C-DOT11-CFGEXT-MIB | 91.72 KB |
hh3cDot11LoadBalanceTrafficEnable (1.3.6.1.4.1.25506.2.75.6.1.1.1)
hh3cDot11LoadBalanceTrafficThres (1.3.6.1.4.1.25506.2.75.6.1.1.2)
hh3cDot11LoadBalanceSessionEnable (1.3.6.1.4.1.25506.2.75.6.1.1.3)
hh3cDot11LoadBalanceSessionThres (1.3.6.1.4.1.25506.2.75.6.1.1.4)
hh3cDot11LoadBalanceTrafficGap (1.3.6.1.4.1.25506.2.75.6.1.1.5)
hh3cDot11LoadBalanceSessionGap (1.3.6.1.4.1.25506.2.75.6.1.1.6)
hh3cDot11LBTrafficThresKbps (1.3.6.1.4.1.25506.2.75.6.1.1.7)
hh3cDot11LBTrafficGapKbps (1.3.6.1.4.1.25506.2.75.6.1.1.8)
About this MIB
This MIB provides extended WLAN configuration information, defining the MIB nodes for advanced WLAN settings, such as load balancing. HH3C-DOT11-CFG-MIB defines the MIB nodes for basic WLAN settings.
MIB file name
hh3c-dot11-cfgext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11CFGEXT(6)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LoadBalanceTrafficEnable (1.3.6.1.4.1.25506.2.75.6.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable traffic-based load balancing. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LoadBalanceTrafficThres (1.3.6.1.4.1.25506.2.75.6.1.1.2) |
read-write |
Integer32 |
Standard MIB values. |
Traffic threshold that triggers traffic-based load balancing. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LoadBalanceSessionEnable (1.3.6.1.4.1.25506.2.75.6.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable session-based load balancing. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LoadBalanceSessionThres (1.3.6.1.4.1.25506.2.75.6.1.1.4) |
read-write |
Integer32 |
Session threshold that triggers session-based load balancing. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LoadBalanceTrafficGap (1.3.6.1.4.1.25506.2.75.6.1.1.5) |
read-write |
Integer32 |
Integer32(10..40) |
Traffic gap threshold that triggers traffic-based WLAN load balancing. The AC performs traffic-based WLAN load balancing when both the traffic threshold and the traffic gap threshold are exceeded. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LoadBalanceSessionGap (1.3.6.1.4.1.25506.2.75.6.1.1.6) |
read-write |
Integer32 |
Integer32(1..12) |
Session gap threshold that triggers session-based load balancing. The AC performs session-based WLAN radio load balancing when both the session threshold and the session gap threshold are exceeded. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LBTrafficThresKbps (1.3.6.1.4.1.25506.2.75.6.1.1.7) |
read-write |
Integer32 |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LBTrafficGapKbps (1.3.6.1.4.1.25506.2.75.6.1.1.8) |
read-write |
Integer32 |
Traffic gap threshold that triggers traffic-based WLAN radio load balancing. The AC performs traffic-based WLAN radio load balancing when the traffic gap threshold is exceeded. |
As per the MIB. |
Tabular objects
hh3cDot11LBRadioGroupId
About this table
Load balancing group ID.
Support for operations
Create:Supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cDot11LBRadioGroupId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11LBRadioGroupId (1.3.6.1.4.1.25506.2.75.6.1.2.1.1) |
not-accessible |
Unsigned32 |
Load balancing group ID. |
As per the MIB. |
hh3cDot11LBRadioGroupDesc (1.3.6.1.4.1.25506.2.75.6.1.2.1.2) |
read-create |
OCTET STRING |
Load balancing group description. |
As per the MIB. |
hh3cDot11LBRadioGroupRowStatus (1.3.6.1.4.1.25506.2.75.6.1.2.1.3) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status of the entry. |
As per the MIB. |
