- 10-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-MPLSSCRLSP-MIB
- 04-HH3C-EVC-MIB
- 05-HH3C-L2VPN-MIB
- 06-HH3C-L3VPN-MIB
- 07-HH3C-MPLS-LDP-MIB
- 08-HH3C-MPLS-VPN-BGP-MIB
- 09-HH3C-MPLSBFD-MIB
- 10-HH3C-MPLSEXT-MIB
- 11-HH3C-VSI-MIB
- 12-HH3C-MPLSTE-MIB
- 13-HH3C-MPLSSLSP-MIB
- 14-HH3C-MPLSPCE-MIB
- 15-MPLS-FRR-FACILITY-STD-MIB
- 16-MPLS-FRR-GENERAL-STD-MIB
- 17-MPLS-FTN-STD-MIB
- 18-MPLS-L3VPN-STD-MIB
- 19-MPLS-LDP-STD-MIB
- 20-MPLS-LSR-STD-MIB
- 21-MPLS-TE-STD-MIB
- 22-PW-ENET-STD-MIB
- 23-PW-MPLS-STD-MIB
- 24-PW-STD-MIB
- 25-TE-MIB
10-HH3C-MPLSEXT-MIB | 297.38 KB |
hh3cMplsExtResCountExceedClear
hh3cMplsExtLabLayerExceedClear
hh3cMplsExtEntryResExceedClear
HH3C-MPLSEXT-MIB
About this MIB
Use this MIB to manage MPLS and LDP capabilities and MPLS BFD sessions.
MIB file name
rfc3812-mpls-te-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).transmission(10).mplsStdMIB(166).mplsTeStdMIB(3)
Scalar objects
hh3cMplsExtLsrID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLsrID (1.3.6.1.4.1.25506.2.142.1.1.1) |
read-write |
OCTET STRING |
OCTET STRING (0..32) |
Global LSR ID. |
As per the MIB. |
hh3cMplsExtLdpStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLdpStatus (1.3.6.1.4.1.25506.2.142.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of global LDP. |
As per the MIB. |
hh3cMplsExtLabelInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLabelInfo (1.3.6.1.4.1.25506.2.142.1.1.3) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (0..127) |
MPLS label information. |
As per the MIB. |
hh3cMplsExtTnlToVpnInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtTnlToVpnInfo (1.3.6.1.4.1.25506.2.142.1.1.4) |
OCTET STRING |
Tunnel policy information. |
As per the MIB. |
hh3cMplsExtDrvInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtDrvInfo (1.3.6.1.4.1.25506.2.142.1.1.5) |
OCTET STRING |
Drive reported information. |
As per the MIB. |
hh3cMplsExtLabelExtInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLabelExtInfo (1.3.6.1.4.1.25506.2.142.1.1.6) |
OCTET STRING |
Extended information of the MPLS label. |
As per the MIB. |
Tabular objects
hh3cMplsExtTable
About this table
Use this table to configure the MPLS capability for interfaces.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
You cannot set an MTU for a tunnel interface. By default, the MPLS MTU depends on the interface MTU. Different types of interfaces have different MTU values. |
The MTU of a tunnel interface cannot be modified. |
Supported |
Supported |
Columns
The table index is hh3cMplsExtIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtIndex (1.3.6.1.4.1.25506.2.142.1.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Index of an interface. |
As per the MIB. |
hh3cMplsExtCapability (1.3.6.1.4.1.25506.2.142.1.2.1.2) |
read-create |
TruthValue |
true(1), false(2) |
MPLS capability of the interface. |
As per the MIB. |
hh3cMplsExtMtu (1.3.6.1.4.1.25506.2.142.1.2.1.3) |
read-create |
Unsigned32 |
Unsigned32 (46..65535) |
MPLS MTU of the interface. |
As per the MIB. |
hh3cMplsExtRowStatus (1.3.6.1.4.1.25506.2.142.1.2.1.4) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cMplsExtLdpTable
About this table
Use this table to configure the LDP capability for interfaces.
