- 10-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-MPLSSCRLSP-MIB
- 04-HH3C-EVC-MIB
- 05-HH3C-L2VPN-MIB
- 06-HH3C-L3VPN-MIB
- 07-HH3C-MPLS-LDP-MIB
- 08-HH3C-MPLS-VPN-BGP-MIB
- 09-HH3C-MPLSBFD-MIB
- 10-HH3C-MPLSEXT-MIB
- 11-HH3C-VSI-MIB
- 12-HH3C-MPLSTE-MIB
- 13-HH3C-MPLSSLSP-MIB
- 14-HH3C-MPLSPCE-MIB
- 15-MPLS-FRR-FACILITY-STD-MIB
- 16-MPLS-FRR-GENERAL-STD-MIB
- 17-MPLS-FTN-STD-MIB
- 18-MPLS-L3VPN-STD-MIB
- 19-MPLS-LDP-STD-MIB
- 20-MPLS-LSR-STD-MIB
- 21-MPLS-TE-STD-MIB
- 22-PW-ENET-STD-MIB
- 23-PW-MPLS-STD-MIB
- 24-PW-STD-MIB
- 25-TE-MIB
18-MPLS-L3VPN-STD-MIB | 215.29 KB |
mplsL3VpnVrfConfRteMxThrshTime
mplsL3VpnVrfRouteMidThreshExceeded
mplsL3VpnVrfNumVrfRouteMaxThreshExceeded
mplsL3VpnNumVrfRouteMaxThreshCleared
MPLS-L3VPN-STD-MIB
About this MIB
Use this MIB to obtain MPLS VPN information.
MIB file name
rfc4382-mpls-l3vpn-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsL3VpnMIB(11)
Scalar objects
mplsL3VpnConfiguredVrfs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnConfiguredVrfs (1.3.6.1.2.1.10.166.11.1.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Number of configured VRFs. |
As per the MIB. |
mplsL3VpnActiveVrfs
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnActiveVrfs (1.3.6.1.2.1.10.166.11.1.1.2) |
read-only |
Gauge32 |
INTEGER(0..4294967295) |
Number of VRFs in up state. |
As per the MIB. |
mplsL3VpnConnectedInterfaces
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnConnectedInterfaces (1.3.6.1.2.1.10.166.11.1.1.3) |
read-only |
Gauge32 |
Number of interfaces bound to the VRF. |
As per the MIB. |
mplsL3VpnNotificationEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnNotificationEnable (1.3.6.1.2.1.10.166.11.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Whether MPLS L3VPN notification is enabled. |
As per the MIB. |
mplsL3VpnVrfConfMaxPossRts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfConfMaxPossRts (1.3.6.1.2.1.10.166.11.1.1.5) |
read-only |
Unsigned32 |
Maximum number of IPv4 and IPv6 routes that all VRFs on the device can have. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfConfRteMxThrshTime (1.3.6.1.2.1.10.166.11.1.1.6) |
read-only |
Unsigned32 |
Interval at which the route max threshold notification is regenerated after the maximum route number is exceeded (or reached if mplsL3VpnVrfConfMaxRoutes and mplsL3VpnVrfConfHighRteThresh are equivalent) and the initial notification is sent. If this value is set to 0, the agent generates only one notification when maximum route number is reached. |
As per the MIB. The return value is always 0. |
mplsL3VpnIllLblRcvThrsh
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnIllLblRcvThrsh (1.3.6.1.2.1.10.166.11.1.1.7) |
read-write |
Unsigned32 |
Number of received incorrect labels. |
Supports only the read operation. This object is not supported. The return value is always 32. |
Tabular objects
mplsL3VpnIfConfTable
About this table
This table specifies MPLS capability and associated VPNs for an interface.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are mplsL3VpnVrfName and mplsL3VpnIfConfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnIfConfIndex(1.3.6.1.2.1.10.166.11.1.2.1.1.1) |
not-accessible |
InterfaceIndex |
Integer32(1..2147483647) |
Interface index. |
As per the MIB. |
mplsL3VpnIfVpnClassification(1.3.6.1.2.1.10.166.11.1.2.1.1.2) |
read-create |
INTEGER |
carrierOfCarrier (1), enterprise (2), interProvider (3) |
Interface category. |
Supports only the read operation. |
mplsL3VpnIfVpnRouteDistProtocol (1.3.6.1.2.1.10.166.11.1.2.1.1.3) |
read-create |
