07-IP Multicast
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10007-IP Multicast
10-HH3C-LswIGSP-MIB
10-HH3C-LswIGSP-MIB 65.81 KB
HH3C-LswIGSP-MIB
About this MIB
IGMP snooping runs on a Layer 2 device as a multicast constraining mechanism to improve multicast forwarding efficiency. When IGMP snooping is not enabled, the Layer 2 switch floods multicast packets to all hosts in a VLAN or VSI. When IGMP snooping is enabled, the Layer 2 switch forwards multicast packets of known multicast groups to only the receivers. In addition to this basic function, Comware implements the following IGMP management and control functions:
·     Limit the number of multicast groups that hosts attached to a switch port can join.
·     Control the enabling status of fast-leaving on a switch port.
·     Control the multicast groups that hosts can join by using an ACL that specifies the multicast groups and the optional sources.
IGMP snooping MIBs are private MIBs used to manage IGMP snooping. This module defines MIB variables corresponding to the parameters and status for the above IGMP management and control functions and combines them to private IGMP snooping MIBs. This module also supports Get and Getnext operations for MIB variables newly added to the IGMP snooping module deployed by the agent.
MIB file name
hh3c-splat-igsp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswIgmpsnoopingMib(7)
Scalar objects
hh3cIgmpSnoopingStatus
Object (OID)
Access
Value range
Implementation
hh3cIgmpSnoopingStatus (1.3.6.1.4.1.25506.8.35.7.1.1)
read-write
EnabledStatus
INTEGER {
enabled(1),
disabled(2)
Enable or disable IGMP snooping.
Default: Disabled.
hh3cIgmpSnoopingRouterPortAge
Object (OID)
Access
Value range
Implementation
hh3cIgmpSnoopingRouterPortAge (1.3.6.1.4.1.25506.8.35.7.1.2)
read-write
INTEGER
INTEGER(1..1000)
Set the aging time of router ports.
Default: 260.
The return value is 260 when the actual value is greater than 1000.
hh3cIgmpSnoopingResponseTime
Object (OID)
Access
Value range
Implementation
hh3cIgmpSnoopingResponseTime (1.3.6.1.4.1.25506.8.35.7.1.3)
read-write
INTEGER
INTEGER(1..25)
Set the maximum query response time.
As per the MIB.
The return value is 25 when the actual value is greater than 25.
hh3cIgmpSnoopingHostTime
Object (OID)
Access
Value range
Implementation
hh3cIgmpSnoopingHostTime (1.3.6.1.4.1.25506.8.35.7.1.4)
read-write
INTEGER
INTEGER(200..1000)
Set the aging time of the multicast group port.
As per the MIB.
The return value is 1000 when the actual value is greater than 1000.
The return value is 200 when the actual value is greater than 200.
hh3cRecvIGMPGQueryNum
Object (OID)
Access
Value range
Implementation
hh3cRecvIGMPGQueryNum (1.3.6.1.4.1.25506.8.35.7.1.10.1)
read-only
Counter32
INTEGER(0..4294967295)
Statistics of IGMP general query packets received on the device.
Globally disabling or enabling IGMP snooping will initialize IGMP snooping data packet statistics collection.
hh3cRecvIGMPSQueryNum
Object (OID)
Access
Value range
Implementation
hh3cRecvIGMPSQueryNum (1.3.6.1.4.1.25506.8.35.7.1.10.2)
read-only
Counter32
Statistics of IGMP specific query packets received on the device.
hh3cRecvIGMPV1ReportNum
Object (OID)
Access
Value range
Implementation
hh3cRecvIGMPV1ReportNum (1.3.6.1.4.1.25506.8.35.7.1.10.3)
read-only
Counter32
Statistics of IGMPv1 report packets received on the device.
hh3cRecvIGMPV2ReportNum
Object (OID)
Access
Value range
Implementation
hh3cRecvIGMPV2ReportNum (1.3.6.1.4.1.25506.8.35.7.1.10.4)
read-only
Counter32
Statistics of IGMPv2 report packets received on the device.
hh3cRecvIGMPLeaveNum
Object (OID)
Access
Value range
Implementation
hh3cRecvIGMPLeaveNum (1.3.6.1.4.1.25506.8.35.7.1.10.5)
read-only
Counter32
Statistics of IGMP leave packets received on the device.
hh3cRecvErrorIGMPPacketNum
Object (OID)
Access
Value range
Implementation
hh3cRecvErrorIGMPPacketNum (1.3.6.1.4.1.25506.8.35.7.1.10.6)
read-only
Counter32
Statistics of error IGMP packets received on the device.
hh3cSentIGMPSQueryNum
Object (OID)
Access
Value range
Implementation
hh3cSentIGMPSQueryNum (1.3.6.1.4.1.25506.8.35.7.1.10.7)
read-only
Counter32
Statistics of IGMP specific query packets sent from the device.
hh3cIgmpSnoopingClearStats
Object (OID)
Access
Value range
Implementation
hh3cIgmpSnoopingClearStats (1.3.6.1.4.1.25506.8.35.7.1.10.8)
read-write
INTEGER
INTEGER {
clear(1),               counting(2)
Clear the statistics of IGMP packets.
As per the MIB.
Tabular objects
hh3cIgmpSnoopingVlanStatusTable
About this table
Use this table to enable or disable IGMP snooping in a VLAN.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cIgmpSnoopingVlanID.
Object (OID)
Access
Value range
Implementation
hh3cIgmpSnoopingVlanID (1.3.6.1.4.1.25506.8.35.7.1.9.1.1)
not-accessible
Integer32
Integer32(1..4094)
An index uniquely identifies on which VLAN IGMP snooping is enabled or disabled.
As per the MIB.
hh3cIgmpSnoopingVlanEnabled (1.3.6.1.4.1.25506.8.35.7.1.9.1.2)
read-write
EnabledStatus
INTEGER {
enabled(1),
disabled(2)
Whether IGMP snooping is enabled in the VLAN.
As per the MIB.
  • Become a Partner
  • Partner Resources
