11-WLAN
HomeSupportWirelessWX3800X Series Access ControllersReference GuidesMIB CompanionH3C Wireless Products MIB Reference(R14xx R12xx)-6W10011-WLAN
13-HH3C-DOT11-RRM-MIB
13-HH3C-DOT11-RRM-MIB 168.05 KB
HH3C-DOT11-RRM-MIB
About this MIB
Use this MIB to manage wireless resources.
MIB file name
hh3c-dot11-rrm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11RRM(8)
Scalar objects
hh3cDot11APInterfNumThreshhd (1.3.6.1.4.1.25506.2.75.8.1.1.9)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
As per the MIB.
AP interference threshold. If the AP interference value exceeds this threshold, the device will send an AP interference trap. If the value for this node is 0, the device will send an AP interference trap immediately.
Supported
hh3cDot11StaInterfNumThreshhd (1.3.6.1.4.1.25506.2.75.8.1.1.10)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
As per the MIB.
Client interference threshold. If the client interference value exceeds this threshold, the device will send a client interference trap. If the value for this node is 0, the device will send a client interference trap immediately.
Supported
Tabular objects
hh3cDot11RRMAPCfgTable
About this table
Use this table to configure RRM-related parameters for an AP.
Support for operations
CreateNot supported
ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11APElementIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11RRMAPWorkMode (1.3.6.1.4.1.25506.2.75.8.1.3.1.1)
read-write
INTEGER
normal(1)
monitor(2)
hybrid(3)
AP operating modes
As per the MIB.
hh3cDot11RRMSDRadioGroupTable
About this table
Use this table to configure an RRM holddown group.
CreateSupported
ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is hh3cDot11RRMSDRadioGroupId.
Object (OID)
Access
Value range
Implementation
hh3cDot11RRMSDRadioGroupId (1.3.6.1.4.1.25506.2.75.8.1.4.1.1)
not-accessible
Unsigned32
Unsigned32(1..128)
ID of the RRM holddown group.
As per the MIB.
hh3cDot11RRMSDRadioGroupDesc(1.3.6.1.4.1.25506.2.75.8.1.4.1.2)
read-create
OCTET STRING
OCTET STRING(0..64)
Description of the RRM holddown group.
As per the MIB.
hh3cDot11RRMSDRdGrpChlHolddownTm(1.3.6.1.4.1.25506.2.75.8.1.4.1.3)
read-create
Unsigned32
Unsigned32(10..1140)
Channel holddown time for the RRM holddown group.
As per the MIB.
hh3cDot11RRMSDRdGrpPwrHolddownTm(1.3.6.1.4.1.25506.2.75.8.1.4.1.4)
read-create
Unsigned32
Power holddown time for the RRM holddown group.
As per the MIB.
hh3cDot11RRMSDRdGroupRowStatus(1.3.6.1.4.1.25506.2.75.8.1.4.1.5)
read-create
RowStatus
active(1)
notInService(2)
notReady (3)
createAndGo(4)
createAndWait (5)
destroy(6)
Row state of the table.
As per the MIB.
hh3cDot11RRMAPCfg2Table
About this table
CreateNot supported
ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cDot11RRMAPSerialID.
Object (OID)
Access
Value range
Implementation
hh3cDot11RRMAPSerialID (1.3.6.1.4.1.25506.2.75.8.1.5.1.1)
not-accessible
Hh3cDot11ObjectIDType
OCTET STRING(0..127)
AP Serial ID
As per the MIB.
hh3cDot11RRMAPIntfThreshold
(1.3.6.1.4.1.25506.2.75.8.1.5.1.2)
read-write
Integer32
Integer32(1..64)
AP interference threshold. If the number of interference sources exceeds this threshold, the device will send an AP interference trap.
As per the MIB.
hh3cDot11RRMStaIntfThreshold
(1.3.6.1.4.1.25506.2.75.8.1.5.1.3)
read-write
Integer32
Integer32(1..64)
Client interference threshold. If the number of interference sources exceeds this threshold, the device will send a client interference trap.
As per the MIB.
hh3cDot11RRMCoChlIntfTrapThhd(1.3.6.1.4.1.25506.2.75.8.1.5.1.4)
read-write
Integer32
Integer32(10..90)
Interference trap threshold for the current AP. If the device signal strength exceeds this threshold, a trap will be sent.
As per the MIB.
hh3cDot11RRMAdjChlIntfTrapThhd(1.3.6.1.4.1.25506.2.75.8.1.5.1.5)
read-write
Integer32
Integer32(10..90)
Trap threshold for adjacent-channel interference for the current AP. If the signal strength on a device exceeds this threshold, a trap will be sent.