Create |
Edit/Modify |
Delete |
Read |
When create, the value of hh3cMplsExtLdpCapability must be true(1). |
Supported |
Supported |
Supported |
Columns
The table index is hh3cMplsExtLdpIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLdpIndex (1.3.6.1.4.1.25506.2.142.1.3.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cMplsExtLdpCapability (1.3.6.1.4.1.25506.2.142.1.3.1.2) |
read-create |
TruthValue |
true(1) false(2) |
LDP capability of the interface. |
As per the MIB. |
hh3cMplsExtLdpRowStatus (1.3.6.1.4.1.25506.2.142.1.3.1.3) |
read-create |
RowStatus |
active(1),
Row status. |
hh3cMplsExtBfdTable
About this table
This table contains information about MPLS BFD sessions.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtBfdLocalDiscr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtBfdLocalDiscr (1.3.6.1.4.1.25506.2.142.1.4.1.1) |
not-accessible |
Unsigned32 |
Local discriminator of a BFD session. |
As per the MIB. |
hh3cMplsExtBfdType (1.3.6.1.4.1.25506.2.142.1.4.1.2) |
read-only |
INTEGER |
1: unknown 4: BFD for VPLS PW 5: BFD for TE |
Type of the BFD session. |
As per the MIB. |
hh3cMplsExtBfdBindIfIndex (1.3.6.1.4.1.25506.2.142.1.4.1.3) |
read-only |
InterfaceIndexOrZero |
This object displays a tunnel interface index when the value of hh3cMplsExtBfdType is 5 (BFD for TE) and displays the index of an AC interface bound to a PW when the value of hh3cMplsExtBfdType is 3 (BFD for VPWS PW). This object is invalid and displays 0 when the value of hh3cMplsExtBfdType is not 5 (BFD for TE) or 3 (BFD for VPWS PW). |
Index of the bound local interface. |
As per the MIB. |
hh3cMplsExtBfdBindIfName (1.3.6.1.4.1.25506.2.142.1.4.1.4) |
read-only |
DisplayString |
DisplayString (0..255) |
Name of the bound local interface. |
As per the MIB. |
hh3cMplsExtBfdXcIndex (1.3.6.1.4.1.25506.2.142.1.4.1.5) |
read-only |
OCTET STRING |
OCTET STRING (0..24) |
MplsOutSegmentEntry index for an LSP entry. |
As per the MIB. |
hh3cMplsExtBfdPwBackupFlag (1.3.6.1.4.1.25506.2.142.1.4.1.6) |
read-only |
INTEGER |
1: Non-PW |
Primary or backup flag of a PW. |
As per the MIB. |
hh3cMplsExtBfdPwId (1.3.6.1.4.1.25506.2.142.1.4.1.7) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
PW identifier. |
As per the MIB. |
hh3cMplsExtBfdVsiIndex (1.3.6.1.4.1.25506.2.142.1.4.1.8) |
read-only |
Unsigned32 |
VSI index + 1. |
As per the MIB. |
hh3cMplsExtBfdPwPeerIpType (1.3.6.1.4.1.25506.2.142.1.4.1.9) |
read-only |
InetAddressType |
IPv4 or IPv6. The value of this object is 0 if the BFD session is not for a PW. |
Type of the PW peer address. |
As per the MIB. |
hh3cMplsExtBfdPwPeerIp (1.3.6.1.4.1.25506.2.142.1.4.1.10) |
read-only |
InetAddress |
OCTET STRING (0..255) |
Peer address of the PW. |
As per the MIB. |
hh3cMplsExtBfdPwSPE (1.3.6.1.4.1.25506.2.142.1.4.1.11) |
read-only |
INTEGER |
1: Non-VPWS PW |
Node information of the VPWS PW. |
As per the MIB. |
hh3cMplsExtBfdPwEncapType (1.3.6.1.4.1.25506.2.142.1.4.1.12) |
read-only |
INTEGER |
1: unknown 2: fr-dlci-martini 3: atm-aal5-sdu 4: atm-trans-cell 5: vlan 6: ethernet 7: hdlc 8: ppp 9: cesom 10: atm-nto1-vcc 11: atm-nto1-vpc 12: ip-interworking 13: atm-1to1-vcc 14: atm-1to1-vpc 15: atm-aal5-pdu 16: fr-port 17: cep 18: satop-e1 19: satop-t1 20: satop-e3 21: satop-t3 22: esopsn-basic 23: tdmoip-aal1-mode 24: tdm-cesopsn-with-cas 25: tdmoip-aal2-mode 26: fr-dlci |
Encapsulation type of the PW. |
As per the MIB. |
hh3cMplsExtVpnStatsTable
About this table
This table contains statistical information about packets received and sent by VPNs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtVpnStatsVrfIndex .
