06-MSDP-MIB | 69.97 KB |
MSDP-MIB
About this MIB
Use the MIB to query state query and record transmitted messages for communication by using MSDP among multicast domains on network devices.
Only notifications are supported.
MIB file name
rcf4624-msdp.mib
Root object
iso(1).org(3).dod(6).internet(1).experimental(3).msdpMIB(92)
Scalar objects
msdpEnabled
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
msdpEnable (1.3.6.1.3.92.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of MSDP. |
Not supported. |
msdpCacheLifetime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
msdpCacheLifetime (1.3.6.1.3.92.1.1.2) |
read-only |
TimeTicks |
Standard MIB values. |
Lifetime of the (S, G) entries contained in SA messages. If the value is 0, (S, G) entries are not cached. |
Not supported. |
msdpNumSACacheEntries
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
msdpNumSACacheEntries (1.3.6.1.3.92.1.1.3) |
read-only |
Gauge32 |
Total number of (S, G) entries in the SA cache. |
Not supported. |
msdpRPAddress
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
msdpRPAddress (1.3.6.1.3.92.1.1.11) |
read-write |
IpAddress |
IP address of the RP that has created an SA message. On a non-RP device, the IP address might be 0.0.0.0. |
Not supported. |
Tabular objects
msdpPeerTable
About this table
This table contains the peer states and packets received and sent when an MSDP peer relationship is established.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
MSDP must be enabled, and an MSDP peer must be configured. |
Columns
The table index is msdpPeerRemoteAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
msdpPeerRemoteAddress (1.3.6.1.3.92.1.1.5.1.1) |
not-accessible |
IpAddress |
IP address of the remote MSDP peer. |
Not supported. |
msdpPeerState (1.3.6.1.3.92.1.1.5.1.3) |
read-only |
INTEGER |
inactive(1), listen(2), connecting(3), established(4), disabled(5) |
State of the MSDP TCP connection with the peer. |
Not supported.. |
msdpPeerRPFFailures (1.3.6.1.3.92.1.1.5.1.4) |
read-only |
Counter32 |
Number of SA messages from the peer that failed RPF checks. |
Not supported. |
msdpPeerInSAs (1.3.6.1.3.92.1.1.5.1.5) |
read-only |
Counter32 |
Number of SA messages received on the link. |
Not supported. |
msdpPeerOutSAs (1.3.6.1.3.92.1.1.5.1.6 |
read-only |
Counter32 |
Number of SA messages sent on the link. |
Not supported. |
msdpPeerInSARequests (1.3.6.1.3.92.1.1.5.1.7) |
read-only |
Counter32 |
Number of SA request messages received on the link. |
Not supported.. |
msdpPeerOutSARequests (1.3.6.1.3.92.1.1.5.1.8) |
read-only |
Counter32 |
Number of SA request messages sent on the link. |
Not supported. |
msdpPeerInSAResponses (1.3.6.1.3.92.1.1.5.1.9) |
read-only |
Counter32 |
Number of SA response messages received on the link. |
Not supported. |
msdpPeerOutSAResponses (1.3.6.1.3.92.1.1.5.1.10) |
read-only |
Counter32 |
Number of SA response messages sent on the link. |
Not supported. |
msdpPeerInControlMessages (1.3.6.1.3.92.1.1.5.1.11) |
read-only |
Counter32 |
Total number of MSDP messages received on the link, excluding encapsulated packets. |
Not supported.. |
msdpPeerOutControlMessages (1.3.6.1.3.92.1.1.5.1.12) |
read-only |
Counter32 |
Total number of MSDP messages sent on the link, excluding encapsulated packets. |
Not supported. |
msdpPeerInDataPackets (1.3.6.1.3.92.1.1.5.1.13) |
read-only |
Counter32 |
Total number of encapsulated packets received from the peer. |
Not supported. |
msdpPeerOutDataPackets (1.3.6.1.3.92.1.1.5.1.14) |
read-only |
Counter32 |
Total number of encapsulated packets sent to the peer. |
Not supported. |
