07-IP Multicast
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10007-IP Multicast
11-HH3C-MPM-MIB
11-HH3C-MPM-MIB 57.54 KB
HH3C-MPM-MIB
About this MIB
The h3cHostStaticJoinTable table was added to this MIB to configure a host as a static member of a multicast group.
MIB file name
hh3c-mpm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMpm(51)
Scalar objects
hh3cMPortGroupLimitMinNumber
Object (OID)
Access
Value range
Implementation
hh3cMPortGroupLimitMinNumber (1.3.6.1.4.1.25506.2.51.1.1)
read-only
Unsigned32
Standard MIB values.
Minimum number of groups that a port can join.
The value of this object is always 0.
hh3cMPortGroupLimitMaxNumber
Object (OID)
Access
Value range
Implementation
hh3cMPortGroupLimitMaxNumber (1.3.6.1.4.1.25506.2.51.1.2)
read-only
Unsigned32
Maximum number of groups that a port can join.
The value of this object is always 4294967295.
Tabular objects
hh3cMPortGroupJoinTable
About this table
Use this table to configure a port in a VLAN to join a multicast group.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ifIndex, hh3cMPortGroupJoinVlanID, hh3cMPortGroupJoinAddressType, and hh3cMPortGroupJoinAddress.
Object (OID)
Access
Value range
Implementation
hh3cMPortGroupJoinVlanID (1.3.6.1.4.1.25506.2.51.2.1.1.1)
not-accessible
Integer32
An index uniquely identifying a port in a VLAN which joined the multicast group.
As per the MIB.
hh3cMPortGroupJoinAddressType (1.3.6.1.4.1.25506.2.51.2.1.1.2)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Type of the multicast group address.
As per the MIB.
hh3cMPortGroupJoinAddress (1.3.6.1.4.1.25506.2.51.2.1.1.3)
not-accessible
InetAddress
OCTET STRING (0..255)
Address of the multicast group. It must be a valid multicast IP address.
As per the MIB.
hh3cMPortGroupJoinStatus (1.3.6.1.4.1.25506.2.51.2.1.1.4)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
hh3cMPortGroupTable
About this table
This table contains information about the status of a port which joined a multicast group in a VLAN.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ifIndex, hh3cMPortGroupVlanID, hh3cMPortGroupAddressType, and hh3cMPortGroupAddress.
Object (OID)
Access
Value range
Implementation
hh3cMPortGroupVlanID (1.3.6.1.4.1.25506.2.51.2.2.1.1)
not-accessible
Integer32
An index uniquely identifies that a port belongs to a specified VLAN.
As per the MIB.
hh3cMPortGroupAddressType (1.3.6.1.4.1.25506.2.51.2.2.1.2)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
As per the MIB.
(1.3.6.1.4.1.25506.2.51.2.2.1.3)
read-only
InetAddress
As per the MIB.
hh3cMPortConfigEntry
About this table
This table contians information about the fast-leaving status, group limit number, and group policy parameters of a port in a VLAN.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ifIndex and hh3cMPortConfigVlanID.
Object (OID)
Access
Value range
Implementation
hh3cMPortConfigVlanID (1.3.6.1.4.1.25506.2.51.2.3.1.1)
not-accessible
Integer32
As per the MIB.
hh3cMPortGroupLimitNumber (1.3.6.1.4.1.25506.2.51.2.3.1.2)
read-create
Unsigned32
As per the MIB.
hh3cMPortFastLeaveStatus (1.3.6.1.4.1.25506.2.51.2.3.1.3)
read-create
EnabledStatus
INTEGER{
enabled(1),
disabled(2)
Fast-leaving status of the port.
As per the MIB.
hh3cMPortGroupPolicyParameter (1.3.6.1.4.1.25506.2.51.2.3.1.4)
read-create
Integer32
Integer32(0|2000..2999)
ACL number which is used as the group policy of the port.
As per the MIB.
hh3cMPortConfigRowStatus (1.3.6.1.4.1.25506.2.51.2.3.1.5)
read-create
RowStatus
active(1),
notReady(3),
createAndGo(4),
destroy(6)
Row status.
Supports only the following values: destroy(6), notReady(3),, createAndGo(4), and destroy(6).
hh3cMPortGroupLimitReplace (1.3.6.1.4.1.25506.2.51.2.3.1.6)
read-create
EnabledStatus
INTEGER{
enabled(1),
disabled(2)
This object is related to the object hh3cMPortGroupLimitNumber.  If the current IGMP group number is less than the value of hh3cMPortGroupLimitNumber, any new IGMP group is permitted.
As per the MIB.
hh3cHostStaticJoinTable
About this table
Use this table to configure a host on a port in a VLAN statically to join a multicast group.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are ifIndex, h3cHostStaticJoinVlanID, h3cHostStaticJoinAddressType, and h3cHostStaticJoinAddress.
Object (OID)
Access
Value range
Implementation
hh3cHostStaticJoinVlanID (1.3.6.1.4.1.25506.2.51.2.4.1.1)
not-accessible
Integer32
An index uniquely identifies the VLAN in which a host on a port statically joined a multicast group.
As per the MIB.
hh3cHostStaticJoinAddressType (1.3.6.1.4.1.25506.2.51.2.4.1.2)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
As per the MIB.
hh3cHostStaticJoinAddress (1.3.6.1.4.1.25506.2.51.2.4.1.3)
not-accessible
InetAddress
As per the MIB.
hh3cHostStaticJoinStatus (1.3.6.1.4.1.25506.2.51.2.4.1.4)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
Supports only the following values: createAndGo(4), active(1), and destroy(6).
  • Become a Partner
  • Partner Resources
