- 10-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-MPLSSCRLSP-MIB
- 04-HH3C-EVC-MIB
- 05-HH3C-L2VPN-MIB
- 06-HH3C-L3VPN-MIB
- 07-HH3C-MPLS-LDP-MIB
- 08-HH3C-MPLS-VPN-BGP-MIB
- 09-HH3C-MPLSBFD-MIB
- 10-HH3C-MPLSEXT-MIB
- 11-HH3C-VSI-MIB
- 12-HH3C-MPLSTE-MIB
- 13-HH3C-MPLSSLSP-MIB
- 14-HH3C-MPLSPCE-MIB
- 15-MPLS-FRR-FACILITY-STD-MIB
- 16-MPLS-FRR-GENERAL-STD-MIB
- 17-MPLS-FTN-STD-MIB
- 18-MPLS-L3VPN-STD-MIB
- 19-MPLS-LDP-STD-MIB
- 20-MPLS-LSR-STD-MIB
- 21-MPLS-TE-STD-MIB
- 22-PW-ENET-STD-MIB
- 23-PW-MPLS-STD-MIB
- 24-PW-STD-MIB
- 25-TE-MIB
15-MPLS-FRR-FACILITY-STD-MIB | 142.63 KB |
mplsFrrConfiguredBypassTunnels
mplsFrrFacilityNotificationsEnabled
mplsFrrFacilityNotificationsMaxRate
About this MIB
Use this MIB to manage tunnels on the MPLS interfaces configured for FRR protection.
MIB file name
rfc6445-mpls-frr-facility-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).mplsFrrFacilityMIB(204)
Scalar objects
mplsFrrConfiguredInterfaces
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrConfiguredInterfaces (1.3.6.1.2.1.204.1.1) |
read-only |
Integer32 |
Integer32 (0..2147483647) |
Number of MPLS interfaces configured for FRR protection. |
As per the MIB. |
mplsFrrActiveInterfaces
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrActiveInterfaces (1.3.6.1.2.1.204.1.2) |
read-only |
Gauge32 |
Gauge32 (0..4294967295) |
Number of interfaces currently being protected. An interface is being protected as long as the bypass tunnel on the interface is up. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrConfiguredBypassTunnels (1.3.6.1.2.1.204.1.3) |
read-only |
Gauge32 |
Number of bypass tunnels configured to protect tunnels on this LSR. |
As per the MIB. |
mplsFrrActiveBypassTunnels
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrActiveBypassTunnels (1.3.6.1.2.1.204.1.4) |
read-only |
Gauge32 |
Number of bypass tunnels in up state (ready to protect tunnels). |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrFacilityNotificationsEnabled (1.3.6.1.2.1.204.1.5) |
read-write |
Integer32 |
true(1), false(2) |
The capability of sending FRR notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrFacilityNotificationsMaxRate (1.3.6.1.2.1.204.1.6) |
read-write |
Gauge32 |
Maximum number of FRR notifications sent per second. |
Not supported. This value is already 0. |
Tabular objects
mplsFrrFacilityDBTable
About this table
Use this table to obtain FRR database information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
The mplsFrrFacilityDBProtectingTunnelResvBw object displays only the bandwidth information. It does not display the CT information. The value active(1) for mplsFrrFacilityDBProtectingTunnelStatus indicates that a primary/bypass tunnel FRR switchover has occurred. The value ready(2) for mplsFrrFacilityDBProtectingTunnelStatus indicates a bypass tunnel has been bound to the primary tunnel but no FRR switchover has occurred. |
Columns
The table indexes are mplsFrrFacilityProtectedIfIndex, mplsFrrFacilityProtectingTunnelIndex, mplsFrrFacilityBackupTunnelIndex, mplsFrrFacilityBackupTunnelInstance, and mplsFrrFacilityBackupTunnelIngressLSRId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrFacilityProtectedIfIndex (1.3.6.1.2.1.204.1.7.1.1) |
not-accessible |
InterfaceIndex |
Integer32 (1..2147483647) |
Index of an interface configured for FRR protection. |
As per the MIB. |
mplsFrrFacilityProtectingTunnelIndex (1.3.6.1.2.1.204.1.7.1.2) |
not-accessible |
MplsTunnelIndex |
Unsigned32 (0..65535) |
Index for a bypass tunnel on the interface specified by mplsFrrFacilityProtectedIfIndex. |
As per the MIB. |
mplsFrrFacilityBackupTunnelIndex (1.3.6.1.2.1.204.1.7.1.3) |
not-accessible |
MplsTunnelIndex |
Index of the protected tunnel on the interface specified by mplsFrrFacilityProtectedIfIndex. |
As per the MIB. |
mplsFrrFacilityBackupTunnelInstance (1.3.6.1.2.1.204.1.7.1.4) |
not-accessible |
MplsTunnelInstanceIndex |
Unsigned32 (0..2147483647) |
Index of the protected tunnel instance. |
As per the MIB. |
mplsFrrFacilityBackupTunnelIngressLSRId (1.3.6.1.2.1.204.1.7.1.5) |
not-accessible |
