- 10-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-MPLSSCRLSP-MIB
- 04-HH3C-EVC-MIB
- 05-HH3C-L2VPN-MIB
- 06-HH3C-L3VPN-MIB
- 07-HH3C-MPLS-LDP-MIB
- 08-HH3C-MPLS-VPN-BGP-MIB
- 09-HH3C-MPLSBFD-MIB
- 10-HH3C-MPLSEXT-MIB
- 11-HH3C-VSI-MIB
- 12-HH3C-MPLSTE-MIB
- 13-HH3C-MPLSSLSP-MIB
- 14-HH3C-MPLSPCE-MIB
- 15-MPLS-FRR-FACILITY-STD-MIB
- 16-MPLS-FRR-GENERAL-STD-MIB
- 17-MPLS-FTN-STD-MIB
- 18-MPLS-L3VPN-STD-MIB
- 19-MPLS-LDP-STD-MIB
- 20-MPLS-LSR-STD-MIB
- 21-MPLS-TE-STD-MIB
- 22-PW-ENET-STD-MIB
- 23-PW-MPLS-STD-MIB
- 24-PW-STD-MIB
- 25-TE-MIB
24-PW-STD-MIB | 215.37 KB |
PW-STD-MIB
About this MIB
Use this MIB to configure PW related settings.
MIB file name
rfc5601-pw-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).pwStdMIB(246)
Scalar objects
pwIndexNext
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwIndexNext (1.3.6.1.2.1.10.246.1.1) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Next available index for creating a PW entry. |
As per the MIB. |
pwPerfTotalErrorPackets
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPerfTotalErrorPackets (1.3.6.1.2.1.10.246.1.6) |
read-only |
Counter32 |
Counter32 (0..4294967295) |
Total number of error at the PW processing level. |
Not supported |
pwUpDownNotifEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwUpDownNotifEnable (1.3.6.1.2.1.10.246.1.9) |
read-write |
TruthValue |
true(1), false(2) |
The capability of sending PW up and PW down notifications. |
As per the MIB. |
pwDeletedNotifEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwDeletedNotifEnable (1.3.6.1.2.1.10.246.1.10) |
read-write |
TruthValue |
true(1), false(2) |
The capability of sending PW-deleted notifications. |
As per the MIB. |
pwNotifRate
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwNotifRate (1.3.6.1.2.1.10.246.1.11) |
read-write |
Unsigned32 |
Unsigned32 (1..2147483647) |
The maximum number of PW notifications that can be sent per second. |
Not supported |
Tabular objects
pwTable
About this table
Use this table to configure PWs.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is pwIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwIndex (1.3.6.1.2.1.10.246.1.2.1.1) |
not-accessible |
PwIndexType |
Index of a PW. |
As per the MIB. |
pwType (1.3.6.1.2.1.10.246.1.2.1.2) |
read-create |
IANAPwTypeTC |
other(0), frameRelayDlciMartiniMode(1), atmAal5SduVcc(2), atmTransparent(3), ethernetTagged(4), ethernet(5), hdlc(6), ppp(7), cem(8), atmCellNto1Vcc(9), atmCellNto1Vpc(10), ipLayer2Transport(11), atmCell1to1Vcc(12), atmCell1to1Vpc(13), atmAal5PduVcc(14), frameRelayPortMode(15), cep(16), e1Satop(17), t1Satop(18), e3Satop(19), t3Satop(20), basicCesPsn(21), basicTdmIp(22), tdmCasCesPsn(23), tdmCasTdmIp(24), frDlci(25), wildcard(32767) |
Encapsulation type. |
The set operation supports only ethernetTagged(4) and ethernet(5). |
pwOwner (1.3.6.1.2.1.10.246.1.2.1.3) |
read-create |
INTEGER |
manual(1), pwIdFecSignaling(2), genFecSignaling(3), l2tpControlProtocol(4), other(5) |
PW owner, the protocol used for establishing the PW. |
The set operation supports only manual(1), pwIdFecSignaling(2), and genFecSignaling(3). |
pwPsnType (1.3.6.1.2.1.10.246.1.2.1.4) |
read-create |
IANAPwPsnTypeTC |
