07-Wireless authentication
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10407-Wireless authentication
Table of Contents
Related Documents
05-Local Portal Auth and SSID-based Auth Page Pushing Configuration Examples
Local Portal Authentication and SSID-based Authentication Page Pushing
Introduction
The following information provides examples for configuring local portal authentication and SSID-based authentication page pushing on the AC.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of portal authentication.
Example: Configuring local portal authentication and SSID-based authentication page pushing
As shown in Figure 1, the AP and the client obtain IP addresses from the DHCP server. The access device AC acts as the portal Web server and the portal authentication server.
Configure the devices to meet the following requirements:
·     The AC provides direct portal authentication for the client. Before passing the authentication, the client can access only the portal Web server. After passing the authentication, the client can access other network resources.
·     The client can access network resources through any Layer 2 ports in its access VLAN without re-authentication.
Figure 1 Network diagram
Analysis
To allow an authenticated user to access network resources on any Layer 2 ports in its access VLAN without re-authentication, you must enable the portal roaming feature.
In wireless networks where the AP forwards client traffic, the AC does not have ARP entries for clients. Therefore, the AC cannot check the validity of portal clients by using ARP entries. To ensure that valid users can perform portal authentication, you must enable wireless client validity check on the AC.
To avoid possible authentication failure caused by frequent logins and logouts of portal clients in a short time, disable the Rule ARP entry feature.
Use the actual serial ID of an AP to uniquely identify that AP.
By default, the portal Web server URL redirected to users does carry parameters. You can configure the parameters to be carried in the redirection URL as needed.
Procedures
Configuring the AC
1.     Configuring VLANs and interfaces:
# Create VLAN 100 and VLAN-interface 100. Assign the VLAN interface an IP address. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 2.2.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200. Assign the VLAN interface an IP address. This VLAN will be used for wireless client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 2.2.2.1 24
[AC-Vlan-interface200] quit
# Configure the interface connected to the switch (GigabitEthernet 1/0/1) as a trunk port, and add the port to VLAN 100 and VLAN 200.
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
2.     Configure the wireless service:
# Create a service template named st1 and enter its view.
[AC] wlan service-template st1
# Configure the SSID of the service template as service.
[AC-wlan-st-st1] ssid service
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-st1] vlan 200
# Configure the AC to forward client data traffic. (Skip this step if the client data traffic forwarder is the AC by default.)
[AC–wlan-st-st1] client forwarding-location ac
# Specify the AKM mode as PSK, and configure the preshared key as 12345678 in plain text.
[AC-wlan-st-st1] akm mode psk
[AC-wlan-st-st1] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC-wlan-st-st1] cipher-suite ccmp
[AC-wlan-st-st1] security-ie rsn
[AC-wlan-st-st1] quit
# Create a service template named st2 and enter its view.
[AC] wlan service-template st2
[AC–wlan-st-st2] client forwarding-location ac
# Configure the SSID of the service template as service2.
[AC-wlan-st-st2] ssid service2
[AC-wlan-st-st2] akm mode psk
[AC-wlan-st-st2] preshared-key pass-phrase simple 12345678
[AC-wlan-st-st2] cipher-suite ccmp
[AC-wlan-st-st2] security-ie rsn
[AC-wlan-st-st2] vlan 200
[AC-wlan-st-st2] quit
3.     Configure the AP:
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create an AP named ap1. Specify the AP model and serial ID.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
# Create AP group group1 and add AP ap1 to AP group group1.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
# Bind service templates st1 and st2 to radio 2 in AP group group1.
[AC-wlan-ap-group-group1] ap-model WA6320
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template st1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template st2
# Enable radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] return
4.     Configure the authentication domain:
# Create an ISP domain named dm1 and enter its view.
<AC> system-view
[AC] domain dm1
# Configure the authentication method as local, and authorization and accounting methods as none for portal users.
[AC-isp-dm1] authentication portal local
[AC-isp-dm1] authorization portal none
[AC-isp-dm1] accounting portal none
# Configure the idle cut feature for users. Log out a user if the user's traffic is less than 1024 bytes in 15 minutes.
[AC-isp-dm1] authorization-attribute idle-cut 15 1024
[AC-isp-dm1] quit
5.     Configure portal authentication:
# Create a portal Web server named newpt and specify the server's URL as http://2.2.2.1/portal.
[AC] portal web-server newpt
[AC-portal-websvr-newpt] url http://2.2.2.1/portal
# Configure the portal redirection URL to carry the wlanuserip parameter and the parameter value is the user's IP address.
[AC-portal-websvr-newpt] url-parameter wlanuserip source-address
[AC-portal-websvr-newpt] quit
# Create an HTTP-based local portal Web service and enter its view.
[AC] portal local-web-server http
# Configure SSID service to use authentication page file abc.zip and SSID service2 to use authentication page file http.zip. (The files must already exist in the root directory of the storage medium of the AC.)