msdpPeerFsmEstablishedTransitions (1.3.6.1.3.92.1.1.5.1.15) |
read-only |
Counter32 |
Total number of times that the MSDP FSM enters the ESTABLISHED state. |
Not supported.. |
msdpPeerFsmEstablishedTime (1.3.6.1.3.92.1.1.5.1.16) |
read-only |
TimeStamp |
Timestamp set when the peer enters or exits the ESTABLISHED state. This value is set to 0 upon startup. |
Not supported. |
msdpPeerInMessageTime (1.3.6.1.3.92.1.1.5.1.17) |
read-only |
TimeStamp |
Timestamp set when the last MSDP message is received from the peer. This value is set to 0 upon startup. |
Not supported. |
msdpPeerLocalAddress (1.3.6.1.3.92.1.1.5.1.18) |
read-create |
IpAddress |
Local IP address used by the MSDP TCP connection. |
Not supported. |
msdpPeerConnectRetryInterval (1.3.6.1.3.92.1.1.5.1.20) |
read-create |
Integer32 |
INTEGER (1..65535) |
Connection retry interval, in the range of 1 to 65535 seconds. The default is 30. |
Not supported.. |
msdpPeerHoldTimeConfigured (1.3.6.1.3.92.1.1.5.1.21) |
read-create |
Integer32 |
INTEGER (0|3..65535) |
Connection hold time in the range of 0 to 65535 or 3 to 65535 seconds. The default is 75. If the hold time is set to 0, the MSDP connection will not be disconnected because it fails to receive messages from the peer. |
Not supported. |
msdpPeerKeepAliveConfigured (1.3.6.1.3.92.1.1.5.1.22) |
read-create |
Integer32 |
Integer32 (0|1..21845) |
Keepalive interval in the range of 0 to 21845 or 1 to 21845 seconds. The default is 60. If the keepalive interval is set to 0, the MSDP connection will not send keepalive messages after it is established. |
Not supported. |
msdpPeerDataTtl (1.3.6.1.3.92.1.1.5.1.23) |
read-create |
Integer32 |
Integer32 (0..255) |
TTL of SA messages, in the range of 0 to 255. The default is 1. |
Not supported. |
msdpPeerProcessRequestsFrom (1.3.6.1.3.92.1.1.5.1.24) |
read-create |
TruthValue |
true(1), false(2) |
Indicates whether to process SA messages from the peer. True(1) indicates processing SA messages from the peer. False(2) indicates ignoring SA messages from the peer. If msdpCacheLifetime is 0, this object is False. If msdpCacheLifetime is not 0, this object is True. |
Not supported.. |
msdpPeerStatus (1.3.6.1.3.92.1.1.5.1.25) |
read-create |
RowStatus |
active(1) destroy(6) |
Add or delete a peer. |
Not supported. |
msdpPeerRemotePort (1.3.6.1.3.92.1.1.5.1.26) |
read-only |
Integer32 |
Integer32 (0..65535) |
Remote port used for establishing TCP connections between peers, in the range of 0 to 65535. The default is 639. |
Not supported. |
msdpPeerLocalPort (1.3.6.1.3.92.1.1.5.1.27) |
read-only |
Integer32 |
Local port used for establishing TCP connections between peers, in the range of 0 to 65535. The default is 639. |
Not supported. |
msdpPeerEncapsulationType (1.3.6.1.3.92.1.1.5.1.29) |
read-create |
INTEGER |
none(0), tcp(1) |
Indicates whether the peer uses SA messages to encapsulate data. Valid values are: 0 (none): The peer does not use SA messages to encapsulate data. 1 (tcp): The peer uses SA messages to encapsulate data. |
Not supported.. |
msdpPeerConnectionAttempts (1.3.6.1.3.92.1.1.5.1.30) |
read-only |
Counter32 |
Number of times the state machine transitions from INACTIVE to CONNECTING. |
Not supported. |
msdpPeerInNotifications (1.3.6.1.3.92.1.1.5.1.31) |
read-only |
Counter32 |
Number of MSDP Notification messages received from the peer. |
Not supported. |
msdpPeerOutNotifications (1.3.6.1.3.92.1.1.5.1.32) |
read-only |
Counter32 |
Number of MSDP Notification messages sent to the peer. |
Not supported. |
msdpPeerLastError (1.3.6.1.3.92.1.1.5.1.33) |
read-only |
OCTET STRING (SIZE (2)) |
OCTET STRING (2) |