mpls(1), l2tp(2), udpOverIp(3), mplsOverIp(4), mplsOverGre(5), other(6) |
PSN type for the PW. |
Supports only the read operation. Supports only mpls(1), mplsOverGre (5), and other (6). |
pwSetUpPriority (1.3.6.1.2.1.10.246.1.2.1.5) |
read-create |
Integer32 |
Integer32 (0..7) |
Setup priority of the PW. |
Supports only the read operation. |
pwHoldingPriority (1.3.6.1.2.1.10.246.1.2.1.6) |
read-create |
Integer32 |
Integer32 (0..7) |
Holding priority of the PW. |
pwPeerAddrType (1.3.6.1.2.1.10.246.1.2.1.8) |
read-create |
InetAddressType |
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16) |
Type of the peer IP address of the PW. |
Supports only ipv4(1). |
pwPeerAddr (1.3.6.1.2.1.10.246.1.2.1.9) |
read-create |
InetAddress |
OCTET STRING (0..255) |
Peer IP address of the PW. |
Supports only an IPv4 address. |
pwAttachedPwIndex (1.3.6.1.2.1.10.246.1.2.1.10) |
read-create |
PwIndexOrZeroType |
Unsigned32 (0..2147483647) |
Index of the attached PW. |
pwIfIndex (1.3.6.1.2.1.10.246.1.2.1.11) |
read-create |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
Interface index of the PW when the PW is modeled as an interface. |
pwID (1.3.6.1.2.1.10.246.1.2.1.12) |
read-create |
PwIDType |
PW ID. |
As per the MIB. |
pwLocalGroupID (1.3.6.1.2.1.10.246.1.2.1.13) |
read-create |
PwGroupID |
Local group ID of the PW. |
pwGroupAttachmentID (1.3.6.1.2.1.10.246.1.2.1.14) |
read-create |
PwAttachmentIdentifierType |
Local AGI of the PW. |
pwLocalAttachmentID (1.3.6.1.2.1.10.246.1.2.1.15) |
read-create |
Local AII of the PW. |
pwRemoteAttachmentID (1.3.6.1.2.1.10.246.1.2.1.16) |
read-create |
Remote AII of the PW. |
pwCwPreference (1.3.6.1.2.1.10.246.1.2.1.17) |
read-create |
TruthValue |
true(1), false(2) |
Indicates whether the control word is set on the local node. |
As per the MIB. |
pwLocalIfMtu (1.3.6.1.2.1.10.246.1.2.1.18) |
read-create |
Unsigned32 |
Unsigned32 (0..65535) |
Local interface MTU. |
Supports the set operation only on VPWS PWs. For a VPLS PW, the set operation will be ignored. Implementation varies by product. |
pwLocalIfString (1.3.6.1.2.1.10.246.1.2.1.19) |
read-create |
TruthValue |
true(1), false(2) |
Indicates whether the local PW is associated with an interface. |
Not supported. |
pwLocalCapabAdvert (1.3.6.1.2.1.10.246.1.2.1.20) |
read-create |
IANAPwCapabilities |
pwStatusIndication(0), pwVCCV(1) |
Capabilities the local node will advertise to the peer. |
The set operation supports only pwStatusIndication(0). |
pwRemoteGroupID (1.3.6.1.2.1.10.246.1.2.1.21) |
read-only |
PwGroupID |
Remote group ID of the PW. |
The value is always 0. |
pwCwStatus (1.3.6.1.2.1.10.246.1.2.1.22) |
read-only |
PwCwStatusTC |
waitingForNextMsg(1), sentWrongBitErrorCode(2), rxWithdrawWithWrongBitErrorCode(3), illegalReceivedBit(4), cwPresent(5), cwNotPresent(6), notYetKnown(7) |
Status of the control word negotiation, indicating whether the control word is to be present for the PW. |
Supports only cwPresent(5) and cwNotPresent(6). |
pwRemoteIfMtu (1.3.6.1.2.1.10.246.1.2.1.23) |
read-only |
Unsigned32 |
Remote interface MTU for the PW. |
As per the MIB. |
pwRemoteIfString (1.3.6.1.2.1.10.246.1.2.1.24) |
read-only |
SnmpAdminString |
OCTET STRING (0..80) |
Description for the remote interface of the PW. |
