11-WLAN
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R14xx R12xx)-6W10011-WLAN
08-HH3C-DOT11-WLANEXT-MIB
08-HH3C-DOT11-WLANEXT-MIB 80.70 KB
About this MIB
Use this MIB to provide extended WLAN information.
MIB file name
hh3c-dot11-wlanext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11WLANEXT(7)
Tabular objects
hh3cDot11RFSignalStatisTable
About this table
This table provides signal strength statistics for each radio frequency of the specified AP.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11RFAPID and hh3cDot11RFRadioID.
Object (OID)
Access
Value range
Implementation
hh3cDot11RFAPID (1.3.6.1.4.1.25506.2.75.7.1.1.1.1)
not-accessible
Hh3cDot11ObjectIDType
OCTET STRING(0..127)
Unique ID of the running AP.
As per the MIB.
hh3cDot11RFRadioID (1.3.6.1.4.1.25506.2.75.7.1.1.1.2)
not-accessible
Hh3cDot11RadioScopeType
Standard MIB values.
Unique ID of the running AP radio frequency.
As per the MIB.
hh3cDot11RFSignalStatisInterv (1.3.6.1.4.1.25506.2.75.7.1.1.1.3)
read-only
Integer32
Statistics collection interval for the AP radio frequency.
As per the MIB.
hh3cDot11RFAverageSignalStrength (1.3.6.1.4.1.25506.2.75.7.1.1.1.4)
read-only
Integer32
Average signal strength of the AP radio frequency.
As per the MIB.
hh3cDot11RFMaxSignalStrength (1.3.6.1.4.1.25506.2.75.7.1.1.1.5)
read-only
Integer32
Maximum signal strength of the AP radio frequency.
As per the MIB.
hh3cDot11RFMinSignalStrength (1.3.6.1.4.1.25506.2.75.7.1.1.1.6)
read-only
Integer32
Minimum signal strength of the AP radio frequency.
As per the MIB.
hh3cDot11QosStatisTable
About this table
This table defines the radio QoS settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11QosAPID and hh3cDot11QosRadioID.
Object (OID)
Access
Value range
Implementation
hh3cDot11QosAPID (1.3.6.1.4.1.25506.2.75.7.2.1.1.1)
not-accessible
OCTET STRING (0..127)
As per the MIB.
hh3cDot11QosRadioID (1.3.6.1.4.1.25506.2.75.7.2.1.1.2)
not-accessible
Radio ID.
As per the MIB.
hh3cDot11QosAverageQueLen (1.3.6.1.4.1.25506.2.75.7.2.1.1.3)
read-only
Integer32
Average number of frames transmitted to the queue.
As per the MIB.
hh3cDot11QosDropFrameRatio (1.3.6.1.4.1.25506.2.75.7.2.1.1.4)
read-only
Integer32
Ratio of frames dropped per minute after the queue was filled.
As per the MIB.
hh3cDot11QosAverageDataRate (1.3.6.1.4.1.25506.2.75.7.2.1.1.5)
read-only
Integer32
Average data transmission rate.
As per the MIB.
hh3cDot11QosAcStatisTable
About this table
This table defines the access-type QoS settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11QosAPID, hh3cDot11QosRadioID, and hh3cDot11QosAcType.
Object (OID)
Access
Value range
Implementation
hh3cDot11QosAcType (1.3.6.1.4.1.25506.2.75.7.2.2.1.1)
not-accessible
Hh3cDot11QosAcType
acbk(1),
acbe(2),
acvi(3),
acvo(4)
Access type.
As per the MIB.
hh3cDot11AcDropFrameCnt (1.3.6.1.4.1.25506.2.75.7.2.2.1.2)
read-only
Counter32
Number of frames dropped per minute after the queue was filled.
As per the MIB.
