05-Layer 3 - IP Services
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10005-Layer 3 - IP Services
03-HH3C-ND-TRAP-MIB
03-HH3C-ND-TRAP-MIB 42.43 KB
HH3C-ND-TRAP-MIB
About this MIB
Use this MIB to obtain information about ND entry learning threshold and packet conflict related alarms.
MIB file name
hh3c-nd-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2). hh3cNDTrap(218)
Notifications
This section contains HH3C-ND-TRAP-MIB notifications.
hh3cNDTrapSlotThresholdResume
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.218.1.0.4
The number of ND entries on the current card dropped below the alarm threshold.
Informational
N/A
N/A
ON
This notification is generated when the number of dynamic ND entries on the card drops below the alarm threshold.
Status control
ON
CLI: Use the ipv6 nd entry-limit record enable command.
OFF
CLI: Use the undo ipv6 nd entry-limit record enable command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.218.1.1.1 (hh3cNDTrapEntryChassis)
Chassis number.
No
Unsigned32
Standard MIB values.
1.3.6.1.4.1.25506.2.218.1.1.2 (hh3cNDTrapEntrySlot)
Slot number.
No
Unsigned32
1.3.6.1.4.1.25506.2.218.1.1.4 (hh3cNDTrapEntryThreshold)
Alarm threshold for the number of ND entries on the card.
No
Unsigned32
1.3.6.1.4.1.25506.2.218.1.1.5 (hh3cNDTrapEntryDynamicNum)
Number of dynamic ND entries.
No
Unsigned32
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
  • Become a Partner
  • Partner Resources