Not supported. |
pwRemoteCapabilities (1.3.6.1.2.1.10.246.1.2.1.25) |
read-only |
Capabilities received from the peer node of the PW. |
As per the MIB. |
pwFragmentCfgSize (1.3.6.1.2.1.10.246.1.2.1.26) |
read-create |
Unsigned32 |
Size of the PW fragment. |
Not supported. |
pwRmtFragCapability (1.3.6.1.2.1.10.246.1.2.1.27) |
read-only |
PwFragStatus |
noFrag(0), cfgFragGreaterThanPsnMtu(1), cfgFragButRemoteIncapable(2), remoteFragCapable(3), fragEnabled(4) |
The PW fragmentation capability of the peer. |
Not supported. |
pwFcsRetentionCfg (1.3.6.1.2.1.10.246.1.2.1.28) |
read-create |
INTEGER |
fcsRetentionDisable(1), fcsRetentionEnable(2) |
The local configuration of FCS retention for this PW. |
Not supported. |
pwFcsRetentionStatus (1.3.6.1.2.1.10.246.1.2.1.29) |
read-only |
BITS |
remoteIndicationUnknown(0), remoteRequestFcsRetention(1), fcsRetentionEnabled(2), fcsRetentionDisabled(3), localFcsRetentionCfgErr(4), fcsRetentionFcsSizeMismatch(5) |
The status of FCS retention negotiated based on local configuration and remote advertisement. |
Not supported. |
pwOutboundLabel (1.3.6.1.2.1.10.246.1.2.1.30) |
read-create |
Unsigned32 |
PW label used in the outbound direction. |
pwInboundLabel (1.3.6.1.2.1.10.246.1.2.1.31) |
read-create |
Unsigned32 |
PW label used in the inbound direction. |
pwName (1.3.6.1.2.1.10.246.1.2.1.32) |
read-create |
SnmpAdminString |
Name of the PW. |
Not supported. |
pwDescr (1.3.6.1.2.1.10.246.1.2.1.33) |
read-create |
SnmpAdminString |
Description for the PW. |
Not supported. |
pwCreateTime (1.3.6.1.2.1.10.246.1.2.1.34) |
read-only |
TimeStamp |
TimeTicks (0..4294967295) |
Time when the PW was created. |
Not supported. |
pwUpTime (1.3.6.1.2.1.10.246.1.2.1.35) |
read-only |
TimeTicks |
Time when the PW came up. |
Not supported. |
pwLastChange (1.3.6.1.2.1.10.246.1.2.1.36) |
read-only |
TimeTicks |
Last time when the PW state changed. |
Not supported. |
pwAdminStatus (1.3.6.1.2.1.10.246.1.2.1.37) |
read-create |
INTEGER |
up(1), down(2), testing(3) |
Administrative status of the PW. |
Supports the set operation only on VPWS PWs. For a VPLS PW, the set operation will be ignored. Supports only up(1) and down(2). |
pwOperStatus (1.3.6.1.2.1.10.246.1.2.1.38) |
read-only |
PwOperStatusTC |
up(1), down(2), testing(3), dormant(4), notPresent(5), lowerLayerDown(6) |
Operational status of the PW. |
Supports up(1), down(2), dormant(4), notPresent(5), and lowerLayerDown(6). |
pwLocalStatus (1.3.6.1.2.1.10.246.1.2.1.39) |
read-only |
PwStatus |
pwNotForwarding(0), servicePwRxFault(1), servicePwTxFault(2), psnPwRxFault(3), psnPwTxFault(4) |
Status of the PW on the local node. |
Supports only zero and BITS {pwNotForwarding(0)}. |
pwRemoteStatusCapable (1.3.6.1.2.1.10.246.1.2.1.40) |
read-only |
INTEGER |
notApplicable(1), notYetKnown(2), remoteCapable(3), remoteNotCapable(4) |
Remote node capability to advertise the PW status notification. |
As per the MIB. |
pwRemoteStatus (1.3.6.1.2.1.10.246.1.2.1.41) |
read-only |
PwStatus |
Status of the PW as was advertised by the remote. |
As per the MIB. |
pwTimeElapsed (1.3.6.1.2.1.10.246.1.2.1.42) |
read-only |
Integer32 |
Integer32 (0..86399) |
