- 11-WLAN
- 01-HH3C-DOT11-ROAM-MIB
- 02-HH3C-DOT11-ACMT-MIB
- 03-HH3C-DOT11-APMT-MIB
- 04-HH3C-DOT11-CFG-MIB
- 05-HH3C-DOT11-CFGEXT-MIB
- 06-HH3C-WAPI-MIB
- 07-HH3C-WLAN-FLEXAPP-CFG-MIB
- 08-HH3C-DOT11-WLANEXT-MIB
- 09-HH3C-DOT11-WIPS-MIB
- 10-HH3C-DOT11-STATION-MIB
- 11-HH3C-DOT11-QOS-MIB
- 12-HH3C-DOT11-SA-MIB
- 13-HH3C-DOT11-RRM-MIB
- 14-HH3C-DOT11-SAVI-MIB
- 15-HH3C-DOT11-WM2U-MIB
- 16-HH3C-DOT11-PROBE-MIB
- 17-HH3C-DOT11S-MESH-MIB
| 10-HH3C-DOT11-STATION-MIB | 252.79 KB |
hh3cDot11StationAssociateTable
hh3cDot11StationAPRelationTable
hh3cDot11StationAuthenErrorTrap
hh3cDot11StationAuthorFailTrap
hh3cDot11StationAuthorSuccTrap
hh3cDot11StationDisconnectTrap
About this MIB
Use this MIB to manage client configuration and statistics.
MIB file name
hh3c-dot11-station.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDot11(75).hh3cDot11STATION(3)
Tabular objects
About this table
Use this table to display association information for wireless clients.
Support for operations
Create:Not supported
Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cDot11StationMAC.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11StationMAC (1.3.6.1.4.1.25506.2.75.3.1.1.1.1) |
not-accessible |
MacAddress |
OCTET STRING (6) |
MAC address of the client. |
As per the MIB. |
hh3cDot11StationIPAddress (1.3.6.1.4.1.25506.2.75.3.1.1.1.2) |
read-only |
IpAddress |
Standard MIB values. |
IP address of the client. |
As per the MIB. |
hh3cDot11StationUserName (1.3.6.1.4.1.25506.2.75.3.1.1.1.3) |
read-only |
OCTET STRING |
Username for the client. |
As per the MIB. |
hh3cDot11StationTxRateSet (1.3.6.1.4.1.25506.2.75.3.1.1.1.4) |
read-only |
OCTET STRING |
Transmission rate for the client. If the MSB (most significant bit) is set, the rate is mandatory. If it is not set, the rate is optional. |
As per the MIB. |
hh3cDot11StationUpTime (1.3.6.1.4.1.25506.2.75.3.1.1.1.5) |
read-only |
Unsigned32 |
How long the client has been associated with this device. |
As per the MIB. |
hh3cDot11StationSignalStrength (1.3.6.1.4.1.25506.2.75.3.1.1.1.6) |
read-only |
Integer32 |
Current signal strength of the client. |
As per the MIB. |
hh3cDot11StationRSSI (1.3.6.1.4.1.25506.2.75.3.1.1.1.7) |
read-only |
Integer32 |
Strength of the received signal. The maximum value is defined by the chipset vendor. |
As per the MIB. |
hh3cDot11StationChannel (1.3.6.1.4.1.25506.2.75.3.1.1.1.8) |
read-only |
Integer32 |
Channel used by the client. |
As per the MIB. |
hh3cDot11StationPowerSaveMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.9) |
read-only |
INTEGER |
active(1), powersave(2) |
Power management mode for the client. |
As per the MIB. |
hh3cDot11StationAid (1.3.6.1.4.1.25506.2.75.3.1.1.1.10) |
read-only |
Integer32 |
ID of the client. |
As per the MIB. |
hh3cDot11StationVlanId (1.3.6.1.4.1.25506.2.75.3.1.1.1.11) |
read-only |
Integer32 |
VLAN ID associated with the client. |
As per the MIB. |
hh3cDot11StationSSIDName (1.3.6.1.4.1.25506.2.75.3.1.1.1.12) |
read-only |
Hh3cDot11SSIDStringType |
ESS name. |
As per the MIB. |
hh3cDot11StationAuthenMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.13) |
read-only |
Hh3cDot11AuthenType |
none(1), opensystem(2), sharedkey(3), all(4) |
Authentication mode defined by 802.11. |
As per the MIB. |
hh3cDot11StationAKMMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.14) |
read-only |
Hh3cDot11AKMType |
none(1), psk(2), dot1x(3), ext(4) |
Authentication and key management mode. |
As per the MIB. |
hh3cDot11StationSecurityCiphers (1.3.6.1.4.1.25506.2.75.3.1.1.1.15) |
read-only |
Hh3cDot11CipherType |
none(1), wep40(2), tkip(4), aesccmp(16), wep104(32), wpisms4(64), wep(128) |
