11-WLAN
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R14xx R12xx)-6W10011-WLAN
12-HH3C-DOT11-SA-MIB
12-HH3C-DOT11-SA-MIB 125.62 KB
HH3C-DOT11-SA-MIB
About this MIB
Use this MIB to configure spectrum analysis and display spectrum analysis information.
MIB file name
hh3c-dot11-sa.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11Sa(13)
Scalar objects
hh3cDot11SaTrapAPID (1.3.6.1.4.1.25506.2.75.13.3.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
DisplayString
OCTET STRING(0..127)
AP ID.
As per the MIB.
hh3cDot11SaTrapRadioID (1.3.6.1.4.1.25506.2.75.13.3.1.2)
Object (OID)
Access
Value range
Implementation
Integer32
Standard MIB values.
Radio ID.
As per the MIB.
hh3cDot11SaTrapDevID (1.3.6.1.4.1.25506.2.75.13.3.1.3)
Object (OID)
Access
Value range
Implementation
Integer32
Unique identifier of an interference device.
As per the MIB.
hh3cDot11SaTrapIntfDevType (1.3.6.1.4.1.25506.2.75.13.3.1.4)
Object (OID)
Access
Value range
Implementation
INTEGER
microwave(1),
microwaveInverter(2),
bluetooth(3),
fixedFreqOthers(4), fixedFreqCordlessPhone(5),
fixedFreqVideo(6),
fixedFreqAudio(7),
freqHopperOthers(8), freqHopperCordlessBase(9), freqHopperCordlessNetwork(10),
freqHopperXbox(11),
genericInterferer(12)
Type of the interference device.
As per the MIB.
hh3cDot11APTrapDevSI (1.3.6.1.4.1.25506.2.75.13.3.1.5)
Object (OID)
Access
Value range
Implementation
Integer32
Severity level of interferences caused by the interference device.
The value is an integer in the range of 0 to 100 (with 100 being the most severe).
As per the MIB.
hh3cDot11SaTrapDevRSSI (1.3.6.1.4.1.25506.2.75.13.3.1.6)
Object (OID)
Access
Value range
Implementation
Integer32
RSSI of the interference device.
As per the MIB.
hh3cDot11APTrapDevDC (1.3.6.1.4.1.25506.2.75.13.3.1.7)
Object (OID)
Access
Value range
Implementation
Integer32
Percentage of time the interference device is active.
As per the MIB.
hh3cDot11APTrapDevChls (1.3.6.1.4.1.25506.2.75.13.3.1.8)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Channel affected by the interference device.
As per the MIB.
hh3cDot11APTrapDevDctTime (1.3.6.1.4.1.25506.2.75.13.3.1.9)
Object (OID)
Access
Value range
Implementation
DateAndTime
Time at which interference was detected.
As per the MIB.
hh3cDot11SaTrapChlNum (1.3.6.1.4.1.25506.2.75.13.3.1.10)
Object (OID)
Access
Value range
Implementation
Integer32
Channel used to monitor the air quality.
As per the MIB.
hh3cDot11SaTrapChlQlt (1.3.6.1.4.1.25506.2.75.13.3.1.11)
Object (OID)
Access
Value range
Implementation
Integer32
Quality of the channel.
As per the MIB.
hh3cDot11SaTrapChlIntfNum (1.3.6.1.4.1.25506.2.75.13.3.1.12)
Object (OID)
Access
Value range
Implementation
Integer32
Number of interference sources detected by 802.11a/n or 802.11b/g/n radios.
As per the MIB.
Tabular objects
hh3cDot11SaRtFFTDataTable
About this table
Use this table to obtain real-time FFT data of spectrum analysis.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11SaAPID, hh3cDot11SaRadioID, hh3cDot11SaRtDataGroupID, and hh3cDot11SaFrequency.
Object (OID)
Access
Value range
Implementation
hh3cDot11SaAPID (1.3.6.1.4.1.25506.2.75.13.2.1.1.1)
not-accessible
DisplayString
Serial number of the AP.
As per the MIB.
hh3cDot11SaRadioID (1.3.6.1.4.1.25506.2.75.13.2.1.1.2)
not-accessible
Integer32
Radio ID.
As per the MIB.
hh3cDot11SaRtDataGroupID (1.3.6.1.4.1.25506.2.75.13.2.1.1.3)
not-accessible
Integer32
Group ID of the collected data. A device might collect multiple groups of data during the data collection period.
