07-IP Multicast
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10007-IP Multicast
09-HH3C-IPMCAST-MIB
09-HH3C-IPMCAST-MIB 48.83 KB
IPMCAST-MIB
About this MIB
The multicast technique effectively addresses the issue of point-to-multipoint data transmission. By enabling high-efficiency point-to-multipoint data transmission over a network, multicast greatly saves network bandwidth and reduces network load.
By using multicast technology, a network operator can easily provide bandwidth-critical and time-critical information services. These services include live webcasting, Web TV, distance learning, telemedicine, Web radio, and real-time video conferencing.
Use the MIB to manage IP multicast settings, including multicast routes.
MIB file name
hh3c-ipmcast.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cIpMcast(212)
Notifications
hh3cIpMcastEntryExceed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.212.0.1
The number of multicast routing entries exceeded the limit.
Fault
Major
1.3.6.1.4.1.25506.212.0.2 (hh3cIpMcastEntryExceedClear)
ON
This notification is generated when the number of multicast routing entries exceeds the limit.
Status control
ON
CLI: Use the snmp-agent trap enable [ ipv6 ] multicast entry-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable [ ipv6 ] multicast entry-exceed command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.212.2.1 (hh3cIpMcastEntryLimitType)
Multicast routing entry type.
No
INTEGER
star-group(1),
source-group(2)
1.3.6.1.4.1.25506.212.2.2 (hh3cIpMcastAddressFamily)
Multicast address type
No
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
1.3.6.1.4.1.25506.212.2.3 (hh3cIpMcastEntryLimitCount)
Limit value
No
Unsigned32
Unsigned32(0..4294967295)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
To resolve the issue:
1.     Reduce the number of multicast routing entries.
2.     If the issue persists, contact H3C Support.
Basic information
OID
Event
Severity
Default status
The number of multicast routing entries fell below the limit.
Fault
Major
N/A
ON
This notification is generated when the number of multicast routing entries falls below the limit.
Status control
ON
CLI: Use the snmp-agent trap enable [ ipv6 ] multicast entry-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable [ ipv6 ] multicast entry-exceed-clear command.
Objects
OID (object name)
Index
Value range
No
INTEGER
star-group(1),
source-group(2)
Multicast address type.
No
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
Limit value.
No
Unsigned32
1.3.6.1.4.1.25506.212.2.4 (hh3cIpMcastEntryLimitReasonType)
Reason why the number of multicast routing entries fell below the limit.
No
INTEGER
entryDeleted(1),
configurationChanged(2),
Recommended action
No action is required.
  • Become a Partner
  • Partner Resources
