05-Layer 3 - IP Services
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10005-Layer 3 - IP Services
11-HH3C-DHCP4-MIB
11-HH3C-DHCP4-MIB 310.22 KB
HH3C-DHCP4-MIB· 1
About this MIB· 1
MIB file name· 1
Root object 1
Scalar objects· 1
hh3cDhcpServer2Enabled· 1
hh3cDhcpServer2AlwaysBroadcast 2
hh3cDhcpServer2IgnoreBootp· 2
hh3cDhcpServer2BootpReplyRfc1048· 2
hh3cDhcpServer2Opt82Enabled· 2
hh3cDhcpServer2PingNumber 2
hh3cDhcpServer2PingTimeout 3
hh3cDhcpServer2AllocThreshold· 3
hh3cDhcpServer2BadNum·· 3
hh3cDhcpServer2BootpRequestNum·· 3
hh3cDhcpServer2DiscoverNum·· 3
hh3cDhcpServer2RequestNum·· 4
hh3cDhcpServer2DeclineNum·· 4
hh3cDhcpServer2ReleaseNum·· 4
hh3cDhcpServer2InformNum·· 4
hh3cDhcpServer2BootpReplyNum·· 4
hh3cDhcpServer2OfferNum·· 5
hh3cDhcpServer2AckNum·· 5
hh3cDhcpServer2NakNum·· 5
hh3cDhcpServer2TotalPoolUsage· 5
hh3cDhcpServer2PoolNumber 5
hh3cDhcpServer2AutoBindNum·· 6
hh3cDhcpServer2ManualBindNum·· 6
hh3cDhcpServer2ExpiredBindNum·· 6
hh3cDhcpServer2ReqCnt 6
hh3cDhcpServer2ReqSuccCnt 6
hh3cDhcpServer2IPTotalNum·· 7
hh3cDhcpServer2IPUsedNum·· 7
hh3cDhcpServer2IPIdleNum·· 7
Tabular objects· 7
hh3cDhcpServer2PoolTable· 7
hh3cDhcpServer2IfApplyPoolTable· 10
hh3cDhcpServer2PoolSecNwTable· 11
hh3cDhcpServer2PoolClassTable· 11
hh3cDhcpServer2PoolStaticTable· 12
hh3cDhcpServer2PoolOptionTable· 13
hh3cDhcpServer2PoolForbidTable· 13
hh3cDhcpServer2ClassTable· 14
hh3cDhcpServer2RuleTable· 14
hh3cDhcpServer2ForbidTable· 15
hh3cDhcpServer2FreeTable· 16
hh3cDhcpServer2ConflictTable· 16
hh3cDhcpServer2ExpiredTable· 17
hh3cDhcpServer2IPInUseTable· 17
hh3cDhcpServer2DefOptGrpTable· 19
hh3cDhcpServer2ValidClassTable· 19
hh3cDhcpServer2RuleHwAddrTable· 20
hh3cDhcpServer2OptionGroupTable· 20
hh3cDhcpServer2OptionTable· 21
hh3cDhcpServer2PoolStatTable· 22
hh3cDhcpRelay2ConfigGroup· 23
hh3cDhcpRelay2StatisticsGroup· 24
hh3cDhcpRelay2IfConfigTable· 26
hh3cDhcpRelay2SrvAddrTable· 27
hh3cDhcpRelay2UserInfoTable· 27
Notifications· 28
hh3cDhcpServer2AddrExhaust 28
hh3cDhcpServer2AddrExhaustRecov· 29
hh3cDhcpServer2IpUsageOverflow· 30
hh3cDhcpServer2AllocOverflow· 30
hh3cDhcpServer2IpUsageOverflowRecov· 31
HH3C-DHCP4-MIB
About this MIB
The Dynamic Host Configuration Protocol (DHCP) provides a framework to assign configuration information to network devices.
DHCP adopts a client/server model. A DHCP client initiates a request for configuration parameters such as IP address, subnet mask, and the gateway address, and the DHCP server replies with the requested parameters.
Both BOOTP and DHCP use UDP protocols for packet encapsulation and use the same packet format. The major difference between BOOTP and DHCP is that BOOTP supports static configuration of the IP addresses while DHCP supports dynamic configuration.
The following figure shows a typical DHCP application scenario where the DHCP clients and the DHCP server reside on the same subnet.
http://press/data/infoblade/Comware V7平台中文/1.2.07 三层技术-IP业务/1.2.07.03 DHCP/DHCP配置.files/20230712_9386414_x_Img_x_png_0_1893290_294551_0.png
The DHCP relay agent enables clients to get IP addresses and configuration parameters from a DHCP server on another subnet.
Typically, a DHCP relay agent can be a host or a router enabled with the DHCP relay agent feature.