Cipher suite |
As per the MIB. |
hh3cDot11StationSSIDEncryptMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.16) |
read-only |
Hh3cDot11SSIDEncryptModeType |
cleartxt(1), cipher(2), ext(3) |
Encryption mode for the ESS. |
As per the MIB. |
hh3cDot11StationRxSNR (1.3.6.1.4.1.25506.2.75.3.1.1.1.17) |
read-only |
Integer32 |
Signal-to-noise ratio for frame receiving. |
As per the MIB. |
hh3cDot11StationTxRate (1.3.6.1.4.1.25506.2.75.3.1.1.1.18) |
read-only |
Integer32 |
Transmission rate of frames. |
As per the MIB. |
hh3cDot11StationRxRate (1.3.6.1.4.1.25506.2.75.3.1.1.1.19) |
read-only |
Integer32 |
Receive rate of frames. |
As per the MIB. |
hh3cDot11StationVendorName (1.3.6.1.4.1.25506.2.75.3.1.1.1.20) |
read-only |
OCTET STRING |
OCTET STRING (0..127) |
Vendor name for the client. |
As per the MIB. |
hh3cDot11StationRadioMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.21) |
read-only |
INTEGER |
dot11a(1), dot11b(2), dot11g(4), dot11n(8), dot11gn(16), dot11an(32), dot11ac(64), dot11gac(128), dot11ax(256), dot11gax(512) |
Radio type supported by the client. |
As per the MIB. |
hh3cDot11StationRxNoise (1.3.6.1.4.1.25506.2.75.3.1.1.1.22) |
read-only |
Integer32 |
Noise received by the client. |
As per the MIB. |
hh3cDot11StationMACAddress (1.3.6.1.4.1.25506.2.75.3.1.1.1.23) |
read-only |
MacAddress |
OCTET STRING (6) |
As per the MIB. |
hh3cDot11StationTxSpeed (1.3.6.1.4.1.25506.2.75.3.1.1.1.24) |
read-only |
Integer32 |
Number of bytes sent to the client per second within the sample interval. |
As per the MIB. |
hh3cDot11StationRxSpeed (1.3.6.1.4.1.25506.2.75.3.1.1.1.25) |
read-only |
Integer32 |
Number of bytes received by the client per second within the sample interval. |
As per the MIB. |
hh3cDot11StationWmmMode (1.3.6.1.4.1.25506.2.75.3.1.1.1.26) |
read-only |
INTEGER |
wmm(1), nonwmm(2) |
QoS mode of the client. |
As per the MIB. |
hh3cDot11StationSecIEStatus (1.3.6.1.4.1.25506.2.75.3.1.1.1.27) |
read-only |
INTEGER |
none(1), rsn(2), wpa(3), all(4), ext(5) |
Security information element of the client. |
As per the MIB. |
hh3cDot11StationUpTimeTicks (1.3.6.1.4.1.25506.2.75.3.1.1.1.28) |
read-only |
TimeTicks |
As per the MIB. |
hh3cDot11StationRadioMode2 (1.3.6.1.4.1.25506.2.75.3.1.1.1.29) |
read-only |
INTEGER |
dot11a(1), dot11b (2), dot11g (4), dot11an (8), dot11gn (16), dot11ac (32), dot11gac (64), dot11ax(128), dot11gax(256) |
As per the MIB. |
hh3cDot11StationAssTime (1.3.6.1.4.1.25506.2.75.3.1.1.1.30) |
read-only |
DateAndTime |
DateAndTime (8), DateAndTime (11) |
How long the client has been connected to the wireless network. |
As per the MIB. |
hh3cDot11StationUserAuthType (1.3.6.1.4.1.25506.2.75.3.1.1.1.31) |
read-only |
INTEGER |
portalAuth(1), authFree(2), associateAuth(3), macAuth(4) |
Authentication mode for the client. |
As per the MIB. |
hh3cDot11StationRfPingTest (1.3.6.1.4.1.25506.2.75.3.1.1.1.32) |
read-only |
TruthValue |
true(1), false(2) |
Use this node to start the RF ping test for the client. For get operations, it will return false. |
As per the MIB. |
hh3cDot11StationMaxRate (1.3.6.1.4.1.25506.2.75.3.1.1.1.33) |
read-only |
Integer32 |
Maximum negotiated rate for the client. |
As per the MIB. |
hh3cDot11StationPowerSaveModeCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.34) |
read-only |
INTEGER |
active(0), powersave(1) |
As per the MIB. |
hh3cDot11StationAuthenModeCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.35) |
read-only |
INTEGER |
opensystem(0), sharedkey(1), |
As per the MIB. |
hh3cDot11StationAKMModeCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.36) |
read-only |
INTEGER |
none(0), psk(1), radius(2), wlanex(3) |