Number of seconds that have elapsed since the beginning of the current interval measurement period. |
As per the MIB. |
pwValidIntervals (1.3.6.1.2.1.10.246.1.2.1.43) |
read-only |
HCPerfValidIntervals |
Integer32 (0..96) |
Number of valid time intervals for which data was collection. |
Value range: 0 to 4. |
pwRowStatus (1.3.6.1.2.1.10.246.1.2.1.44) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports active(1), notInService(2), createAndGo(4), and destroy(6). |
pwStorageType (1.3.6.1.2.1.10.246.1.2.1.45) |
read-create |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for the PW. |
Supports only the read operation. The value is always nonVolatile(3). |
pwOamEnable (1.3.6.1.2.1.10.246.1.2.1.46) |
read-create |
TruthValue |
"true(1), false(2)" |
Indicates whether OAM is enabled for the PW. |
As per the MIB. |
pwGenAGIType (1.3.6.1.2.1.10.246.1.2.1.47) |
read-create |
PwGenIdType |
Unsigned32 (0..254) |
AGI type of the PW. |
pwGenLocalAIIType (1.3.6.1.2.1.10.246.1.2.1.48) |
read-create |
PwGenIdType |
Local AII type of the PW. |
pwGenRemoteAIIType (1.3.6.1.2.1.10.246.1.2.1.49) |
read-create |
PwGenIdType |
Remote AII type of the PW. |
pwPerfCurrentTable
About this table
This table provides per-PW performance information for the current interval.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPerfCurrentInHCPackets (1.3.6.1.2.1.10.246.1.3.1.1) |
read-only |
HCPerfCurrentCount |
Counter64 (0..18446744073709551615) |
High-capacity counter for number of packets received by the PW. |
As per the MIB. |
pwPerfCurrentInHCBytes (1.3.6.1.2.1.10.246.1.3.1.2) |
read-only |
High-capacity counter for number of bytes received by the PW. |
As per the MIB. |
pwPerfCurrentOutHCPackets (1.3.6.1.2.1.10.246.1.3.1.3) |
read-only |
High-capacity counter for number of packets forwarded by the PW. |
As per the MIB. |
pwPerfCurrentOutHCBytes (1.3.6.1.2.1.10.246.1.3.1.4) |
read-only |
High-capacity counter for number of bytes forwarded by the PW. |
As per the MIB. |
pwPerfCurrentInPackets (1.3.6.1.2.1.10.246.1.3.1.5) |
read-only |
PerfCurrentCount |
Gauge32 (0..4294967295) |
Counter for number of packets received by the PW. |
As per the MIB. |
pwPerfCurrentInBytes (1.3.6.1.2.1.10.246.1.3.1.6) |
read-only |
PerfCurrentCount |
Counter for number of bytes received by the PW. |
As per the MIB. |
pwPerfCurrentOutPackets (1.3.6.1.2.1.10.246.1.3.1.7) |
read-only |
PerfCurrentCount |
Counter for number of packets forwarded by the PW. |
As per the MIB. |
pwPerfCurrentOutBytes (1.3.6.1.2.1.10.246.1.3.1.8) |
read-only |
PerfCurrentCount |
Counter for number of bytes forwarded by the PW. |
As per the MIB. |
pwPerfIntervalTable
About this table
This table provides per-PW performance information for the latest four intervals.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwIndex and pwPerfIntervalNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPerfIntervalNumber (1.3.6.1.2.1.10.246.1.4.1.1) |
not-accessible |
Integer32 |
Integer32 (1..96) |
Number of a time interval. |
As per the MIB. |
pwPerfIntervalValidData (1.3.6.1.2.1.10.246.1.4.1.2) |
read-only |
TruthValue |
false(2) |
Indicates whether the data for this interval is valid. |
As per the MIB. |
pwPerfIntervalTimeElapsed (1.3.6.1.2.1.10.246.1.4.1.3) |