MIB file name
hh3c-dhcp4.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDhcp4(122)
Scalar objects
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2Enabled (1.3.6.1.4.1.25506.2.122.1.1.1)
read-write
TruthValue
true(1),
false(2)
Enabling status of the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2AlwaysBroadcast (1.3.6.1.4.1.25506.2.122.1.1.2)
read-write
TruthValue
true(1),
false(2)
Whether to enable the DHCP server to always broadcast responses.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2IgnoreBootp (1.3.6.1.4.1.25506.2.122.1.1.3)
read-write
TruthValue
true(1),
false(2)
Whether to ignore BOOTP requests.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2BootpReplyRfc1048 (1.3.6.1.4.1.25506.2.122.1.1.4)
read-write
TruthValue
true(1),
false(2)
Whether to enable the sending of BOOTP responses in RFC 1048 format.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2Opt82Enabled (1.3.6.1.4.1.25506.2.122.1.1.5)
read-write
TruthValue
true(1),
false(2)
Whether to enable the DHCP server to handle Option 82.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PingNumber (1.3.6.1.4.1.25506.2.122.1.1.6)
read-write
Unsigned32
Unsigned32(0..10)
Maximum number of attempts that the DHCP server pings an IP address before assigning the IP address to a DHCP client.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PingTimeout (1.3.6.1.4.1.25506.2.122.1.1.7)
read-write
Unsigned32
Unsigned32(0..10000)
Ping response timeout time for the DHCP server to ping an IP address.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.1.8)
read-write
Unsigned32
Unsigned32(0..100)
IP address allocation success rate threshold. The success rate is the rate of successfully allocated IP addresses to received DHCP requests within a specific time period
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2BadNum (1.3.6.1.4.1.25506.2.122.1.2.1)
read-only
Counter64
INTEGER(0..18446744073709551615)
Number of error packets received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2BootpRequestNum (1.3.6.1.4.1.25506.2.122.1.2.2)
read-only
Counter64
Number of BOOTP-REQUEST messages that the DHCP server receives.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2DiscoverNum (1.3.6.1.4.1.25506.2.122.1.2.3)
read-only
Counter64
Number of DHCP-DISCOVER messages that the DHCP server receives.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2RequestNum (1.3.6.1.4.1.25506.2.122.1.2.4)
read-only
Counter64
Number of DHCP-REQUEST messages that the DHCP server receives.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2DeclineNum (1.3.6.1.4.1.25506.2.122.1.2.5)
read-only
Counter64
Number of DHCP-DECLINE messages that the DHCP server receives.
As per the MIB.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ReleaseNum (1.3.6.1.4.1.25506.2.122.1.2.6)
read-only
Counter64
Number of DHCP-RELEASE messages that the DHCP server receives.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.7)
read-only
Counter64
Number of DHCP-INFORM messages that the DHCP server receives.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.8)
read-only
Counter64
Number of BOOTP-REPLY messages that the DHCP server sends.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.9)
read-only
Counter64
Number of DHCP-OFFER messages that the DHCP server sends.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.10)
read-only
Counter64
Number of DHCP-ACK messages that the DHCP server sends.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.11)
read-only
Counter64
Number of DHCP-NAK messages that the DHCP server sends.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.12)
read-only
Unsigned32
Unsigned32(0..100)
DHCP address pool usage.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.13)
read-only
Unsigned32
Standard MIB values.
Total number of DHCP address pools.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.15)
read-only
Unsigned32
Number of dynamic DHCP bindings.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.16)
read-only
Unsigned32
Number of static DHCP bindings.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.17)
read-only
Unsigned32
Number of expired DHCP bindings.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.18)
read-only
Counter64
Number of address requests received by the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.19)
read-only
Counter64
Number of successful processes of the received requests.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.20)
read-only
Unsigned32
Total number of IP addresses in all DHCP address pools on the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.21)
read-only
Unsigned32
Number of assigned IP addresses on the DHCP server.
As per the MIB.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.122.1.2.22)
read-only
Unsigned32
Number of free IP addresses on the DHCP server.
As per the MIB.
Tabular objects
About this table
This table records the address pool configuration on a DHCP server.
Support for operations
Create
Edit/Modify
Delete
Read
Supported.
When you create a new address pool, this table automatically creates an instance for the pool.
Supported
Supported
Supported
Columns
The table index is h3cDhcpServer2PoolIndex.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolIndex (1.3.6.1.4.1.25506.2.122.2.1.1.1)
not-accessible
Unsigned32
DHCP address pool index.
Implementation varies by product.
hh3cDhcpServer2PoolName (1.3.6.1.4.1.25506.2.122.2.1.1.2)
read-create
OCTET STRING
OCTET STRING (1..63)
DHCP address pool name.
As per the MIB.
hh3cDhcpServer2PoolVpnName (1.3.6.1.4.1.25506.2.122.2.1.1.3)
read-create
OCTET STRING
OCTET STRING (0..31)
VPN to which the DHCP address pool is bound.
As per the MIB.
hh3cDhcpServer2PoolNetwork (1.3.6.1.4.1.25506.2.122.2.1.1.4)
read-create
InetAddressIPv4
OCTET STRING (4)
Primary network address of the DHCP address pool.
As per the MIB.
hh3cDhcpServer2PoolNetworkMask (1.3.6.1.4.1.25506.2.122.2.1.1.5)
read-create
InetAddressIPv4
OCTET STRING (4)
Mask for the primary network address.
As per the MIB.
hh3cDhcpServer2PoolStartAddr (1.3.6.1.4.1.25506.2.122.2.1.1.6)
read-create
InetAddressIPv4
OCTET STRING (4)
Start IP address of an IP address range in the DHCP address pool.
As per the MIB.
hh3cDhcpServer2PoolEndAddr (1.3.6.1.4.1.25506.2.122.2.1.1.7)
read-create
InetAddressIPv4
OCTET STRING (4)
End IP address of an IP address range in the DHCP address pool.
As per the MIB.
hh3cDhcpServer2PoolLeaseDay (1.3.6.1.4.1.25506.2.122.2.1.1.8)
read-create
Integer32
Integer32(0..365)
Lease duration in days.
As per the MIB.
hh3cDhcpServer2PoolLeaseHour (1.3.6.1.4.1.25506.2.122.2.1.1.9)
read-create
Integer32
Integer32 (0..23)
Lease duration in hours.
As per the MIB.
hh3cDhcpServer2PoolLeaseMinute (1.3.6.1.4.1.25506.2.122.2.1.1.10)
read-create
Integer32
Integer32 (0..59)
Lease duration in minutes.
As per the MIB.
hh3cDhcpServer2PoolLeaseSecond (1.3.6.1.4.1.25506.2.122.2.1.1.11)
read-create
Integer32
Integer32 (0..59)
Lease duration in seconds.
As per the MIB.
hh3cDhcpServer2PoolLeaseUnlimit (1.3.6.1.4.1.25506.2.122.2.1.1.12)
read-create
TruthValue
true(1),
false(2)
Whether the lease duration is unlimited.
