05-Layer 3 - IP Services
HomeSupportResource CenterSwitchesS12500R SeriesS12500R SeriesTechnical DocumentsReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10005-Layer 3 - IP Services
10-HH3C-ARP-TRAP-MIB
10-HH3C-ARP-TRAP-MIB 42.22 KB
HH3C-ARP-TRAP-MIB
About this MIB
Use this MIB to output notifications for the ARP module.
MIB file name
hh3c-arp-trap.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cARPTrap(217)
Notifications
hh3cARPTrapIPConflictAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.217.2.1.0.5
Local IP address conflicted.
Informational
Major
1.3.6.1.4.1.25506.2.217.2.1.0.6(hh3cARPTrapMACIPConflictResume)
OFF
This notification is generated when the sender IP address in the ARP packet is the same as the IP address of the local device.
Status control
ON
CLI: Use the snmp-agent trap enable arp local-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable arp local-conflict command.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.217.2.1.1.1 (hh3cARPTrapLocalConflictIf)
Interface that received the ARP packet with a duplicate IP address.
No
OCTET STRING
OCTET STRING  (1..47)
1.3.6.1.4.1.25506.2.217.2.1.1.3
(hh3cARPTrapLocalConflictIP)
Sender IP address in the ARP packet.
No
IpAddress
Standard MIB values.
1.3.6.1.4.1.25506.2.217.2.1.1.5 (hh3cARPTrapLocalSrcMac)
Sender MAC address in the ARP packet.
No
OCTET STRING
OCTET STRING  (1..15)
1.3.6.1.4.1.25506.2.217.2.1.1.8
(hh3cARPTrapLocalPeVlan)
Outer VLAN of the ARP packet.
No
INTEGER
Integer32 (1..2147483647)
1.3.6.1.4.1.25506.2.217.2.1.1.9
(hh3cARPTrapLocalCeVlan)
Inner VLAN of the ARP packet.
No
INTEGER
Recommended action
Check whether an ARP packet attack or a loop exists on the network.
  • Become a Partner
  • Partner Resources