read-only |
HCPerfTimeElapsed |
Duration of this interval in seconds. |
As per the MIB. |
pwPerfIntervalInHCPackets (1.3.6.1.2.1.10.246.1.4.1.4) |
read-only |
HCPerfIntervalCount |
As per the MIB. |
pwPerfIntervalInHCBytes (1.3.6.1.2.1.10.246.1.4.1.5) |
read-only |
As per the MIB. |
pwPerfIntervalOutHCPackets (1.3.6.1.2.1.10.246.1.4.1.6) |
read-only |
As per the MIB. |
pwPerfIntervalOutHCBytes (1.3.6.1.2.1.10.246.1.4.1.7) |
read-only |
As per the MIB. |
pwPerfIntervalInPackets (1.3.6.1.2.1.10.246.1.4.1.8) |
read-only |
PerfIntervalCount |
As per the MIB. |
pwPerfIntervalInBytes (1.3.6.1.2.1.10.246.1.4.1.9) |
read-only |
PerfIntervalCount |
As per the MIB. |
pwPerfIntervalOutPackets (1.3.6.1.2.1.10.246.1.4.1.10) |
read-only |
PerfIntervalCount |
As per the MIB. |
pwPerfIntervalOutBytes (1.3.6.1.2.1.10.246.1.4.1.11) |
read-only |
PerfIntervalCount |
As per the MIB. |
pwPerf1DayIntervalTable
About this table
This table provides per-PW performance information for the current day's interval and the previous day's interval.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwIndex and pwPerf1DayIntervalNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPerf1DayIntervalNumber (1.3.6.1.2.1.10.246.1.5.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..31) |
As per the MIB. |
pwPerf1DayIntervalValidData (1.3.6.1.2.1.10.246.1.5.1.2) |
read-only |
TruthValue |
true(1), false(2) |
As per the MIB. |
pwPerf1DayIntervalTimeElapsed (1.3.6.1.2.1.10.246.1.5.1.3) |
read-only |
HCPerfTimeElapsed |
As per the MIB. |
pwPerf1DayIntervalInHCPackets (1.3.6.1.2.1.10.246.1.5.1.4) |
read-only |
Counter64 |
As per the MIB. |
pwPerf1DayIntervalInHCBytes (1.3.6.1.2.1.10.246.1.5.1.5) |
read-only |
Counter64 |
As per the MIB. |
pwPerf1DayIntervalOutHCPackets (1.3.6.1.2.1.10.246.1.5.1.6) |
read-only |
Counter64 |
As per the MIB. |
pwPerf1DayIntervalOutHCBytes (1.3.6.1.2.1.10.246.1.5.1.7) |
read-only |
Counter64 |
As per the MIB. |
pwIndexMappingTable
About this table
This table enables the reverse mapping of the unique PWid parameters [peer IP, PW type, and PW ID] and the pwIndex.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwIndexMappingPwType, pwIndexMappingPwID, pwIndexMappingPeerAddrType, and pwIndexMappingPeerAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwIndexMappingPwType (1.3.6.1.2.1.10.246.1.7.1.1) |
not-accessible |
IANAPwTypeTC |
PW encapsulation type. |
As per the MIB. |
pwIndexMappingPwID (1.3.6.1.2.1.10.246.1.7.1.2) |
not-accessible |
PwIDType |
Unsigned32 |
PW ID. |
As per the MIB. |
pwIndexMappingPeerAddrType (1.3.6.1.2.1.10.246.1.7.1.3) |
not-accessible |
InetAddressType |
IP address type of the peer node. |
As per the MIB. |
pwIndexMappingPeerAddr (1.3.6.1.2.1.10.246.1.7.1.4) |
not-accessible |
InetAddress |
IP address of the peer node. |
As per the MIB. |
pwIndexMappingPwIndex (1.3.6.1.2.1.10.246.1.7.1.5) |
read-only |
PwIndexType |
Index of the PW in the pwTable. |
As per the MIB. |
pwPeerMappingTable
About this table
This table provides information about mappings between the PW parameters and pwIndex.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwPeerMappingPeerAddrType, pwPeerMappingPeerAddr, pwPeerMappingPwType, and pwPeerMappingPwID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwPeerMappingPeerAddrType (1.3.6.1.2.1.10.246.1.8.1.1) |