As per the MIB.
hh3cDhcpServer2PoolLeaseTime (1.3.6.1.4.1.25506.2.122.2.1.1.13)
read-create
TimeTicks
DHCP lease time in TimeTicks
As per the MIB.
hh3cDhcpServer2PoolDomainName (1.3.6.1.4.1.25506.2.122.2.1.1.14)
read-create
OCTET STRING
Domain name suffix assigned to DHCP clients.
As per the MIB.
hh3cDhcpServer2PoolGatewayIP (1.3.6.1.4.1.25506.2.122.2.1.1.15)
read-create
OCTET STRING
OCTET STRING (0..127)
Gateway IP address.
As per the MIB.
hh3cDhcpServer2PoolDNSIP(1.3.6.1.4.1.25506.2.122.2.1.1.16)
read-create
OCTET STRING
DNS server IP address.
As per the MIB.
hh3cDhcpServer2PoolPrimaryDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.17)
read-create
InetAddressIPv4
OCTET STRING (4)
Primary DNS server IP address.
As per the MIB.
hh3cDhcpServer2PoolSecondDNSIP (1.3.6.1.4.1.25506.2.122.2.1.1.18)
read-create
InetAddressIPv4
OCTET STRING (4)
Secondary DNS server IP address.
As per the MIB.
hh3cDhcpServer2PoolNetbiosType (1.3.6.1.4.1.25506.2.122.2.1.1.19)
read-create
INTEGER
null(0),        bnode(1)            pnode(2),           mnode(4),        hnode(8)
NETBIOS node type.
As per the MIB.
hh3cDhcpServer2PoolNbnsIP(1.3.6.1.4.1.25506.2.122.2.1.1.20)
read-create
OCTET STRING
SIZE(0..127)
NETBIOS server IP address.
As per the MIB.
hh3cDhcpServer2PoolBootFileName (1.3.6.1.4.1.25506.2.122.2.1.1.21)
read-create
OCTET STRING
SIZE(0..63)
Name of a configuration file to be assigned to DHCP clients.
As per the MIB.
hh3cDhcpServer2PoolBimsIP(1.3.6.1.4.1.25506.2.122.2.1.1.22)
read-create
InetAddressIPv4
OCTET STRING (4)
BIMS server IP address.
As per the MIB.
hh3cDhcpServer2PoolBimsPort (1.3.6.1.4.1.25506.2.122.2.1.1.23)
read-create
Unsigned32
Unsigned32(0..65534)
BIMS server port number.
As per the MIB.
hh3cDhcpServer2PoolBimsKeyStr (1.3.6.1.4.1.25506.2.122.2.1.1.24)
read-create
OCTET STRING
OCTET STRING (0..16)
Shared key for the DHCP clients to encrypt packets sent to the BIMS server.
Does not support GET.
hh3cDhcpServer2PoolNextServer (1.3.6.1.4.1.25506.2.122.2.1.1.25)
read-create
InetAddressIPv4
OCTET STRING (4)
IP address of the next DHCP server.
As per the MIB.
hh3cDhcpServer2PoolTftpDomName (1.3.6.1.4.1.25506.2.122.2.1.1.26)
read-create
OCTET STRING
OCTET STRING (0..63)
TFTP server domain name.
As per the MIB.
hh3cDhcpServer2PoolTftpIP (1.3.6.1.4.1.25506.2.122.2.1.1.27)
read-create
InetAddressIPv4
OCTET STRING (4)
TFTP server IP address.
As per the MIB.
hh3cDhcpServer2PoolVoiceAsIP (1.3.6.1.4.1.25506.2.122.2.1.1.28)
read-create
InetAddressIPv4
OCTET STRING (4)
IP address of the backup network calling processor.
As per the MIB.
hh3cDhcpServer2PoolVoiceFailIP (1.3.6.1.4.1.25506.2.122.2.1.1.29)
read-create
InetAddressIPv4
OCTET STRING (4)
Failover IP address.
As per the MIB.
hh3cDhcpServer2PoolVoiceFailStr (1.3.6.1.4.1.25506.2.122.2.1.1.30)
read-create
OCTET STRING
OCTET STRING (0..39)
Failover dialer string.
As per the MIB.
hh3cDhcpServer2PoolVoiceNCPIP (1.3.6.1.4.1.25506.2.122.2.1.1.31)
read-create
InetAddressIPv4
OCTET STRING (4)
IP address of the primary network calling processor.
As per the MIB.
hh3cDhcpServer2PoolVoiceVlanId (1.3.6.1.4.1.25506.2.122.2.1.1.32)
read-create
Unsigned32
Unsigned32(2..4094|65535)
Voice VLAN ID.
As per the MIB.
hh3cDhcpServer2PoolVoiceVlanEnbl (1.3.6.1.4.1.25506.2.122.2.1.1.33)
read-create
TruthValue
true(1),
false(2)
Enabling status of the voice VLAN.
As per the MIB.
hh3cDhcpServer2PoolRowStatus (1.3.6.1.4.1.25506.2.122.2.1.1.34)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
hh3cDhcpServer2PoolVerifyClass(1.3.6.1.4.1.25506.2.122.2.1.1.35)
read-create
TruthValue
true(1),
false(2)
Enabling status of the user class whitelist.
As per the MIB.
hh3cDhcpServer2PoolThreshold
(1.3.6.1.4.1.25506.2.122.2.1.1.36)
read-create
Unsigned32
Unsigned32(0..100)
DHCP address pool usage threshold.
As per the MIB.
About this table
This table records the address pool bound to an interface.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2IfApplyPoolName (1.3.6.1.4.1.25506.2.122.2.2.1.1)
read-write
OCTET STRING
Name of the address pool bound to an interface.
As per the MIB.
