- 10-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-MPLSLSPV-MIB
- 03-HH3C-MPLSSCRLSP-MIB
- 04-HH3C-EVC-MIB
- 05-HH3C-L2VPN-MIB
- 06-HH3C-L3VPN-MIB
- 07-HH3C-MPLS-LDP-MIB
- 08-HH3C-MPLS-VPN-BGP-MIB
- 09-HH3C-MPLSBFD-MIB
- 10-HH3C-MPLSEXT-MIB
- 11-HH3C-VSI-MIB
- 12-HH3C-MPLSTE-MIB
- 13-HH3C-MPLSSLSP-MIB
- 14-HH3C-MPLSPCE-MIB
- 15-MPLS-FRR-FACILITY-STD-MIB
- 16-MPLS-FRR-GENERAL-STD-MIB
- 17-MPLS-FTN-STD-MIB
- 18-MPLS-L3VPN-STD-MIB
- 19-MPLS-LDP-STD-MIB
- 20-MPLS-LSR-STD-MIB
- 21-MPLS-TE-STD-MIB
- 22-PW-ENET-STD-MIB
- 23-PW-MPLS-STD-MIB
- 24-PW-STD-MIB
- 25-TE-MIB
13-HH3C-MPLSSLSP-MIB | 88.75 KB |
HH3C-MPLSSLSP-MIB
About this MIB
Use this MIB to notify static LSP traps.
MIB file name
hh3c-mplsslsp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsSlsp(230)
Tabular objects
hh3cMplsSlspBaseInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsSlspBaseInfo (1.3.6.1.4.1.25506.2.230.1.1.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (0..127) |
Static LSP basic information |
As per the MIB. |
hh3cMplsSlspExtInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsSlspExtInfo (1.3.6.1.4.1.25506.2.230.1.1.2) |
OCTET STRING |
Static LSP extended information |
As per the MIB. |
Notifications
hh3cMplsSlspDown
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.230.0.1 |
Static LSP down |
Error |
Major |
1.3.6.1.4.1.25506.2.230.0.2(hh3cMplsSlspUp) |
OFF |
Notification triggers
This notification might be generated when the following events occur:
1. MPLS disabled on an interface.
2. Route change.
3. Inbound interface Down.
4. Outbound interface Down.
5. Static LSP configuration updated.
6. Others.
System impact
· Service interruption will occur on services that use the static LSP for traffic forwarding.
· No negative impact will occur on services that do not use the static LSP for traffic forwarding.
Status control
ON
CLI: Use the snmp-agent trap enable mpls-private slsp-up-down command.
OFF
CLI: Use the undo snmp-agent trap enable mpls-private slsp-up-down command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.230.1.1.1 (hh3cMplsSlspBaseInfo) |
N/A |
OCTET STRING |
As per the MIB. |
1.3.6.1.4.1.25506.2.230.1.1.2 (hh3cMplsSlspExtInfo) |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
To resolve this issue:
1. Execute the display mpls interface command to check interface information.
If the alarm was generated at the ingress of the static LSP, check the outgoing interface. If the alarm was generated at the egress of the static LSP, check the incoming interface. If the alarm was generated at the transit node of the static LSP, check both the incoming interface and outgoing interface.
In the command output, verify that the corresponding interface exists and the interface status is Up.
¡ If the interface status is not Up, check and correct the interface configuration, and then go to step 2.
¡ If the corresponding interface is not displayed in the command output, it indicates that MPLS is not enabled on the interface. Enable MPLS on the interface and then go to step 2.
2. Execute the display ip routing-table ip-address command at the ingress node, and check whether a valid route exists.
¡ If yes, go to step 3.
¡ If not, check the route configuration and ensure that the next hop address is reachable. Then, go to step 4.
3. Execute the display mpls lsp command at the ingress node to check whether a dynamic LSP with the same prefix as the static LSP is configured.
¡ If yes, disable the dynamic LSP and go to step 4.
¡ If not, go to step 5.
4. Check whether the alarms have been cleared.
¡ If yes, the issue has been resolved.
5. Collect alarm information and configuration data, and then contact Technical Support for help.
hh3cMplsSlspUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.230.0.2 |
Static LSP up |
Recovery |
Major |
N/A |
OFF |
This notification is generated when a static LSP comes up.
System impact
No negative impact on services.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
hh3cMplsSlspLabelDup
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.230.0.3 |
The incoming label of the static LSP is already used by a static PW or static CRLSP. |
Error |
Major |
N/A |
OFF |
1. MPLS is enabled and then a static LSP is configured with an incoming label that has been used by an existing static PW or static CRLSP.
2. A static LSP is configured with an incoming label that has been used by an existing static PW or static CRLSP, and then MPLS is enabled.
System impact
The incoming label request failed.
Status control
ON
CLI: Use the snmp-agent trap enable mpls-private label-duplicate command.
OFF
CLI: Use the undo snmp-agent trap enable mpls-private label-duplicate command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Basic information of the static LSP |
N/A |
OCTET STRING |
As per the MIB. |
Extended information of the static LSP |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
1. Delete the configuration for the occupied label to release the label.
2. Request an unused label.
3. If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