not-accessible |
InetAddressType |
As per the MIB. |
pwPeerMappingPeerAddr (1.3.6.1.2.1.10.246.1.8.1.2) |
not-accessible |
InetAddress |
As per the MIB. |
pwPeerMappingPwType (1.3.6.1.2.1.10.246.1.8.1.3) |
not-accessible |
IANAPwTypeTC |
As per the MIB. |
pwPeerMappingPwID (1.3.6.1.2.1.10.246.1.8.1.4) |
not-accessible |
PwIDType |
Unsigned32(0..4294967295) |
PW ID |
As per the MIB. |
pwPeerMappingPwIndex (1.3.6.1.2.1.10.246.1.8.1.5) |
read-only |
PwIndexType |
As per the MIB. |
pwGenFecIndexMappingTable
About this table
This table provides information about mappings between the GenFec PW parameters and pwIndex.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are pwGenFecIndexMappingAGIType, pwGenFecIndexMappingAGI, pwGenFecIndexMappingLocalAIIType, pwGenFecIndexMappingLocalAII, pwGenFecIndexMappingRemoteAIIType, and pwGenFecIndexMappingRemoteAII.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwGenFecIndexMappingAGIType (1.3.6.1.2.1.10.246.1.12.1.1) |
not-accessible |
PwGenIdType |
As per the MIB. |
pwGenFecIndexMappingAGI (1.3.6.1.2.1.10.246.1.12.1.2) |
not-accessible |
AGI value of the PW. |
As per the MIB. |
pwGenFecIndexMappingLocalAIIType (1.3.6.1.2.1.10.246.1.12.1.3) |
not-accessible |
PwGenIdType |
As per the MIB. |
pwGenFecIndexMappingLocalAII (1.3.6.1.2.1.10.246.1.12.1.4) |
not-accessible |
Local AII value of the PW. |
As per the MIB. |
pwGenFecIndexMappingRemoteAIIType (1.3.6.1.2.1.10.246.1.12.1.5) |
not-accessible |
PwGenIdType |
As per the MIB. |
pwGenFecIndexMappingRemoteAII (1.3.6.1.2.1.10.246.1.12.1.6) |
not-accessible |
Remote AII value of the PW. |
As per the MIB. |
pwGenFecIndexMappingPwIndex (1.3.6.1.2.1.10.246.1.12.1.7) |
read-only |
PwIndexType |
As per the MIB. |
Notifications
pwDown
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.10.246.0.1 |
PW down |
Error |
Major |
1.3.6.1.2.1.10.246.0.2 (pwUp) |
OFF |
Notification triggers
This notification is generated when the pwOperStatus object for one or more contiguous entries in the pwTable are about to enter the down(2) or lowerLayerDown(6) state from any other state, except for transition from the notPresent(5) state.
Possible reasons for this notification include the following:
· The physical link of the PW went down.
· The configuration at the two ends of the PW changed.
System impact
Traffic forwarding fails in the PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-up-down command.
OFF
CLI: undo snmp-agent trap enable l2vpn pw-up-down command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.10.246.1.2.1.38 (pwOperStatus) |
PW operational status. |
pwIndex |
PwOperStatusTC |
up(1) down(2) testing(3) dormant(4) notPresent(5) lowerLayerDown(6) |
Recommended action
To resolve this issue:
Use the display l2vpn pw verbose command to view the Down Reasons field. Common reasons and solutions are as follows:
· BFD session for PW down—The BFD session for PW detection is down. In this case, use the display bfd session command to view the reasons for the BFD session down, and then correct the BFD configuration or troubleshoot the physical link and link quality issues accordingly.