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtVpnStatsVrfIndex (1.3.6.1.4.1.25506.2.142.1.5.1.1) |
not-accessible |
Unsigned32 |
Index of a VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsVpnName (1.3.6.1.4.1.25506.2.142.1.5.1.2) |
read-only |
OCTET STRING |
OCTET STRING (1..31 ) |
Name of the VPN instance. |
As per the MIB. This object is invalid if VPN statistics is not enabled. When read, this object returns a zero-length string. |
hh3cMplsExtVpnStatsInOctets (1.3.6.1.4.1.25506.2.142.1.5.1.3) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Number of octets received by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsInPackets (1.3.6.1.4.1.25506.2.142.1.5.1.4) |
read-only |
Counter64 |
Number of packets received by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsInErrors (1.3.6.1.4.1.25506.2.142.1.5.1.5) |
read-only |
Counter64 |
Number of error packets received by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsInDiscards (1.3.6.1.4.1.25506.2.142.1.5.1.6) |
read-only |
Counter64 |
Number of incoming packets discarded by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutOctets (1.3.6.1.4.1.25506.2.142.1.5.1.7) |
read-only |
Counter64 |
Number of octets sent by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutPackets (1.3.6.1.4.1.25506.2.142.1.5.1.8) |
read-only |
Counter64 |
Number of packets sent by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutErrors (1.3.6.1.4.1.25506.2.142.1.5.1.9) |
read-only |
Counter64 |
Number of error packets sent by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnStatsOutDiscards (1.3.6.1.4.1.25506.2.142.1.5.1.10) |
read-only |
Counter64 |
Number of outgoing packets discarded by the VPN instance. |
As per the MIB. |
hh3cMplsExtVpnTable
About this table
This table contains MPLS L3VPN information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtVpnName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtVpnName (1.3.6.1.4.1.25506.2.142.1.6.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..31) |
Name of a VPN instance. |
As per the MIB. |
hh3cMplsExtVrfIndex (1.3.6.1.4.1.25506.2.142.1.6.1.2) |
read-only |
Unsigned32 |
Index of the VPN instance. |
As per the MIB. |
hh3cMplsExtStaticLspTable
About this table
This table contains information about MPLS static LSPs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtStaticLspName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtStaticLspName (1.3.6.1.4.1.25506.2.142.1.7.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..67) |
Name of a static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspType (1.3.6.1.4.1.25506.2.142.1.7.1.2) |
read-only |
Enumeration |
1—Ingress 2—Transit 3—Egress |
Type of the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspInLabel (1.3.6.1.4.1.25506.2.142.1.7.1.3) |
read-only |
Unsigned integer. |
Unsigned integer. (16..1048575) |
Incoming label for the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspOutLabel (1.3.6.1.4.1.25506.2.142.1.7.1.4) |
read-only |
Unsigned integer |
Unsigned integer. (0,3,16..1048575) |
Outgoing label for the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspDestAddr (1.3.6.1.4.1.25506.2.142.1.7.1.5) |
read-only |
String, dotted decimal notation. |
Destination address of the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspDestAddrMaskLen (1.3.6.1.4.1.25506.2.142.1.7.1.6) |
read-only |
Unsigned integer. |
Unsigned integer. (0..32) |
Mask length of the destination address. |
As per the MIB. |
hh3cMplsExtStaticLspNextHopAddr (1.3.6.1.4.1.25506.2.142.1.7.1.7) |
read-only |
Nexthop address of the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspOutIfIndex (1.3.6.1.4.1.25506.2.142.1.7.1.8) |
read-only |
Unsigned integer. |
Unsigned integer. (0..4294967295) |
Index of the outgoing interface for this static LSP. |
As per the MIB. |
Notifications
hh3cMplsExtLabThreExceed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.142.0.1 |
The MPLS LSM label usage reached the upper threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.142.0.2 (hh3cMplsExtLabThreExceedClear) |
ON |
Notification triggers
This notification is generated when the usage of a type of MPLS labels reaches the upper threshold. Support for a type of MPLS labels depends on the device model. The following types of MPLS labels are available:
· 0—Static MPLS label.