As per the MIB.
hh3cDot11RRMChlRptTable
About this table
Use this table to display RRM channel information for each radio on all APs.
CreateNot supported
ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11RRMRadioIndex and hh3cDot11RRMChlRptChlNum.
Object (OID)
Access
Value range
Implementation
hh3cDot11RRMRadioIndex (1.3.6.1.4.1.25506.2.75.8.2.1.1.1)
accessible-for-notify
Hh3cDot11RadioElementIndex
Standard MIB values.
Radio ID and AP ID.
As per the MIB.
(1.3.6.1.4.1.25506.2.75.8.2.1.1.2)
Integer32
Channel number.
As per the MIB.
hh3cDot11RRMChlRptChlType
(1.3.6.1.4.1.25506.2.75.8.2.1.1.3)
read-only
INTEGER
primeChannel(1)
offChannel(2)
Channel type.
As per the MIB.
hh3cDot11RRMChlRptChlQlty
(1.3.6.1.4.1.25506.2.75.8.2.1.1.4)
read-only
INTEGER
good(1)
bad(2)
Channel quality.
As per the MIB.
hh3cDot11RRMChlRptNbrCnt
(1.3.6.1.4.1.25506.2.75.8.2.1.1.5)
read-only
Integer32
Number of neighbors on the current channel.
As per the MIB.
hh3cDot11RRMChlRptLoad
(1.3.6.1.4.1.25506.2.75.8.2.1.1.6)
read-only
Integer32
Integer32 (0..100)
Load percentage on the channel.
As per the MIB.
hh3cDot11RRMChlRptUtlz
(1.3.6.1.4.1.25506.2.75.8.2.1.1.7)
read-only
Integer32
Integer32 (0..100)
Channel usage.
As per the MIB.
hh3cDot11RRMChlRptIntrf
(1.3.6.1.4.1.25506.2.75.8.2.1.1.8)
read-only
Integer32
Integer32 (0..100)
Percentage of interference observed on the channel.
As per the MIB.
hh3cDot11RRMChlRptPER (1.3.6.1.4.1.25506.2.75.8.2.1.1.9)
read-only
Integer32
Integer32 (0..100)
Package error rate observed on the channel.
As per the MIB.
hh3cDot11RRMChlRptRetryRate
(1.3.6.1.4.1.25506.2.75.8.2.1.1.10)
read-only
Integer32
Integer32 (0..100)
Packet retransmission rate on the channel.
As per the MIB.
hh3cDot11RRMChlRptNoise
(1.3.6.1.4.1.25506.2.75.8.2.1.1.11)
read-only
Integer32
Noise on the channel.
As per the MIB.
hh3cDot11RRMChlRptRadarIndtcr(1.3.6.1.4.1.25506.2.75.8.2.1.1.12)
read-write
INTEGER
detected(1)
notDetected(2)
Radar state.
As per the MIB.
hh3cDot11RRMNbrInfoTable
About this table
Use this table to display neighbor information for each radio on all APs.
CreateSupported
ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cDot11RRMRadioIndex and hh3cDot11RrmNbrBSSID.
Object (OID)
Access
Value range
Implementation
hh3cDot11RrmNbrBSSID (1.3.6.1.4.1.25506.2.75.8.2.2.1)
not-accessible
MacAddress
AP's MAC address.
As per the MIB.
hh3cDot11RrmNbrChl
(1.3.6.1.4.1.25506.2.75.8.2.2.2)
read-only
Hh3cDot11ChannelScopeType
Neighbor's channel number.
As per the MIB.
hh3cDot11RRMNbrIntrf
(1.3.6.1.4.1.25506.2.75.8.2.2.3)
read-only
Integer32
Integer32(0..100)
Neighbor channel interference percentage.
As per the MIB.
hh3cDot11RrmNbrRSSI
(1.3.6.1.4.1.25506.2.75.8.2.2.4)
read-only
Integer32
AP signal strength.
As per the MIB.
hh3cDot11RrmNbrType
(1.3.6.1.4.1.25506.2.75.8.2.2.5)
read-only
INTEGER
managed(1)
unmanaged(2)
Neighbor type, managed or unmanaged.
As per the MIB.
hh3cDot11RrmNbrSSID
(1.3.6.1.4.1.25506.2.75.8.2.2.6)
read-only
Hh3cDot11SSIDStringType
Neighbor's SSID.
As per the MIB.
hh3cDot11RrmNbrSNR
(1.3.6.1.4.1.25506.2.75.8.2.2.7)
read-only
Integer32
Signal-to-noise ratio of the AP.
