01-Typical configuration example
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration ExamplesH3C CR16000-F Routers Configuration Examples All-In-One-R8530Pxx-6W10001-Typical configuration example
Table of Contents
Related Documents
45-H3C_IS-IS_Route_Summarization_Configuration_Examples
Introduction
This document provides IS-IS route summarization configuration examples.
This document assumes that you have basic knowledge of IS-IS route summarization.
Example: Configuring IS-IS route summarization
As shown in Figure 1, the five departments of a company use IS-IS to connect to the backbone network. The three departments are assigned the networks 192.168.1.0/24, 192.168.2.0/24, 192.168.3.0/24. Configure IS-IS route summarization to reduce routing entries and save system resources for Device B.
Figure 1 Network diagram
Device
IP Address
Device
IP Address
Device A
XGE3/1/15
172.16.1.1/24
Device B
XGE3/1/1
172.16.1.2/24
XGE3/1/1
10.1.1.1/24
GW 1
XGE3/1/1
10.1.1.2/24
XGE3/1/2
10.1.2.1/24
GW 2
XGE3/1/2
10.1.2.2/24
XGE3/1/3
10.1.3.1/24
GW3
XGE3/1/3
10.1.3.2/24
Analysis
Configure route summarization on Device A because route summarization applies only to locally generated LSPs.
To avoid blackhole routes, set the summary route to 192.168.0.0/22.
Procedures
Configuring IP addresses for interfaces
# Configure an IP address for the interface Ten-GigabitEthernet3/1/15 on Device A.
[DeviceA] interface Ten-GigabitEthernet 3/1/15
[DeviceA-Ten-GigabitEthernet3/1/15] ip address 172.16.1.1 24
[DeviceA-Ten-GigabitEthernet3/1/15] quit
# Configure IP addresses for other interfaces as shown in Figure 1 in the same way VLAN-interface 10 is configured. (Details not shown.)
Configuring basic IS-IS
Configuring Device A
# Enable IS-IS on Device A and configure Device A as a Level-1-2 router.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 10.0000.0000.0001.00
[DeviceA-isis-1] is-level level-1-2
[DeviceA-isis-1] quit
# Enable IS-IS on the interface Ten-GigabitEthernet3/1/15.
[DeviceA–Ten-GigabitEthernet3/1/15] isis enable 1
[DeviceA–Ten-GigabitEthernet3/1/15] quit
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
Configuring Device B
# Enable IS-IS on Device B and configure Device B as a Level-2 router.
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 10.0000.0000.0002.00
[DeviceB-isis-1] is-level level-2
[DeviceB-isis-1] quit
# Enable IS-IS on the interface Ten-GigabitEthernet3/1/1.
[DeviceB] interface Ten-GigabitEthernet 3/1/1
[DeviceB–Ten-GigabitEthernet3/1/1] isis enable 1
[DeviceB–Ten-GigabitEthernet3/1/1] quit
Configuring the gateways
# Enable IS-IS on GW 1 and configure GW 1 as a Level-1 router.
[GW1] isis 1
[GW1-isis-1] network-entity 10.0001.0001.0001.00
[GW1-isis-1] is-level level-1
[GW1-isis-1] quit
[GW1] interface Ten-GigabitEthernet 3/1/1
[GW1–Ten-GigabitEthernet3/1/1] isis enable 1
[GW1–Ten-GigabitEthernet3/1/1] quit
# Configure other gateways in the same way GW 1 is configured. (Details not shown.)
Displaying IS-IS routing information on Device B
# Display IS-IS routing information on Device B to view the network address of each department.
[DeviceB] display isis route
                         Level-2 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 192.168.1.0/24       30         NULL    XGE3/1/1        172.16.1.1      R/-/-
 10.1.1.0/24          20         NULL    XGE3/1/1         172.16.1.1      R/-/-
 192.168.2.0/24       30         NULL    XGE3/1/1        172.16.1.1      R/-/-
 10.1.2.0/24          20         NULL    XGE3/1/1        172.16.1.1      R/-/-
 192.168.3.0/24       30         NULL    XGE3/1/1        172.16.1.1      R/-/-
 10.1.3.0/24          20         NULL    XGE3/1/1        172.16.1.1      R/-/-
 172.16.1.0/24        10         NULL    XGE3/1/1        Direct          D/L/-
# Configure IS-IS route summarization on Device A.
[DeviceA] isis 1
[DeviceA-isis-1]address-family ipv4
[DeviceA-isis-1-ipv4] summary 192.168.0.0 22
# Display IS-IS routing information on Device B.
 192.168.0.0/22       30         NULL    XGE3/1/1        172.16.1.1      R/-/-
      Flags: D-Direct, R-Added to Rib, L-Advertised in LSPs, U-Up/Down bit set
The output shows that the networks have been summarized into a single network 192.168.0.0/22.
Configuration files
·     Device A:
isis 1
 address-family ipv4 unicast
  summary 192.168.0.0 255.255.252.0
 port link-mode route
 ip address 172.16.1.1 255.255.255.0
 isis enable 1
 isis enable 1
interface Ten-GigabitEthernet3/1/2
 ip address 10.1.2.1 255.255.255.0
 isis enable 1
interface Ten-GigabitEthernet3/1/3
 ip address 10.1.3.1 255.255.255.0
 isis enable 1
·     Device B:
isis 1
 is-level level-2
 ip address 172.16.1.2 255.255.255.0
 isis enable 1
·     GW 1:
isis 1
 is-level level-1
 isis enable 1
 isis enable 1
·     The configuration files for other gateways are similar to the configuration file for GW 1. (Details not shown.)
Related documentation
·     H3C CR16000-F Routers Layer—3 IP Routing Configuration Guide
·     H3C CR16000-F Routers Layer—3 IP Routing Command Reference