About this table
This table records the secondary network configuration in the DHCP address pool.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex, h3cDhcpServer2PoolSecNw, and h3cDhcpServer2PoolSecNwMask.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolSecNw(1.3.6.1.4.1.25506.2.122.2.3.1.1)
not-accessible
InetAddressIPv4
OCTET STRING (4)
Secondary network IP address.
As per the MIB.
hh3cDhcpServer2PoolSecNwMask (1.3.6.1.4.1.25506.2.122.2.3.1.2)
not-accessible
InetAddressIPv4
OCTET STRING (4)
Mask of the secondary network IP address.
As per the MIB.
hh3cDhcpServer2PoolSecNwGwIP (1.3.6.1.4.1.25506.2.122.2.3.1.3)
read-create
OCTET STRING
Gateway IP address for the secondary network.
As per the MIB.
hh3cDhcpServer2PoolSecNwStatus (1.3.6.1.4.1.25506.2.122.2.3.1.4)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records address ranges for DHCP user classes in a DHCP address pool on a DHCP server.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolClassName.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolClassName (1.3.6.1.4.1.25506.2.122.2.4.1.1)
not-accessible
OCTET STRING
User class name.
As per the MIB.
hh3cDhcpServer2PoolClassStart (1.3.6.1.4.1.25506.2.122.2.4.1.2)
read-create
InetAddressIPv4
OCTET STRING (4)
Start IP address of an address range for a DHCP user class.
As per the MIB.
hh3cDhcpServer2PoolClassEnd
(1.3.6.1.4.1.25506.2.122.2.4.1.3)
read-create
InetAddressIPv4
OCTET STRING (4)
End IP address of an address range for a DHCP user class.
As per the MIB.
hh3cDhcpServer2PoolClassStatus (1.3.6.1.4.1.25506.2.122.2.4.1.4)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records static bindings in a DHCP address pool.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolStaticIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolStaticIP (1.3.6.1.4.1.25506.2.122.2.5.1.1)
not-accessible
InetAddressIPv4
OCTET STRING (4)
IP address in a static binding.
As per the MIB.
hh3cDhcpServer2PoolStaticMask (1.3.6.1.4.1.25506.2.122.2.5.1.2)
read-create
InetAddressIPv4
OCTET STRING (4)
IP address mask in the static binding.
As per the MIB.
hh3cDhcpServer2PoolStaticCID (1.3.6.1.4.1.25506.2.122.2.5.1.3)
read-create
OCTET STRING
OCTET STRING (0|4..254)
Client identifier in the static binding.
As per the MIB.
hh3cDhcpServer2PoolStaticHAddr
(1.3.6.1.4.1.25506.2.122.2.5.1.4)
read-create
OCTET STRING
OCTET STRING (0|4..39)
Hardware address in the static binding.
As per the MIB.
hh3cDhcpServer2PoolStaticHType
(1.3.6.1.4.1.25506.2.122.2.5.1.5)
read-create
INTEGER
default(1), ethernet(2), tokenRing(3)
Hardware address type.
As per the MIB.
hh3cDhcpServer2PoolStaticStatus (1.3.6.1.4.1.25506.2.122.2.5.1.6)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records user-defined options in the DHCP address pool.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolOptCode.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolOptCode (1.3.6.1.4.1.25506.2.122.2.6.1.1)
not-accessible
Integer32
Integer32(2..254), excluding 50..54, 56, 58, 59, 61, 82.
Option code.
As per the MIB.
hh3cDhcpServer2PoolOptType (1.3.6.1.4.1.25506.2.122.2.6.1.2)
read-create
INTEGER
ascii(1), hex(2), ip(3)
Option type.
As per the MIB.
hh3cDhcpServer2PoolOptAscii (1.3.6.1.4.1.25506.2.122.2.6.1.3)
read-create
OCTET STRING
OCTET STRING (0..255)
ASCII string as the option content.
As per the MIB.
hh3cDhcpServer2PoolOptHexStr (1.3.6.1.4.1.25506.2.122.2.6.1.4)
read-create
OCTET STRING
OCTET STRING (0..510)
Hexadecimal number as the option content.
The string length cannot exceed 256.
hh3cDhcpServer2PoolOptIPStr (1.3.6.1.4.1.25506.2.122.2.6.1.5)
read-create
OCTET STRING
IP address as the option content.
As per the MIB.
hh3cDhcpServer2PoolOptRowStatus (1.3.6.1.4.1.25506.2.122.2.6.1.6)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records excluded IP addresses in a DHCP address pool.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2PoolForbidIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolForbidIP (1.3.6.1.4.1.25506.2.122.2.7.1.1)
not-accessible
InetAddressIPv4
IP address excluded from dynamic allocation.
As per the MIB.
hh3cDhcpServer2PoolForbidStatus (1.3.6.1.4.1.25506.2.122.2.7.1.2)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records DHCP user class information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is h3cDhcpServer2ClassName.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ClassName (1.3.6.1.4.1.25506.2.122.2.8.1.1)
not-accessible
OCTET STRING
User class name.
As per the MIB.
hh3cDhcpServer2ClassRowStatus (1.3.6.1.4.1.25506.2.122.2.8.1.2)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records DHCP user class match rules.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2ClassName and h3cDhcpServer2RuleNumber.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2RuleNumber
(1.3.6.1.4.1.25506.2.122.2.9.1.1)
not-accessible
Integer32
Integer32(1..16)
Rule ID.
As per the MIB.
hh3cDhcpServer2RuleOptCode (1.3.6.1.4.1.25506.2.122.2.9.1.2)
read-create
Integer32
Integer32(1..254)
Option code.
As per the MIB.
hh3cDhcpServer2RuleOptHexStr (1.3.6.1.4.1.25506.2.122.2.9.1.3)
read-create
OCTET STRING
Content to match specific options in packets.