MplsLsrIdentifier |
OCTET STRING (0..255) |
Ingress LSR ID of the protected tunnel. |
As per the MIB. |
mplsFrrFacilityBackupTunnelEgressLSRId (1.3.6.1.2.1.204.1.7.1.6) |
not-accessible |
MplsLsrIdentifier |
Egress LSR ID of the protected tunnel. |
As per the MIB. |
mplsFrrFacilityDBNumProtectingTunnelOnIf (1.3.6.1.2.1.204.1.7.1.7) |
read-only |
Gauge32 |
Number of bypass tunnels on the interface. |
As per the MIB. |
mplsFrrFacilityDBNumProtectedLspOnIf (1.3.6.1.2.1.204.1.7.1.8) |
read-only |
Gauge32 |
Gauge32 (0.. 4294967295) |
Number of LSPs being protected on the interface. |
As per the MIB. |
mplsFrrFacilityDBNumProtectedTunnels (1.3.6.1.2.1.204.1.7.1.9) |
read-only |
Gauge32 |
Number of tunnels being protected on the interface. |
As per the MIB. |
mplsFrrFacilityDBProtectingTunnelStatus (1.3.6.1.2.1.204.1.7.1.10) |
read-only |
Integer32 |
active(1), ready(2), partial(3) |
State of the bypass tunnel. |
Supports only active(1) and ready(2) |
mplsFrrFacilityDBProtectingTunnelResvBw (1.3.6.1.2.1.204.1.7.1.11) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Bandwidth reserved for the bypass tunnel to provide bandwidth protection. |
As per the MIB. |
Notifications
mplsFrrFacilityInitialBackupTunnelInvoked
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.204.0.1 |
Interface failed and bypass tunnel took over. |
Error |
Major |
1.3.6.1.2.1.204.0.2 (mplsFrrFacilityFinalTunnelRestored) |
ON |
Notification triggers
This notification is generated when the interface or link protected by a bypass tunnel goes down and the service traffic is switched to the bypass tunnel accordingly.
System impact
The tunnel service is switched to the bypass tunnel. The service traversed path is not the expected primary tunnel, thus risks might increase for the service.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.204.1.7.1.7 (mplsFrrFacilityDBNumProtectingTunnelOnIf) |
Number of bypass tunnels on an interface for protection. |
1.3.6.1.2.1.204.1.7.1.1 (mplsFrrFacilityProtectedIfIndex) 1.3.6.1.2.1.204.1.7.1.2 (mplsFrrFacilityProtectingTunnelIndex) 1.3.6.1.2.1.204.1.7.1.3 (mplsFrrFacilityBackupTunnelIndex) 1.3.6.1.2.1.204.1.7.1.4 (mplsFrrFacilityBackupTunnelInstance) 1.3.6.1.2.1.204.1.7.1.5 (mplsFrrFacilityBackupTunnelIngressLSRId) |
Gauge32 |
Standard MIB values. |
1.3.6.1.2.1.204.1.7.1.8 (mplsFrrFacilityDBNumProtectedLspOnIf) |
Number of CRLSPs protected on the interface. |
Gauge32 |
1.3.6.1.2.1.204.1.7.1.9 (mplsFrrFacilityDBNumProtectedTunnels) |
Number of tunnels protected on the interface. |
Gauge32 |
1.3.6.1.2.1.204.1.7.1.10 (mplsFrrFacilityDBProtectingTunnelStatus) |
State of a bypass tunnel on the interface. |
INTEGER |
active(1) ready(2) |
1.3.6.1.2.1.204.1.7.1.11 (mplsFrrFacilityDBProtectingTunnelResvBw) |
Amount of bandwidth reserved by a bypass tunnel on the interface. |
Unsigned32 |
Recommended action
To resolve this issue:
¡ If an explicit path is configured, check whether the interfaces on each hop of the explicit path are faulty.
- If yes, clear link faults.
- If no, go to step 2.
2. If no explicit path is configured, check whether a path that satisfies the tunnel requirements exists. If yes, execute step 2.
3. If the issue persists, collect log messages and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.204.0.2 |
Interface recovered and primary tunnel recovered. |
Recovery |
Major |
N/A |
ON |
This notification is generated when the state of the interface or link protected by a bypass tunnel changes from down to up and the service traffic is switched from the bypass tunnel back to the primary tunnel accordingly.
System impact
No negative impact on services.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Number of bypass tunnels for FRR facility backup. |
Unsigned32 |
Number of LSPs protected by FRR facility backup. |
Unsigned32 |
Number of tunnels protected by FRR facility backup. |
Unsigned32 |
State of a bypass tunnel for FRR facility backup. |
Integer32 |
Amount of bandwidth reserved by the bypass tunnel for FRR facility backup. |
Unsigned32 |
Recommended action
No action is required.