BITS |
none (0), bgp (1), ospf (2), rip(3), isis(4), static(5), other (6) |
Route distribution protocol. |
mplsL3VpnIfConfStorageType (1.3.6.1.2.1.10.166.11.1.2.1.1.4) |
read-create |
StorageType |
INTEGER { other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) } |
Storage type of the interface. |
mplsL3VpnIfConfRowStatus (1.3.6.1.2.1.10.166.11.1.2.1.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
As per the MIB. |
mplsL3VpnVrfTable
About this table
This table contains VRF configuration information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is mplsL3VpnVrfName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfName (1.3.6.1.2.1.10.166.11.1.2.2.1.1) |
not-accessible |
MplsL3VpnName |
OCTET STRING (0..31) |
VRF name. |
As per the MIB. |
mplsL3VpnVrfVpnId (1.3.6.1.2.1.10.166.11.1.2.2.1.2) |
read-create |
VPNIdOrZero |
OCTET STRING (0 | 7) |
VPN ID. |
As per the MIB. |
mplsL3VpnVrfDescription (1.3.6.1.2.1.10.166.11.1.2.2.1.3) |
read-create |
SnmpAdminString |
OCTET STRING (0..255) |
VRF description. |
As per the MIB. |
mplsL3VpnVrfRD (1.3.6.1.2.1.10.166.11.1.2.2.1.4) |
read-create |
MplsL3VpnRouteDistinguisher |
OCTET STRING(0..256) |
Configured RD. By default, a get operation obtains the global RD. If no global RD is configured, it obtains the RD for the IPv4 unicast address family. If the IPv4 unicast address family RD is not configured either, "0:0" is displayed. |
As per the MIB. |
mplsL3VpnVrfCreationTime (1.3.6.1.2.1.10.166.11.1.2.2.1.5) |
read-only |
TimeStamp |
TimeTicks |
Time when the VRF entry was created. |
As per the MIB. |
mplsL3VpnVrfOperStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.6) |
read-only |
INTEGER |
up (1), down (2) |
Up/down state. |
As per the MIB. |
mplsL3VpnVrfActiveInterfaces (1.3.6.1.2.1.10.166.11.1.2.2.1.7) |
read-only |
Gauge32 |
Number of associated interfaces in up state. |
As per the MIB. |
mplsL3VpnVrfAssociatedInterfaces (1.3.6.1.2.1.10.166.11.1.2.2.1.8) |
read-only |
Unsigned32 |
Number of associated interfaces. |
As per the MIB. |
mplsL3VpnVrfConfMidRteThresh (1.3.6.1.2.1.10.166.11.1.2.2.1.9) |
read-create |
Unsigned32 |
Mid-level water marker for the number of IPv4 and IPv6 routes that this VRF supports. |
mplsL3VpnVrfConfHighRteThresh (1.3.6.1.2.1.10.166.11.1.2.2.1.10) |
read-create |
Unsigned32 |
High-level water marker for the number of IPv4 and IPv6 routes that the VRF supports. |
mplsL3VpnVrfConfMaxRoutes (1.3.6.1.2.1.10.166.11.1.2.2.1.11) |
read-create |
Unsigned32 |
Maximum number of IPv4 and IPv6 routes that this VRF is configured to hold. This value is equal to that of mplsL3VpnVrfConfHighRteThresh. |
mplsL3VpnVrfConfLastChanged (1.3.6.1.2.1.10.166.11.1.2.2.1.12) |
read-only |
TimeStamp |
TimeTicks |
Time when the entry changed most recently. |
As per the MIB. |
mplsL3VpnVrfConfRowStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.13) |
read-create |
RowStatus |
Row status. |
As per the MIB. |
mplsL3VpnVrfConfAdminStatus (1.3.6.1.2.1.10.166.11.1.2.2.1.14) |
read-create |
INTEGER |
up(1), down(2), testing(3) |
Administrative state of the VRF. |
mplsL3VpnVrfConfStorageType (1.3.6.1.2.1.10.166.11.1.2.2.1.15) |
read-create |
StorageType |
Storage type of the VRF. |
mplsL3VpnVrfRTTable
About this table
This table contains VPN RT information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are mplsL3VpnVrfName, mplsL3VpnVrfRTIndex, and mplsL3VpnVrfRTType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfRTIndex (1.3.6.1.2.1.10.166.11.1.2.3.1.2) |
not-accessible |
Unsigned32 |
Unsigned32(1..4294967295) |
