03-LEDs | 2.70 MB |
3 LEDs
RFU LEDs
Figure 3-1 RFU-360-G LEDs
(1) Management Ethernet copper port LED |
(2) Cloud cluster management SFP+ fiber port LED |
(3) System status LED (SYS) |
(4) RFU active/standby status LED (ACT) |
(5) Fan tray status LED (FAN) |
Figure 3-2 RFU-560-G LEDs
Table 3-1 RFU LED description
LED |
Status |
System LED (SYS) |
Flashing green (eight times per second) |
The router is in BootWare stage. |
Steady green |
The router is in Kernel stage, including Eshell stage. |
Flashing green (once per second) |
The Comware system is starting up or is operating correctly. |
Flashing yellow (once per second) |
Memory test failed in BootWare stage. |
Flashing yellow (eight times per second) |
The extended BootWare segment does not exist. |
Steady yellow |
The boot.bin file does not exist. |
Off |
No power input, or an exception has occurred. |
Steady green |
The RFU is in active mode. |
The router is performing an active/standby RFU switchover. |
Off |
The RFU is in standby mode. |
Steady green |
Both fan trays are operating correctly. |
One fan tray is operating correctly and the other one is not present. |
Steady yellow |
A minimum of one fan try is faulty. |
Off |
Both fan trays are not present. |
Steady green |
A 10 Gbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 10 Gbps. |
Steady yellow |
A 1000 Mbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 1000 Mbps. |
Off |
No link is present on the port. |
Steady green |
Flashing green |
Steady yellow |
A 10 or 100 Mbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 10 or 100 Mbps. |
Off |
Interface module LEDs
For more information about HMIC interface module LEDs, see H3C SR6608-M Router Interface Module Guide.
Power supply LEDs
Figure 3-3 PSR250-12A power supply LEDs
(1) Status LED |
Figure 3-4 PSR450-12A power supply LEDs
(1) Status LED |
Figure 3-5 PSR450-12D-F power supply LEDs
(1) Status LED |
Table 3-2 Power supply LED description
LED |
Status |
Status LED |
Steady green |
The power supply is operating correctly. |
Flashing green |
The power supply has normal power input but has not been turned on. |
Steady red |
The power supply is faulty. |
Flashing red/green |
An alarm is present on the power supply. |
Flashing red |
This power supply does not have power input but the other power supply has power input. |
Off |
No power is present. |
Fan tray status LEDs
Figure 3-6 FAN-80B-2-C fan tray LEDs
(1) Status LED |
Table 3-3 Fan tray status LED description
LED |
LED status |
RUN |
Steady green |
The fan tray is operating correctly. |
Steady yellow |
The fan tray is faulty. |
Off |
No fan tray is present or no power is present on the fan tray. |