Key management mode defined by 802.11i. |
As per the MIB. |
hh3cDot11StationSecurityCiphersCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.37) |
read-only |
INTEGER |
none(0), wep40(1), wep104(2) tkip(3), aesccmp(4), wpisms4(5) |
Type of password used for frame encryption on the client. |
As per the MIB. |
hh3cDot11StationSecIEStatusCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.38) |
read-only |
INTEGER |
none(0), wpa(1), wpa2(2), wlanex(3) |
As per the MIB. |
hh3cDot11StationIPv6Address (1.3.6.1.4.1.25506.2.75.3.1.1.1.39) |
read-only |
OCTET STRING |
IPv6 address of the client. |
As per the MIB. |
hh3cDot11StationAssociateAPMACAddressCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.40) |
read-only |
MacAddress |
MacAddress(6) |
MAC address of the client currently connected to the AP. |
As per the MIB. |
hh3cDot11StationDeviceType(1.3.6.1.4.1.25506.2.75.3.1.1.1.41) |
read-only |
OCTET STRING |
Type of device with which the client will be associated. |
As per the MIB. |
hh3cDot11StationTxRateCM (1.3.6.1.4.1.25506.2.75.3.1.1.1.42) |
read-only |
OCTET STRING |
As per the MIB. |
hh3cDot11StationRxRateCM(1.3.6.1.4.1.25506.2.75.3.1.1.1.43) |
read-only |
OCTET STRING |
As per the MIB. |
About this table
Use this table to save the relationships between AP, radio, and WLAN ID, as well as the detailed information about a client.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11CurrAPID (1.3.6.1.4.1.25506.2.75.3.1.2.1.1) |
read-only |
OCTET STRING |
To uniquely identify each AP, the relationship between hh3cDot11CurrAPID and the AP device will be static. |
As per the MIB. |
hh3cDot11CurrRadioID (1.3.6.1.4.1.25506.2.75.3.1.2.1.2) |
read-only |
Integer32 |
Each radio. |
As per the MIB. |
hh3cDot11CurrWlanID (1.3.6.1.4.1.25506.2.75.3.1.2.1.3) |
read-only |
Integer32 |
WLAN ID of the BSS associated with the client. |
As per the MIB. |
hh3cDot11CurrAntennaID (1.3.6.1.4.1.25506.2.75.3.1.2.1.4) |
read-only |
Integer32 |
Radio ID of the client. |
As per the MIB. |
hh3cDot11StationStatisTable
About this table
Use this table to display all statistical information and states for clients.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cDot11StationRxFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.1) |
read-only |
Counter32 |
Number of frames received by the AP from the client. |
As per the MIB. |
hh3cDot11StationTxFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.2) |
read-only |
Counter32 |
Number of frames sent from the AP to the client. |
As per the MIB. |
hh3cDot11StationDropFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.3) |
read-only |
Counter32 |
Number of discarded frames. |
As per the MIB. |
hh3cDot11StationRxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.4) |
read-only |
Counter64 |
Number of bytes received by the AP from the client. |
As per the MIB. |
hh3cDot11StationTxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.5) |
read-only |
Counter64 |
Number of bytes sent from the AP to the client. |
As per the MIB. |
hh3cDot11StationDropFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.6) |
read-only |
Counter64 |
Number of discarded bytes. |
As per the MIB. |
hh3cDot11StationRxRetryPkts (1.3.6.1.4.1.25506.2.75.3.1.3.1.7) |
read-only |
Counter32 |
Number of frames retransmitted from the client to the AP. |
As per the MIB. |
hh3cDot11StationTxRetryPkts (1.3.6.1.4.1.25506.2.75.3.1.3.1.8) |
read-only |
Counter32 |
Number of frames retransmitted from the AP to the client. |
As per the MIB. |
hh3cDot11StationRxRetryBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.9) |
read-only |
Counter64 |
Number of bytes retransmitted from the client to the AP. |