· 1—Egress MPLS label.
· 2—Dynamic MPLS label.
· 3—L3VPN MPLS label.
· 4—VPWS MPLS label.
· 5—VPLS MPLS label.
· 6—IPv6 egress MPLS label.
· 7—SRGB MPLS label.
· 8—SRLB MPLS label.
· 9—L3VPN MPLS label.
System impact
Services might be affected if new services that use the type of MPLS labels are added.
Status control
ON
CLI: Use the snmp-agent trap enable lsm-private command.
OFF
CLI: Use the undo snmp-agent trap enable lsm-private command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
To resolve this issue:
1. If the label type is VPWS or VPLS, this issue is caused by too many VPLS or VPWS services existing on the device. Execute the display l2vpn pw command to display PW information, delete unnecessary PWs, and then go to step 3.
2. Execute the display mpls lsp statistics command to identify the protocols that generate too many LSPs. Execute the display mpls lsp protocol command to display the LSP information of these protocols, delete unnecessary LSPs, and then go to step 3.
3. Check whether the hh3cMplsExtLabThreExceedClear notification has been generated.
¡ If yes, this issue has been resolved.
¡ If not, collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.2 |
MPLS LSM label usage dropped below the lower threshold. |
Recovery |
Warning |
N/A |
ON |
This notification is generated when the usage of a type of MPLS labels drops below the lower threshold.
System impact
No negative impact on the system.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
hh3cMplsExtLabTotExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.3 |
MPLS LSM labels are used up. |
Error |
Major |
1.3.6.1.4.1.25506.2.142.0.4 (hh3cMplsExtLabTotExceedClear) |
ON |
This notification is generated when the usage of a type of MPLS labels reaches 100%. The following types of MPLS labels are available:
System impact
No LSPs can be established for services that use a type of MPLS labels after that type of MPLS labels are used up.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
1. If the label type is VPWS or VPLS, this issue is caused by too many VPWS or VPLS services existing on the device. Execute the display l2vpn pw command to display PW information, delete unnecessary PWs, and then go to step 3.
3. Check whether the hh3cMplsExtLabTotExceedClear notification has been generated.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.4 |
The MPLS LSM label usage dropped to the specified value. |
Recovery |
Major |
N/A |
ON |
This notification is generated when the MPLS LSM label usage drops to the specified value, which is 95%.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsExtTnlToVpnEvent
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.5 |
The tunnel selected for the VPN changed. |
Recovery |
Major |
N/A |
ON |
This notification is generated when the selected tunnel for the VPN changes.
Possible reasons are as follows:
· The situation that no tunnel is selected for the VPN changes to the situation that a tunnel is selected for the VPN.
· The situation that a tunnel is selected for the VPN changes to the situation that no tunnel is selected for the VPN.
· The selected tunnel for the VPN is changed.
System impact
If the tunnel used by the VPN service changes from reachable to unreachable, or the situation that a tunnel is selected for the VPN changes to the situation that no tunnel is selected for the VPN, the VPN service is interrupted.
If the selected tunnel for the VPN is changed, the forwarding path for the VPN service traffic changes accordingly. Existing services on the new forwarding path might be affected.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Tunnel policy information |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
If the EcmpNum value in the notification is not 0, this notification is generated because the selected tunnel for the VPN is changed. Perform the following tasks to identify whether the change is desired:
1. Execute the display ip vpn-instance instance-name name command to identify whether a tunnel policy is applied to the VPN.
¡ If the command output has the Tunnel Policy field, a tunnel policy is applied to the VPN. In this case, go to step 2.
¡ If the command output does not have the Tunnel Policy field, no tunnel policy is applied to the VPN. In this case, go to step 3.