The length of the content cannot exceed 256.
hh3cDhcpServer2RuleOptMask (1.3.6.1.4.1.25506.2.122.2.9.1.4)
read-create
OCTET STRING
Hexadecimal mask for the match operation.
If it is bound to hh3cDhcpServer2RuleOptHexStr, the entire command length cannot exceed 512.
hh3cDhcpServer2RuleOptOffset (1.3.6.1.4.1.25506.2.122.2.9.1.5)
read-create
Integer32
Integer32(0..254)
Offset in bytes after which the match operation starts
As per the MIB.
hh3cDhcpServer2RuleOptLength (1.3.6.1.4.1.25506.2.122.2.9.1.6)
read-create
Integer32
Integer32(0..128)
Length of the option content to be matched.
As per the MIB.
hh3cDhcpServer2RuleRowStatus (1.3.6.1.4.1.25506.2.122.2.9.1.7)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records excluded IP address ranges.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2ForbidVpnName, h3cDhcpServer2ForbidStart, and h3cDhcpServer2ForbidEnd.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ForbidVpnName (1.3.6.1.4.1.25506.2.122.2.10.1.1)
not-accessible
OCTET STRING
OCTET STRING (1..31)
Name of the VPN to which the excluded IP address belongs.
As per the MIB.
hh3cDhcpServer2ForbidStart (1.3.6.1.4.1.25506.2.122.2.10.1.2)
not-accessible
InetAddressIPv4
OCTET STRING (4)
Start IP address of the excluded IP address range.
As per the MIB.
hh3cDhcpServer2ForbidEnd (1.3.6.1.4.1.25506.2.122.2.10.1.3)
not-accessible
InetAddressIPv4
OCTET STRING (4)
End IP address of the excluded IP address range.
As per the MIB.
hh3cDhcpServer2ForbidRowStatus (1.3.6.1.4.1.25506.2.122.2.10.1.4)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table records free IP address ranges on a DHCP server.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2FreeStart.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2FreeStart (1.3.6.1.4.1.25506.2.122.2.11.1.1)
not-accessible
InetAddressIPv4
Start IP address of a free IP address range.
As per the MIB.
hh3cDhcpServer2FreeEnd (1.3.6.1.4.1.25506.2.122.2.11.1.2)
read-only
InetAddressIPv4
End IP address of a free IP address range.
As per the MIB.
About this table
This table records conflicting IP addresses on a DHCP server.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ConflictIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ConflictIP (1.3.6.1.4.1.25506.2.122.2.12.1.1)
not-accessible
InetAddressIPv4
Conflicting IP address.
As per the MIB.
hh3cDhcpServer2ConflictType (1.3.6.1.4.1.25506.2.122.2.12.1.2)
read-only
INTEGER
detectByServer(1), detectByClient(2)
Conflict type.
As per the MIB.
hh3cDhcpServer2ConflictTime (1.3.6.1.4.1.25506.2.122.2.12.1.3)
read-only
OCTET STRING
OCTET STRING (1..19)
Time when the conflict was detected.
As per the MIB.
hh3cDhcpServer2ConflictRowStatus
(1.3.6.1.4.1.25506.2.122.2.12.1.4)
read-create
RowStatus
destroy
Row status.
As per the MIB.
About this table
This table records lease expiration information on a DHCP server.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ExpiredIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ExpiredIP (1.3.6.1.4.1.25506.2.122.2.13.1.1)
not-accessible
InetAddressIPv4
Expired IP address.
As per the MIB.
hh3cDhcpServer2ExpiredClientId (1.3.6.1.4.1.25506.2.122.2.13.1.2)
read-only
OCTET STRING
OCTET STRING (4..254)
ID of the DHCP client of the expired IP address.
As per the MIB.
hh3cDhcpServer2ExpiredTime (1.3.6.1.4.1.25506.2.122.2.13.1.3)
read-only
OCTET STRING
OCTET STRING (1..19), a time string in the format of MM/DD/YYYY hh:mm:ss.
Time when the lease expired.
As per the MIB.
hh3cDhcpServer2ExpiredRowStatus (1.3.6.1.4.1.25506.2.122.2.13.1.4)
read-create
RowStatus
destroy
Row status.
As per the MIB.
About this table
This table records binding information about IP addresses in use on a DHCP server.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2IPInUseIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2IPInUseIP (1.3.6.1.4.1.25506.2.122.2.14.1.1)
not-accessible
InetAddressIPv4
OCTET STRING (4)
IP address in use.
As per the MIB.
hh3cDhcpServer2IPInUseClientId (1.3.6.1.4.1.25506.2.122.2.14.1.2)
read-only
OCTET STRING
Client ID of the IP address.
As per the MIB.
hh3cDhcpServer2IPInUseHardAddr
(1.3.6.1.4.1.25506.2.122.2.14.1.3)
read-only
OCTET STRING
Hardware address of the DHCP client.
As per the MIB.
hh3cDhcpServer2IPInUseHardType
(1.3.6.1.4.1.25506.2.122.2.14.1.4)
read-only
INTEGER
As per the MIB.
hh3cDhcpServer2IPInUseVlanId (1.3.6.1.4.1.25506.2.122.2.14.1.5)
read-only
Unsigned32
Unsigned32(1..4094 | 65535)
VLAN where the DHCP client resides.
As per the MIB.
hh3cDhcpServer2IPInUseEndLease (1.3.6.1.4.1.25506.2.122.2.14.1.6)
read-only
OCTET STRING
Lease expiration time.
As per the MIB.
hh3cDhcpServer2IPInUseType (1.3.6.1.4.1.25506.2.122.2.14.1.7)
read-only
INTEGER
staticUnallocated(1), staticOffered(2), staticCommitted(3), autoOffered(4),
autoCommitted(5)
Binding type.
As per the MIB.
hh3cDhcpServer2IPInUseIfIndex (1.3.6.1.4.1.25506.2.122.2.14.1.8)
read-only
InterfaceIndexOrZero
Integer32(0..2147483647)
Index of the interface that connects to the DHCP client.
