07-IP Multicast
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10007-IP Multicast
01-HH3C-PIM-STD-MIB
01-HH3C-PIM-STD-MIB 70.18 KB
HH3C-PIM-STD-MIB
About this MIB
Use this MIB to manage PIM routers.
MIB file name
hh3c-pim-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPimStd(213)
Notifications
hh3cPimNeighborAdd
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.213.0.1
PIM neighbor created.
Fault
Major
N/A
ON
This notification is generated when a PIM neighbor is created.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } neighbor-add command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } neighbor-add command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.213.1.3 (hh3cPimNeighborExpiryTime)
Neighbor timeout time.
No
TimeTicks
INTEGER (0..4294967295)
1.3.6.1.4.1.25506.213.1.1 (hh3cPimInstanceID)
PIM instance ID.
No
Unsigned32
Unsigned32(0..4294967295)
1.3.6.1.4.1.25506.213.1.2 (hh3cPimInstanceName)
PIM instance name.
No
DisplayString
OCTET STRING (0..255)
1.3.6.1.4.1.25506.213.1.15 (hh3cpimNbrAddressType)
PIM neighbor address type.
No
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
1.3.6.1.4.1.25506.213.1.14 (hh3cpimNbrAddressIfIndex)
PIM neighbor interface.
No
InterfaceIndex
Integer32(1..2147483647)
1.3.6.1.4.1.25506.213.1.16 (hh3cpimNbrAddress)
PIM neighbor address.
No
InetAddress
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cPimRouteThresholdExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.213.0.2
The number of multicast routing entries exceeded the alarm threshold.
Fault
Major
1.3.6.1.4.1.25506.213.2.2 (hh3cPimRouteThresholdExceedClear)
ON
This notification is generated when the number of multicast routing entries exceeds the alarm threshold.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } route-threshold-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } route-threshold-exceed command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.213.1.4 (hh3cPimNotificationLimitType)
Multicast routing entry type.
No
INTEGER
sm-star-group(1),
sm-source-group(2)
1.3.6.1.4.1.25506.213.1.5 (hh3cPimNotificationAddressFamily)
Multicast address type.
No
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
1.3.6.1.4.1.25506.213.1.6 (hh3cPimNotificationEntryCount)
Current number of multicast routing entries.
No
Unsigned32
1.3.6.1.4.1.25506.213.1.8 (hh3cPimNotificationThresholdCnt)
Alarm threshold.
No
Unsigned32
1.3.6.1.4.1.25506.213.1.9 (hh3cPimThresholdReasonType)
Reason why the number of multicast routing entries exceeded the alarm threshold.
No
INTEGER
entryCreated(1),
configurationChanged(2)
Recommended action
To resolve the issue:
1.     Increase the alarm threshold for multicast routing entries.
2.     Reduce the number of multicast routing entries.
3.     If the issue persists, contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.213.2.3
The number of multicast routing entries fell below the alarm threshold.
Fault
Major
N/A
ON
This notification is generated when the number of multicast routing entries falls below the alarm threshold.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } route-threshold-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } route-threshold-exceed-clear command.
Objects
OID (object name)
Index
Value range
No
INTEGER
sm-star-group(1),
sm-source-group(2)
No
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
No
Unsigned32
Alarm threshold
No
Unsigned32
1.3.6.1.4.1.25506.213.1.11 ( hh3cPimNotificationThreshReType )
Reason why the number of multicast routing entries fell below the alarm threshold.
No
INTEGER
entryDeleted(1),
configurationChanged(2),
Recommended action
hh3cPimRouteExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.213.0.4
The number of multicast routing entries exceeded the limit.
Fault
Major
1.3.6.1.4.1.25506.213.0.5 (hh3cPimRouteExceedClear)
ON
This notification is generated when the number of multicast routing entries exceeds the limit.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } route-exceed command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } route-exceed command.
Objects
OID (object name)
Index
Value range
No
INTEGER
sm-star-group(1),
sm-source-group(2)
No
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
No
Unsigned32
1.3.6.1.4.1.25506.213.1.7 (hh3cPimNotificationLimitCount)
Limit value.
No
Unsigned32
1.3.6.1.4.1.25506.213.1.12 (hh3cPimNotificationSourceAddress)
Source address of the multicast routing entry.
No
InetAddress
1.3.6.1.4.1.25506.213.1.13 (hh3cPimNotificationGroupAddress)
Group address of the multicast routing entry.
No
InetAddress
PIM instance name.
No
DisplayString
Recommended action
1.     Increase the limit for multicast routing entries.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.213.2.5
The number of multicast routing entries fell below the limit.
Fault
Major
N/A
ON
This notification is generated when the number of multicast routing entries falls below the limit.
Status control
ON
CLI: Use the snmp-agent trap enable { pim | pim6 } route-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable { pim | pim6 } route-exceed-clear command.
Objects
OID (object name)
Index
Value range
No
INTEGER
sm-star-group(1),
sm-source-group(2)
No
InetAddressType
unknown(0),
ipv4(1),
ipv6(2),
No
Unsigned32
Limit value.
No
Unsigned32
No
InetAddress
No
InetAddress
1.3.6.1.4.1.25506.213.1.10 (hh3cPimRouteEClearReasonType)
Reason why the number of multicast routing entries fell below the limit.
No
INTEGER
entryDeleted(1),
PIM instance name.
DisplayString
Recommended action
  • Become a Partner
  • Partner Resources