2. Execute the display tunnel-policy tunnel-policy-name command to check the tunnel policy. A tunnel policy uses tunnel selection methods in descending order of tunnel binding, preferred tunnel, and load sharing. In the command output, identify the tunnel selection methods used in the tunnel policy and find the tunnels that the VPN is expected to select through the tunnel policy.
¡ If the command output has the Binding-destination field, the tunnel binding method is used. The VPN is expected to select the tunnels in this field.
¡ If the command output has the Preferred paths field, the preferred tunnel method is used. The VPN is expected to select the tunnels in this field.
¡ If the command output has the Select-Seq field, the load sharing method is used. In this case, execute the display mpls tunnel all or display tunnel-info ipv6 all command to display information about the specified types of tunnels in the Select-Seq field. You can find the tunnels that the VPN is expected to select according to the tunnel policy and the tunnel information.
If the mpls te reserved-for-binding command is used on an MPLS TE tunnel interface, this MPLS TE tunnel cannot be used for load sharing.
3. Execute the display fib vpn-instance vpn-instance-name command to check the FIB of the VPN instance. According to the value in the OutInterface/Token field, execute the display mpls forwarding nhlfe command to display information about the selected tunnels.
¡ If no tunnel policy is applied to the VPN, identify whether the selected tunnels are the expected tunnels. If yes, no action is required. If not, go to step 4.
¡ If a tunnel policy is applied to the VPN, identify whether the selected tunnels are the same as the expected tunnels found in step 2. If yes, no action is required. If not, go to step 4.
4. If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
If the EcmpNum value in the notification is 0, no tunnel is selected for the VPN. To resolve this issue:
¡ If the command output has the Tunnel Policy filed, a tunnel policy is applied to the VPN. In this case, go to step 2.
¡ If the command output has the Binding-destination field, the tunnel binding method is used. In this case, execute the display interface tunnel command to verify that the bound tunnel interfaces in the tunnel policy are up.
- If a tunnel interface is up, enter tunnel interface view and execute the mpls te reserved-for-binding command. If the hh3cMplsExtTnlToVpnEvent notification is generated, this issue has been resolved. If the hh3cMplsExtTnlToVpnEvent notification is not generated, go to step 4.
- If all tunnel interfaces are down, identify the interface down reason and bring up the interfaces according to TE related notifications. If the hh3cMplsExtTnlToVpnEvent notification is generated, this issue has been resolved. If the hh3cMplsExtTnlToVpnEvent notification is not generated, go to step 4.
¡ If the command output has the Preferred paths field, the preferred tunnel method is used. If the preferred tunnel is not available, the system automatically uses other methods to select tunnels. Unavailable of the preferred tunnel does not cause tunnel selection failure.
¡ If the command output has the Select-Seq field, the load sharing method is used. In this case, execute the display mpls tunnel all or display tunnel-info ipv6 all command to display information about the tunnels in the Select-Seq field and identify whether a qualified tunnel exists.
- If no qualified tunnels are available, configure a qualified tunnel or change the tunnel policy applied to the VPN. If the hh3cMplsExtTnlToVpnEvent notification is generated, this issue has been resolved. If the hh3cMplsExtTnlToVpnEvent notification is not generated, go to step 4.
- If a qualified tunnel is available, go to step 4.
3. Execute the display mpls lsp command to identify whether a public tunnel is available. If no public tunnel is available, modify the public tunnel configuration, for example, the LDP configuration, to establish a public tunnel.
¡ If the hh3cMplsExtTnlToVpnEvent notification is generated, this issue has been resolved.
¡ If the hh3cMplsExtTnlToVpnEvent notification is not generated, go to step 4.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.6 |
The MPLS resource usage reached the maximum. |
Error |
Major |
1.3.6.1.4.1.25506.2.142.0.7 (hh3cMplsExtResCountExceedClear) |
OFF |
This notification is generated when the usage of a type of MPLS resources reaches the maximum allowed. Support for MPLS resources depends on the device model.
System impact
A type of MPLS resources have been used up and services might fail to be established by using that type of MPLS resources.
Status control
ON
CLI: Use the snmp-agent trap enable mpls-private resources-exceeded command.