As per the MIB. |
hh3cDot11StationTxRetryBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.10) |
read-only |
Counter64 |
Number of bytes retransmitted from the AP to the client. |
As per the MIB. |
hh3cDot11StationThroughput (1.3.6.1.4.1.25506.2.75.3.1.3.1.11) |
read-only |
Counter64 |
Number of valid load in the data frames transmitted and received by the client. |
As per the MIB. |
hh3cDot11StationSuccessTxCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.12) |
read-only |
Counter32 |
Number of frames successfully transmitted to the client. |
As per the MIB. |
hh3cDot11StationSuccessTxDataCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.13) |
read-only |
Counter32 |
Number of data frames successfully transmitted to the client. |
As per the MIB. |
hh3cDot11StationRxDataFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.14) |
read-only |
Counter32 |
Number of data frames received from the client. |
As per the MIB. |
hh3cDot11StationTxDataFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.15) |
read-only |
Counter32 |
Number of data frames transmitted to the client. |
As per the MIB. |
hh3cDot11StationRxDataFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.16) |
read-only |
Counter64 |
Number of bytes received from the client. |
As per the MIB. |
hh3cDot11StationTxDataFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.17) |
read-only |
Counter64 |
Number of bytes transmitted to the client. |
As per the MIB. |
hh3cDot11StationRxFragCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.18) |
read-only |
Counter32 |
Number of fragmented data frames received from the client. |
As per the MIB. |
hh3cDot11StaRxErrDataFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.19) |
read-only |
Counter64 |
Number of error data frames received by the AP from the client. |
As per the MIB. |
hh3cDot11StaTxRetryDataFrameCnt (1.3.6.1.4.1.25506.2.75.3.1.3.1.20) |
read-only |
Counter64 |
Number of data frames retransmitted from the AP to the client. |
As per the MIB. |
hh3cDot11StaTxDataRatePkts (1.3.6.1.4.1.25506.2.75.3.1.3.1.21) |
read-only |
OCTET STRING |
Number of data frames received from the client at each rate. |
As per the MIB. |
hh3cDot11StaRxDataRatePkts (1.3.6.1.4.1.25506.2.75.3.1.3.1.22) |
read-only |
OCTET STRING |
Numbers of data frames that are transmitted to the client at each rate. |
As per the MIB. |
hh3cDot11StaTxSignalStrengthPkts (1.3.6.1.4.1.25506.2.75.3.1.3.1.23) |
read-only |
OCTET STRING |
Numbers of data frames received from the client with different signal strengths. |
As per the MIB. |
hh3cDot11StaInternetRxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.24) |
read-only |
Counter64 |
Number of bytes of Internet traffic received from the client. |
As per the MIB. |
hh3cDot11StaInternetTxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.25) |
read-only |
Counter64 |
Number of bytes of Internet traffic sent to the client. |
As per the MIB. |
hh3cDot11StaLocalRxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.26) |
read-only |
Counter64 |
Local traffic in bytes received from the client. |
As per the MIB. |
hh3cDot11StaLocalTxFrameBytes (1.3.6.1.4.1.25506.2.75.3.1.3.1.27) |
read-only |
Counter64 |
Local traffic in bytes transmitted to the client. |
As per the MIB. |
Notifications
hh3cDot11StationMICErrorTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.1 |
A client detected a TKIP decryption MIC error. |
Informational |
Warning |
N/A (N/A) |
Off |
Notification triggers
This notification is triggered when a MIC error occurs.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable wlan usersec command.