As per the MIB.
hh3cDhcpServer2IPInUseRowStatus (1.3.6.1.4.1.25506.2.122.2.14.1.9)
read-create
RowStatus
destroy
Row status.
As per the MIB.
hh3cDhcpServer2IPInUseSecondVlanId (1.3.6.1.4.1.25506.2.122.2.14.1.10)
read-only
Unsigned32
Inner VLAN (customer VLAN) tag contained in the DHCP request.
As per the MIB.
About this table
This table defines option information associated with the DHCP user class.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2DefOptGrpClass.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2DefOptGrpClass (1.3.6.1.4.1.25506.2.122.2.15.1.1)
not-accessible
OCTET STRING
User class name.
As per the MIB.
hh3cDhcpServer2DefOptGrpId (1.3.6.1.4.1.25506.2.122.2.15.1.2)
read-create
Integer32
Integer32(1..32768)
Option group ID.
As per the MIB.
hh3cDhcpServer2DefOptGrpStatus(1.3.6.1.4.1.25506.2.122.2.15.1.3)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines user class whitelist.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2PoolIndex and h3cDhcpServer2ValidClassName.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2ValidClassName (1.3.6.1.4.1.25506.2.122.2.16.1.1)
not-accessible
OCTET STRING
User class name.
As per the MIB.
hh3cDhcpServer2ValidClassStatus (1.3.6.1.4.1.25506.2.122.2.16.1.2)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines the user class hardware address match rule.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2ClassName and h3cDhcpServer2RuleHwAddrNumber.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2RuleHwAddrNumber (1.3.6.1.4.1.25506.2.122.2.17.1.1)
not-accessible
Integer32
Integer32 (1..16)
Rule ID.
As per the MIB.
hh3cDhcpServer2RuleHwAddress (1.3.6.1.4.1.25506.2.122.2.17.1.2)
read-create
OCTET STRING
OCTET STRING (4..39)
Hardware address.
As per the MIB.
hh3cDhcpServer2RuleHwAddrMask (1.3.6.1.4.1.25506.2.122.2.17.1.3)
read-create
OCTET STRING
Hardware address mask.
As per the MIB.
hh3cDhcpServer2RuleHwAddrType (1.3.6.1.4.1.25506.2.122.2.17.1.4)
read-create
Integer32
1, representing the Ethernet
As per the MIB.
hh3cDhcpServer2RuleHwAddrStatus (1.3.6.1.4.1.25506.2.122.2.17.1.5)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines a DHCP option group for a DHCP user class.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is h3cDhcpServer2OptionGroupId.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2OptionGroupId (1.3.6.1.4.1.25506.2.122.2.18.1.1)
not-accessible
Integer32
Integer32(1..32768)
Option group ID.
As per the MIB.
hh3cDhcpServer2OptionGroupStatus (1.3.6.1.4.1.25506.2.122.2.18.1.2)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines user option information in a DHCP option group.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are h3cDhcpServer2OptionGroupId and h3cDhcpServer2OptionCode.
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2OptionCode (1.3.6.1.4.1.25506.2.122.2.19.1.1)
not-accessible
Integer32
Integer32(2..254),excluding 50..54, 56, 58, 59, 61, 82
Option code.
As per the MIB.
hh3cDhcpServer2OptionType (1.3.6.1.4.1.25506.2.122.2.19.1.2)
read-create
INTEGER
Option type.
As per the MIB.
hh3cDhcpServer2OptionAscii (1.3.6.1.4.1.25506.2.122.2.19.1.3)
read-create
OCTET STRING
OCTET STRING(0..255)
The value read from this object is 0 if ascii(1) is specified as the option type but no ASCII string is specified.
hh3cDhcpServer2OptionHexStr (1.3.6.1.4.1.25506.2.122.2.19.1.4)
read-create
OCTET STRING
OCTET STRING(0|2..256)
The value read from this object is 0 if hex(2) is specified as the option type but no hexadecimal string is specified.
hh3cDhcpServer2OptionIPStr (1.3.6.1.4.1.25506.2.122.2.19.1.5)
read-create
OCTET STRING
OCTET STRING(0..127)
As per the MIB.
hh3cDhcpServer2OptionRowStatus (1.3.6.1.4.1.25506.2.122.2.19.1.6)
read-create
RowStatus
Active(1)
createAndGo(4)
destroy(6)
Row status.
As per the MIB.
About this table
This table defines DHCP address pool statistic.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDhcpServer2PoolUsage
(1.3.6.1.4.1.25506.2.122.2.20.1.1)
read-only
Unsigned32
Unsigned32(0..100)
As per the MIB.
hh3cDhcpServer2PoolReqCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.2)
read-only
Counter64
Number of requests received by the address pool.
As per the MIB.
hh3cDhcpServer2PoolReqSuccCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.3)
read-only
Counter64
Number of successful processes of the received requests in the address pool.
As per the MIB.
hh3cDhcpServer2PoolDiscoverCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.4)
read-only
Counter64
Number of DHCP-DISCOVER messages received by the address pool.
As per the MIB.
hh3cDhcpServer2PoolOfferCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.5)
read-only
Counter64
Number of DHCP-OFFER messages sent by the address pool.
As per the MIB.
hh3cDhcpServer2PoolAckCnt
(1.3.6.1.4.1.25506.2.122.2.20.1.6)
read-only
Counter64
Number of DHCP-ACK messages sent by the address pool.