As per the MIB.
hh3cDot11RrmNbrNF
(1.3.6.1.4.1.25506.2.75.8.2.2.8)
read-only
Integer32
AP’s noise floor.
As per the MIB.
hh3cDot11RRMHistoryTable
About this table
Use this table to display details of adjustments to AP channel, power, and bandwidth, including the time of change, the reasons for the change, and parameters related to channel, power, and interference.
CreateNot supported
ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11RRMRadioIndex, hh3cDot11RRMHistoryId, and hh3cDot11RRMHistoryRecIndctr.
Object (OID)
Access
Value range
Implementation
hh3cDot11RRMHistoryId (1.3.6.1.4.1.25506.2.75.8.2.3.1.1)
not-accessible
Integer32
Change history number
As per the MIB.
(1.3.6.1.4.1.25506.2.75.8.2.3.1.2)
not-accessible
INTEGER
before(1)
after(2)
Change history type.
As per the MIB.
hh3cDot11RRMHistoryChl
(1.3.6.1.4.1.25506.2.75.8.2.3.1.3)
read-only
Channel where the radio is running before and after changes.
As per the MIB.
hh3cDot11RRMHistoryPwr
(1.3.6.1.4.1.25506.2.75.8.2.3.1.4)
read-only
Integer32
Power of the radio before and after changes.
As per the MIB.
hh3cDot11RRMHistoryLoad
(1.3.6.1.4.1.25506.2.75.8.2.3.1.5)
read-only
Integer32
Integer32(0..100)
Load percentage on the radio before or after the channel or power is changed.
As per the MIB.
hh3cDot11RRMHistoryUtlz
(1.3.6.1.4.1.25506.2.75.8.2.3.1.6)
read-only
Integer32
Integer32(0..100)
Radio usage before or after the channel or power is changed.
As per the MIB.
hh3cDot11RRMHistoryIntrf
(1.3.6.1.4.1.25506.2.75.8.2.3.1.7)
read-only
Integer32
Integer32(0..100)
Interference percentage on the radio before or after the channel or power is changed.
As per the MIB.
hh3cDot11RRMHistoryNoise
(1.3.6.1.4.1.25506.2.75.8.2.3.1.8)
read-only
Integer32
Noise on the radio before or after the channel or power is changed.
As per the MIB.
hh3cDot11RRMHistoryPER
(1.3.6.1.4.1.25506.2.75.8.2.3.1.9)
read-only
Integer32
Integer32(0..100)
Error rate on the radio before or after the channel or power is changed.
As per the MIB.
hh3cDot11RRMHistoryRetryRate
(1.3.6.1.4.1.25506.2.75.8.2.3.1.10)
read-only
Integer32
Integer32(0..100)
Retransmission ratio on the radio before or after the channel or power is changed.
As per the MIB.
hh3cDot11RRMHistoryChgReason(1.3.6.1.4.1.25506.2.75.8.2.3.1.11)
read-only
BITS
others(0)
coverage(1)
radar(2)
retransmission(3)
packetsDiscarded(4)
interference(5)
Reasons for changes in power and channel.
As per the MIB.
hh3cDot11RRMHistoryChgDateTime(1.3.6.1.4.1.25506.2.75.8.2.3.1.12)
read-only
DateAndTime
Time of power or channel change.
As per the MIB.
hh3cDot11RRMRadioNbrInfoTable
About this table
Use this table to manage information about the neighbors of each radio on all APs.
CreateSupported
ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cDot11RRMRadioNbrAPID and hh3cDot11RRMRadioNbrRadioID.
Object (OID)
Access
Value range
Implementation
hh3cDot11RRMRadioNbrAPID (1.3.6.1.4.1.25506.2.75.8.2.4.1.1)
not-accessible
AP ID.
As per the MIB.
(1.3.6.1.4.1.25506.2.75.8.2.4.1.2)
not-accessible
Hh3cDot11RadioScopeType
AP radio ID.
As per the MIB.
hh3cDot11RRMRadioNbrSSID
(1.3.6.1.4.1.25506.2.75.8.2.4.1.3)
read-only
OCTET STRING
Information about all neighbors detected by the specified radio.
As per the MIB.
hh3cDot11MonitorDetectedDevTable
About this table
Use this table to configure detected device information.
CreateNot supported
ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cDot11MonitorDevMAC and hh3cDot11APElementIndex.
Object (OID)
Access
Value range
Implementation
hh3cDot11MonitorDevMAC (1.3.6.1.4.1.25506.2.75.8.4.1.1.1)
not-accessible
MacAddress
MAC address of the detected device.