· BGP RD was deleted—The BGP RD has been deleted. In this case, execute the route-distinguisher route-distinguisher command in auto-discovery cross-connect group view.
· BGP RD was empty—No BGP RD is configured. In this case, execute the route-distinguisher route-distinguisher command in auto-discovery cross-connect group view.
· Control word not match—The control word configuration on the two ends of the PW is inconsistent. In this case, configure the same control word setting on the two ends of the PW by using the control-word enable command in the PW class specified for the PW.
· Encapsulation not match—The encapsulation types on the two ends of the PW are inconsistent. In this case, configure the same PW data encapsulation type on the two ends of the PW by using the pw-type command in the PW class specified for the PW.
· LDP interface parameter not match—The LDP negotiation parameters on the two ends of the PW are inconsistent. In this case, configure the same VCCV CC type on the two ends of the PW by using the vccv cc command in the PW class specified for the PW. Or, configure the same CEM class settings for the CEM interfaces used by the two ends of the PW.
· Non-existent remote LDP PW—The remote device has deleted the LDP PW. In this case, reconfigure the PW on the remote device.
· Local AC Down—The local AC is down. In this case, verify that the configuration of the AC interface is correct and the state of the AC interface is up on the local device.
· Local AC was non-existent—No local AC is configured. In this case, configure a local AC and associate it with the VSI.
· MTU not match—The MTU configuration on the two ends of the PW is inconsistent. In this case, configure the same MTU on the two ends of the PW or use the mtu-negotiate disable command to disable PW MTU negotiation.
· Remote AC Down—The remote AC is down. In this case, verify that the configuration of the AC interface is correct and the state of the AC interface is up on the remote device.
pwUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.246.0.2 |
PW up |
Recovery |
Warning |
N/A |
OFF |
This notification is generated when the pwOperStatus object for one or more contiguous entries in the pwTable are about to enter the up(1) state from some other state except the notPresent(5) state and given that the pwDown notification been issued for these entries.
System impact
The service carried on the PW will become available again.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
pwIndex |
PwOperStatusTC |
Recommended action
No action is required.
pwDeleted
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.246.0.3 |
PW deleted |
Error |
Major |
N/A |
OFF |
This notification is generated when a PW is deleted.
· The peer was deleted in VSI view or the VSI was deleted manually.
· The peer was deleted in cross-connect view or the cross-connect was deleted manually.
· L2VPN or MPLS was disabled.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-delete command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-delete command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.10.246.1.2.1.2 (pwType) |
PW data encapsulation type. |
pwIndex |
IANAPwTypeTC |
other(0) frameRelayDlciMartiniMode(1) atmAal5SduVcc(2) atmTransparent(3) ethernetTagged(4) ethernet(5) hdlc(6) ppp(7) cem(8) -- Historic type atmCellNto1Vcc(9) atmCellNto1Vpc(10) ipLayer2Transport(11) atmCell1to1Vcc(12) atmCell1to1Vpc(13) atmAal5PduVcc(14) frameRelayPortMode(15) cep(16), e1Satop(17) t1Satop(18) e3Satop(19) t3Satop(20) basicCesPsn(21) basicTdmIp(22) tdmCasCesPsn(23) tdmCasTdmIp(24) frDlci(25) wildcard (32767) |
1.3.6.1.2.1.10.246.1.2.1.12 (pwID) |
PW ID. |
pwIndex |
PwIDType |
Unsigned32(1..4294967295) |
1.3.6.1.2.1.10.246.1.2.1.8 (pwPeerAddrType) |
pwIndex |
InetAddressType |
unknown(0) ipv4(1) ipv6(2) ipv4z(3) ipv6z(4) dns(16) |
1.3.6.1.2.1.10.246.1.2.1.9 (pwPeerAddr) |
pwIndex |
InetAddress |
OCTET STRING (SIZE (0..255)) |
Recommended action
This is a normal operating message. If the related configuration was deleted mistakenly, restore the configuration as needed.
