09-HH3C-ARP-RATELIMIT-MIB | 39.79 KB |
About this MIB
This MIB contains ARP rate limiting notifications.
MIB file name
hh3c-arp-ratelimit.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cARPRatelimit(110)
Notifications
hh3cARPRatelimitOverspeedTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.110.1.1.0.1 |
Rate of ARP packets delivered to the CPU on a device exceeded the threshold. |
Informational |
N/A |
N/A |
OFF |
This notification is generated when the rate of ARP packets delivered to the CPU on a device exceeds the threshold.
Status control
ON
CLI: Use the snmp-agent trap enable arp rate-limit command.
OFF
CLI: Use the undo snmp-agent trap enable arp rate-limit command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.110.1.1.1.1 (hh3cARPRatelimitTrapVer) |
Version of the trap. |
No |
Unsigned32 |
1 |
1.3.6.1.4.1.25506.2.110.1.1.1.2 (hh3cARPRatelimitTrapCount) |
Alarm threshold that the ARP packet rate exceeded. |
No |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.110.1.1.1.3 (hh3cARPRatelimitTrapMsg) |
Trap messages. |
No |
OCTET STRING |
SIZE (1..254) |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