OFF
CLI: Use the undo snmp-agent trap enable wlan usersec command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.3.1.2.1.1 (hh3cDot11CurrAPID) |
APID |
OCTET STRING |
OCTET STRING , (0..127) |
1.3.6.1.4.1.25506.2.75.3.1.2.1.2 (hh3cDot11CurrRadioID) |
Radio ID |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.1 (hh3cDot11StationTrapBSSID) |
BSSID |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.1.1.1.12 (hh3cDot11StationSSIDName) |
SSID |
OCTET STRING |
OCTET STRING (0..32) |
1.3.6.1.4.1.25506.2.75.3.2.1.2 (hh3cDot11StationTrapStaMAC) |
Client MAC address. |
MacAddress |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.2 |
Client link authentication failed. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when an error occurs during the authentication negotiation process of 802.11 link establishment by a wireless client.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
APID |
OCTET STRING |
Radio ID |
Integer32 |
BSSID |
MacAddress |
SSID |
OCTET STRING |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.1.1.1.13 (hh3cDot11StationAuthenMode) |
Authentication mode. |
1.3.6.1.4.1.25506.2.75.3.1.1.1.14 (hh3cDot11StationAKMMode) |
Key management mode. |
Hh3cDot11AKMType |
none(1),, psk(2),, dot1x(3),, ext(4) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.3 |
Client authorization failed. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when a client successfully establishes a wireless link but fails access authentication.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.3.1.1.1.3 (hh3cDot11StationUserName) |
OCTET STRING |
OCTET STRING, (0..255) |
MacAddress |
Radio ID |
Integer32 |
SSID |
OCTET STRING |
hh3cDot11StationAuthorFailCause (hh3cDot11StationAuthorFailCause) |
Reasons for client authorization failure. |
Hh3cDot11AuthorFailType |
1.3.6.1.4.1.25506.2.75.3.2.1.6 (hh3cDot11StationFailCauseDesc) |
Fault description for the client. |
OCTET STRING |
APID |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.11 (hh3cDot11StationBSSID) |
BSSID to which the client is connected. |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.13 (hh3cDot11StationAuthMode) |
Client authentication mode. |
INTEGER |
1.3.6.1.4.1.25506.2.75.3.2.1.16 (hh3cDot11StationTrapAPMacAddress) |
AP's MAC address. |
MacAddress |
Recommended action
hh3cDot11StationAssocFailTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.4 |
Client association failed. |
Informational |
Warning |
N/A (N/A) |
Off |
This notification is triggered when a wireless client fails to establish a connection with an AP.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan client command.
OFF
CLI: Use the undo snmp-agent trap enable wlan client command.
Object
OID (object name) |
Index |
Type |
Value range |
MacAddress |
Radio ID |
Integer32 |
ESS name. |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.4 (hh3cDot11StationAssocFailCause) |
Reasons for client association failure. |
Hh3cDot11AssocFailType |
OCTET STRING |
OCTET STRING |
AP's MAC address. |
MacAddress |
MacAddress |
Recommended action
hh3cDot11StationDeAssocTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.5 |
A disassociation request was sent to a client. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when a system needs to transmit a disassociation packet to a wireless client.
System impact
N/A
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
MAC address of the client where a MIC error occurred. |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.1.1.1.11 (hh3cDot11StationVlanId) |
Integer32 |
Each radio. |
Integer32 |
ESS name. |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.7 (hh3cDot11StationSessionDuration) |
Duration of the client session. |
Unsigned32 |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.10 (hh3cDot11StationAPName) |
Name of the AP to which the client is connected. |
OCTET STRING |
MacAddress |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.6 |
Client authorization succeeded. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when the system determines that the client has successfully connected to the WLAN network and completed link negotiation and access authentication.