As per the MIB.
(1.3.6.1.4.1.25506.2.75.13.2.1.1.4)
not-accessible
Integer32
Frequency, in 100 Hz.
As per the MIB.
hh3cDot11SaRtFreqPower
(1.3.6.1.4.1.25506.2.75.13.2.1.1.5)
read-only
Integer32
Power at the frequency point.
As per the MIB.
hh3cDot11SaRtFreqMaxPower (1.3.6.1.4.1.25506.2.75.13.2.1.1.6)
read-only
Integer32
Maximum power at the frequency point.
As per the MIB.
hh3cDot11SaRtFreqDutyCycle
(1.3.6.1.4.1.25506.2.75.13.2.1.1.7)
read-only
Integer32
Duty cycle at the frequency point.
As per the MIB.
hh3cDot11SaRtFreqDataSeqNo
(1.3.6.1.4.1.25506.2.75.13.2.1.1.8)
read-only
Unsigned32
Serial number of the data.
As per the MIB.
hh3cDot11SaIntfDevTable
About this table
Use this table to obtain information about interference devices in spectrum analysis.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11SaAPID, hh3cDot11SaRadioID, and hh3cDot11SaDevID.
Object (OID)
Access
Value range
Implementation
hh3cDot11SaDevID (1.3.6.1.4.1.25506.2.75.13.2.2.1.1)
not-accessible
Integer32
As per the MIB.
hh3cDot11SaDevType (1.3.6.1.4.1.25506.2.75.13.2.2.1.2)
read-only
INTEGER
microwave(1), microwaveInverter(2),
bluetooth(3), fixedFreqOthers(4), fixedFreqCordlessPhone(5), fixedFreqVideo(6), fixedFreqAudio(7), freqHopperOthers(8), freqHopperCordlessBase(9), freqHopperCordlessNetwork(10), freqHopperXbox(11), genericInterferer(12)
Type of the interference source.
As per the MIB.
hh3cDot11SaDevSI (1.3.6.1.4.1.25506.2.75.13.2.2.1.3)
read-only
Integer32
Severity level of interferences caused by the interference device. The value is an integer in the range of 0 to 100 (with 100 being the most severe).
As per the MIB.
hh3cDot11SaDevRSSI (1.3.6.1.4.1.25506.2.75.13.2.2.1.4)
read-only
Integer32
As per the MIB.
hh3cDot11SaDevDutyCycle
(1.3.6.1.4.1.25506.2.75.13.2.2.1.5)
read-only
Integer32
As per the MIB.
hh3cDot11SaDevAffectedChls (1.3.6.1.4.1.25506.2.75.13.2.2.1.6)
read-only
OCTET STRING
As per the MIB.
hh3cDot11SaDevDetectedTime (1.3.6.1.4.1.25506.2.75.13.2.2.1.7)
read-only
DateAndTime
As per the MIB.
hh3cDot11SaAirQualityTable
About this table
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11SaAPID, hh3cDot11SaRadioID, and hh3cDot11SaChlNum.
Object (OID)
Access
Value range
Implementation
hh3cDot11SaChlNum (1.3.6.1.4.1.25506.2.75.13.2.3.1.1)
not-accessible
Integer32
As per the MIB.
hh3cDot11SaAvgQuality (1.3.6.1.4.1.25506.2.75.13.2.3.1.2)
read-only
Integer32
Average air quality of the channel.
As per the MIB.
hh3cDot11SaMinQuality (1.3.6.1.4.1.25506.2.75.13.2.3.1.3)
read-only
Integer32
Lowest air quality of the channel.
As per the MIB.
hh3cDot11SaIntfDevNum (1.3.6.1.4.1.25506.2.75.13.2.3.1.4)
read-only
Integer32
As per the MIB.
hh3cDot11SaWiFiUtil (1.3.6.1.4.1.25506.2.75.13.2.3.1.5)
read-only
Integer32
Percentage of channels currently used by Wi-Fi devices.
As per the MIB.
hh3cDot11SaNonWiFiUtil (1.3.6.1.4.1.25506.2.75.13.2.3.1.6)
read-only
Integer32
Percentage of channels currently used by non-Wi-Fi interferences.
As per the MIB.
hh3cDot11SaNoiseFloor (1.3.6.1.4.1.25506.2.75.13.2.3.1.7)
read-only
Integer32
Current noise floor recorded for the channel.
As per the MIB.