RT index. |
As per the MIB. |
mplsL3VpnVrfRTType (1.3.6.1.2.1.10.166.11.1.2.3.1.3) |
not-accessible |
MplsL3VpnRtType |
import (1), export (2), or both (3). |
Incoming and outgoing policies. |
As per the MIB. |
mplsL3VpnVrfRT (1.3.6.1.2.1.10.166.11.1.2.3.1.4) |
read-create |
RT character string. |
mplsL3VpnVrfRTDescr (1.3.6.1.2.1.10.166.11.1.2.3.1.5) |
read-create |
SnmpAdminString |
RT description. |
mplsL3VpnVrfRTRowStatus (1.3.6.1.2.1.10.166.11.1.2.3.1.6) |
read-create |
RowStatus |
Row status. |
mplsL3VpnVrfRTStorageType (1.3.6.1.2.1.10.166.11.1.2.3.1.7) |
read-create |
StorageType |
RT storage type. |
mplsL3VpnVrfSecTable
About this table
This table contains MPLS VRF security statistics information about interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
This table index is mplsL3VpnVrfName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfSecIllegalLblVltns (1.3.6.1.2.1.10.166.11.1.2.6.1.1) |
read-only |
Counter32 |
Number of invalid labels that are received. |
As per the MIB. |
mplsL3VpnVrfSecDiscontinuityTime (1.3.6.1.2.1.10.166.11.1.2.6.1.2) |
read-only |
TimeStamp |
TimeTicks |
Interruption time. |
As per the MIB. |
mplsL3VpnVrfPerfTable
About this table
This table contains MPLS L3VPN VRF table performance information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfPerfRoutesAdded (1.3.6.1.2.1.10.166.11.1.3.1.1.1) |
read-only |
Counter32 |
Total number of added IPv4 and IPv6 routes. |
As per the MIB. |
mplsL3VpnVrfPerfRoutesDeleted (1.3.6.1.2.1.10.166.11.1.3.1.1.2) |
read-only |
Counter32 |
Total number of deleted IPv4 and IPv6 routes. |
As per the MIB. |
mplsL3VpnVrfPerfCurrNumRoutes (1.3.6.1.2.1.10.166.11.1.3.1.1.3) |
read-only |
Gauge32 |
Total number of active IPv4 and IPv6 routes. |
As per the MIB. |
mplsL3VpnVrfPerfRoutesDropped (1.3.6.1.2.1.10.166.11.1.3.1.1.4) |
read-only |
Counter32 |
Number of discarded routes. |
As per the MIB. |
mplsL3VpnVrfPerfDiscTime (1.3.6.1.2.1.10.166.11.1.3.1.1.5) |
read-only |
TimeStamp |
TimeTicks |
Interruption time. The value of this object is always 0. |
As per the MIB. |
mplsL3VpnVrfRteTable
About this table
This table contains information about routes configured for a VRF.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are mplsL3VpnVrfName, mplsL3VpnVrfRteInetCidrDestType, mplsL3VpnVrfRteInetCidrDest, mplsL3VpnVrfRteInetCidrPfxLen, mplsL3VpnVrfRteInetCidrPolicy, mplsL3VpnVrfRteInetCidrNHopType, and mplsL3VpnVrfRteInetCidrNextHop.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsL3VpnVrfRteInetCidrDestType (1.3.6.1.2.1.10.166.11.1.4.1.1.1) |
not-accessible |
InetAddressType |
INTEGER{ unknown(0), ipv4(1), ipv6(2), dns(16) } |
Destination address type. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrDest (1.3.6.1.2.1.10.166.11.1.4.1.1.2) |
not-accessible |
InetAddress |
Destination IP address. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrPfxLen (1.3.6.1.2.1.10.166.11.1.4.1.1.3) |
not-accessible |
InetAddressPrefixLength |
Unsigned32(0..128) |
Prefix length of the destination address. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrPolicy (1.3.6.1.2.1.10.166.11.1.4.1.1.4) |
not-accessible |
OBJECT IDENTIFIER |
Additional index that delineates between multiple entries to the same destination. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrNHopType (1.3.6.1.2.1.10.166.11.1.4.1.1.5) |
not-accessible |
InetAddressType |
Next hop type. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrNextHop (1.3.6.1.2.1.10.166.11.1.4.1.1.6) |
not-accessible |
InetAddress |
