02-HH3C-NAT-MIB | 45.53 KB |
HH3C-NAT-MIB (Not ADE)
About this MIB
Use this MIB to obtain NAT information.
MIB file name
hh3c-nat.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cNat(18)
Tabular objects
hh3cNATStatVer2Table
About this table
This table obtains NAT statistics of version 2.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cNATStatChassis, hh3cNATStatSlot, and hh3cNATStatCPUID.
Access |
Syntax |
Value range |
Implementation |
hh3cNATStatChassis (1.3.6.1.4.1.25506.2.18.2.13.1.1) |
not-accessible |
Unsigned32 |
0..65534 |
Chassis number. |
As per the MIB. |
hh3cNATStatSlot (1.3.6.1.4.1.25506.2.18.2.13.1.2) |
not-accessible |
Unsigned32 |
0..65534 |
Slot number. |
As per the MIB. |
hh3cNATStatCPUID (1.3.6.1.4.1.25506.2.18.2.13.1.3) |
not-accessible |
Unsigned32 |
0..7 |
CPU number. |
As per the MIB. |
hh3cNATTotalNATSessionCount (1.3.6.1.4.1.25506.2.18.2.13.1.4) |
read-only |
Unsigned32 |
Standard MIB values. |
Total number of NAT sessions. |
As per the MIB. |
hh3cNATEimTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.5) |
read-only |
Unsigned32 |
Number of EIM entries. |
As per the MIB. |
hh3cNATInboundNoPATTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.6) |
read-only |
Unsigned32 |
NO-PAT entries generated for the inbound NAT translation. |
As per the MIB. |
hh3cNATOutboundNoPATTableCount (1.3.6.1.4.1.25506.2.18.2.13.1.7) |
read-only |
Unsigned32 |
NO-PAT entries generated for the outbound NAT translation. |
As per the MIB. |
hh3cNATMaxDynamicPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.8) |
read-only |
Unsigned32 |
Number of NAT444 dynamic port blocks. |
As per the MIB. |
hh3cNATMaxStaticPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.9) |
read-only |
Unsigned32 |
Number of NAT444 static port blocks. |
As per the MIB. |
hh3cNATActiveDynamicPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.10) |
read-only |
Unsigned32 |
Number of active NAT444 dynamic port blocks. |
As per the MIB. |
hh3cNATActiveStaticPortblock (1.3.6.1.4.1.25506.2.18.2.13.1.11) |
read-only |
Unsigned32 |
Number of active NAT444 static port blocks. |
As per the MIB. |
hh3cNatIPPoolGroupTable
About this table
Use this table to obtain NAT address group resources usage in a NAT instance.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cNatIPPoolName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cNatIPPoolName (1.3.6.1.4.1.25506.2.18.2.19.1.1) |
not-accessible |
Unsigned32 |
OCTET STRING |
Name of the NAT address pool. |
As per the MIB. |
hh3cNatIPPoolAddrUsage (1.3.6.1.4.1.25506.2.18.2.19.1.2) |
read-only |
IpAddress |
Unsigned32 |
NAT address pool usage. |
As per the MIB. |
hh3cNatIPPoolTotalCount (1.3.6.1.4.1.25506.2.18.2.19.1.3) |
read-only |
Unsigned32 |
Unsigned32 |
Total number of IP addresses in the NAT address pool. |
As per the MIB. |
hh3cNatIPPoolUsedCount (1.3.6.1.4.1.25506.2.18.2.19.1.4) |
read-only |
Unsigned32 |
Unsigned32 |
Number of used IP addresses in the NAT address pool. |
As per the MIB. |
hh3cNatIPPoolUnusedCount (1.3.6.1.4.1.25506.2.18.2.19.1.5) |
read-only |
OCTET STRING |
Unsigned32 |
Number of unused IP addresses in the NAT address pool. |
As per the MIB. |