[AC–portal-local-websvr-http] default-logon-page abc.zip
[AC–portal-local-websvr-http] logon-page bind ssid service2 file http.zip
[AC–portal-local-websvr-http] quit
# Configure a local user for local portal authentication.
[AC] local-user 123 class network
[AC-luser-network-123] password simple 123
[AC-luser-network-123] service-type portal
[AC-luser-network-123] quit
# Enable the portal roaming feature.
[AC] portal roaming enable
# Disable the Rule ARP entry feature for portal clients.
[AC] undo portal refresh arp enable
# Enable the wireless client validity check feature.
[AC] portal host-check enable
6.     Configure service template st1:
# Enable direct portal authentication on service template st1.
[AC–wlan-st-st1] portal enable method direct
# Configure the authentication domain for portal users as dm1.
[AC-wlan-st-st1] portal domain dm1
# Specify portal Web server newpt on service template st1.
[AC–wlan-st-st1] portal apply web-server newpt
[AC–wlan-st-st1] quit
# Enable service template st1.
[AC–wlan-st-st1] service-template enable
7.     Configure service template st2:
# Enable direct portal authentication on service template st2.
[AC–wlan-st-st2] portal enable method direct
[AC-wlan-st-st2] portal domain dm1
# Specify portal Web server newpt on service template st2.
[AC–wlan-st-st2] portal apply web-server newpt
[AC–wlan-st-st2] quit
# Enable service template st2.
[AC–wlan-st-st2] service-template enable
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward traffic on the CAPWAP tunnel between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward traffic of wireless clients.
[Switch] vlan 200
[Switch-vlan200] quit
# Create VLAN 2.
[Switch] vlan 2
[Switch-vlan2] quit
# Configure GigabitEthernet 1/0/1 (the port connected to the AC) as a trunk port. Assign the trunk port to VLAN 100 and VLAN 200.
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 (the port connected to the AP) as an access port. Assign the access port to VLAN 100.
# Enable PoE on the access port.
# Configure GigabitEthernet 1/0/3 (the port connected to the DHCP server) as an access port. Assign the access port to VLAN 2.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type access
[Switch-GigabitEthernet1/0/3] port access vlan 2
[Switch-GigabitEthernet1/0/3] quit
# Assign an IP address to VLAN interface 200.
[Switch] interface vlan-interface 200
[Switch-Vlan-interface200] ip address 2.2.2.100 255.255.255.0
[Switch-Vlan-interface200] quit
# Assign an IP address to VLAN interface 2.
[Switch-Vlan-interface2] ip address 192.168.0.100 255.255.255.0
[Switch-Vlan-interface2] quit
# Use the configured username and password to perform portal authentication through a Web browser on the client. Before passing authentication, all Web accesses are redirected to the portal authentication page (http://2.2.2.1/portal). After passing authentication, you can access other network resources.
# Display the online portal user information on the AC.
[AC] display portal user all
Total portal users: 1
Username: 123
  AP name: ap1
  Radio ID: 2
  SSID: service
  Portal server: newpt
  State: Online
  VPN instance: N/A
  MAC             IP                    VLAN    Interface
  0021-6330-0933  2.2.2.2               200     WLAN-BSS1/0/1
  Authorization information:
    DHCP IP pool: N/A
    User profile: N/A
    Session group profile: N/A
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Configuration files
·     AC:
vlan 100
vlan 200
 ssid service
 akm mode psk
 cipher-suite ccmp
 security-ie rsn
 vlan 200
portal domain dm1
 ssid service2
 akm mode psk
 cipher-suite ccmp
 security-ie rsn
 vlan 200
portal domain dm1
interface Vlan-interface100
 ip address 2.2.1.1 255.255.255.0
interface Vlan-interface200
 ip address 2.2.2.1 255.255.255.0
 port link-mode bridge
 port trunk permit vlan 1 100 200
domain dm1
 password cipher $c$3$evSrJBp31wOqEZw7KdwPugEfvJ5M/w==
 service-type portal
ap ap1
ap-model WA6320
 radio 1
 radio 2
  radio enable
·     Switch:
vlan 2
vlan 100
vlan 200
poe enable
 port access vlan 2
Related documentation
·     AP and WT Management Command Reference in H3C Access Controllers Command References
·     AP and WT Management Configuration Guide in H3C Access Controllers Configuration Guides
·     User Access and Authentication Command Reference in H3C Access Controllers Command References
·     User Access and Authentication Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Access Command Reference in H3C Access Controllers Command References
·     WLAN Access Configuration Guide in H3C Access Controllers Configuration Guides