OFF
CLI: Use the undo snmp-agent trap enable mpls-private resources-exceeded command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
Standard MIB values. |
Recommended action
1. Determine the resource overuse situation according to the MPLS resource type.
2. Reduce the configuration that uses this type of MPLS resources, or reduce the configuration or messages that trigger the creation of such resources.
¡ If the hh3cMplsExtResCountExceedClear notification is generated, this issue has been resolved.
¡ If the hh3cMplsExtResCountExceedClear notification is not generated, collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.7 |
The MPLS resource usage dropped below the maximum. |
Recovery |
Major |
N/A |
OFF |
This notification is generated when the MPLS resource usage drops below the maximum allowed. Support for MPLS resources depends on the device model.
System impact
No negative impact on services.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.8 |
The number of MPLS labels exceeds the maximum supported by the device. |
Error |
Major |
1.3.6.1.4.1.25506.2.142.0.9 (hh3cMplsExtLabLayerExceedClear) |
OFF |
This notification is generated when the number of MPLS labels exceeds the maximum supported by the device.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Information reported by the driver. |
Yes. |
OCTET STRING |
Recommended action
1. Reduce the number of labels.
2. If the issue persists, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.9 |
The number of MPLS labels has decreased to a value that the device supports. |
Recovery |
N/A |
N/A |
OFF |
This notification is generated when the number of MPLS labels decreases to a value that the device supports.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes. |
OCTET STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.10 |
Insufficient driver resources. |
Error |
Major |
1.3.6.1.4.1.25506.2.142.0.11 (hh3cMplsExtEntryResExceedClear) |
OFF |
The number of a certain type of driver resources used has reached the maximum capacity supported by the system. Support for driver resources depends on the device model.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes. |
OCTET STRING |
Recommended action
Contact Technical Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.11 |
The driver resource usage has decreased below the maximum value. |
Recovery |
N/A |
N/A |
OFF |
This notification is generated when the usage of a driver resource drops below its maximum value. Support for driver resources depends on the device model.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes. |
OCTET STRING |
Recommended action
hh3cMplsExtSRLabelConflict
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.12 |
Another protocol has allocated a different label to the current prefix address. |
Error |
Major |
N/A |
OFF |
A routing protocol allocates a label to the prefix address of an SR node but another protocol has allocated a different label to the prefix address on the same SR node.
System impact
The current routing protocol cannot allocate a label to the prefix address.
Status control
ON
CLI: Use the snmp-agent trap enable mpls-private sr-label-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable mpls-private sr-label-conflict command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
Standard MIB values |
N/A |
OCTET STRING |
Recommended action
1. Make sure different routing protocols allocate the same label to the same prefix address.
2. Delete the used routing protocol process and make sure only one routing protocol allocates a label to the prefix address.
3. If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
hh3cMplsExtSRPrefixConflict
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.13 |
The current label has been allocated to another prefix address. |
Error |
Major |
N/A |
OFF |
The same label is allocated to two different prefix addresses, resulting label conflict.
System impact
Failed to allocate a label to the current prefix address.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
N/A |
OCTET STRING |
Recommended action
1. Delete the label configuration for the conflicted prefix address to release the label.
2. Allocate a different label to the new prefix address.
hh3cMplsExtHardResNotEnough
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.15 |
Not enough MPLS hardware resources |
Error |
Major |
1.3.6.1.4.1.25506.2.142.0.14 (hh3cMplsExtHardResRestore) |
OFF |
MPLS hardware resources are not enough.
System impact
The device will fail to request resources for deploying subsequent MPLS settings to the drive.
Status control
ON
CLI: Use the snmp-agent trap enable lsm-private hard-resource command.
OFF
CLI: Use the undo snmp-agent trap enable lsm-private hard-resource command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
Recommended action
1. Check whether the device has generated a large number of unnecessary LSPs. If yes, configure or edit the LSP generation policy, label advertisement policy and label acceptance policy of the label distribution protocol to remove unnecessary LSPs.
2. If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.14 |
MPLS hardware resources restored |
Recovery |
Major |
N/A |
OFF |
MPLS hardware resources are restored.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
Recommended action