Next hop. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrIfIndex (1.3.6.1.2.1.10.166.11.1.4.1.1.7) |
read-create |
InterfaceIndexOrZero |
Integer32(0..2147483647) |
Egress interface index. |
mplsL3VpnVrfRteInetCidrType (1.3.6.1.2.1.10.166.11.1.4.1.1.8) |
read-create |
INTEGER |
other(1), reject(2), local(3), remote (4), blackhole(5) |
Route type. |
mplsL3VpnVrfRteInetCidrProto (1.3.6.1.2.1.10.166.11.1.4.1.1.9) |
read-only |
IANAipRouteProtocol |
Routing protocol. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrAge(1.3.6.1.2.1.10.166.11.1.4.1.1.10) |
read-only |
Gauge32 |
Route update time. |
As per the MIB. |
mplsL3VpnVrfRteInetCidrNextHopAS (1.3.6.1.2.1.10.166.11.1.4.1.1.11) |
read-create |
InetAutonomousSystemNumber |
AS number of the next hop. |
mplsL3VpnVrfRteInetCidrMetric1 (1.3.6.1.2.1.10.166.11.1.4.1.1.12) |
read-create |
Integer32 |
Integer32(-1 | 0..2147483647) |
Primary route metric. |
mplsL3VpnVrfRteInetCidrMetric2 (1.3.6.1.2.1.10.166.11.1.4.1.1.13) |
read-create |
Integer32 |
Optional route metric. |
Supports only the read operation. Set the value of this object to -1 if this object is not used. |
mplsL3VpnVrfRteInetCidrMetric3 (1.3.6.1.2.1.10.166.11.1.4.1.1.14) |
read-create |
Integer32 |
mplsL3VpnVrfRteInetCidrMetric4 (1.3.6.1.2.1.10.166.11.1.4.1.1.15) |
read-create |
Integer32 |
mplsL3VpnVrfRteInetCidrMetric5 (1.3.6.1.2.1.10.166.11.1.4.1.1.16) |
read-create |
Integer32 |
mplsL3VpnVrfRteXCPointer (1.3.6.1.2.1.10.166.11.1.4.1.1.17) |
read-create |
MplsIndexType |
mplsXCTable index. |
Supports only the read operation. This object is not supported. The return value is always 00.00.00.00. |
mplsL3VpnVrfRteInetCidrStatus (1.3.6.1.2.1.10.166.11.1.4.1.1.18) |
read-create |
RowStatus |
Row status. |
Notifications
mplsL3VpnVrfUp
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.10.166.11.0.1 |
An interface associated with a VRF comes up. |
Recovery |
Major |
N/A |
ON |
Notification triggers
This notification is generated for a VPN instance (VRF) in the following conditions:
· When the VPN instance is not bound to any interface, bind the VPN instance with an interface whose state (ifOperStatus) is up.
· The VPN instance is bound to only one interface, and the bound interface's state (ifOperStatus) changes from down to up.
· The VPN instance is bound to multiple interfaces. When all the interfaces are in down state (ifOperStatus), one of the interfaces changes from down state to up state.
System impact
No impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable l3vpn command.
OFF
CLI: Use the undo snmp-agent trap enable l3vpn command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.10.166.11.1.2.1.1.5 (mplsL3VpnIfConfRowStatus) |
Row status used to create, modify, and delete a row in this table. |
mplsL3VpnVrfName mplsL3VpnIfConfIndex |
INTEGER |
active(1) |
1.3.6.1.2.1.10.166.11.1.2.2.1.6 (mplsL3VpnVrfOperStatus) |
Operational state of the VPN. |
mplsL3VpnVrfName |
INTEGER |
up(1) down(2) |
Recommended action
No action is required.
mplsL3VpnVrfDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.11.0.2 |
An interface associated with a VRF goes down. |
Error |
Major |
1.3.6.1.2.1.10.166.11.0.1 (mplsL3VpnVrfUp) |
ON |
· The VPN instance is bound to only one interface and the interface’s state (ifOperStatus) is up. The interface state changes from up to down or the interface is unbound from the VPN instance.
· The VPN instance is bound to multiple interfaces. The ifOperStatus state of the last bound interface changes from up to down, or the last up interface is unbound from the VPN instance.