System impact
N/A
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
MacAddress |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.3 (hh3cDot11StationSessionStartTime) |
DateAndTime |
Each radio. |
Integer32 |
ESS name. |
OCTET STRING |
OCTET STRING |
OCTET STRING |
MacAddress |
Recommended action
hh3cDot11StationRoamingTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.7 |
A client roamed to another AP. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when a client roams from one AP to another.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable wlan mobility command.
OFF
CLI: Use the undo snmp-agent trap enable wlan mobility command.
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
OCTET STRING |
MacAddress |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.8 (hh3cDot11StationRoamingTime) |
Time when the client roamed to another AP. |
Unsigned32 |
Each radio. |
Integer32 |
ESS name. |
OCTET STRING |
1.3.6.1.4.1.25506.2.75.3.2.1.9 (hh3cDot11StationACIPAddress) |
IP address of the home AC for roaming clients. IP address of the foreign AC for roaming clients. |
IpAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.14 (hh3cDot11StationACIPv6Add) |
IPv6 address of the home AC for roaming clients. IPv6 address of the foreign AC for roaming clients. |
OCTET STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.8 |
A client went offline. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when the system detects that a client is no longer present after the client successfully registers to the system, regardless of how the client left the network.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
MacAddress |
ESS name. |
OCTET STRING |
Unsigned32 |
Integer32 |
OCTET STRING |
Each radio. |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.12 (hh3cDot11StaDisconnectReason) |
Reasons for disconnection between the client and the AP. |
OCTET STRING |
MacAddress |
Recommended action
hh3cDot11UserDisconnectTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.9 |
A user went offline unexpectedly. |
Informational |
Warning |
N/A (N/A) |
OFF |
This notification is triggered when a client times out. Set the idle-time to 60 seconds. For a PC, if it goes offline unexpectedly, it will be forcibly shut down. For a client other than a PC, a disassociation packet will be sent. If no username exists, the packet is empty.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
OCTET STRING |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.15 (hh3cDot11UserName) |
Username. |
OCTET STRING |
Recommended action
hh3cDot11StationAuditTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.75.3.2.0.11 |
Client behavior notification. |
Informational |
Warning |
N/A (N/A) |
Off |
This notification is triggered when a client comes online, goes offline, roams, or obtains an IP address.
System impact
N/A
Status control
ON
CLI: Use the snmp-agent trap enable wlan client-audit command.
OFF
CLI: Use the undo snmp-agent trap enable wlan client-audit command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.75.3.2.1.21 (hh3cDot11StationAuditTrapOpType) |
Client operation type. |
Unsigned32 |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.22 (hh3cDot11StationTrapStaIPAddress) |
IpAddress |
AP's MAC address. |
MacAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.19 (hh3cDot11StationTrapAPIPAddress) |
AP's IP address. |
IpAddress |
1.3.6.1.4.1.25506.2.75.3.2.1.23 (hh3cDot11StationTrapRadioID) |
ID of each channel. |
Hh3cDot11RadioScopeType |
1.3.6.1.4.1.25506.2.75.3.2.1.24 (hh3cDot11StationTrapRadioMode) |
Hh3cDot11RadioType2 |
1.3.6.1.4.1.25506.2.75.3.2.1.25 (hh3cDot11StationTrapWlanID) |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.26 (hh3cDot11StationTrapSSIDName) |
ESS name. |
1.3.6.1.4.1.25506.2.75.3.2.1.27 (hh3cDot11StationTrapVlan) |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.28 (hh3cDot11StationTrapChannel) |
Current channel used by the client. |
Hh3cDot11ChannelScopeType |
1.3.6.1.4.1.25506.2.75.3.2.1.29 (hh3cDot11StationTrapRSSI) |
Integer32 |
1.3.6.1.4.1.25506.2.75.3.2.1.20 (hh3cDot11StationTrapStartTime) |
Time when the device starts connecting to the client. |
Unsigned32 |
Unsigned32 |
1.3.6.1.4.1.25506.2.75.3.2.1.30 (hh3cDot11StationTrapRxFrameKbit) |
Number of data frames bits received from the client. |
Counter64 |
1.3.6.1.4.1.25506.2.75.3.2.1.31 (hh3cDot11StationTrapTxFrameKbit) |
Number of data frame bits sent to the client. |
Counter64 |
Recommended action
