- 10-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-MPLSSCRLSP-MIB
- 04-HH3C-EVC-MIB
- 05-HH3C-L2VPN-MIB
- 06-HH3C-L3VPN-MIB
- 07-HH3C-MPLS-LDP-MIB
- 08-HH3C-MPLS-VPN-BGP-MIB
- 09-HH3C-MPLSBFD-MIB
- 10-HH3C-MPLSEXT-MIB
- 11-HH3C-VSI-MIB
- 12-HH3C-MPLSTE-MIB
- 13-HH3C-MPLSSLSP-MIB
- 14-HH3C-MPLSPCE-MIB
- 15-MPLS-FRR-FACILITY-STD-MIB
- 16-MPLS-FRR-GENERAL-STD-MIB
- 17-MPLS-FTN-STD-MIB
- 18-MPLS-L3VPN-STD-MIB
- 19-MPLS-LDP-STD-MIB
- 20-MPLS-LSR-STD-MIB
- 21-MPLS-TE-STD-MIB
- 22-PW-ENET-STD-MIB
- 23-PW-MPLS-STD-MIB
- 24-PW-STD-MIB
- 25-TE-MIB
02-HH3C-MPLSLSPV-MIB | 52.81 KB |
HH3C-MPLSLSPV-MIB
About this MIB
Use this MIB to notify LSPV traps.
MIB file name
hh3c-mplslspv.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsLspv(241)
Scalar objects
hh3cMplsLspvBaseInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsLspvBaseInfo (1.3.6.1.4.1.25506.2.241.1.1.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (0..127) |
Basic LSPV information |
As per the MIB. |
Notifications
hh3cMplsLspvPingProbe
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.241.0.1 |
LSP ping test |
Informational |
Major |
ON |
Notification triggers
This notification is generated when the device receives LSP ping packets and the reply mode is no reply.
System impact
No negative impact on the system.
Status control
None
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.241.1.1.1 (hh3cMplsLspvBaseInfo) |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
hh3cMplsLspvTracertProbe
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.241.0.2 |
LSP tracert test |
Informational |
Major |
ON |
This notification is generated when the device receives LSP tracert packets and the reply mode is no reply.
System impact
Status control
None
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