As per the MIB.
hh3cDhcpServer2PoolIPTotalNum
(1.3.6.1.4.1.25506.2.122.2.20.1.7)
read-only
Unsigned32
Total number of addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolIPUsedNum
(1.3.6.1.4.1.25506.2.122.2.20.1.8)
read-only
Unsigned32
Number of assigned IP addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolIPIdleNum
(1.3.6.1.4.1.25506.2.122.2.20.1.9)
read-only
Unsigned32
Number of free IP addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolIPExcludeNum
(1.3.6.1.4.1.25506.2.122.2.20.1.10)
read-only
Unsigned32
Number of excluded IP addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolConflictNum
(1.3.6.1.4.1.25506.2.122.2.20.1.11)
read-only
Unsigned32
Number of conflicting IP addresses in the address pool.
As per the MIB.
hh3cDhcpServer2PoolAutoBindNum
(1.3.6.1.4.1.25506.2.122.2.20.1.12)
read-only
Unsigned32
Number of dynamic IP bindings in the address pool.
As per the MIB.
hh3cDhcpServer2PoolManualBindNum
(1.3.6.1.4.1.25506.2.122.2.20.1.13)
read-only
Unsigned32
Number of static IP bindings in the address pool.
As per the MIB.
hh3cDhcpServer2PoolExpiredBindNum
(1.3.6.1.4.1.25506.2.122.2.20.1.14)
read-only
Unsigned32
Number of expired IP bindings in the address pool.
As per the MIB.
hh3cDhcpServer2PoolNameInfo
(1.3.6.1.4.1.25506.2.122.2.20.1.15)
read-only
OCTET STRING
As per the MIB.
About this table
This table configures global DHCP relay agent settings.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2UserInfoRecord
(1.3.6.1.4.1.25506.2.122.3.1.1)
read-write
TruthValue
true(1),
false(2)
Enabling status of recording client information in relay entries.
As per the MIB.
hh3cDhcpRelay2UserInfoRefresh
(1.3.6.1.4.1.25506.2.122.3.1.2)
read-write
TruthValue
true(1),
false(2)
Enabling status of refreshing relay entries.
As per the MIB.
hh3cDhcpRelay2UserInfoFlushTime (1.3.6.1.4.1.25506.2.122.3.1.3)
read-write
Unsigned32
Unsigned32(0..120)
Interval at which the DHCP relay agent refreshes relay entries.
As per the MIB.
hh3cDhcpRelay2ReleaseAddr
(1.3.6.1.4.1.25506.2.122.3.1.4)
read-write
OCTET STRING
OCTET STRING (0..47)
IP address release request sent to the server.
The set operation enables the relay agent to send a release request for the specified IP address to the DHCP server.
When you perform a get operation on this object, a value of 0 is returned.
About this table
This table records the global statistics on a DHCP relay agent.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2RxClientNum (1.3.6.1.4.1.25506.2.122.3.2.1)
read-only
Counter64
Number of received packets that are sent by the DHCP clients.
As per the MIB.
hh3cDhcpRelay2TxClientNum (1.3.6.1.4.1.25506.2.122.3.2.2)
read-only
Counter64
Number of packets sent to the DHCP clients.
As per the MIB.
hh3cDhcpRelay2RxServerNum (1.3.6.1.4.1.25506.2.122.3.2.3)
read-only
Counter64
Number of received packets sent by DHCP servers.
As per the MIB.
hh3cDhcpRelay2TxServerNum (1.3.6.1.4.1.25506.2.122.3.2.4)
read-only
Counter64
Number of packets sent to the DHCP servers.
As per the MIB.
hh3cDhcpRelay2BadNum
(1.3.6.1.4.1.25506.2.122.3.2.5)
read-only
Counter64
Number of error packets processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2BootpRequestNum
(1.3.6.1.4.1.25506.2.122.3.2.6)
read-only
Counter64
Number of BOOTP requests processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2DiscoverNum (1.3.6.1.4.1.25506.2.122.3.2.7)
read-only
Counter64
Number of DHCP-DISCOVER messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2RequestNum (1.3.6.1.4.1.25506.2.122.3.2.8)
read-only
Counter64
Number of DHCP-REQUEST messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2DeclineNum (1.3.6.1.4.1.25506.2.122.3.2.9)
read-only
Counter64
Number of DHCP-DECLINE messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2ReleaseNum (1.3.6.1.4.1.25506.2.122.3.2.10)
read-only
Counter64
Number of DHCP-RELEASE messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2InformNum (1.3.6.1.4.1.25506.2.122.3.2.11)
read-only
Counter64
Number of DHCP-INFORM messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2BootpReplyNum
(1.3.6.1.4.1.25506.2.122.3.2.12)
read-only
Counter64
Number of BOOTP replies processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2OfferNum (1.3.6.1.4.1.25506.2.122.3.2.13)
read-only
Counter64
Number of DHCP-OFFER messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2AckNum (1.3.6.1.4.1.25506.2.122.3.2.14)
read-only
Counter64
Number of DHCP-ACK messages processed by the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2NakNum (1.3.6.1.4.1.25506.2.122.3.2.15)
read-only
Counter64
Number of DHCP-NAK messages processed by the DHCP relay agent.
As per the MIB.
About this table
This table records the DHCP relay agent configuration on an interface.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2IfSelectRelay (1.3.6.1.4.1.25506.2.122.4.1.1.1)
read-write
TruthValue
true(1),
false(2)
Enabling status of the DHCP relay agent.
As per the MIB.
hh3cDhcpRelay2IfCheckMac
(1.3.6.1.4.1.25506.2.122.4.1.1.2)
read-write
TruthValue
true(1),
false(2)
Enabling status of MAC address check.
As per the MIB.
hh3cDhcpRelay2IfOpt82Enable
(1.3.6.1.4.1.25506.2.122.4.1.1.3)
read-write
TruthValue
true(1),
false(2)
Enabling status of support for option 82.
As per the MIB.
hh3cDhcpRelay2IfOpt82Strategy
(1.3.6.1.4.1.25506.2.122.4.1.1.4)
read-write
INTEGER
drop(1), keep(2), replace(3)
Strategy for handling DHCP requests that contain Option 82.