System impact
The VPN instance does not have an interface to forward IPv4 traffic.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
INTEGER |
active(1) |
mplsL3VpnVrfName |
INTEGER |
up(1) down(2) |
Recommended action
Identify whether the VPN instance is in use. If the VPN instance is not in use, unbinding the VPN instance from interfaces is normal and no action is required. If the VPN instance is in use, execute the display ip vpn-instance instance-name vpn-instance-name command to view the Interfaces field in the output.
· If the Interfaces field is not displayed, it indicates that no interface is bound to the VPN instance. In this case, identify the interface for the VPN instance, execute the ip binding vpn-instance command to bind the interface to the VPN instance, and then execute the ip address command to configure an IPv4 address for the interface.
· If the value of the Interfaces field is an interface or multiple interfaces, execute the display ip interface command to view interface state.
¡ If the interface physical state (current state) is down, troubleshoot the physical link faults.
¡ If the interface physical state (current state) is Administratively DOWN, execute the undo shutdown command to bring up the interface.
¡ If the interface does not have an IPv4 address, execute the iP address command to assign an IPv4 address to the interface.
If the issue persists, collect log messages, configuration data, and alarm information, and then contact Technical Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.11.0.3 |
The number of routes in a VRF exceeds the value indicated by mplsL3VpnVrfMidRouteThreshold. |
Informational |
Warning |
ON |
This notification is generated when the number of route prefixes in the routing table of the VPN instance exceeds the warning threshold.
System impact
The number of routes in the routing table of the VPN instance has reached the warning threshold. New routes can still be added to the VPN routing table and no route loss or traffic disruption will occur currently.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.2.1.10.166.11.1.3.1.1.3 (mplsL3VpnVrfPerfCurrNumRoutes) |
mplsL3VpnVrfName |
Gauge32 |
1.3.6.1.2.1.10.166.11.1.2.2.1.9 (mplsL3VpnVrfConfMidRteThresh) |
Mid-level water marker for the number of routes that this VRF supports. |
mplsL3VpnVrfName |
Unsigned32 |
Recommended action
1. Execute the display ip routing-table vpn-instance vpn-instance-name summary command to view the values for the Max Active Route, Remain Active Route, and Threshold value percentage fields to identify whether the VPN instance route limit has reached the MidRoute warning threshold.
2. Execute the display ip routing-table vpn-instance vpn-instance-name statistics command to view the number of routes of each protocol in the VPN instance. Identify whether the route counts satisfy the expected size.
¡ If yes, enter VPN instance view, edit the routing-table limit configuration with a bigger warning threshold value.
¡ If no, check the routing protocol whose route count exceeds the expected size and adjust the configuration to remove the exceeding routes. Then, execute the command in step 1 to identify whether the number of route prefixes has dropped below the warning threshold.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.11.0.4 |
The number of routes in a VRF exceeds or about to exceed the maximum allowed value as indicated by mplsL3VpnVrfMaxRouteThreshold. |
Error |
Warning |
1.3.6.1.2.1.10.166.11.0.6 (mplsL3VpnNumVrfRouteMaxThreshCleared) |
ON |
This notification is generated when the number of prefixes in the routing table of a VPN instance exceeds the maximum allowed.
System impact
No new routes can be added to the routing table of the VPN instance, and thus some traffic might be interrupted.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
mplsL3VpnVrfName |
Gauge32 |
1.3.6.1.2.1.10.166.11.1.2.2.1.10 (mplsL3VpnVrfConfHighRteThresh) |
High-level water marker for the number of routes that the VRF supports. |
mplsL3VpnVrfName |
Unsigned32 |
Recommended action
1. Execute the display ip routing-table vpn-instance vpn-instance-name summary command to view the values for the Max Active Route, Remain Active Route, and Threshold value percentage fields to identify whether the number of route prefixes in the VPN instance has reached the maximum.
¡ If yes, enter VPN instance view, edit the routing-table limit configuration with a bigger maximum value.
3. If the issue persists, collect configuration data, log messages, and alarm information, and then contact Technical Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.10.166.11.0.6 |
The number of routes in a VRF falls below the value of the mplsVrfMaxRouteThreshold object. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the number of route prefixes in the routing table of a VPN instance drops below the maximum value.
System impact
The number of routes in the routing table of the VPN instance has dropped below the maximum value. New routes can be added to the VPN instance’s routing table again.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
mplsL3VpnVrfName |
Gauge32 |
mplsL3VpnVrfName |
Unsigned32 |
Recommended action