As per the MIB.
hh3cDot11MonitorDevType
(1.3.6.1.4.1.25506.2.75.8.4.1.1.2)
read-only
INTEGER
client(1)
ap(2)
adhoc(3)
wirelessBridge(4)
unknown(5)
Type of the detected device.
As per the MIB.
hh3cDot11MonitorDevVendor
(1.3.6.1.4.1.25506.2.75.8.4.1.1.3)
read-only
OCTET STRING
Vendor for the detected device.
As per the MIB.
hh3cDot11MonitorDevSSID
(1.3.6.1.4.1.25506.2.75.8.4.1.1.4)
read-only
OCTET STRING
SSID type for the device, ap or adhoc.
As per the MIB.
hh3cDot11MonitorDevBSSID
(1.3.6.1.4.1.25506.2.75.8.4.1.1.5)
read-only
MacAddress
BSSID of the detected device.
As per the MIB.
hh3cDot11MonitorDevChannel
(1.3.6.1.4.1.25506.2.75.8.4.1.1.6)
read-only
Channel of the device detected last time. The AP will select the channel with the strongest signal as the effective channel due to interference between adjacent channels.
As per the MIB.
hh3cDot11MonitorRadioId
(1.3.6.1.4.1.25506.2.75.8.4.1.1.7)
read-only
Radio ID detected by the AP.
As per the MIB.
hh3cDot11MonitorDevMaxRSSI
(1.3.6.1.4.1.25506.2.75.8.4.1.1.8)
read-only
Integer32
Maximum RSSI value detected by the device during the scan report period.
As per the MIB.
hh3cDot11MonitorDevBeaconIntvl
(1.3.6.1.4.1.25506.2.75.8.4.1.1.9)
read-only
Integer32
Beacon interval for the detected device (excluding clients).
As per the MIB.
hh3cDot11MonitorDevFstDctTime
(1.3.6.1.4.1.25506.2.75.8.4.1.1.10)
read-only
DateAndTime
OCTET STRING (SIZE (8 | 11))
(without time zone: 8, with time zone: 11)
Time when the device was first detected
As per the MIB.
hh3cDot11MonitorDevLstDctTime (1.3.6.1.4.1.25506.2.75.8.4.1.1.11)
read-only
DateAndTime
Last time the device was detected.
As per the MIB.
hh3cDot11MonitorDevClear (1.3.6.1.4.1.25506.2.75.8.4.1.1.12)
read-write
TruthValue
true(1)
false(2)
Clear the detected device information.
As per the MIB.
hh3cDot11MonitorDevSNR(1.3.6.1.4.1.25506.2.75.8.4.1.1.13)
read-only
Integer32
Signal-to-noise ratio during the scan period.
As per the MIB.
Notifications
hh3cDot11RRMIntrfLimit
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.75.8.3.1.0.1
Air interface interference crossing threshold alarm.
Informational
Warning
N/A (N/A)
Off
Notification triggers
This notification is triggered when the air interface detects that channel interference exceeds the specified threshold.
System impact
None.
Status control
ON
CLI: Use the snmp-agent trap enable wlan rrm command.
OFF
CLI: Use the undo snmp-agent trap enable wlan rrm command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.8.2.1.1.8 (hh3cDot11RRMChlRptIntrf)
Channel interference.
N/A
Integer32
Integer32, (0..100)
Recommended action
1.No action is required.
hh3cDot11RRMPERLimit
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.8.3.1.0.2
Error packet crossing threshold alarm
Informational
Warning
N/A (N/A)
Off
This notification is triggered when the air interface detects that the proportion of received error packets exceeds the specified threshold.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.8.2.1.1.9 (hh3cDot11RRMChlRptPER)
Error packet ratio
N/A
Integer32
Integer32, (0..100)
Recommended action
hh3cDot11RRMPowerChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.75.8.3.2.0.1
Power change notification
Informational
Warning
N/A (N/A)
Off
This notification is triggered when the transmission power of a radio changes.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.75.8.2.1.1.1 (hh3cDot11RRMRadioIndex)
RADIO ID
N/A
Integer32
Integer32, (1..4)
1.3.6.1.4.1.25506.2.75.8.3.3.1
 (hh3cDot11NewPower)
New power value.
N/A
Integer32
Integer32, (1..100)
1.3.6.1.4.1.25506.2.75.8.3.3.2 (hh3cDot11OldPower)
Old power value.
N/A.
Integer32
Integer32, (1..100)
Recommended action