The last error code and subcode in a Notification message received from the peer. The first byte contains the O bit and the error code, and the second byte contains the subcode. The default is 0000. |
Not supported.. |
msdpPeerDiscontinuityTime (1.3.6.1.3.92.1.1.5.1.34) |
read-only |
TimeStamp |
Timestamp when one or more counters for the last entry are interrupted. Counters might be interrupted when a peer relationship is established. |
Not supported. |
msdpSACacheTable
About this table
This table contains SA information in the SA cache.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Columns
The table indexes are msdpSACacheGroupAddr, msdpSACacheSourceAddr, and msdpSACacheOriginRP.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
msdpSACacheGroupAddr (1.3.6.1.3.92.1.1.6.1.1) |
not-accessible |
IpAddress |
Group address of the SA cache entry. |
Not supported. |
msdpSACacheSourceAddr (1.3.6.1.3.92.1.1.6.1.2) |
not-accessible |
IpAddress |
Source address of the SA cache entry. |
Not supported.. |
msdpSACacheOriginRP (1.3.6.1.3.92.1.1.6.1.3) |
not-accessible |
IpAddress |
RP of the SA cache entry. This field is contained in indexes and is used to store RPs that advertise multiple source-group pairs. |
Not supported. |
msdpSACachePeerLearnedFrom (1.3.6.1.3.92.1.1.6.1.4) |
Read-only |
IpAddress |
IP address of the peer from which the last SA cache entry is received. The IP address must be a value of the msdpPeerRemoteAddress in the MSDP peer table. This value is 0.0.0.0 on the device that sends the SA cache entry. |
Not supported. |
msdpSACacheRPFPeer (1.3.6.1.3.92.1.1.6.1.5) |
Read-only |
IpAddress |
IP address of the peer from which the SA cache entry corresponding to the SA message. The peer is the RPF peer in msdpSACacheOriginRP. |
Not supported. |
msdpSACacheInSAs (1.3.6.1.3.92.1.1.6.1.6) |
read-only |
Counter32 |
Number of received SA messages relevant to the cached entry. When a cached entry is created, this object must be initialized to 0. |
Not supported.. |
msdpSACacheInDataPackets (1.3.6.1.3.92.1.1.6.1.7) |
read-only |
Counter32 |
Number of received MSDP-encapsulated messages relevant to the cached entry. When a cached entry is created, this object must be initialized to 0. |
Not supported. |
msdpSACacheUpTime (1.3.6.1.3.92.1.1.6.1.8) |
read-only |
TimeTicks |
Time the entry is cached. |
Not supported. |
msdpSACacheExpiryTime (1.3.6.1.3.92.1.1.6.1.9) |
read-only |
TimeTicks |
Remaining time before the entry ages out. |
Not supported. |
msdpSACacheStatus (1.3.6.1.3.92.1.1.6.1.10) |
read-write |
RowStatus |
Row status. Rows cannot be created. |
Not supported. |
msdpMeshGroupTable
About this table
This table contains all configured mesh groups
Create |
Edit/Modify |
Delete |
Read |
When an entry is created, the msdpPeerTable must have the corresponding row. This table supports only CreatAndGo. To create a row , you must specify all of the following: msdpMeshGroupName, msdpMeshGroupPeerAddress, and msdpMeshGroupStatus. |
Supported |
Supported |
MSDP must be enabled, and an MSDP peer with mesh groups must be configured. |
Columns
The table indexes are msdpMeshGroupName and msdpMeshGroupPeerAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
msdpMeshGroupName (1.3.6.1.3.92.1.1.12.1.1) |
not-accessible |
DisplayString |
OCTET STRING (1..64) |
Name of the mesh group, a string of 1 to 64 characters. |
Not supported. |
msdpMeshGroupPeerAddress (1.3.6.1.3.92.1.1.12.1.2) |
not-accessible |
IpAddress |
IP address of the peer, which is a member of msdpMeshGroupName. |
Not supported.. |
msdpMeshGroupStatus (1.3.6.1.3.92.1.1.12.1.3) |
read-create |
RowStatus |
Not supported. |
Notifications