As per the MIB.
hh3cDhcpRelay2IfOpt82CIDMode
(1.3.6.1.4.1.25506.2.122.4.1.1.5)
read-write
INTEGER
normal(1),
verbose(2),
userDefine(3)
Mode of the circuit ID sub-option in option 82.
The return value is normal(1) if the system reads an unsupported mode.
hh3cDhcpRelay2IfOpt82CIDNodeType
(1.3.6.1.4.1.25506.2.122.4.1.1.6)
read-write
INTEGER
invalid(1),
mac(2),
sysname(3),
userDefine(4)
Access node identifier for the circuit ID sub-option in verbose mode.
If no access node identifier is specified, the value read from this object is invalid(1).
hh3cDhcpRelay2IfOpt82CIDNodeStr
(1.3.6.1.4.1.25506.2.122.4.1.1.7)
read-write
OCTET STRING
OCTET STRING (0..50)
User-defined string as the access node identifier for the circuit ID sub-option in verbose mode.
As per the MIB.
hh3cDhcpRelay2IfOpt82CIDStr
(1.3.6.1.4.1.25506.2.122.4.1.1.8)
read-write
OCTET STRING
OCTET STRING (0|3..63)
User-defined string as the access node identifier for the circuit ID sub-option in userDefine mode.
As per the MIB.
hh3cDhcpRelay2IfOpt82CIDFormat
(1.3.6.1.4.1.25506.2.122.4.1.1.9)
read-write
INTEGER
hex(1),
ascii(2),
undefine(3)
Padding format of the circuit ID sub-option in option 82.
As per the MIB.
hh3cDhcpRelay2IfOpt82RIDMode
(1.3.6.1.4.1.25506.2.122.4.1.1.10)
read-write
INTEGER
normal(1),
sysname(2),
userDefine(3)
Mode of the remote ID sub-option in option 82.
As per the MIB.
hh3cDhcpRelay2IfOpt82RIDStr
(1.3.6.1.4.1.25506.2.122.4.1.1.11)
read-write
OCTET STRING
User-defined string as the access node identifier for the remote ID sub-option in userDefine mode.
If the mode of the remote ID sub-option is sysname(2), the value read from this object is 0.
hh3cDhcpRelay2IfOpt82RIDFormat
(1.3.6.1.4.1.25506.2.122.4.1.1.12)
read-write
INTEGER
hex(1),
ascii(2)
Padding format of the remote ID sub-option in normal mode.
As per the MIB.
About this table
This table describes the IP address of a DHCP server.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ifIndex and h3cDhcpRelay2SrvAddrIP.
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2SrvAddrIP
(1.3.6.1.4.1.25506.2.122.4.2.1.1)
not-accessible
InetAddressIPv4
OCTET STRING (4)
DHCP server IP address.
As per the MIB.
hh3cDhcpRelay2SrvAddrRowStatus (1.3.6.1.4.1.25506.2.122.4.2.1.2)
read-create
RowStatus
Active
createAndGo
destroy
Row status.
As per the MIB.
About this table
Use this table to delete DHCP relay entries.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Supported
Supported
Columns
The table indexes are h3cDhcpRelay2UserInfoVpnIndex and h3cDhcpRelay2UserInfoIpAddr.
Object (OID)
Access
Value range
Implementation
hh3cDhcpRelay2UserInfoVpnIndex
(1.3.6.1.4.1.25506.2.122.4.3.1.1)
not-accessible
Unsigned32
Unsigned32 (0 . 65534), 0 represents the public network.
VPN to which the IP address of the relay entry belongs.
As per the MIB.
hh3cDhcpRelay2UserInfoIpAddr (1.3.6.1.4.1.25506.2.122.4.3.1.2)
not-accessible
InetAddressIPv4
OCTET STRING (0.255)
Client IP address in the relay entry.
As per the MIB.
hh3cDhcpRelay2UserInfoMacAddr (1.3.6.1.4.1.25506.2.122.4.3.1.3)
read-only
MacAddress
OCTET STRING (6)
Client MAC address in the relay entry.
As per the MIB.
hh3cDhcpRelay2UserInfoIfIndex (1.3.6.1.4.1.25506.2.122.4.3.1.4)
read-only
Index of the Layer 3 interface that connects to the DHCP client.
As per the MIB.
hh3cDhcpRelay2UserInfoRowStatus (1.3.6.1.4.1.25506.2.122.4.3.1.5)
read-create
RowStatus
destroy
Row status.
As per the MIB.
Notifications
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.122.5.0.1
Exhaustion of addresses in a DHCP address pool.
Informational
Major
1.3.6.1.4.1.25506.2.122.5.0.2
ON
This notification is generated when all addresses in a DHCP address pool are assigned.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server address-exhaust command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server address-exhaust command.
Objects
OID (object name)
Index
Value range
(hh3cDhcpServer2PoolIndex)
No
Unsigned32
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
DHCP address pool is recovered from address exhaustion state.
Informational
Warning
ON
This notification is generated when the DHCP address pool is recovered from the address exhaustion state.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.3
Address pool usage threshold is exceeded.
Informational
Warning
ON
This notification is generated when the address pool usage threshold is exceeded. The address pool usage is read every 5 minutes.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server ip-in-use command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp server ip-in-use command.
Objects
OID (object name)
Index
Value range
No
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.4
DHCP address allocation success rate is below the specified threshold.
Informational
Warning
ON
This notification is generated when the DHCP address allocation success rate is below the specified threshold during the past five minutes.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp server allocated-ip command
OFF
CLI: Use the undo snmp-agent trap enable dhcp server allocated-ip command
Objects
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.122.5.0.5
Address usage in the pool drops below the threshold.
Informational
Warning
ON
This notification is generated when the address usage of the pool drops below the threshold.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
No
Unsigned32
Recommended action
  • Become a Partner
  • Partner Resources
